015295
015295
    EXCELITASTECHNOLOGIES(埃赛力达)
    LASER MODULE 642NM 100MW
015295 数据手册
iFLEX-iRIS Laser Systems The iFLEX-iRIS® laser series is a range of solid- Features: state, high performance lasers with low  All wavelengths same compact size amplitude all  Fully integrated electronics wavelengths are offered with the same control  Class leading power stability inputs and small size. All TEC and smart  Ultra-low noise performance control electronics are inside the laser.  Class-leading beam pointing stability  USB, RS232 noise. For ease of use, Precision control electronics make these lasers ideally suited to demanding imaging applications, which need excellent signal-to- Options:  noise ratios. with CLM feature  Automatic power control ensures excellent power stability for all lasers operating CW. The innovative Closed Loop Modulation (CLM) feature for diode wavelengths maintains adjustment at all output power levels. Unlike traditional open loop laser modulation, when using iFLEX-iRIS lasers with CLM feature, there is no need for laser calibration reset. iFLEX-iRIS lasers are CDRH compliant when used with the iFLEX-iRIS interlock remote power supply. This is recommended for PSM1056_3 laboratory use. Fiber delivery: SM PM, modular design with kineFLEX® and it can be added later  OEM and End User versions  Customised designs optimised for your application, please contact us to discuss excellent power stability during modulation and over the laser lifetime, plus precise power Analogue, Digital, Dual Mode Modulation Applications:  Confocal Microscopy  Flow Cytometry  Medical Imaging & Instrumentation  DNA Sequencing  Metrology  Ophthalmology  Analytical Instrumentation iFLEX-iRIS Specification Overview 375 405 413 445 458 473 488 505 515 520 532 561 594 633 640 647 660 670 730 780 852 20 50 100 20 20 75 20 50 20 30 20 20 20 30 20 50 80 10 20 70 35 40 100 50 70 40 40 70 40 50 200 75 50 100 60 100 140 150 iFLEX-iRIS® CLM, 375-520nm & 633-852nm 561 594 3 Power supply LASER CONTROL I/O LASER RADIATION AVOID EXPOSURE TO BEAM CLASS 3B LASER PRODUCT CW EMISSION
015295
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离和传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:EL817广泛应用于数字电路、通信设备、工业控制系统等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
015295 价格&库存
很抱歉,暂时无法提供与“015295”相匹配的价格&库存,您可以联系我们找货
