LINOS Focus-Ronar Lenses
1064nm + 532nm
Part number
A
Outer diameter
(mm)
4401-505-000-20
4401-486-000-20
4401-490-000-20
4401-420-000-21
Ø 41 h7
B
Clear Aperture
(mm)
34.0
35.4
35.4
35.0
C
Height
(mm)
24.6
18.9
33.6
24.0
Dimensions without tolerances are nominal values and illustration not to scale
Part number
4401-505-000-20
4401-486-000-20
4401-490-000-20
4401-420-000-21
Design wavelength
λ
(nm)
1064
Coating wavelength
λ
(nm)
1064 + 532
Focal length, nominal
FL
(mm)
58
77
90
122
Effective focal length (1064nm / 532nm)
EFL
(mm)
58.1 / 57.5
77.4 / 76.7
90.1 / 89.7
122.2 / 121.4
Working distance (1064nm / 532nm)
Spot diameter, nominal (1064nm @ 35mm EAP) /
(532nm @ 23mm EAP)
Transmission (@ 1064 nm / @ 532 nm)
WD
(mm)
48.3 / 47.8
72.2 / 71.6
73.7 / 73.1
111.5 / 110.6
Øspot
(µm)
3.2 / 2.5
4.6 / 3.3
5.0 / 3.8
6.9 / 5.1
T
≥ 97 / ≥ 96
LIDT coating @1064nm, 9ns, 100Hz
(J/cm²)
10
LIDT coating @532nm, 6ns, 100Hz
(J/cm²)
6
Subject to technical change
Qioptiq Photonics GmbH & Co. KG
Königsallee 23
D - 37081 Göttingen
All rights reserved
O-LM_DS-Focus-Ronar-1064-532_2021.04-V2
Not export controlled
Tel: +49 (0) 551 6935-0
lmp@excelitas.com
www.qioptiq-shop.com
很抱歉,暂时无法提供与“4401-486-000-20”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3354.960001+434.01530
