Carriers X 95
Clamping Carrier X 95
The Clamping Carrier X 95 allows the construction of
T-shaped structures with X 95 profiles. In contrast to the
Carriers X 95 (see page 08), these clamping versions are not
equipped with a Teflon film on the bottom side to provide a
non-slippery connection to the profiles.
• Building T-structures with X 95 profiles
• Equipped with two anvil clamps
• Ø 11 mm center bore for mounting Levelling Feet
• 63 mm hole grid with Ø 6.6 mm holes
10
A Closer Look
CAD files of all mechanical components can be
found at www.qioptiq-shop.com under "Docs and
Drawings"on the respective product sheets.
Item Title
Width (B) / mm
Width (B) / inch
Anodized
Part No.
Clamping Carrier colorless
95
3.74
Colorless
G026408000
Clamping Carrier black
95
3.74
Black
G026508000
Application example: With the help of clamping carriers
it is possible to mount two X 95 profiles vertical to each
other wherein the second profile can be moved along the
first to the desired position. Finally, it can be fixed there.
In the shown example the lower horizontal profile is held
by two clamping carriers between two vertical profiles. The
Endplate
G026201000
upper horizontal profile is held by two corner connectors. To
compensate the additional distance, which is generated by
the thickness of the clamping carriers, two additional end
plates are inserted.
Clamping Carrier,
colorless
Phone +49(0) 551 69 35-0
sales.qioptiq@excelitas.com
很抱歉,暂时无法提供与“G026408000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1175.012551+151.80246
