29-90-67-000
29-90-67-000
    EXCELITASTECHNOLOGIES(埃赛力达)
    DUAL MAGNIFICATION MODULE
29-90-67-000 数据手册
Optem® FMOS Fixed-Magnification Optical System Micro-Inspection Lens System Optem FMOS in offers exceptional value and versatility while offering precision micro-inspection imaging over a broad range of parameters. FMOS consists of a wide range of upper and lower lens modules which, when combined in various configurations, yield a broad variety of static working distances and magnifications at the image plane of your CCD. FMOS Lower Function Modules offer a variety of manual and motorized focus, illumination, custom configuration and objective integration options. The recent expansion of the FMOS line uses a special adapter for coupling Optem Zoom 125C Lower Modules to the FMOS upper tubes. This provides integration options with larger illuminated FOV’s, polarized light and motorized focus. Min. Mag. Configuration (FT60 Upper Fixed Tube + B190 Lower Module) Magnification Range 0.3X Numerical Aperture 0.010 Resolution 30 lp/mm Depth-of-Field 5.8 mm Working Distance 195 mm FOV (1/3“ Camera) 11.9 x 15.9 mm FOV (1/2“ Camera) 15.9 x 21.2 mm FOV (2/3“ Camera) 21.9 x 29.2 mm FOV (1“ Camera) Max. Mag. Configuration Magnification Range Numerical Aperture 31.8 x 42.4 mm (FTM500 Upper Fixed Tube + Basic Obj Module + 50X MPlan APO Obj.) 125X 0.55 Resolution 1650 lp/mm Depth-of-Field 0.0019 mm Working Distance 13 mm FOV (1/3“ Camera) 0.029 x 0.038 mm FOV (1/2“ Camera) 0.053 x 0.070 mm FOV (2/3“ Camera) 0.59 x 0.78 mm FOV (1“ Camera) 0.077 x 0.10 mm Specifying Your Optem FMOS Lens System To specify your Optem FMOS Fixed-Magnification Lens System identify the parameters of your application and select the modular components which deliver the optimum imaging solution. STEP 1. Determine the Field-of-View (FOV) you require Camera dimension (mm) Optical Mag. = FOV desired (mm) STEP 2. The FMOS System requires a Fixed Tube and a Lower Function Module. First determine what Lower Function Module you require. Options include; Basic (B), Coaxial Illumination (C), Internal Focus (F) and Internal Focus with Coaxial illumination (FC). Note: There are separate Optical Performance Charts for varying illumination methods and objective integration: • Oblique (Ring light) or Substage Illumination (p. 06) • Coaxial Illumination (p. 07) • Infinity Corrected M PLAN APO Objectives (p. 08) Choose the appropriate working distance you require for your application. By referring to the Optical Performance Charts TOP AXIS, choose the best working distance (WD). Keeping in mind, the higher resolution (NA) will be achieved with the shorter working distances. (see Optical Performance Charts p. 06-08). STEP 4. Select the Fixed Tube: The Fixed Tubes are shown on the LEFT AXIS of all Optical Performance Charts, and each Fixed Tube has an optical focal length associated to it. When combined with the focal length of the lens in the Lower Function Module, the two create a magnification factor. This magnification factor, in relation to your camera format, will yield a specific Field-of-View (FOV), which is displayed in the box where the LEFT AXIS and TOP AXIS intersect. STEP 5. When completed, you will have identified the following two components required for your functional FMOS Lens System. • Fixed Tube • Lower Function Module Useful Formulas & Definitions Camera Chip Dimensions (mm): 1/4" ChIP 6.0 8.0 1/3" ChIP 1/2" ChIP 8.8 .0 11 2/3" ChIP 9.6 6.4 6.6 4.8 4.8 3.7 4.6 3.6 12.8 2.7 02 by choosing your intended camera format (1/3”, 1/2”, 2/3” etc…), and using the dimensions of that camera format to calculate the optical magnification required (see camera dimensions below): STEP 3. .0 16 1" ChIP Depth-of-Field (DOF): The axial depth of the space on both sides of the object plane within which the object can be moved without objectionable loss of sharpness. DOF = l ÷ NA2 l = Wavelength of Light (Green Light = 0.000550mm or 550nm) Magnification: The ratio of image size to actual object size. Optical Mag. = Camera Chip dim. ÷ Field-of-View (FOV) Electronic Mag. = Monitor Diag. ÷ Camera Diag. Numerical Aperture (NA): A measurement of the light collecting ability of the lens. A higher NA translates to a brighter image, better resolution, and shallower depth-of-field. Components and New Features Upper Fixed Tubes Fixed Tubes (FT) – As the upper most component of your Optem FMOS Lens System, Fixed Tubes function to provide the desired magnification factor and correct back focal distance to the sensor of your C-mount camera. Fixed Tubes, MINI (FTM) – For installations where space is at a premium, Mini Fixed Tubes deliver the same optical performance as FT Fixed Tubes in a fraction of the length. Lower Function Modules Lower Function Modules dictate working distance. When configuring your FMOS Lens System, select from a wide array of Function Modules to integrate the specific functionality desired in your Lens System: Basic (B) Module - This component delivers the most economical and space efficient system when ambient or independent illumination is planned and system focus can be affected through staging. Internal Focus (F) Module - Self-contained 10mm manual focus for precision image adjustment without manipulating staging or disturbing image stability. Coaxial Illumination (C) Module - Introduces coaxial (vertical) illumination using fiber optic, halogen or LED coaxial illuminators. (See p. 04 and p. 07) Resolution: The ability to distinguish or separate fine detail. Expressed in line pairs per millimeter (lp/mm). Numerical Aperture (NA) is the controlling factor over resolution... the higher the NA, the brighter the image, and the better the resolution. Visual Resolution (lp/mm) = 3000 X NA 1 ÷ lp/mm = Approx. microns (µ) resolved Internal Focus, Coaxial Illumination (FC) Module - Introduces 10mm manual internal focus with coaxial (vertical) illumination. Objective Modules - Afford integration of Infinity-Corrected Objectives utilizing one of the following Modules: Basic Objectives Module; Coaxial Illumination Objectives Module; Internal Focus Objectives Module; Internal Focus, Coaxial Objectives Module. Objectives Modules feature M26 x 36T threads to accept Optem and Mitutoyo Objectives (See p. 08). An RMS thread adapter is available for Olympus and Nikon Objectives. Variable Working Distance Auxiliary Lens - Intended for applications requiring working distances from 127 (5”) – 432mm (17”), (See p. 09). Optem Zoom 125C LOWER Module Adapter - Expand the modular flexibility of your FMOS Lens System with the imaging and functional versatility offered by Optem Zoom 125C Lens System Lower Function Modules, including: • 15mm Manual or motorized fine focus • 5mm Manual or motorized fine focus with coaxial illumination • Polarized fiber optic coaxial illumination • Infinity Macro Lens Accessory (See p. 09) Vignetting: The blockage of rays from off-axis object points by constraining apertures. Vignetting results in the darkening of the corners on your monitor. 03 Illumination Options Illumination Options The Optem FMOS Lens System offers a variety of illumination options to meet a variety of imaging requirements. 04 You have two basic illumination options which can be integrated with your FMOS System... coaxial illumination or oblique ringlight illumination. Fiber Optic Coaxial Illuminators – Integrate coaxial illumination from you choice of either 110V or 220V Optem VSI Fiber Optic Illuminators using flexible 40- or 60-inch flexible fiber bundles. Coaxial Illumination Options Coaxial (or vertical) illumination is most useful on highly reflective objects. Optem’s Coaxial Illuminators project cool, white light perpendicularly onto the specimen for exceptional contrast and field uniformity (Refer p. 07 for performance). Select from one of several coaxial-equipped lower function modules when specifying your FMOS lens system and integrate one of the three following options of coaxial illumination (See FMOS System Diagram p 10-11). LED Coaxial Illuminators – Programmable 1-Watt LED Coaxial Illuminators offer reduced power requirements and heat generation with substantial service life gains. LED Coaxial illuminators are available in straight and right-angle configurations to meet your specific space requirements, and feature compact designs and simplified cable management. These can be driven by stand-alone, singlechannel programmable controllers. Coaxial LEDs emit brilliant cool light in the visible spectrum and deliver virtually identical optical performance to our fiber optic and halogen Coaxial Illuminators. 10W halogen Coaxial Illuminators – When economy is high priority, Halogen light sources are available with a 6V Variable Transformer (110V / 220V). Ventilated lamphouses are required for use with halogen illuminators (see System Diagram p. 10-11). Polarized Light – When imaging highly reflective subjects, Polarizer Modules with built-in Analyzers are available to introduce polarization to both LED and Fiber Optic Coaxial Illumination paths. Oblique Ringlight Options Dark Field Illumination is generally used on 3-D objects to cast light rays at an angle onto an object, thus better defining its surface profile. Optem offers the following dark field illuminators for the FMOS System (Refer p. 06 for performance). Fiber Optic Ring Lights – Oblique Ringlight Illumination is ideal to better define features of dimension rich subjects. Driven with the same VSI Fiber Optic Illuminator as conventional coaxial systems. Qioptiq offers Ringlights specifically designed for a variety of configurations, including integration of objectives (see System Diagram p. 10-11). Motorization and Configuration Accessories Configuration Accessories Extend the versatility of your FMOS Lens System with two new innovations in form and function. Motorizing Lens System Optem FMOS Lens Systems can be specified with motorized focus functions utilizing Zoom 125C Lower Function Modules. Select from Stepper or DC Motor options. STEPPER MOTOR – The stepper motors provide accurate repeatability of zoom magnification and/ or focus using a Hall-effect sensor to set repeatable home position. A desktop rocker switch controller offers manual control and features an RS-232 port for automated computer control. Includes controller instructions with a list of RS-232 control commands, a Windows® control program, and startup LabVIEW control program. An OEM controller board version is available for streamlined integration. DC MOTOR – DC motors provide continuous, fine adjustment and control of focus function. A desktop joystick controller offers simultaneous control of both zoom and focus functions. Mid-System Right-Angle Module – This accessory allows the introduction of a 90° of your optical axis at the mid-body point of your FMOS Lens System. Users can now integrate any FMOS, Zoom 70XL or Zoom 125C Lower Function Modules below the right-angle turn, maintaining full working distance and affording greater configuration flexibility. NOTE: the MidSystem Right-Angle Module produces a mirror (reversed) image. Dual-Magnification Module – Simultaneously integrate two Optem FMOS Fixed Tubes and/or Zoom 70XL Zoom Modules with TV Tube, over a single subject. This permits real-time dual fixed and/or zoom imaging of your object of interest with your choice of magnifications, FOVs, camera formats and camera types. Integrate any of the full range of FMOS, Zoom 70XL and Zoom 125C Lower Function Modules below the Dual-Mag Module, or integrate compact vertical illumination through the compact Dual-Mag coaxial block. 05 B150/F150 B130/F130 WD: 133 mm WD: 89 mm WD: 55 mm WD: 32 mm 0.010 0.011 0.013 0.014 0.021 NA Res (lp/mm) Mag FOV (mm) Cam Format DOF (mm) FT60 x 4.80 2.36 x 3.15 1/2" 15.9 x 21.2 14.0 x 19 12.5 x 16.7 11.0 x 14.7 7.59 x 10.1 4.80 x 6.40 3.15 x 4.20 2/3" 21.9 x 29.2 19.3 x 26 17.2 x 23.0 15.1 x 20.2 10.4 x 13.9 6.60 x 8.80 4.33 x 5.77 1" 31.8 x 42.4 28.0 x 37.4 25.0 x 33.4 22.0 x 29.4 15.2 x 20.2 9.60 x 12.8 6.30 x 8.39 0.016 55 61 70 0.62 0.71 1.0 1.6 2.5 1.4 1.1 0.50 0.20 0.086 x 9.82 6.49 x 8.66 5.80 x 7.73 5.10 x 6.80 3.52 x 4.69 2.22 x 2.96 1.46 x 1.94 1/2" 9.82 x 13.1 8.66 x 11.5 7.73 x 10.3 6.80 x 9.07 4.69 x 6.25 2.96 x 3.95 1.94 x 2.59 2/3" 13.5 x 18.0 11.9 x 15.9 10.6 x 14.2 9.35 x 12.5 6.45 x 8.60 4.07 x 5.43 2.67 x 3.56 1" 19.6 x 26.2 17.3 x 23.1 15.5 x 20.6 13.6 x 18.1 9.38 x 12.5 5.93 x 7.90 3.89 x 5.18 FOV (mm) Cam Format Cam Format FOV (mm) FOV (mm) Cam Format 0.041 0.066 0.10 86 124 197 300 0.59 0.67 1.4 0.75 1.1 0.86 0.90 1.2 0.69 2.0 0.33 3.0 0.13 0.057 x 8.08 5.35 x 7.13 4.77 x 6.36 4.20 x 5.60 2.90 x 3.86 1.83 x 2.44 1.20 x 1.60 1/2" 8.08 x 10.8 7.13 x 9.50 6.36 x 8.49 5.60 x 7.47 3.86 x 5.15 2.44 x 3.25 1.60 x 2.13 2/3" 11.1 x 14.8 9.80 x 13.1 8.75 x 11.7 7.70 x 10.3 5.31 x 7.08 3.36 x 4.47 2.20 x 2.93 1" 16.2 x 21.6 14.3 x 19.0 12.7 x 17.0 11.2 x 14.9 7.72 x 10.3 4.88 x 6.51 3.20 x 4.27 0.023 0.026 68 0.029 77 0.033 87 0.048 99 0.075 143 0.12 226 345 0.69 0.79 0.88 1.0 1.5 2.3 3.5 1.1 0.85 0.68 0.53 0.25 0.10 0.043 1/3" 5.20 x 6.93 4.58 x 6.11 4.09 x 5.45 3.60 x 4.80 2.48 x 3.31 1.57 x 2.09 1.03 x 1.37 1/2" 6.93 x 9.24 6.11 x 8.15 5.45 x 7.27 4.80 x 6.40 3.31 x 4.41 2.09 x 2.79 1.37 x 1.83 2/3" 9.53 x 12.7 8.40 x 11.2 7.50 x 10.0 6.60 x 8.80 4.55 x 6.07 2.88 x 3.83 1.89 x 2.51 1" 13.9 x 18.5 12.2 x 16.3 10.9 x 14.5 9.60 x 12.8 6.62 x 8.82 4.18 x 5.58 2.74 x 3.66 0.026 0.029 0.033 0.038 0.054 0.086 0.13 78 88 99 113 163 258 394 0.79 0.90 0.84 1.0 0.65 1.1 0.52 1.7 0.40 2.6 0.19 4.0 0.077 0.033 1/3" 4.55 x 6.06 4.01 x 5.35 3.58 x 4.77 3.15 x 4.20 2.17 x 2.90 1.37 x 1.83 0.90 x 1.20 1/2" 6.06 x 8.08 5.35 x 7.13 4.77 x 6.36 4.20 x 5.60 2.90 x 3.86 1.83 x 2.44 1.20 x 1.60 2/3" 8.34 x 11.1 7.35 x 9.80 6.56 x 8.75 5.78 x 7.70 3.98 x 5.31 2.52 x 3.36 1.65 x 2.20 1" 12.1 x 16.2 10.7 x 14.3 9.55 x 12.7 8.40 x 11.2 5.79 x 7.72 3.66 x 4.88 2.40 x 3.20 0.030 0.034 89 0.038 101 0.043 113 0.062 129 0.098 187 0.15 295 450 0.89 1.0 1.1 1.3 1.9 3.0 4.5 0.64 0.50 0.40 0.31 0.15 0.059 0.025 Cam Format FOV (mm) 0.029 75 Mag Cam Format FOV (mm) 0.025 67 DOF (mm) 1/3" 4.04 x 5.39 3.56 x 4.75 3.18 x 4.24 2.80 x 3.73 1.93 x 2.57 1.22 x 1.63 0.80 x 1.07 1/2" 5.39 x 7.19 4.75 x 6.34 4.24 x 5.66 3.73 x 4.98 2.57 x 3.43 1.63 x 2.17 1.07 x 1.42 2/3" 7.41 x 9.88 6.53 x 8.71 5.83 x 7.78 5.13 x 6.84 3.54 x 4.72 2.24 x 2.98 1.47 x 1.96 1" 10.8 x 14.4 9.50 x 12.7 8.49 x 11.3 7.47 x 9.96 5.15 x 6.86 3.25 x 4.34 2.13 x 2.84 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 1.0 1.1 0.55 1.3 0.43 1.4 0.34 2.1 0.26 3.3 0.12 5.0 0.050 0.021 1/3" 3.64 x 4.85 3.21 x 4.28 2.86 x 3.82 2.52 x 3.36 1.74 x 2.32 1.10 x 1.46 0.72 x 0.96 1/2" 4.85 x 6.47 4.28 x 5.70 3.82 x 5.09 3.36 x 4.48 2.32 x 3.09 1.46 x 1.95 0.96 x 1.28 2/3" 6.67 x 8.89 5.88 x 7.84 5.25 x 7.00 4.62 x 6.16 3.18 x 4.25 2.01 x 2.68 1.32 x 1.76 1" 9.70 x 12.9 8.55 x 11.4 7.64 x 10.2 6.72 x 8.96 4.63 x 6.18 2.93 x 3.90 1.92 x 2.56 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 Mag 1.2 1.4 1.6 1.8 2.6 4.1 6.3 DOF (mm) 0.55 0.43 0.34 0.26 0.12 0.050 0.021 Cam Format FOV (mm) 0.022 59 6.06 1/3" 2.91 x 3.88 2.57 x 3.42 2.29 x 3.05 2.02 x 2.69 1.39 x 1.85 0.88 x 1.17 0.58 x 0.77 1/2" 3.88 x 5.17 3.42 x 4.56 3.05 x 4.07 2.69 x 3.58 1.85 x 2.47 1.17 x 1.56 0.77 x 1.02 2/3" 5.34 x 7.11 4.70 x 6.27 4.20 x 5.60 3.70 x 4.93 2.55 x 3.40 1.61 x 2.15 1.06 x 1.41 1" 7.76 x 10.3 6.84 x 9.12 6.11 x 8.15 5.38 x 7.17 3.71 x 4.94 2.34 x 3.12 1.54 x 2.05 Cam Format 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 1.7 0.55 1.9 0.43 2.1 0.34 3.1 0.26 4.9 0.12 7.5 0.050 0.021 1/3" 2.43 x 3.23 2.14 x 2.85 1.91 x 2.55 1.68 x 2.24 1.16 x 1.54 0.73 x 0.98 0.48 x 0.64 1/2" 3.23 x 4.31 2.85 x 3.80 2.55 x 3.39 2.24 x 2.99 1.54 x 2.06 0.98 x 1.30 0.64 x 0.85 2/3" 4.45 x 5.93 3.92 x 5.23 3.50 x 4.67 3.08 x 4.11 2.12 x 2.83 1.34 x 1.79 0.88 x 1.17 1" 6.47 x 8.62 5.70 x 7.60 5.09 x 6.79 4.48 x 5.97 3.09 x 4.12 1.95 x 2.60 1.28 x 1.71 NA Mag 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 1.7 DOF (mm) Cam Format 0.032 1.5 DOF (mm) FOV (mm) 0.020 1/3" DOF (mm) FOV (mm) 244 7.36 DOF (mm) 2.0 0.55 2.2 0.43 2.5 0.34 3.6 0.26 5.7 0.12 8.8 0.050 0.021 1/3" 2.08 x 2.77 1.83 x 2.44 1.64 x 2.18 1.44 x 1.92 0.99 x 1.32 0.63 x 0.84 0.41 x 0.55 1/2" 2.77 x 3.70 2.44 x 3.26 2.18 x 2.91 1.92 x 2.56 1.32 x 1.76 0.84 x 1.12 0.55 x 0.73 2/3" 3.81 x 5.08 3.36 x 4.48 3.00 x 4.00 2.64 x 3.52 1.82 x 2.43 1.15 x 1.53 0.75 x 1.01 1" 5.54 x 7.39 4.89 x 6.52 4.36 x 5.82 3.84 x 5.12 2.65 x 3.53 1.67 x 2.23 1.10 x 1.46 NA 0.032 Res (lp/mm) 0.036 96 0.041 109 0.046 123 0.067 139 0.11 202 0.16 320 488 Mag 2.0 2.2 2.5 2.9 4.1 6.6 10 DOF (mm) 0.55 0.43 0.34 0.26 0.12 0.050 0.021 Cam Format FOV (mm) 160 1/3" DOF (mm) 1/3" 1.82 x 2.43 1.60 x 2.14 1.43 x 1.91 1.26 x 1.68 0.87 x 1.16 0.55 x 0.73 0.36 x 0.48 1/2" 2.43 x 3.23 2.14 x 2.85 1.91 x 2.55 1.68 x 2.24 1.16 x 1.54 0.73 x 0.98 0.48 x 0.64 2/3" 3.33 x 4.45 2.94 x 3.92 2.63 x 3.50 2.31 x 3.08 1.59 x 2.12 1.01 x 1.34 0.66 x 0.88 1" 4.85 x 6.47 4.28 x 5.70 3.82 x 5.09 3.36 x 4.48 2.32 x 3.09 1.46 x 1.95 0.96 x 1.28 NA Res (lp/mm) Mag Cam Format 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 2.2 DOF (mm) FOV (mm) 101 0.081 1.7 DOF (mm) 2.5 0.55 2.8 0.43 3.2 0.34 4.7 0.26 7.4 0.12 11 0.050 0.021 1/3" 1.62 x 2.16 1.43 x 1.90 1.27 x 1.70 1.12 x 1.49 0.77 x 1.03 0.49 x 0.65 0.32 x 0.43 1/2" 2.16 x 2.87 1.90 x 2.53 1.70 x 2.26 1.49 x 1.99 1.03 x 1.37 0.65 x 0.87 0.43 x 0.57 2/3" 2.96 x 3.95 2.61 x 3.48 2.33 x 3.11 2.05 x 2.74 1.42 x 1.89 0.89 x 1.19 0.59 x 0.78 1" 4.31 x 5.75 3.80 x 5.07 3.39 x 4.53 2.99 x 3.98 2.06 x 2.74 1.30 x 1.74 0.85 x 1.14 NA 0.032 Res (lp/mm) FOV (mm) 0.053 0.55 Res (lp/mm) FTM 500 0.034 48 Mag FTM 450 0.023 2.2 Res (lp/mm) FTM 400 0.020 0.49 NA FTM 350 0.018 Mag NA FTM 300 0.23 3.60 Res (lp/mm) FTM 250 1.5 0.53 7.59 DOF (mm) 0.036 96 0.041 109 0.046 123 0.067 139 0.11 202 0.16 320 488 Mag 2.5 2.8 3.1 3.6 5.2 8.2 13 DOF (mm) 0.55 0.43 0.34 0.26 0.12 0.050 0.021 Cam Format 32.54 DIA 1.3 x Mag 27.94 DIA 2.8 5.70 NA 27.94 DIA 3.6 11.0 Res (lp/mm) 55.83 4.5 x Res (lp/mm) FT/FTM 200 150 8.26 Mag 35.81 98 1.0 12.5 Res (lp/mm) 35.0 DIA 62 0.63 x NA 35.0 DIA 43 0.44 9.39 NA FT/FTM 180 38 0.38 14.0 Mag FT/FTM 160 0.050 34 0.34 x Res (lp/mm) available in various lengths 06 0.033 30 10.5 NA FT/FTM 140 B30/F30 15.9 Mag FTM 120 B50/F50 x NA 31.37 B90/F90 0.30 5.8 Res (lp/mm) 1"x32 "C" Mount WD: 152 mm 11.9 Res (lp/mm) FT/FTM 100 WD: 171 mm 1/3" NA FOV (mm) FMOS Substage/Oblique Illumination B170/F170 WD: 195 mm Cam Format Optical Performance B190/F190 1/3" 1.46 x 1.94 1.28 x 1/2" 1.94 x 2.59 1.71 x 2.28 1.53 x 2.04 1.34 x 1.79 0.93 x 1.24 0.59 x 0.78 0.38 x 0.51 2/3" 2.67 x 3.56 2.35 x 1.71 3.14 1.15 2.10 x x 1.53 2.80 1.01 1.85 x x 1.34 2.46 0.69 1.27 x x 0.93 1.70 0.44 0.81 x x 0.59 1.07 0.29 0.53 x x 0.38 0.70 1" 3.88 x 5.17 3.42 x 4.56 3.05 x 4.07 2.69 x 3.58 1.85 x 2.47 1.17 x 1.56 0.77 x 1.02 B150/F150 B130/F130 WD: 133 mm WD: 89 mm WD: 55 mm WD: 32 mm 0.010 0.011 0.013 0.014 0.021 0.033 0.050 30 34 38 43 62 98 Mag 0.30 0.34 0.38 0.44 0.63 1.0 1.5 DOF (mm) 5.8 4.5 3.6 2.8 1.3 0.53 0.23 1/3" -- -- 10.5 1/2" -- -- 2/3" -- 1" -- NA Mag FOV (mm) DOF (mm) Cam Format FT/FTM 100 available in various lengths Cam Format FOV (mm) FOV (mm) Cam Format 4.80 x 6.40 3.15 x 4.20 -- -- -- -- -- -- 10.4 x 13.9 6.60 x 8.80 4.33 x 5.77 -- -- -- -- -- -- -- 9.60 x 12.8 6.30 x 8.39 0.023 0.034 0.053 0.081 48 55 61 70 101 160 244 0.49 0.018 0.55 0.020 0.62 0.71 1.0 1.6 1.7 1.4 1.1 0.50 2.5 0.20 0.086 x 9.82 x 13.1 8.66 x 11.5 7.73 x 10.3 6.80 x 9.07 4.69 x 6.25 2.96 x 3.95 1.94 x 2.59 2/3" -- -- -- -- 10.6 x 14.2 9.35 x 12.5 6.45 x 8.60 4.07 x 5.43 2.67 x 3.56 1" -- -- -- -- -- -- -- -- 9.38 x 12.5 5.93 x 7.90 3.89 x 5.18 0.020 0.022 0.025 0.029 0.041 0.066 0.10 59 67 75 86 124 197 300 0.59 0.67 1.4 0.75 1.1 5.35 0.86 0.90 7.13 4.77 6.36 4.20 1.2 5.60 2.90 x 2.0 3.0 0.13 3.86 1.83 x 0.057 8.08 1/2" 8.08 x 10.8 7.13 x 9.50 6.36 x 8.49 5.60 x 7.47 3.86 x 5.15 2.44 x 3.25 1.60 x 2.13 2/3" -- -- 9.80 x 13.1 8.75 x 11.7 7.70 x 10.3 5.31 x 7.08 3.36 x 4.47 2.20 x 2.93 1" -- -- -- -- -- -- -- -- 7.72 x 10.3 4.88 x 6.51 3.20 x 4.27 0.029 x 0.33 x 0.026 x 0.69 6.06 0.023 x 2.44 1.20 x 0.033 0.048 0.075 68 77 87 99 143 226 0.69 0.79 0.88 1.0 1.5 2.3 3.5 1.1 0.85 0.68 0.53 0.25 0.10 0.043 345 1/3" 5.20 x 6.93 4.58 x 6.11 4.09 x 5.45 3.60 x 4.80 2.48 x 3.31 1.57 x 2.09 1.03 x 1.37 1/2" 6.93 x 9.24 6.11 x 8.15 5.45 x 7.27 4.80 x 6.40 3.31 x 4.41 2.09 x 2.79 1.37 x 1.83 2/3" 9.53 x 12.7 8.40 x 11.2 7.50 x 10.0 6.60 x 8.80 4.55 x 6.07 2.88 x 3.83 1.89 x 2.51 1" -- -- -- -- 10.9 x 14.5 9.60 x 12.8 6.62 x 8.82 4.18 x 5.58 2.74 x 3.66 0.033 0.038 0.054 0.086 88 99 113 163 258 0.90 1.0 1.1 1.7 2.6 4.0 DOF (mm) 0.84 0.65 0.52 0.40 0.19 0.077 0.033 0.026 0.029 394 1/3" 4.55 x 6.06 4.01 x 5.35 3.58 x 4.77 3.15 x 4.20 2.17 x 2.90 1.37 x 1.83 0.90 x 1/2" 6.06 x 8.08 5.35 x 7.13 4.77 x 6.36 4.20 x 5.60 2.90 x 3.86 1.83 x 2.44 1.20 x 2/3" 8.34 x 11.1 7.35 x 9.80 6.56 x 8.75 5.78 x 7.70 3.98 x 5.31 2.52 x 3.36 1.65 x 2.20 1" -- -- 10.7 x 14.3 9.55 x 12.7 8.40 x 11.2 5.79 x 7.72 3.66 x 4.88 2.40 x 3.20 0.030 0.034 0.038 0.043 0.062 0.098 0.15 89 101 113 129 187 295 450 0.89 1.0 1.1 1.3 1.9 3.0 0.64 0.50 0.40 0.31 0.15 4.5 0.059 0.025 x 5.39 3.56 x 4.75 3.18 x 4.24 2.80 x 3.73 1.93 x 2.57 1.22 x 1.63 0.80 x 1/2" 5.39 x 7.19 4.75 x 6.34 4.24 x 5.66 3.73 x 4.98 2.57 x 3.43 1.63 x 2.17 1.07 x 2/3" 7.41 x 9.88 6.53 x 8.71 5.83 x 7.78 5.13 x 6.84 3.54 x 4.72 2.24 x 2.98 1.47 x 1.96 1" -- -- 9.50 x 12.7 8.49 x 11.3 7.47 x 9.96 5.15 x 6.86 3.25 x 4.34 2.13 x 2.84 0.032 0.036 96 0.041 109 0.046 123 0.067 139 0.11 202 320 1.3 1.4 2.1 3.3 5.0 0.34 0.26 0.12 0.050 0.021 Cam Format 1.1 0.43 1/3" 3.64 x 4.85 3.21 x 4.28 2.86 x 3.82 2.52 x 3.36 1.74 x 2.32 1.10 x 1.46 0.72 x 0.96 1/2" 4.85 x 6.47 4.28 x 5.70 3.82 x 5.09 3.36 x 4.48 2.32 x 3.09 1.46 x 1.95 0.96 x 1.28 2/3" 6.67 x 8.89 5.88 x 7.84 5.25 x 7.00 4.62 x 6.16 3.18 x 4.25 2.01 x 2.68 1.32 x 1.76 1" -- -- 8.55 x 11.4 7.64 x 10.2 6.72 x 8.96 4.63 x 6.18 2.93 x 3.90 1.92 x 2.56 0.041 0.046 0.067 0.11 109 123 139 202 320 1.4 1.6 1.8 2.6 4.1 6.3 DOF (mm) 0.55 0.43 0.34 0.26 0.12 0.050 0.021 FOV (mm) 0.036 96 1.2 FOV (mm) Cam Format 0.16 488 1/3" 2.91 x 3.88 2.57 x 3.42 2.29 x 3.05 2.02 x 2.69 1.39 x 1.85 0.88 x 1.17 0.58 x 0.77 1/2" 3.88 x 5.17 3.42 x 4.56 3.05 x 4.07 2.69 x 3.58 1.85 x 2.47 1.17 x 1.56 0.77 x 1.02 2/3" 5.34 x 7.11 4.70 x 6.27 4.20 x 5.60 3.70 x 4.93 2.55 x 3.40 1.61 x 2.15 1.06 x 1.41 1" 7.76 x 10.3 6.84 x 9.12 6.11 x 8.15 5.38 x 7.17 3.71 x 4.94 2.34 x 3.12 1.54 x 2.05 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 1.5 DOF (mm) 1.7 0.55 1.9 0.43 2.1 0.34 3.1 0.26 4.9 0.12 7.5 0.050 0.021 1/3" 2.43 x 3.23 2.14 x 2.85 1.91 x 2.55 1.68 x 2.24 1.16 x 1.54 0.73 x 0.98 0.48 x 0.64 1/2" 3.23 x 4.31 2.85 x 3.80 2.55 x 3.39 2.24 x 2.99 1.54 x 2.06 0.98 x 1.30 0.64 x 0.85 2/3" 4.45 x 5.93 3.92 x 5.23 3.50 x 4.67 3.08 x 4.11 2.12 x 2.83 1.34 x 1.79 0.88 x 1.17 1" 6.47 x 8.62 5.70 x 7.60 5.09 x 6.79 4.48 x 5.97 3.09 x 4.12 1.95 x 2.60 1.28 x 1.71 Mag 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 1.7 DOF (mm) FOV (mm) 1.42 488 1.0 0.55 Cam Format 1.07 0.16 0.032 2.0 0.55 2.2 0.43 2.5 0.34 3.6 0.26 5.7 0.12 8.8 0.050 0.021 1/3" 2.08 x 2.77 1.83 x 2.44 1.64 x 2.18 1.44 x 1.92 0.99 x 1.32 0.63 x 0.84 0.41 x 0.55 1/2" 2.77 x 3.70 2.44 x 3.26 2.18 x 2.91 1.92 x 2.56 1.32 x 1.76 0.84 x 1.12 0.55 x 0.73 2/3" 3.81 x 5.08 3.36 x 4.48 3.00 x 4.00 2.64 x 3.52 1.82 x 2.43 1.15 x 1.53 0.75 x 1.01 1" 5.54 x 7.39 4.89 x 6.52 4.36 x 5.82 3.84 x 5.12 2.65 x 3.53 1.67 x 2.23 1.10 x 1.46 NA Res (lp/mm) Mag 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 2.0 DOF (mm) FOV (mm) 1.60 4.04 Mag Cam Format 1.20 1/3" Mag 2.2 0.55 2.5 0.43 2.9 0.34 4.1 0.26 6.6 0.12 10 0.050 0.021 1/3" 1.82 x 2.43 1.60 x 2.14 1.43 x 1.91 1.26 x 1.68 0.87 x 1.16 0.55 x 0.73 0.36 x 0.48 1/2" 2.43 x 3.23 2.14 x 2.85 1.91 x 2.55 1.68 x 2.24 1.16 x 1.54 0.73 x 0.98 0.48 x 0.64 2/3" 3.33 x 4.45 2.94 x 3.92 2.63 x 3.50 2.31 x 3.08 1.59 x 2.12 1.01 x 1.34 0.66 x 0.88 1" 4.85 x 6.47 4.28 x 5.70 3.82 x 5.09 3.36 x 4.48 2.32 x 3.09 1.46 x 1.95 0.96 x 1.28 NA Res (lp/mm) Mag 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 2.2 DOF (mm) FOV (mm) 07 0.13 DOF (mm) Cam Format 1.60 0.12 Res (lp/mm) 2.5 0.55 2.8 0.43 3.2 0.34 4.7 0.26 7.4 0.12 11 0.050 0.021 1/3" 1.62 x 2.16 1.43 x 1.90 1.27 x 1.70 1.12 x 1.49 0.77 x 1.03 0.49 x 0.65 0.32 x 0.43 1/2" 2.16 x 2.87 1.90 x 2.53 1.70 x 2.26 1.49 x 1.99 1.03 x 1.37 0.65 x 0.87 0.43 x 0.57 2/3" 2.96 x 3.95 2.61 x 3.48 2.33 x 3.11 2.05 x 2.74 1.42 x 1.89 0.89 x 1.19 0.59 x 0.78 1" 4.31 x 5.75 3.80 x 5.07 3.39 x 4.53 2.99 x 3.98 2.06 x 2.74 1.30 x 1.74 0.85 x 1.14 NA Res (lp/mm) Mag 0.032 0.036 0.041 0.046 0.067 0.11 0.16 96 109 123 139 202 320 488 2.5 DOF (mm) FOV (mm) 1.94 1/3" 78 Cam Format FOV (mm) 10.1 0.79 Cam Format FOV (mm) x 1/2" DOF (mm) FOV (mm) 7.59 1.46 Res (lp/mm) FTM 500 14.7 2.96 NA FTM 450 x x Mag FTM 400 11.0 2.22 Res (lp/mm) FTM 350 3.15 -- 4.69 NA FTM 300 x -- Mag Cam Format 32.54 DIA 2.36 x DOF (mm) Cam Format 27.94 DIA FTM 250 4.80 3.52 NA 27.94 DIA x 6.80 Res (lp/mm) 85.83 3.60 x DOF (mm) 39.37 25.40 DIA 7.59 5.10 NA 60.63 x 7.73 NA 25.40 DIA 5.70 x NA FT/FTM 200 11.0 5.80 Mag 39.37 x 8.66 Res (lp/mm) 35.0 DIA 8.26 x Res (lp/mm) 35.0 DIA 12.5 6.49 NA FT/FTM 180 -- -- 150 9.82 Mag FT/FTM 160 -- B30/F30 x Res (lp/mm) FT/FTM 140 -- 2.2 Mag FTM 120 -- x B50/F50 7.36 NA 31.37 9.39 B90/F90 1/3" Res (lp/mm) 1"x32 "C" Mount 14.0 0.016 Res (lp/mm) x WD: 152 mm 2.8 0.55 3.1 0.43 3.6 0.34 5.2 0.26 8.2 0.12 13 0.050 0.021 1/3" 1.46 x 1.94 1.28 x 1.71 1.15 x 1.53 1.01 x 1.34 0.69 x 0.93 0.44 x 0.59 0.29 x 0.38 1/2" 1.94 x 2.59 1.71 x 2.28 1.53 x 2.04 1.34 x 1.79 0.93 x 1.24 0.59 x 0.78 0.38 x 0.51 2/3" 2.67 x 3.56 2.35 x 3.14 2.10 x 2.80 1.85 x 2.46 1.27 x 1.70 0.81 x 1.07 0.53 x 0.70 1" 3.88 x 5.17 3.42 x 4.56 3.05 x 4.07 2.69 x 3.58 1.85 x 2.47 1.17 x 1.56 0.77 x 1.02 Max FOV at Low Mag (Dia.): 7.0 mm ø 7.0 mm ø 7.0 mm ø 7.0 mm ø 9.0 mm ø 9.0 mm ø 9.0 mm ø -- Not recommended due to significant illumination losses. FT60 WD: 171 mm -- FOV Limited by illumination. Approximate maximum illuminated FOV given as diameter at top of chart. NA Res (lp/mm) FOV (mm) FMOS Coaxial Illumination B170/F170 WD: 195 mm Cam Format Optical Performance B190/F190 2X M Plan Apo 5X M Plan Apo 10X M Plan Apo 20X M Plan Apo 0.020 0.050 0.10 0.20 0.50 60 150 300 600 1500 0.61 1.5 3.1 6.1 FOV (mm) Cam Format DOF (mm) FT60 1.4 x 3.15 1.18 x 1.57 0.59 x 0.79 0.24 x 0.31 1/2" 7.87 x 10.5 3.15 x 4.20 1.57 x 2.10 0.79 x 1.05 0.31 x 0.42 x 1.44 0.43 x 0.58 x 2.10 -- 2/3" 10.8 1" 15.7 24.7 x 4.86 1.46 x 1.94 0.73 x 0.97 0.36 x 0.49 0.15 x 0.19 1/2" 4.86 x 6.48 1.94 x 2.59 0.97 x 1.30 0.49 x 0.65 0.19 x 0.26 2/3" 6.68 1" 9.72 120 x 1.78 0.67 x 2.59 0.97 0.20 300 x 0.89 0.27 x 1.30 0.39 0.40 600 x 0.36 x 0.52 0.55 1200 1650 3.0 6.0 12 30 0.014 0.0035 0.0019 Cam Format FOV (mm) 1.34 1.94 0.057 Cam Format FOV (mm) 3.56 5.18 1.2 1/3" 3.00 x 4.00 1.20 x 1.60 0.60 x 0.80 0.30 x 0.40 0.12 x 4.00 x 5.33 1.60 x 2.13 0.80 x 1.07 0.40 x 0.53 0.16 x 0.21 5.50 x 7.33 2.20 x 2.93 1.10 x 1.47 0.55 x 0.73 0.22 x 0.29 1" 8.00 x 10.7 3.20 x 4.27 1.60 x 2.13 0.80 x 1.07 0.32 x 0.43 1/3" 0.046 0.12 0.23 0.42 0.55 138 345 690 1260 1650 1.4 3.5 0.27 2.57 x 7.0 0.043 3.43 1.03 x 14 0.011 1.37 0.51 x 35 0.0032 0.69 0.26 0.0019 x 0.34 0.10 x 3.43 x 4.57 1.37 x 1.83 0.69 x 0.91 0.34 x 0.46 0.14 x 0.18 4.71 x 6.29 1.89 x 2.51 0.94 x 1.26 0.47 x 0.63 0.19 x 0.25 1" 6.86 x 9.14 2.74 x 3.66 1.37 x 1.83 0.69 x 0.91 0.27 x 0.37 0.053 0.13 0.26 0.42 0.55 158 394 788 1260 1650 1.6 4.0 0.21 8.0 0.033 16 0.0082 40 0.0032 0.0019 1/3" 2.25 x 3.00 0.90 x 1.20 0.45 x 0.60 0.23 x 0.30 0.09 x 0.12 1/2" 3.00 x 4.00 1.20 x 1.60 0.60 x 0.80 0.30 x 0.40 0.12 x 0.16 2/3" 4.13 1" 6.00 x 5.50 1.65 x 8.00 2.40 0.055 x 2.20 0.83 x 3.20 1.20 0.14 165 x 1.10 0.41 x 1.60 0.60 0.30 420 x 0.55 0.17 x 0.80 0.24 0.42 900 x 0.22 x 0.32 0.55 1260 1650 1.8 4.5 9.0 18 45 0.19 0.029 0.0063 0.0032 0.0019 1/3" 2.00 x 2.67 0.80 x 1.07 0.40 x 0.53 0.20 x 0.27 0.08 x 2.67 x 3.56 1.07 x 1.42 0.53 x 0.71 0.27 x 0.36 0.11 x 0.14 3.67 x 4.89 1.47 x 1.96 0.73 x 0.98 0.37 x 0.49 0.15 x 0.20 1" 5.33 x 7.11 2.13 x 2.84 1.07 x 1.42 0.53 x 0.71 0.21 x 0.28 0.055 0.14 0.30 0.42 0.55 165 420 900 1260 1650 2.0 5.0 0.19 10 0.029 20 0.0063 50 0.0032 0.0019 1/3" 1.80 x 2.40 0.72 x 0.96 0.36 x 0.48 0.18 x 0.24 0.07 x 0.10 1/2" 2.40 x 3.20 0.96 x 1.28 0.48 x 0.64 0.24 x 0.32 0.10 x 0.13 2/3" 3.30 1" 4.80 x 4.40 1.32 x 6.40 1.92 0.055 x 1.76 0.66 x 2.56 0.96 0.14 165 x 0.88 0.33 x 1.28 0.48 0.30 420 x 0.44 0.13 x 0.64 0.19 0.42 900 x 0.18 x 0.26 0.55 1260 1650 2.5 6.3 13 25 63 0.19 0.029 0.0063 0.0032 0.0019 Cam Format Mag 0.19 0.058 1/2" 1.92 x 2.56 0.77 x 1.02 0.38 x 0.51 0.19 x 0.26 0.077 x 0.10 2/3" 1/3" 2.64 1.44 x 3.52 1.06 x 1.41 0.53 x 0.70 0.26 x 0.35 0.11 x 0.14 1" 3.84 x 5.12 1.54 x 2.05 0.77 x 1.02 0.38 x 0.51 0.15 x 0.20 NA Res (lp/mm) Mag Cam Format x 1.92 0.58 x 0.77 0.29 x 0.38 0.14 x x 0.055 0.14 0.30 0.42 0.55 165 420 900 1260 1650 3.0 DOF (mm) 7.5 0.19 15 0.029 30 0.0063 0.077 75 0.0032 0.0019 1/3" 1.20 x 1.60 0.48 x 0.64 0.24 x 0.32 0.12 x 0.16 0.048 x 0.064 1/2" 1.60 x 2.13 0.64 x 0.85 0.32 x 0.43 0.16 x 0.21 0.064 x 0.085 x 0.29 0.088 x 0.43 0.13 2/3" 2.20 1" 3.20 NA x 2.93 0.88 x 4.27 1.28 0.055 Res (lp/mm) x 1.17 0.44 x 1.71 0.64 0.14 165 x 0.59 0.22 x 0.85 0.32 0.30 420 0.42 900 x 0.12 x 0.17 0.55 1260 1650 Mag 3.5 8.8 18 35 88 DOF (mm) 0.19 0.029 0.0063 0.0032 0.0019 Cam Format 0.11 1/2" 2/3" DOF (mm) x 0.055 1/2" 1.37 x 1.83 0.55 x 0.73 0.27 x 0.37 0.14 x 0.18 0.055 x 0.073 2/3" 1/3" 1.89 1.03 x 2.51 0.75 x 1.01 0.38 x 0.50 0.19 x 0.25 0.075 x 0.10 1" 2.74 x 3.66 1.10 x 1.46 0.55 x 0.73 0.27 x 0.37 0.11 x 0.15 NA x 1.37 0.41 0.055 Res (lp/mm) x 0.55 0.21 0.14 165 x 0.27 0.10 x 0.30 420 0.14 0.041 0.42 900 0.55 1260 1650 Mag 4.0 10 20 40 100 DOF (mm) 0.19 0.029 0.0063 0.0032 0.0019 Cam Format 0.14 1/2" 2/3" Mag 1/3" 0.90 x 1.20 0.36 x 0.48 0.18 x 0.24 0.090 x 0.12 0.036 x 0.048 1/2" 1.20 x 1.60 0.48 x 0.64 0.24 x 0.32 0.12 x 0.16 0.048 x 0.064 2/3" 1.65 x 2.20 0.66 x 0.88 0.33 x 0.44 0.17 x 0.22 0.066 x 0.088 1" 2.40 x 3.20 0.96 x 1.28 0.48 x 0.64 0.24 x 0.32 0.096 x 0.13 NA 0.055 Res (lp/mm) 0.14 165 0.30 420 0.42 900 0.55 1260 1650 Mag 4.5 11 23 45 113 DOF (mm) 0.19 0.029 0.0063 0.0032 0.0019 Cam Format 0.16 1/2" 2/3" DOF (mm) Cam Format FOV (mm) x x 0.10 0.35 Cam Format FOV (mm) 2.67 3.89 Mag Res (lp/mm) FOV (mm) 8.91 13.0 DOF (mm) NA FOV (mm) x x 0.040 Mag FOV (mm) 1650 3.64 DOF (mm) FOV (mm) 975 1/3" DOF (mm) FOV (mm) 488 -0.55 0.0019 NA 1/3" 0.80 x 1.07 0.32 x 0.43 0.16 x 0.21 0.080 x 0.11 0.032 x 0.043 1/2" 1.07 x 1.42 0.43 x 0.57 0.21 x 0.28 0.11 x 0.14 0.043 x 0.057 2/3" 1.47 x 1.96 0.59 x 0.78 0.29 x 0.39 0.15 x 0.20 0.059 x 0.078 1" 2.13 x 2.84 0.85 x 1.14 0.43 x 0.57 0.21 x 0.28 0.085 x 0.11 NA Res (lp/mm) Mag FTM 500 244 0.33 9.9 Res (lp/mm) FTM 450 1.08 1.57 0.0054 Res (lp/mm) FTM 400 2.89 4.20 4.9 Mag FTM 350 x x 0.16 0.021 NA FTM 300 2.16 3.15 2.5 Res (lp/mm) FTM 250 5.77 8.39 0.086 Cam Format FOV (mm) 98 Mag FT/FTM 200 x x 0.081 0.54 DOF (mm) 1/3" 0.055 0.14 0.30 0.42 0.55 165 420 900 1260 1650 5.0 DOF (mm) FOV (mm) 28-21-02-000.................... 2X M Plan APO, LWD 28-21-05-000.................... 5X M Plan APO, LWD 28-21-10-000.................. 10X M Plan APO, LWD 28-21-11-000.................. 20X M Plan APO, LWD 28-21-50-000.................. 50X M Plan APO, LWD 4.33 6.30 0.99 Res (lp/mm) FT/FTM 180 14.4 21.0 Mag NA LWD Infinity-Corrected M-Plan APO Objectives x x 0.033 Res (lp/mm) FT/FTM 160 0.0023 2.36 DOF (mm) Cam Format 08 15 0.014 7.87 NA FT/FTM 140 28-21-50-000 WD: 13 mm x NA Optem M-Plan APO – Eliminate chromatic aberration across exceptionally flat fields for the ultimate in high-magnification accuracy. Select from 2X, 5X, 10X, 20X and 50X Long-Working Distance Objectives. These objectives are exact replacements for Mitutoyo 378 series objectives and are ideal for metrology applications. 0.057 50X M Plan Apo 5.90 Res (lp/mm) FTM 120 0.23 28-21-11-000 WD: 20 mm 1/3" NA FT/FTM 100 28-21-10-000 WD: 34 mm 13 0.19 x 25 0.029 0.96 x 0.38 50 x 125 0.0019 x 0.038 0.96 x 1.28 0.38 x 0.51 0.19 x 0.26 0.096 x 0.13 0.038 x 0.051 1.32 x 1.76 0.53 x 0.70 0.26 x 0.35 0.13 x 0.18 0.053 x 0.070 1" 1.92 x 2.56 0.77 x 1.02 0.38 x 0.51 0.19 x 0.26 0.077 x 0.10 9.5 mm ø 0.14 0.0032 1/2" 16 mm ø 0.29 0.0063 2/3" Max FOV at Low Mag (Dia.): 0.72 5.0 mm ø 0.19 0.072 x 0.096 0.029 2.0 mm ø 0.4 mm ø -- Not recommended due to significant illumination losses. Achieve significantly higher magnifications and increased resolution. Combine your FMOS with the expanded line of Optem LWD Infinity-Corrected Objectives. Mag FOV (mm) Optical Performance NA Res (lp/mm) Cam Format FMOS Coaxial with LWD M-Plan APO Objectives 28-21-05-000 WD: 34 mm -- FOV Limited by illumination. Approximate maximum illuminated FOV given as diameter at top of chart. 28-21-02-000 WD: 34 mm Optical Performance Optical Performance Infinity Macro Lens Accessory Variable Working Distance Lower Module Working Distance Magnification* Working Distance Magnification* 50 mm 100 mm 150 mm 200 mm 300 mm 400 mm 0.37X 0.25X 0.18X 0.14X 0.1X 0.08X 5” 6” 7” 8” 9” 10” 11” 12” 13” 14” 15” 16” 17” 0.288X 0.253X 0.226X 0.202X 0.184X 0.169X 0.158X 0.147X 0.138X 0.130X 0.123X 0.116X 0.109X * Magnification factor is relative to B90/F90 values as shown on p. 06. Beyond 500 mm, the lens can be thought of as a video lens with focal lengths and f# as follows: Working Distance 500mm 1m 10m to infinity EFL Low EFL High F# Low F# High 18 18 18 165 190 225 13.8 13.8 13.8 33 33 33 * Magnification factor is relative to B90/F90 values as shown on p. 06. 1"x32 "C" Mount Ø1.375 [Ø34.93] 31.37 1.000 [25.40] available in various lengths Ø1.625 [Ø41.28] ø1.77 [ø45] 3.12 [79.2] 48.37 DIA 1.437-32UNS-2A Ø1.750 [44.45] 95.76 2.910 [73.90] Ø1.250 [31.75] 27.94 DIA 09 FMOS Lens System Diagram Color Key Illumination 29-60-83-000 Optical Path VSI 110 ILLUMINATOR 110 VOLT / 150 WATT 30-16-40-000 Illumination Path 29-60-84-000 40” FLEX BUNDLE Electrical VSI 220 ILLUMINATOR 220VOLT / 150 WATT 30-16-60-000 FMOS Upper Fixed Tubes 60” FLEX BUNDLE FT180 FIXED TUBE FT140 POLARIZER ZOOM 125 LOWER MODULES ONLY 10 FT200 FIXED TUBE FIXED TUBE 29-69-13-000 29-69-02-000 FIXED TUBE FT160 FT100 RIGHT ANGLE COAX ADAPTER ZOOM 125 LOWER MODULES ONLY FIXED TUBE 30-16-01-000 10MM ADAPTER 33-04-00-000 30-16-02-000 FIXED TUBE MINI FIXED TUBE MINI FIXED TUBE MINI FIXED TUBE FTM140 FTM120 FTM100 FT60 29-90-66-000 LOW PROFILE, R.A. FIBER OPTIC COAXIAL LAMPHOUSE COAXIAL FMOS LOWER LAMPHOUSE MODULES ONLY ZOOM 125 LOWER MODULES ONLY LONG WORKING RIGHT-ANGLE MODULE NOTE: Yields a reversed image 299067-310 COAXIAL BLOCK 33-03-63-000 ZOOM 125 LOWER MODULE ADAPTER ! Zoom 125 Lower Function Modules 299066-306 ZOOM 125 LOWER MODULE COUPLER NOTE: Contact Qioptiq for FMOS optical performance with Zoom 125 Lower Modules 39-60-10-000 396010-810 SINGLE-CHANNEL PROGRAMMABLE LED CONTROLLER 30-14-10-000 FMOS STRAIGHT 1-WATT COAXIAL LED Z125 COAX ILLUM. 5mm FOCUS 30-60-10-000 ZOOM 125 STRAIGHT 1-WATT COAXIAL LED 30-12-00-000 BASIC MODULE 30-14-13-000 Z125 COAX ILLUM. W/ANALYZER 5mm FOCUS 30-14-20-000 Z125 COAX ILLUM. DC MOTOR FOCUS 30-14-23-000 Z125 COAX ILLUM. W/ANALYZER DC MOTOR FOCUS 30-14-37-000 Z125 COAX ILLUM. STEP MOTOR FOCUS 30-14-38-000 Z125 COAX ILLUM. W/ANALYZER STEP MOTOR FOCUS 30-14-00-000 Z125 COAX ILLUM. NO FOCUS 30-13-20-000 Z125 15mm FOCUS DC MOTOR 30-13-37-000 Z125 15mm FOCUS STEP MOTOR 30-13-10-000 Z125 15mm FOCUS MANUAL 30-14-03-000 Z125 COAX ILLUM. W/ANALYZER NO FOCUS SOR 1 NOTE: Direct path to Flexible Bundle, FMOS LOWER MODULES ONLY SEN ! Illumination 29-99-01-000 1.437x32T - M25x0.75T ADAPTER 39-60-20-000 FMOS RIGHT-ANGLE 1-WATT COAXIAL LED 30-17-01-000 30-60-20-000 MALE/FEMALE THREAD 0.5X AUX LENS ZOOM 125 RIGHT-ANGLE 1-WATT COAXIAL LED 30-17-02-000 27-60-07-000 MALE/FEMALE THREAD 0.75X AUX LENS 110/6 VOLT VARIABLE 27-60-17-000 29-99-02-000 1.437x32T – M26 x 36T OBJECTIVE ADAPTER 30-17-03-000 25mm – M26 x 36T OBJECTIVE ADAPTER 42-35-41-000 INFINITY MACRO LENS 29-99-03-000 1.437 x 32T – 0.800 x 36T OBJECTIVE ADAPTER 30-17-04-000 25mm – 0.800 x 36T OBJECTIVE ADAPTER (FOR FOCUS MODULES) (FOR FOCUS MODULES) High Magnification 29-69-21-000 220/6 VOLT VARIABLE NOTE: Must remove lens from Lower Function Module before integrating Objective Adapters and Objectives RING-LIGHT ADAPTER 29-99-59-000 RIGHT ANGLE ADAPTER 29-60-09-000 10 WATT HALOGEN LAMP 29-69-14-000 HALOGEN LAMPHOUSE 29-60-81-000 HORIZONTAL RING LIGHT NOTE: 29-99-59-000 yields a reversed image, and reduces effective working distance by 48mm 29-69-01-000 1/4 WAVE PLATE Optem Long Working Distance M-Plan APO Objectives 28-21-02-000 2X M PLAN APO 28-21-05-000 5X M PLAN APO 28-21-10-000 10X M PLAN APO 28-21-11-000 20X M PLAN APO 28-21-50-000 50X M PLAN APO 30-16-50-000 OBJECTIVE RING LIGHT CAMERA FMOS Upper Fixed Tubes FTM160 FIXED TUBE MINI FTM200 FTM180 FTM250 FIXED TUBE MINI FIXED TUBE MINI FTM350 FTM300 FIXED TUBE MINI FIXED TUBE MINI FIXED TUBE MINI FTM500 FTM450 FTM400 FIXED TUBE MINI FIXED TUBE MINI FIXED TUBE MINI Mounting Upper Tube Microscope Stand Mounting Clamps 11 30-25-76-000 - 76mm O.D. for OLYM., NIKON, LEICA 30-25-82-000 - 82mm O.D. for UNITRON 30-25-83-000 - 83mm O.D. for API 30-25-84-000 - 84mm O.D. for MEIJI 29-50-10-000 29-90-67-000 GENERIC TUBE CLAMP DUAL MAGNIFICATION MODULE 29-90-67-000 NOT recommended for use with FT 60 Upper Tube FMOS Lower Function Module Available Working Distances LOWER MODULE 299066-304 FMOS Lower Function Modules 299085-310 299084-310 BASIC OBJECTIVE MODULE DUAL FOCUS OBJECTIVE MODULE FMOS LOWER MODULE COUPLER 296085-310 COAXIAL OBJECTIVE MODULE 299066-302 M25 x 0.75 THREAD AUX LENS COUPLER 296084-310 B COAXIAL W/ FOCUS OBJECTIVE MODULE BASIC MODULE F 10mm FOCUS MODULE B F C FC WORKING DISTANCE B30 B50 B90 B130 B150 B170 B190 F30 F50 F90 F130 F150 F170 F190 C30 C50 C90 C130 C150 C170 C190 FC30 FC50 FC90 FC130 FC150 FC170 FC190 32mm 54mm 89mm 132mm 152mm 172mm 195mm C COAXIAL MODULE FC 10mm FOCUS COAXIAL MODULE 29-25-15-000 VARIABLE WORKING DISTANCE MODULE 29-20-31-000 CONVERSION LENS 299066-305 299066-303 NIKON / OLY OBJECTIVES COUPLER OPTEM / MITU. OBJECTIVES COUPLER 29-90-59-000 29-20-32-000 RMS ADAPTER NOTE: Yields a reversed image and reduces effective working distance by 48mm RIGHT ANGLE ADAPTER Lower Function Module Power Supply & Controls DC MOTOR 28-80-18-000 110V TRANSFORMER 28-80-19-000 220V TRANSFORMER MITUTOYO 30-17-70-000 STEPPING MOTOR DRIVER 30-17-74-000 HALL EFFECT SENSOR JUNCTION BOX NIKON/OLYMPUS 30-17-20-000 DC MOTOR DRIVER 30-17-75-000 STEPPING MOTOR O.E.M. BOARD STEPPER MOTOR 30-17-31-000 UNIV. TRANSFORMER (100-240V, 50-60Hz) 30-17-37-000 (N. AMER CORD) 29-60-31-000 MINI-ANNULAR RING PROBE 30-17-36-000 (EUR CORD) 30-17-33-000 (UK CORD) FMOS - 03/10/11 Your Key to Photonic Innovation... Qioptiq serves a wide variety of applications across the industrial manufacturing sector. With a rich history of delivering innovative photonic components, modules and instruments to integrators, engineers and OEMs, we also offer custom-tailored photonic solutions to maximize the potential and capabilities of tomorrow’s many processes and industrial manufacturing systems. ...and Manufacturing Advancement For technical information Qioptiq www.qioptiq.com photonics@qioptiq.com North America Qioptiq, Inc. Fairport, NY USA Toll free: 800-724-4274 Tel: (585) 223-2370 Europe Qioptiq Photonics GmbH Göttingen, Germany Tel: +49 551 6935-0 Asia Pacific Qioptiq Pte Ltd. Singapore Tel: +65 6499 7766 Copyright ©2011 Qioptiq, Inc. All rights reserved. 150140FC-450, ed 3.0-1.5k • Printed in the USA Due to our on-going commitment to excellence in serving our customers, all specifications herein are subject to change without notice.
29-90-67-000
物料型号:Optem FMOS镜头系统
器件简介: - 提供卓越的价值和多功能性 - 适用于广泛的参数的精密微检成像 - 包括多种上部和下部镜头模块,可组合成不同的配置
引脚分配:文档中未提及引脚分配信息。
参数特性: - 包括最小倍率配置和最大倍率配置的详细参数,如放大倍数、数值孔径、分辨率、景深、工作距离和针对不同尺寸相机的视场大小(FOV)
功能详解: - FMOS下部分功能模块提供手动和电动聚焦、照明、定制配置和目标集成选项 - 通过特殊适配器将Optem Zoom 125C下部分模块与FMOS上部管耦合,提供更大的照明视场、偏振光和电动聚焦的集成选项
应用信息: - 适用于工业制造领域的多种应用 - 提供创新的光子组件、模块和仪器
封装信息: - 提供了如何为特定应用指定Optem FMOS镜头系统的详细步骤 - 包括选择工作距离、固定管和下部功能模块的指南
附加信息: - 提供了有用的公式和定义,如相机芯片尺寸、放大倍数、景深(DOF)、数值孔径(NA)、分辨率等 - 介绍了上部固定管和下部功能模块的详细信息,包括不同的模块类型和它们的功能 - 讨论了不同的照明选项,如同轴照明、环形光照明和偏振光 - 还提供了关于电动化镜头系统和配置配件的信息
29-90-67-000 价格&库存
很抱歉,暂时无法提供与“29-90-67-000”相匹配的价格&库存,您可以联系我们找货
  • 1+11314.712931+1466.60222
