502-1130-4
502-1130-4
    EXCELITASTECHNOLOGIES(埃赛力达)
    LS-1130-4
502-1130-4 数据手册
DATASHEET Lighting Solutions 1100 Series FlashPacs Key Features 1100 Series FlashPacs from Excelitas are ideal sources for UV-VIS-NIR applications. • • • • • • • • • Compact 10 or 20 Watts average power High radiant intensity Continuous spectrum UV-VIS-NIR User adjustable charge voltage Selection of flashlamps Selection of discharge capacitors Microsecond flash duration Simple fiber optic coupling Applications 1100 Series FlashPacs from Excelitas Technologies have been designed to combine state-of-the-art circuitry and components into a packaged light source which provides microsecond-duration pulses of broadband light with exceptional arc stability. 1100 Series FlashPacs utilize the PS-1110 and PS-1120 variable output power supplies in conjunction with the appropriate Lite-Pac® trigger module to operate several types of flashlamps. A fully shielded steel case and EMI suppression circuitry combine to diminish the radiated and conducted noise normally associated with high peak discharge currents. FlashPacs can be ordered with a wide range of discharge capacitance values and several types of the 1100 Series flashlamps. These systems make ideal sources of pulsed light for ultraviolet-visible absorption spectroscopy, HPLC, blood analyzers, colorimetry, machine vision and ultraviolet applications. www.excelitas.com 1100 Series FlashPacs 9/2011 page 1 of 5 • • • • • • • • Absorption analysis Immunoassay modules Fluorimetry Spectroradiometry Liquid and gas chromatography Colorimetry UV-VIS-NIR applications Machine vision 1100 Series FlashPacs 1100 Series FlashPacs Electrical Inputs LS-1102 Voltage LS-1130 11-28 VDC 15-28 VDC DC Current 1.3 Amps @ 12 VDC 1.4 Amps @ 24 VDC Peak Current 3.5 Amps @ 12 VDC 3.5 Amps @ 24 VDC Trigger +5V, 20-50mA peak input, 10-100μs pulse width, leading edge trigger. Optically isolated internal series resistor = 150Ω. V ref (V 0 /V ref = 100) 4.5 – 6.0 VDC 4-10 VDC 1 2 EMI Supression Yes 1 Inductor and filter capacitor for power input. All inputs through shielded 9-PIN “D” connector. 2 Yes Common-mode inductor and filter capacitor in power input. All inputs through shielded 9-PIN “D” connector. Electrical Outputs (Discharge) Voltage (V 0 ) Power Output Charge Rate, minimum LS-1102 LS-1130 450-600 ± 2% VDC 400-1000 ± 2% VDC 10 Watts max. 20 Watts max. 10j/sec (12V input , 600V output) 20j/sec (24V input , 600V output) Line Regulation 1% 1 Ripple 0.5% Internal Discharge Capacitor 0.1µF Standard. See charts following for other vaules availavble Recharge Delay 1 Peak to peak maximum with 0.10 µF internal discharge capacitor at maximum output. 200µsec LS-1102 FlashPac Specifications Model Number Discharge Capacitor Maximum Input Energy Per Flash Maximum Flash Rate @ 600 VDC LS-1102-1 0.10 µF - Standard 18 mJ 550 Hz LS-1102-2 0.22 µF 40 mJ 250 Hz LS-1102-3 0.47 µF 85 mJ 118 Hz LS-1102-4 1.0 µF 180 mJ 55 Hz LS-1102-5 2.0 µF 360 mJ 28 Hz LS-1130 FlashPac Specifications Discharge Capacitor Maximum Input Energy Per Flash Maximum Flash Rate @ 1000 VDC LS-1130-1 Model Number 0.10 µF - Standard 50 mJ 400 Hz LS-1130-2 0.22 µF 110 mJ 180 Hz LS-1130-3 0.47 µF 235 mJ 85 Hz LS-1130-4 1.0 µF 500 mJ 40 Hz Environmental LS-1102 Operating Temperature Storage Temperature www.excelitas.com LS-1130 +32°F to +104°F (0°C to +40°C) -40°F to +194°F (-40°C to +90°C) page 2 of 5 1100 Series FlashPacs Mechanical Dimensions LS-1102 Outline LS-1102 Optical Connector – Included with unit LS-1130 Outline www.excelitas.com page 3 of 5 1100 Series FlashPacs LS-1130 Heat Sink (p/n: MVS-15) – Included with unit Type Arc Length (mm) Spectral Distribution (nm) LS-1130 Optical Adapter (p/n: MVS-14-1) – Included with unit Window Material Average Power (watts) Life (flashes) Stability 10 >1x109 1x109 1x109 1x109 1x109 1x109
502-1130-4
物料型号:1100系列FlashPacs,包括LS-1102和LS-1130型号。
器件简介:FlashPacs是理想的UV-VIS-NIR应用光源,提供微秒级持续时间的宽带光脉冲,具有出色的电弧稳定性。它们结合了先进的电路和组件,具有全屏蔽钢壳和电磁干扰抑制电路。
引脚分配:所有输入通过屏蔽的9针“D”连接器。
参数特性: - 电气输入:LS-1102电压11-28VDC,LS-1130电压15-28VDC。 - 电气输出:LS-1102功率输出最大10瓦,LS-1130最大20瓦。 - 环境:工作温度0°C至40°C,存储温度-40°C至90°C。
功能详解:FlashPacs可用于紫外-可见吸收光谱学、高效液相色谱法(HPLC)、血液分析仪、比色法、机器视觉和紫外线应用。
应用信息:适用于吸收分析、免疫分析模块、荧光测量、光谱辐射度、液相和气相色谱、比色法、机器视觉等。
封装信息:包括机械尺寸和光学连接器的详细信息。
502-1130-4 价格&库存
很抱歉,暂时无法提供与“502-1130-4”相匹配的价格&库存,您可以联系我们找货
