30-61-10-000
30-61-10-000
    EXCELITASTECHNOLOGIES(埃赛力达)
    12.5X ZOOM MANUAL
30-61-10-000 数据手册
Optem® Zoom 125C 12.5:1 Micro-Inspection Zoom Lens System The Optem Zoom 125C Lens System is designed to deliver extended zoom imaging performance. With a broad 12.5:1 zoom range and the signature threepiece modular design, the Optem Zoom 125C Lens System can be configured to meet an extensive range of manual and automated zoom imaging parameters. With the widest selection of modules and accessories in the Optem Lens line, Zoom 125C delivers exceptional flexibility offering options including independent motorized Focus Modules, polarized illumination, and the expanded flexibility to be configured for micro imaging up to 125X, or macro imaging for broad fields-of-view across infinite working distances. Base Configuration (@ Low Mag.) (@ High Mag.) Magnification Range 0.52X 6.5X Numerical Aperture 0.019 0.10 58 lp/mm 300 lp/mm 1.5 mm 0.057 mm (1X TV Tube with no Aux. Lens) Resolution Depth-of-Field Working Distance 89 mm 89 mm FOV (1/3“ Camera) 6.92 x 9.23 mm 0.55 x 0.74 mm FOV (1/2“ Camera) 9.23 x 12.3 mm 0.74 x 0.98 mm FOV (2/3“ Camera) 12.7 x 16.9 mm 1.02 x 1.35 mm FOV (1“ Camera) 18.5 x 24.6 mm 1.48 x 1.97 mm (@ Low Mag.) (@ High Mag.) 0.035X 0.44X Min. Configuration (0.375X TV Tube + 0.18X Aux. Lens) Magnification Range Numerical Aperture 0.0035 0.018 Resolution 11 lp/mm 55 lp/mm Depth-of-Field 46.0 mm 1.7 mm Working Distance 468 mm 468 mm Max. Configuration (@ Low Mag.) (@ High Mag.) Magnification Range 10X 125X Numerical Aperture 0.19 0.60 Resolution 555 lp/mm 1800 lp/mm Depth-of-Field 0.017 mm 0.0016 mm 13 mm 13 mm (2.0X TV Tube + 20X HR Obj.) Working Distance Specifying Your Optem Lens System Referring to the Optical Performance Charts (p. 6-9), you can select the best combination of Aux. Lens (if necessary) and TV Tube to best meet the parameters of your application. STEP 1. Determine the Field-of-View (FOV) you STEP 3. Select the Upper Zoom Module: The upper require by choosing your intended camera format (1/3”, 1/2”, 2/3” etc.), and using the dimensions of that camera format to calculate the optical magnification required (see camera dimensions below): module has the following options available: iris, detents and motorization (see System Diagram p. 10-11). Camera dimension (mm) Optical Mag. = FOV desired (mm) STEP 2. The Zoom 125C base configuration consists of a Manual Zoom, a Basic Lower Function Module and a 1X TV Tube, which yields an optical magnification range of 0.52X - 6.5X. Given your optical magnification requirement from STEP 1, determine if your needs fall into the base configuration range of 0.52X - 6.5X. If you require higher than 6.5X optical magnification, you can add an Auxiliary Lens with a magnification factor greater than 1X, AND/OR you can choose a TV Tube with a magnification factor greater than 1X (keeping in mind that Aux. Lenses affect the working distance of the system and TV Tubes do not). Select the Lower Function Module: Lower Function Modules integrate the features and functions desired in your lens system which include: coaxial illumination, internal focus and motorization (see System Diagram p. 10-11). STEP 4. When completed, you will have identified the following four components required for your functional Zoom 70XL Lens System. 1) TV Tube 2) Upper Zoom Module 3) Lower Function Module 4) Auxiliary Lens (if needed) Optem Lens Systems are specifically designed to deliver maximum versatility for your micro-inspection needs. If you do not see a standard configuration that meets your requirements, Qioptiq offers efficient and affordable custom modifications to meet special parameters. Useful Formulas & Definitions Camera Chip Dimensions (mm): 1/4" CHiP 6.0 8.0 1/3" CHiP 1/2" CHiP 8.8 .0 11 2/3" CHiP 9.6 6.4 6.6 4.8 4.8 3.7 4.6 3.6 12.8 2.7 02 To specify your Optem Lens System identify the parameters of your application and select the modular components which deliver the optimum imaging solution. .0 16 1" CHiP Depth-of-Field (DOF): The axial depth of the space on both sides of the object plane within which the object can be moved without objectionable loss of sharpness. DOF = l ÷ NA2 l = Wavelength of Light (Green Light = 0.000550mm or 550nm) Magnification: The ratio of image size to actual object size. Optical Mag. = Camera Chip dim. ÷ Field-of-View (FOV) Electronic Mag. = Monitor Diag. ÷ Camera Diag. Numerical Aperture (NA): A measurement of the light collecting ability of the lens. A higher NA translates to a brighter image, better resolution, and shallower depth-of-field. Zoom and Function Modules Upper Zoom Modules The specific Upper Zoom Module selected will determine the type of zoom operation for your Zoom 125C System. Manual Zoom Module – Provides basic hand-driven 12.5:1 optical system. Lower Function Modules When configuring your Zoom 125C Lens System, choose from the following Lower Modules to specify the lighting and focus functions of your systems: • Basic Module • Internal Focus Module (motor avail.) • Coaxial Illumination Module Iris Diaphragm Module – All Zoom 125C Upper Modules are available with an optional integral iris for better control of light level and increased depth-of-field. Detent Module – Offers repeatable magnification stops throughout the 12.5:1 zoom range without the complexity and cost of motorization. Detents are ideal for metrology applications where each position can be calibrated. Factory-set stops are located at 0.6X, 1.0X, 2.0X, 3.0X, 4.0X, 5.0X, and 6.0X. Motorized Zoom Module – Provides automated zoom in either DC or Stepper Motorized Versions. All Stepper Motorized Models come complete with homing and limit sensors. Resolution: The ability to distinguish or separate fine detail. Expressed in line pairs per millimeter (lp/mm). Numerical Aperture (NA) is the controlling factor over resolution... the higher the NA, the brighter the image, and the better the resolution. Visual Resolution (lp/mm) = 3000 X NA 1 ÷ lp/mm = Approx. microns (µ) resolved • Internal Focus Coaxial Module (motor avail.) If you require extended optical performance from your Zoom 125C, select from these specialized Lower Modules. Objective Adapter Rings – Integrate Infinity-Corrected Objectives utilizing one of four Objective Adapter Rings. Choose from M26 x 36T thread Adapter to accept Optem and Mitutoyo Objectives, and 0.800 x 36T thread adapter available for Nikon and Olympus Objectives. NOTE: Lens will need to be removed from Lower Function Module before integrating Objective Adapters and Objective. Vignetting: The blockage of rays from off-axis object points by constraining apertures. Vignetting results in the darkening of the corners on your monitor. 03 Illumination Options Illumination Options The Zoom 125C Lens System offers a variety of illumination options to meet a variety of imaging requirements. 04 LED Coaxial Illuminators – Programmable 1-Watt LED Coaxial Illuminators offer reduced power requirements and heat generation with substantial service-life gains. Coaxial (or vertical) illumination is most useful on highly reflective objects. Optem’s Coaxial Illuminators project cool, white light perpendicularly onto the specimen for exceptional contrast and field uniformity. LED Coaxial illuminators are available in straight and right-angle configurations to meet your specific space requirements, and feature compact designs and simplified cable management. These can be driven by stand-alone, singlechannel programmable controllers. Coaxial LEDs emit brilliant, cool light in the visible spectrum and deliver virtually identical optical performance to our traditional Coaxial options. Select from one of several coaxial-equipped lower function modules when specifying your Zoom 125C lens system and integrate one of three coaxial illumination options. 10W halogen Coaxial Illuminators – When economy is high priority, Halogen light sources are available with a 6V Variable Transformer (110V / 220V). Fiber Optic Coaxial Illuminators – Integrate coaxial illumination from you choice of either 110V or 220V Optem VSI Fiber Optic Illuminators using flexible 40- or 60-inch flexible fiber bundles. Polarized Light – When imaging highly reflective subjects, Polarizer Modules with built-in Analyzers are available to introduce polarization to both LED and Fiber Optic Coaxial Illumination paths. You have two basic illumination options which can be integrated with your Zoom 125C System... coaxial illumination or oblique ring light illumination (see System Diagram p. 10-11). Coaxial Illumination Options Oblique Ring light Options Dark Field Illumination is generally used on 3-D objects to cast light rays at an angle onto an object, thus better defining its surface profile. Optem offers the following dark field illuminators for the Zoom 125C System. Fiber Optic Ring Lights – Ring light Illuminators are ideal to better define features of dimensionrich subjects. Driven with the same VSI Fiber Optic Illuminator as conventional coaxial systems. Optem offers Ring lights specifically designed for a variety of configurations, including integration of objectives. (see System Diagram p. 10-11). Motorization and Macro Imaging Infinity Macro Lens When extended working distances and broader fields-of-view are required, integrate the Infinity Macro Lens accessory below a manual or motorized Fine-Focus Lower function Module. Motorizing Optem Lens Systems Optem Lens Systems can be specified with motorized zoom and/or focus functions. STEPPER MOTORS – The stepper motors provide accurate repeatability of zoom magnification and/ or focus using a Hall-effect sensor to set repeatable home position. A desktop rocker-switch controller offers manual control and features an RS-232 port for automated computer control. Includes controller instructions with a list of RS-232 control commands, a Windows® control program, and startup LabVIEW control program. An OEM controller board version is available for streamlined integration. 301730-802 (DB-25) 301730-803 (DB-9) 30-17-74-000 30-17-31-000 Junction Box (110V 60Hz) 30-17-75-000 ZOOM OEM Controller Board 30-17-36-000 (EURO) 30-17-32-000 (230V 50Hz) 30-17-33-000 (U.K.) To Computer Com Port DC MOTORS – DC motors provide continuous control of zoom magnification and/or focus. A desktop joystick controller offers simultaneous control of both zoom and focus functions. This versatile accessory converts your Zoom 125C from micro-imaging at close working distances to a powerful macro-imaging lens covering broad fieldsof-view at working distances from 50mm to infinity (see Optical Performance Chart p. 7). 05 137 188 1/2" 2/3" 11 141 2/3" NA 103 1/2" 76.9 106 154 1/2" 2/3" 1" 51.3 70.5 103 2/3" 1" 11 x x x x 46 0.094 46 x 25.6 34.2 47.0 68.4 Mag DOF (mm) 1/3" 1/2" 2/3" 1" 137 94.0 68.4 51.3 91.2 62.7 45.6 34.2 46 x 19.2 25.6 35.3 51.3 Mag DOF (mm) 1/3" 1/2" 2/3" 1" 4.10 2.82 2.05 1.54 120 mm ø 68.4 47.0 34.2 25.6 5.47 3.76 2.74 2.05 8.21 5.64 4.10 3.08 12.3 8.46 6.15 4.61 11.3 8.21 6.15 15.0 10.9 8.21 x x x x 1.7 2.3 55 0.018 x x x x 1.7 1.8 55 0.018 x x x x 1.7 1.17 55 0.018 x x x x 1.7 0.78 55 0.018 x x x 1.7 0.59 55 0.018 x x x 1.7 0.44 55 0.018 5.47 3.76 2.74 2.05 7.29 5.01 3.65 2.74 10.9 7.52 5.47 4.10 16.4 11.3 8.20 6.15 15.0 10.9 8.21 20.1 14.6 10.9 High Mag x x x 181 131 98.5 x x x 135 98.5 73.8 x x x x 148 101 73.8 55.4 x x x x 98.5 67.7 49.2 36.9 x x x x 65.6 45.1 32.8 24.6 36.9 25.4 18.5 13.8 x x x x 25 0.26 14 2.95 2.03 1.48 1.11 3.94 2.71 1.97 1.48 5.91 4.06 2.95 2.22 8.86 6.09 4.43 3.32 8.12 5.91 4.43 10.8 7.88 5.91 x x x x 0.91 3.3 75 0.025 x x x x 0.91 2.4 75 0.025 x x x x 0.91 1.6 75 0.025 x x x x 0.91 1.08 75 0.025 x x x 0.91 0.81 75 0.025 x x x 0.91 0.61 75 0.025 3.94 2.71 1.97 1.48 5.25 3.61 2.63 1.97 7.88 5.42 3.94 2.95 11.8 8.12 5.90 4.43 10.8 7.88 5.91 14.4 10.5 7.88 High Mag 86 mm ø 49.2 33.8 24.6 18.5 0.0048 49.2 33.8 24.6 18.5 25 0.20 14 0.0048 73.8 50.8 36.9 27.7 25 0.13 14 0.0048 111 76.1 55.4 41.5 25 0.087 14 0.0048 102 73.8 55.4 25 0.065 14 0.0048 135 98.5 73.8 25 0.049 14 0.0048 Low Mag 29-20-09-000 WD: 310 mm 0.25X Aux Lens x x x 90.3 65.6 49.2 x x x 67.7 49.2 36.9 x x x x 73.8 50.7 36.9 27.7 x x x x 49.2 33.8 24.6 18.5 x x x x 32.8 22.6 16.4 12.3 18.5 12.7 9.23 6.92 x x x x 6.8 0.52 27 1.48 1.02 0.74 0.55 1.97 1.35 0.98 0.74 2.95 2.03 1.48 1.11 4.43 3.04 2.21 1.66 4.06 2.95 2.22 5.42 3.94 2.95 x x x x 0.25 6.5 143 0.048 x x x x 0.25 4.9 143 0.048 x x x x 0.25 3.3 143 0.048 x x x x 0.25 2.2 143 0.048 x x x 0.25 1.6 143 0.048 x x x 0.25 1.22 143 0.048 1.97 1.35 0.98 0.74 2.63 1.81 1.31 0.98 3.94 2.71 1.97 1.48 5.90 4.06 2.95 2.21 5.42 3.94 2.95 7.22 5.25 3.94 High Mag 54 mm ø 24.6 16.9 12.3 9.23 0.0091 24.6 16.9 12.3 9.23 6.8 0.39 27 0.0091 36.9 25.4 18.5 13.8 6.8 0.26 27 0.0091 55.4 38.1 27.7 20.8 6.8 0.17 27 0.0091 50.8 36.9 27.7 6.8 0.13 27 0.0091 67.7 49.2 36.9 6.8 0.10 27 0.0091 Low Mag 29-20-38-000 WD: 178 mm 0.5X Aux Lens 12.3 8.46 6.15 4.62 16.4 11.3 8.21 6.15 24.6 16.9 12.3 9.23 36.9 25.4 18.5 13.8 33.8 24.6 18.5 45.1 32.8 24.6 x x x x 2.9 0.78 42 0.014 x x x x 2.9 0.59 42 0.014 x x x x 2.9 0.39 42 0.014 x x x x 2.9 0.26 42 0.014 x x x 2.9 0.20 42 0.014 x x x 2.9 0.15 42 0.014 0.98 0.68 0.49 0.37 1.31 0.90 0.66 0.49 1.97 1.35 0.98 0.74 2.95 2.03 1.48 1.11 2.71 1.97 1.48 3.61 2.63 1.97 x x x x 0.11 9.8 217 0.072 x x x x 0.11 7.3 217 0.072 x x x x 0.11 4.9 217 0.072 x x x x 0.11 3.3 217 0.072 x x x 0.11 2.4 217 0.072 x x x 0.11 1.8 217 0.072 1.31 0.90 0.66 0.49 1.75 1.20 0.88 0.66 2.63 1.81 1.31 0.98 3.94 2.71 1.97 1.48 3.61 2.63 1.97 4.81 3.50 2.63 High Mag 36 mm ø 16.4 11.3 8.21 6.15 21.9 15.0 10.9 8.21 32.8 22.6 16.4 12.3 49.2 33.8 24.6 18.5 45.1 32.8 24.6 60.2 43.8 32.8 Low Mag 29-20-39-000 WD: 114 mm 0.75X Aux Lens 9.23 6.35 4.62 3.46 12.3 8.46 6.15 4.62 18.5 12.7 9.23 6.92 27.7 19.0 13.8 10.4 25.4 18.5 13.8 33.8 24.6 18.5 x x x x 1.5 1.0 58 0.019 x x x x 1.5 0.78 58 0.019 x x x x 1.5 0.52 58 0.019 x x x x 1.5 0.35 58 0.019 x x x 1.5 0.26 58 0.019 x x x 1.5 0.20 58 0.019 0.74 0.51 0.37 0.28 0.98 0.68 0.49 0.37 1.48 1.02 0.74 0.55 2.21 1.52 1.11 0.83 2.03 1.48 1.11 2.71 1.97 1.48 x x x x 0.057 13 300 0.10 x x x x 0.057 9.8 300 0.10 x x x x 0.057 6.5 300 0.10 x x x x 0.057 4.3 300 0.10 x x x 0.057 3.3 300 0.10 x x x 0.057 300 0.10 0.98 0.68 0.49 0.37 1.31 0.90 0.66 0.49 1.97 1.35 0.98 0.74 2.95 2.03 1.48 1.11 2.71 1.97 1.48 3.61 2.63 1.97 High Mag 27 mm ø 12.3 8.46 6.15 4.62 16.4 11.3 8.21 6.15 24.6 16.9 12.3 9.23 36.9 25.4 18.5 13.8 33.8 24.6 18.5 45.1 32.8 24.6 Low Mag No Aux Lens required WD: 89 mm Base Configuration 6.15 4.23 3.08 2.31 8.21 5.64 4.10 3.08 12.3 8.46 6.15 4.62 18.5 12.7 9.23 6.92 16.9 12.3 9.23 22.6 16.4 12.3 x x x x 0.69 1.6 86 0.029 x x x x 0.69 1.2 86 0.029 x x x x 0.69 0.78 86 0.029 x x x x 0.69 0.52 86 0.029 x x x 0.69 0.39 86 0.029 x x x 0.69 0.29 86 0.029 0.49 0.34 0.25 0.18 0.66 0.45 0.33 0.25 0.98 0.68 0.49 0.37 1.48 1.01 0.74 0.55 1.35 0.98 0.74 1.81 1.31 x x x x 0.026 20 447 0.15 x x x x 0.026 15 447 0.15 x x x x 0.026 9.8 447 0.15 x x x x 0.026 6.5 447 0.15 x x x 0.026 4.9 447 0.15 x x x 0.026 3.7 447 0.15 0.66 0.45 0.33 0.25 0.88 0.60 0.44 0.33 1.31 0.90 0.66 0.49 1.97 1.35 0.98 0.74 1.81 1.31 0.98 2.41 1.75 1.31 High Mag 0.98 18 mm ø 8.21 5.64 4.10 3.08 10.9 7.52 5.47 4.10 16.4 11.3 8.21 6.15 24.6 16.9 12.3 9.23 22.6 16.4 12.3 30.1 21.9 16.4 Low Mag 29-20-40-000 WD: 52 mm 1.5X Aux Lens Oblique/Substage Illumination -- FOV Limited by vignetting at low mags. Approximate maximum illuminated FOV given as diameter above. x x x 11 0.19 Res (lp/mm) 0.0035 x x x 11 0.14 Res (lp/mm) NA 205 141 0.0035 38.5 1/2" NA x x 103 76.9 0.0035 1/3" DOF (mm) Mag Res (lp/mm) NA x 57.7 1/3" x 46 0.062 11 DOF (mm) Mag 188 137 103 0.0035 x x x 76.9 1/3" 0.047 46 Res (lp/mm) 251 182 137 0.0035 x DOF (mm) Mag Res (lp/mm) NA x 103 1/3" x 46 0.035 11 0.0035 Low Mag 29-20-09-000 (No Spacer) WD: 468 mm DOF (mm) Mag Max FOV at Low Mag (Dia.): TV Tube 2.0X TV Tube 1.5X TV Tube 1.0X TV Tube 0.67X TV Tube 0.5X TV Tube FOV (mm) FOV (mm) 0.375X NA Res (lp/mm) FOV (mm) FOV (mm) FOV (mm) FOV (mm) 0.18X Aux Lens Optical Performance - Cam Format Cam Format Cam Format Cam Format Cam Format Cam Format 06 4.62 3.17 2.31 1.73 6.15 4.23 3.08 2.31 9.23 6.35 4.62 3.46 13.8 9.51 6.92 5.19 12.7 9.23 6.92 16.9 12.3 9.23 x x x x 0.39 2.1 114 0.038 x x x x 0.39 1.6 114 0.038 x x x x 0.39 1.0 114 0.038 x x x x 0.39 0.69 114 0.038 x x x 0.39 0.52 114 0.038 x x x 0.39 0.39 114 0.038 0.37 0.25 0.18 0.14 0.49 0.34 0.25 0.18 0.74 0.51 0.37 0.28 1.11 0.76 0.55 0.42 1.02 0.74 0.55 1.35 0.98 x x x x 0.014 26 594 0.20 x x x x 0.014 20 594 0.20 x x x x 0.014 13 594 0.20 x x x x 0.014 8.7 594 0.20 x x x 0.014 6.5 594 0.20 x x x 0.014 4.9 594 0.20 0.49 0.34 0.25 0.18 0.66 0.45 0.33 0.25 0.98 0.68 0.49 0.37 1.48 1.01 0.74 0.55 1.35 0.98 0.74 1.81 1.31 0.98 High Mag 0.74 14 mm ø 6.15 4.23 3.08 2.31 8.21 5.64 4.10 3.08 12.3 8.46 6.15 4.62 18.5 12.7 9.23 6.92 16.9 12.3 9.23 22.6 16.4 12.3 Low Mag 29-20-41-000 WD: 32 mm 2.0X Aux Lens x x x 13.8 18.5 25.4 -- 1/3" 1/2" 2/3" 1" 12.3 16.9 24.6 1/2" 2/3" 1" 16.4 1" x x 6.15 8.46 12.3 1/2" 2/3" 1" x 1/3" 0.98 0.68 0.49 0.37 1.31 0.90 11 mm ø 16.4 11.3 8.21 6.15 21.9 15.0 x x x x 0.11 9.8 217 0.072 x x x x 1.31 0.90 0.66 0.49 1.75 1.20 0.88 0.66 1.81 2.63 1.31 0.98 -- 2.71 1.97 1.48 -- 2.63 1.97 9.23 6.35 4.62 3.46 12.3 8.46 6.15 4.62 12.7 18.5 9.23 6.92 27.7 19.0 13.8 10.4 25.4 18.5 13.8 58 x x x x 1.5 1.0 58 0.019 x x x x 1.5 0.78 58 0.019 x x x x 1.5 0.52 0.74 0.51 0.37 0.28 0.98 0.68 0.49 0.37 1.02 1.48 0.74 0.55 2.21 1.52 1.11 0.83 2.03 1.48 1.11 x x x x 0.057 13 300 0.10 x x x x 0.057 9.8 300 0.10 x x x x 0.057 6.5 300 0.10 x x x x 0.057 4.3 300 0.10 x x x 0.057 3.3 300 0.10 0.98 0.68 0.49 0.37 1.31 0.90 0.66 0.49 1.35 1.97 0.98 0.74 2.95 2.03 1.48 1.11 2.71 1.97 1.48 High Mag 18 mm ø 12.3 8.46 6.15 4.62 16.4 11.3 8.21 6.15 16.9 24.6 12.3 9.23 36.9 x 0.019 25.4 18.5 x x x 1.5 0.35 58 13.8 33.8 x 0.019 24.6 18.5 x x 1.5 0.26 58 0.019 Low Mag No Aux Lens Required WD: 89 mm Base Configuration 6.15 4.23 3.08 2.31 8.21 5.64 4.10 3.08 8.46 12.3 6.15 4.62 18.5 12.7 9.23 6.92 16.9 12.3 9.23 x x x x 0.69 1.6 86 0.029 x x x x 0.69 1.2 86 0.029 x x x x 0.69 0.78 86 0.029 x x x x 0.69 0.52 86 0.029 x x x 0.69 0.39 86 0.029 0.49 0.34 0.25 0.18 0.66 0.45 0.33 0.25 0.68 0.98 0.49 0.37 1.48 1.01 0.74 0.55 1.35 0.98 0.74 -- Not recommended due to significant illumination losses throughout entire zoom range. x x x x 0.026 20 447 0.15 x x x x 0.026 15 447 0.15 x x x x 0.026 9.8 447 0.15 x x x x 0.026 6.5 447 0.15 x x x 0.026 4.9 447 0.15 0.66 0.45 0.33 0.25 0.88 0.60 0.44 0.33 0.90 1.31 0.66 0.49 1.97 1.35 0.98 0.74 1.81 1.31 0.98 High Mag 14 mm ø 8.21 5.64 4.10 3.08 10.9 7.52 5.47 4.10 11.3 16.4 8.21 6.15 24.6 16.9 12.3 9.23 22.6 16.4 12.3 Low Mag 29-20-40-000 WD: 52 mm 1.5X Aux Lens 4.62 3.17 2.31 1.73 6.15 4.23 3.08 2.31 6.35 9.23 4.62 3.46 13.8 9.51 6.92 5.19 12.7 9.23 6.92 x x x x 0.39 2.1 114 0.038 x x x x 0.39 1.6 114 0.038 x x x x 0.39 1.0 114 0.038 x x x x 0.39 0.69 114 0.038 x x x 0.39 0.52 114 0.038 0.37 0.25 0.18 0.14 0.49 0.34 0.25 0.18 0.51 0.74 0.37 0.28 1.11 0.76 0.55 0.42 1.02 0.74 0.55 x x x x 0.014 26 594 0.20 x x x x 0.014 20 594 0.20 x x x x 0.014 13 594 0.20 x x x x 0.014 8.7 594 0.20 x x x 0.014 6.5 594 0.20 0.49 0.34 0.25 0.18 0.66 0.45 0.33 0.25 0.68 0.98 0.49 0.37 1.48 1.01 0.74 0.55 1.35 0.98 0.74 High Mag 11 mm ø 6.15 4.23 3.08 2.31 8.21 5.64 4.10 3.08 8.46 12.3 6.15 4.62 18.5 12.7 9.23 6.92 16.9 12.3 9.23 Low Mag 29-20-41-000 WD: 32 mm 2.0X Aux Lens 0.37 0.25 0.18 0.14 0.1 0.08 50 mm 100 mm 150 mm 200 mm 300 mm 400 mm 500 mm 1m 10m – Infinity 18 18 18 EFL Low 165 190 225 EFL High 13.8 13.8 13.8 F# Low 33 33 33 F# High Beyond 500 mm, the lens can be thought of as a video lens w/focal lengths and f# as follows: Auxiliary Lens Mag. Working Distance Infinity Macro Lens Accessory Optical Performance Coaxial Illumination -- FOV Limited by illumination at low mags. Approximate maximum illuminated FOV given as diameter above. x 2.9 4.62 DOF (mm) 42 0.78 Mag 0.014 x x Res (lp/mm) NA 11.3 2/3" 0.66 8.21 1/2" 10.9 x 6.15 1/3" x 7.3 2.9 0.11 0.59 0.072 x x x x Mag 0.49 1.35 1.97 0.98 0.74 0.11 4.9 217 0.072 DOF (mm) 8.21 22.6 32.8 16.4 12.3 -- x x x 0.11 3.3 217 0.072 217 0.014 x x x x -- 2.03 1.48 1.11 -- 42 Res (lp/mm) NA 9.23 1/3" 2.9 Mag DOF (mm) 42 0.39 Res (lp/mm) 0.014 2.9 DOF (mm) NA 0.26 Mag 33.8 18.5 24.6 42 0.014 -- Res (lp/mm) NA -- 2/3" 1.97 x x 1.48 24.6 1/2" 32.8 x x 18.5 1/3" 24.6 0.11 2.9 DOF (mm) Max FOV at Low Mag (Dia.): TV Tube 2.0X TV Tube 1.5X TV Tube 1.0X TV Tube 0.67X TV Tube 2.4 0.20 Mag Cam Format Cam Format Cam Format Cam Format Cam Format 0.5X FOV (mm) FOV (mm) FOV (mm) FOV (mm) FOV (mm) 217 0.072 High Mag 42 0.014 Low Mag 29-20-39-000 WD: 114 mm 0.75X Aux Lens Res (lp/mm) NA NOTE: 0.18X, 0.25X and 0.5X Aux Lenses are not recommended for use with coaxial illumination Optical Performance - 07 Long-Working Distance Objectives Achieve significantly higher magnifications and increased resolution. Combine your Zoom 125C with the expanded line of Optem LWD InfinityCorrected Objectives. 08 When integrating objectives onto your Zoom 125C Lens System, You will need to specify one of four Objective Lower Function Modules (see System Diagram p. 10-11). Optem M-Plan APO, LWD Objectives Eliminate chromatic aberration across exceptionally flat fields for the ultimate in high-magnification accuracy. Select from 2X, 5X, 10X, and 20X LongWorking Distance Objectives. These objectives are exact replacements for Mitutoyo 378 series objectives and are ideal for metrology applications. LWD Infinity-Corrected M-Plan APO Objectives • 2X M Plan APO, LWD................... 28-21-02-000 • 5X M Plan APO, LWD .................. 28-21-05-000 • 10X M Plan APO, LWD ................ 28-21-10-000 • 20X M Plan APO, LWD................. 28-21-11-000 Optem High-Resolution, LWD Objectives Specifically designed to capture maximum resolution at the high-end magnifications of Optem Zoom Lenses, the 5X, 10X and 20X Optem HR Objectives are ideal for applications where distinguishing every finite detail is critical. LWD Infinity-Corrected Hi Res Objectives • 5X High-Resolution, LWD............. 28-20-44-000 • 10X High-Resolution, LWD........... 28-20-45-000 • 20X High-Resolution, LWD........... 28-20-46-000 26.4 x 19.8 x 19.2 1" 8.81 12.8 2/3" 1" 6.61 9.62 2/3" 1" 19.2 1.15 0.77 0.53 0.38 0.29 1.03 0.71 0.51 0.38 1.54 1.06 0.77 0.58 1.59 1.15 0.86 2.12 1.54 11 mm ø 12.8 8.81 6.41 4.81 17.1 11.8 8.55 6.41 25.6 17.6 12.8 9.62 26.4 19.2 14.4 35.3 25.6 x x x x x 0.19 12 165 0.055 x x x x 0.19 9.4 165 0.055 x x x x 0.19 6.2 165 0.055 x x x 0.19 4.2 165 0.055 x x 1.54 1.03 0.71 0.51 0.38 1.37 0.94 0.68 0.51 2.05 1.41 1.03 0.77 2.11 1.54 1.15 2.82 2.05 5.77 3.85 2.64 1.92 1.44 5.13 3.53 2.56 1.92 7.69 5.29 3.85 2.88 7.93 5.77 4.32 10.6 7.69 x x x x 0.27 2.5 138 0.046 x x x x 0.27 1.9 138 0.046 x x x x 0.27 1.2 138 0.046 x x x 0.27 0.83 138 0.046 x x x 0.27 0.62 138 0.046 7.69 0.46 0.31 0.21 0.15 0.12 0.41 0.28 0.21 0.15 0.62 0.42 0.31 0.23 0.63 0.46 0.35 0.85 0.62 4.7 mm ø 5.13 3.53 2.56 1.92 6.84 4.70 3.42 2.56 10.3 7.05 5.13 3.85 10.6 7.69 5.77 14.1 10.3 x x x x 0.029 31 420 0.14 x x x x 0.029 23 420 0.14 x x x x 0.029 16 420 0.14 x x x 0.029 10 420 0.14 x x x 0.029 7.8 420 0.14 0.41 0.28 0.21 0.15 0.55 0.38 0.27 0.21 0.82 0.56 0.41 0.31 0.85 0.62 0.46 1.13 0.82 0.62 High Mag 28-21-05-000 WD: 34 mm Low Mag 5X M Plan APO LWD Objective 2.88 1.92 1.32 0.96 0.72 2.56 1.76 1.28 0.96 3.85 2.64 1.92 1.44 3.96 2.88 2.16 5.29 3.85 x x x x 0.067 5.0 277 0.092 x x x x 0.067 3.7 277 0.092 x x x x 0.067 2.5 277 0.092 x x x 0.067 1.7 277 0.092 x x x 0.067 1.2 277 0.092 3.85 0.23 0.15 0.11 0.077 0.058 0.21 0.14 0.10 0.08 0.31 0.21 0.15 0.12 0.32 0.23 0.17 0.42 0.31 2.2 mm ø 2.56 1.76 1.28 0.96 3.42 2.35 1.71 1.28 5.13 3.53 2.56 1.92 5.29 3.84 2.88 7.05 5.13 -- Not recommended due to significant illumination losses throughout entire zoom range. x x x x 0.0063 62 900 0.30 x x x x 0.0063 47 900 0.30 x x x x 0.0063 31 900 0.30 x x x 0.0063 21 900 0.30 x x x 0.0063 16 900 0.30 0.21 0.14 0.10 0.077 0.27 0.19 0.14 0.10 0.41 0.28 0.21 0.15 0.42 0.31 0.23 0.56 0.41 0.31 High Mag 28-21-10-000 WD: 34 mm Low Mag 10X M Plan APO LWD Objective 1.44 x 0.96 0.66 0.48 0.36 1.28 0.88 0.64 0.48 1.92 1.32 0.96 0.72 x 1.98 x x x x 0.017 10 555 0.19 x x x x 0.017 7.5 555 0.19 x x x x 0.017 5.0 555 0.19 x x 0.017 3.3 555 0.19 x 1.44 1.08 -- 1.92 0.017 2.5 555 0.19 1.92 0.12 0.077 0.053 0.038 0.029 0.10 0.071 0.051 0.038 0.15 0.11 0.077 0.058 0.16 0.12 0.086 -- 0.15 0.8 mm ø 1.28 0.88 0.64 0.48 1.71 1.18 0.85 0.64 2.56 1.76 1.28 0.96 2.64 1.92 1.44 -- 2.56 x x x x 0.0032 125 1260 0.42 x x x x 0.0032 94 1260 0.42 x x x x 0.0032 62 1260 0.42 x x x 0.0032 42 1260 0.42 x x 0.0032 31 1260 0.42 0.10 0.071 0.051 0.038 0.14 0.094 0.068 0.051 0.21 0.14 0.10 0.077 0.21 0.15 0.12 -- 0.21 0.15 High Mag 28-21-11-000 WD: 20 mm Low Mag 20X M Plan APO LWD Objective 3.85 2.64 1.92 1.44 5.13 3.53 2.56 1.92 7.69 5.29 3.85 2.88 7.93 5.77 4.32 10.6 7.69 x x x 0.15 0.21 0.31 3.53 5.13 4.8 mm ø 0.115 1.92 x x x x 0.011 0.27 2.56 31 x 675 x 2.5 0.41 6.84 x 138 0.28 4.70 x x 0.23 0.15 0.21 0.046 x x x 2.56 0.011 0.27 3.42 23 x 675 x 1.9 0.62 10.3 x 138 0.42 7.05 x x 0.23 0.23 0.31 0.046 x x x 3.85 0.011 0.27 5.13 16 x 675 1.2 x 138 0.63 10.6 x x 0.23 0.35 0.46 5.77 7.69 0.046 x x x 0.46 0.41 0.28 0.21 0.15 0.55 0.38 0.27 0.21 0.82 0.56 0.41 0.31 0.85 0.62 2.16 1.92 1.32 0.96 0.72 2.56 1.76 1.28 0.96 3.85 2.64 1.92 1.44 3.96 2.88 0.011 0.27 3.85 x x x x x 0.067 5.0 277 0.092 0.23 0.11 x 21 1350 0.45 x 31 1350 0.45 x x x x x x 0.0028 62 1350 0.45 x x x x 0.0028 47 1350 0.45 x x x x 0.0028 0.077 0.15 x x 0.0028 0.058 0.21 0.14 0.10 16 1350 0.45 0.0028 0.077 0.31 0.21 0.15 0.12 0.32 0.23 0.17 0.42 0.31 2.2 mm ø 2.56 1.76 1.28 0.96 3.42 2.35 1.71 x 1.28 x 5.13 3.53 2.56 1.92 5.29 3.84 2.88 7.05 5.13 x 0.067 3.7 277 0.092 x x x x 0.067 2.5 277 0.092 x x x 0.067 1.7 277 x 10 5.29 x x 675 1.13 2.88 3.85 138 x 0.62 0.82 0.83 0.85 14.1 x x 0.092 0.46 0.067 1.2 277 0.092 0.21 0.14 0.10 0.077 0.27 0.19 0.14 0.10 0.41 0.28 0.21 0.15 0.42 0.31 0.23 0.56 0.41 0.31 High Mag 28-20-45-000 WD: 19 mm Low Mag 10X High-Res LWD Objective 0.23 0.046 x x 0.62 0.27 7.69 7.8 0.011 0.62 10.3 675 138 x 0.23 0.046 5.77 High Mag 28-20-44-000 WD: 34 mm Low Mag 5X High-Res LWD Objective 1.44 0.96 0.66 0.48 0.36 1.28 0.88 0.64 0.48 1.92 1.32 0.96 0.72 1.98 1.44 1.08 2.64 1.92 x x x x 0.017 10 555 0.19 x x x x 0.017 7.5 555 0.19 x x x x 0.017 5.0 555 0.19 x x x 0.017 3.3 555 0.19 x x x 0.017 2.5 555 0.19 1.92 0.12 x 62 1800 0.60 x x x 94 1800 0.60 x x x 125 1800 0.60 x x x x 0.077 0.053 0.038 x x x x 0.15 0.21 0.15 0.12 0.28 0.21 0.10 0.071 0.051 0.038 0.14 0.094 0.068 0.051 0.21 0.14 0.10 0.077 0.0016 0.029 0.10 0.071 0.051 0.038 0.15 42 1800 0.0016 0.077 0.11 x 0.60 0.0016 0.058 0.16 0.12 x x 0.0016 0.086 0.21 0.15 1.1 mm ø 1.28 0.88 0.64 0.48 1.71 1.18 0.85 0.64 2.56 1.76 1.28 0.96 2.64 1.92 1.44 3.53 2.56 0.0016 31 1800 0.60 High Mag 28-20-46-000 WD: 13 mm 20X High-Res LWD Objective Low Mag Objectives with Coaxial Illumination -- FOV Limited by illumination at low mags. Approximate maximum illuminated FOV given as diameter above. x x x x 3.61 4.81 1/3" 1.7 DOF (mm) 1/2" 55 1.0 Mag 0.018 x x x x 1.7 Res (lp/mm) NA 4.81 6.41 1/3" 1/2" DOF (mm) 55 0.75 Mag 0.018 x x Res (lp/mm) NA 13.2 2/3" x x 7.21 9.62 1/3" 1.7 DOF (mm) 1/2" 55 0.50 Mag 0.018 Res (lp/mm) NA 2/3" x x 10.8 14.4 1/3" 1.7 DOF (mm) 1/2" 55 0.33 Mag 0.018 Res (lp/mm) NA 2/3" x x 14.4 19.2 1/3" 1/2" 3.1 1.7 0.19 0.25 Mag DOF (mm) 0.055 High Mag 165 0.018 Low Mag 28-21-02-000 WD: 34 mm 2x M Plan APO LWD Objective 55 NA Max FOV at Low Mag (Dia.): TV Tube 2.0X TV Tube 1.5X TV Tube 1.0 TV Tube 0.67X TV Tube FOV (mm) FOV (mm) FOV (mm) FOV (mm) 0.5X FOV (mm) Res (lp/mm) Cam Format Cam Format Cam Format Cam Format Cam Format NOTE: 0.375X TV Tube is not recommended for use with Optem Objectives Optical Performance - 09 Zoom 125C Lens System Diagram Flange Mounts Tube Clamp Mounts (for manual versions) (for motorized versions) 30-15-06-000 76mm O.D. FLANGE MOUNT 30-25-76-000 76mm O.D. TUBE CLAMP 30-15-02-000 82mm O.D. FLANGE MOUNT 30-25-82-000 82mm O.D. TUBE CLAMP 30-15-03-000 83mm O.D. FLANGE MOUNT 30-25-83-000 83mm O.D. TUBE CLAMP 30-15-04-000 84mm O.D. FLANGE MOUNT 30-25-84-000 84mm O.D. TUBE CLAMP (OLYMPUS, NIKON, LEICA) (UNITRON) (GENERIC) (MEIJI) 30-15-00-000 FLAT FLANGE MOUNT (for Manual versions) Right-Angle TV Tubes 29-90-86-000 – 0.5X RA 29-90-87-000 – 0.67X RA 29-90-74-000 – 1.0X RA 29-90-88-000 – 1.5X RA 29-90-89-000 – 2.0X RA (OLYMPUS, NIKON, LEICA) (UNITRON) (GENERIC) 29-90-81-000 1.0X U-BEND TV TUBE NOTE: Right-Angle TV Tubes yield a reversed image U-Bend TV Tube (MEIJI) 30-65-34-000 FLAT MOUNT (for Motorized versions) Mini TV Tubes 29-90-26-000 0.5X MINI TV TUBE 29-90-27-000 0.67X MINI TV TUBE 29-90-90-000 1.0X MINI TV TUBE 29-50-10-000 UNIVERSAL CLAMP (top view) Upper Zoom Modules 10 30-13-10-000 15mm FINE FOCUS MANUAL 30-13-20-000 15mm FINE FOCUS DC MOTOR 30-61-40-000 MANUAL DETENT 30-61-41-000 MANUAL DETENT w/IRIS 29-60-84-000 VSI 220 ILLUMINATOR 220VOLT / 150 WATT 30-16-02-000 FIBER OPTIC LAMPHOUSE Illumination 29-69-13-000 RIGHT ANGLE COAX ADAPTER 396010-810 SINGLE-CHANNEL PROGRAMMABLE LED CONTROLLER 30-61-11-000 MANUAL w/IRIS 30-13-37-000 15mm FINE FOCUS STEPPING MOTOR HALL-EFFECT SENSOR SOR 1 30-16-01-000 10mm ADAPTER 30-61-10-000 MANUAL SEN 30-16-40-000 40” FLEX BUNDLE 30-16-60-000 60” FLEX BUNDLE 29-60-83-000 VSI 110 ILLUMINATOR 110 VOLT / 150 WATT 30-12-00-000 BASIC 30-60-10-000 STRAIGHT 1-WATT COAXIAL LED 29-69-02-000 POLARIZER 30-17-01-000 MALE/FEMALE THREAD 0.5X AUX LENS 29-69-21-000 FIXED MAG/WD RING-LIGHT ADAPTER 27-60-07-000 110/6 VOLT VARIABLE 27-60-17-000 220/6 VOLT VARIABLE 42-35-41-000 INFINITY MACRO LENS 30-17-02-000 MALE/FEMALE THREAD 0.75X AUX LENS 29-99-01-000 1.437x32T - M25x0.75T ADAPTER 30-60-20-000 RIGHT-ANGLE 1-WATT COAXIAL LED 29-99-59-000 RIGHT ANGLE ADAPTER 29-69-01-000 1/4 WAVE PLATE 29-60-09-000 10 WATT HALOGEN LAMP 29-69-14-000 HALOGEN LAMPHOUSE 29-60-81-000 HORIZONTAL RING LIGHT NOTE: Yields a reversed image, and reduces effective working distance by 48mm CAMERA Standard TV Tubes Non-Inverting Right-Angle TV Tubes 29-90-28-000 1.5X MINI TV TUBE 29-90-29-000 2.0X MINI TV TUBE 29-90-82-000 0.38X TV TUBE 29-90-70-000 0.5X TV TUBE 29-90-71-000 0.67X TV TUBE 29-90-73-000 1.5X 29-90-72-000 TV TUBE 1.0X TV TUBE 29-90-80-000 2.0X TV TUBE 29-90-92-000 – 0.5X NIRA 29-90-93-000 – 0.67X NIRA 29-90-94-000 – 1.0X NIRA 29-90-95-000 – 1.5X NIRA 29-90-96-000 – 2.0X NIRA Motorization Control & Power Supply 30-61-21-000 DC MOTOR w/IRIS 30-61-20-000 DC MOTOR 30-61-37-000 STEPPING MOTOR HALL-EFFECT SENSOR 28-80-18-000 110V TRANSFORMER 30-17-20-000 DC MOTOR DRIVER 28-80-19-000 220V TRANSFORMER 30-17-70-000 STEPPING MOTOR DRIVER Lower Function Modules 30-14-10-000 COAX ILLUM. 5mm FOCUS 30-14-13-000 COAX W/ANALYZER 5mm FOCUS 30-14-00-000 COAX ILLUM. NO FOCUS 30-14-03-000 COAX W/ANALYZER NO FOCUS 30-14-20-000 COAX ILLUM. DC MOTORIZED FOCUS 30-14-23-000 COAX W/ANALYZER DC MOTORIZED FOCUS 11 DC MOTOR 30-61-38-000 STEPPING MOTOR HALL EFFECT SENSOR w/IRIS 30-17-74-000 HALL EFFECT SENSOR JUNCTION BOX STEPPER MOTOR 30-17-31-000 UNIV. TRANSFORMER (100-240V, 50-60Hz) 30-17-37-000 (N. AMER CORD) 30-14-37-000 COAX ILLUM. STEPPER MOTOR FOCUS HALL-EFFECT SENSOR 30-14-38-000 COAX W/ANALYZER STEPPER MOTOR FOCUS HALL-EFFECT SENSOR 30-17-75-000 STEPPING MOTOR O.E.M. BOARD 30-17-36-000 (EUR CORD) 30-17-33-000 (UK CORD) Magnification Auxiliary Lenses 29-20-09-000 0.18X / 0.25X CONVERTIBLE AUX LENS 29-20-38-000 0.5X AUX LENS 29-20-39-000 0.75X AUX LENS 29-20-40-000 1.5X AUX LENS 29-20-41-000 2.0X AUX LENS 29-99-03-000 1.437 x 32T – 0.800 x 36T OBJECTIVE ADAPTER 30-17-04-000 25mm – 0.800 x 36T OBJECTIVE ADAPTER (for Focus Modules) NIKON/OLYMPUS 29-99-02-000 1.437x32T – M26 x 36T OBJECTIVE ADAPTER 30-17-03-000 25mm – M26 x 36T OBJECTIVE ADAPTER (for Focus Modules) MITUTOYO Optem® LWD Objectives 28-21-02-000 - 2X M PLAN APO 28-21-05-000 - 5X M PLAN APO 28-21-10-000 - 10X M PLAN APO 28-21-11-000 - 20X M PLAN APO 28-20-44-000 - 5X HIGH-RES 28-20-45-000 - 10X HIGH-RES 28-20-46-000 - 20X HIGH-RES Color Key Optical Path NOTE: Must remove lens from Lower Function Module before integrating Objective Adapters and Objective 30-16-50-000 OBJECTIVE RING LIGHT Illumination Path Electrical ZOOM 125 - 04/12/2011 Your Key to Photonic Innovation... Qioptiq serves a wide variety of applications across the industrial manufacturing sector. With a rich history of delivering innovative photonic components, modules and instruments to integrators, engineers and OEMs, we also offer custom-tailored photonic solutions to maximize the potential and capabilities of tomorrow’s many processes and industrial manufacturing systems. ...and Manufacturing Advancement For technical information Qioptiq www.qioptiq.com photonics@qioptiq.com North America Qioptiq, Inc. Fairport, NY USA Toll free: 800-724-4274 Tel: (585) 223-2370 Europe Qioptiq Photonics GmbH Göttingen, Germany Tel: +49 551 6935-0 Asia Pacific Qioptiq Pte Ltd. Singapore Tel: +65 6499 7766 Copyright ©2011 Qioptiq, Inc. All rights reserved. 30-61-10-450, ed 4.0-1.5k • Printed in the USA Due to our on-going commitment to excellence in serving our customers, all specifications herein are subject to change without notice.
30-61-10-000 价格&库存
很抱歉,暂时无法提供与“30-61-10-000”相匹配的价格&库存,您可以联系我们找货
