LHI 968 / 3866
LHI 968 / 3866
    EXCELITASTECHNOLOGIES(埃赛力达)
    TO-205AA
    传感器 PIR(无源红外) TO-205AA,TO-5-3 金属罐
LHI 968 / 3866 数据手册
PYROELECTRIC DETECTORS FOR INTRUSION ALARM Pyroelectric, Dual-Element Detectors 'PS*OUSVTJPO"MBSNT -)J 1:%o)JHI&OE1ZSP Product Description The analog LHi 968 series with Dual Element configuration is performance-proven top of the line product in high-end applications. The LHi 968 design provides for a reduced sensitivity to EMI and excellent White Light Immunity (WLI). PYD 1398 offers a higher level of RF immunity and is optionally available with grading for lower white light sensitivity. Applications tIntrusion Alarms tHigh-end Motion Sensors Features and Benefits tTO-5 metal housing tImproved EMI protection tReduced (WLI) LHi 968 and PYD 1398 Parameter Responsivity, min. Responsivity, typ. Match, max. Noise, max. Noise, typ. spec. Detectivity Field of View, horizontal Field of View, vertical Source Voltage Operating Voltage EMI performance White Light performance Height Optical Element Location Filter Size 14 4ZNCPM Rmin R Mmax Nmax N D* FoV h he /ho XxY -)J 3,3 4 10 50 20 19 100° 100° 0,2…1,5 2,0…10 ** ** 4,2 2,6 / 0,95 5,2 x 4,2 1:% 3,3 4 10 50 20 19 100° 100° 0,2…1,5 2,0…10 ** *** 4,2 2,6 / 0,95 5,2 x 4,2 Unit kV/W kV/W % µVpp µVpp 107cm*√Hz/W V V 3FNBSLT f = 1 Hz f = 1 Hz 0,4…10Hz/20°C 0,4…10Hz/20°C 1Hz / 1Hz BW/20°C unobstructed unobstructed 47 kΩ, 20°C, VDD=10V 47 kΩ, 20°C Excelitas test set up mm mm mm www.excelitas.com
LHI 968 / 3866 价格&库存
很抱歉,暂时无法提供与“LHI 968 / 3866”相匹配的价格&库存,您可以联系我们找货
