29-20-32-000
29-20-32-000
    EXCELITASTECHNOLOGIES(埃赛力达)
    M26 X 36T TO RMS THREAD ADAPTER
29-20-32-000 数据手册
Optem® Zoom 70XL 7:1 Micro-Inspection Zoom Lens System The Optem Zoom 70XL is specifically designed to stand up to the grueling conditions of automated imaging. The “XL” stands for Xtended Life backed by superior engineering and only the highest-quality components and materials. The Zoom 70XL Lens System features robust optomechanics to deliver defect-free performance out to 250,000 zoom cycles... guaranteed! The Zoom 70XL features a three-piece modular design in most configurations for maximum flexibility. With a wide variety of function options and magnification accessories, Zoom 70XL can be configured to cover a wide range of micro-imaging applications. Base Configuration (@ Low Mag.) (@ High Mag.) Magnification Range 0.75X 5.25X Numerical Aperture 0.024 0.080 Resolution 72 lp/mm 240 lp/mm Depth-of-Field 0.98 mm 0.09 mm (1X TV Tube with no Aux. Lens) Working Distance 89 mm 89 mm FOV (1/3“ Camera) 4.80 x 6.40 mm 0.69 x 0.92 mm FOV (1/2“ Camera) 6.40 x 8.53 mm 0.91 x 1.23 mm FOV (2/3“ Camera) 8.80 x 11.73 mm 1.26 x 1.69 mm FOV (1“ Camera) 12.80 x 17.07 mm 1.85 x 2.46 mm Min. Configuration (@ Low Mag.) (@ High Mag.) Working Distance 468 mm 468 mm Magnification Range 0.051X 0.35X Numerical Aperture 0.0043 0.015 13 lp/mm 45 lp/mm 31 mm 2.5 mm (0.375X TV Tube + 0.18X Aux. Lens) Resolution Depth-of-Field Max. Configuration (@ Low Mag.) (@ High Mag.) Magnification Range 14X 100X Numerical Aperture 0.24 0.60 Resolution 720 lp/mm 1800 lp/mm Depth-of-Field 0.0098 mm 0.0016 mm 13 mm 13 mm (2.0X TV Tube + 20X HR Obj.) Working Distance Specifying Your Optem Lens System Referring to the Optical Performance Charts (p. 6-9), you can select the best combination of Aux. Lens (if necessary) and TV Tube to best meet the parameters of your application. STEP 1. Determine the Field-of-View (FOV) you STEP 3. Select the Upper Zoom Module: The upper require by choosing your intended camera format (1/3”, 1/2”, 2/3” etc.), and using the dimensions of that camera format to calculate the optical magnification required (see camera dimensions below): module has the following options available: iris, detents and motorization (see System Diagram p. 1011). Camera dimension (mm) Optical Mag. = FOV desired (mm) STEP 2. The Zoom 70XL base configuration consists of a Manual Zoom, a Basic Lower Function Module and a 1X TV Tube, which yields an optical magnification range of 0.75X - 5.25X. Given your optical magnification requirement from STEP 1, determine if your needs fall into the base configuration range of 0.75X - 5.25X. If you require higher than 5.25X optical magnification, you can add an Auxiliary Lens with a magnification factor greater than 1X, AND/OR you can choose a TV Tube with a magnification factor greater than 1X (keeping in mind that Aux. Lenses affect the working distance of the system and TV Tubes do not). Select the Lower Function Module: Lower Function Modules integrate the features and functions desired in your lens system which include: coaxial illumination, internal focus and motorization (see System Diagram p. 10-11). STEP 4. When completed, you will have identified the following four components required for your functional Zoom 70XL Lens System. 1) TV Tube 2) Upper Zoom Module 3) Lower Function Module 4) Auxiliary Lens (if needed) Optem Lens Systems are specifically designed to deliver maximum versatility for your micro-inspection needs. If you do not see a standard configuration that meets your requirements, Qioptiq offers efficient and affordable custom modifications to meet special parameters. Useful Formulas & Definitions Camera Chip Dimensions (mm): 1/4" CHiP 6.0 8.0 1/3" CHiP 1/2" CHiP 8.8 .0 11 2/3" CHiP 9.6 6.4 6.6 4.8 4.8 3.7 4.6 3.6 12.8 2.7 02 To specify your Optem Lens System identify the parameters of your application and select the modular components which deliver the optimum imaging solution. .0 16 1" CHiP Depth-of-Field (DOF): The axial depth of the space on both sides of the object plane within which the object can be moved without objectionable loss of sharpness. DOF = l ÷ NA2 l = Wavelength of Light (Green Light = 0.000550mm or 550nm) Magnification: The ratio of image size to actual object size. Optical Mag. = Camera Chip dim. ÷ Field-of-View (FOV) Electronic Mag. = Monitor Diag. ÷ Camera Diag. Numerical Aperture (NA): A measurement of the light collecting ability of the lens. A higher NA translates to a brighter image, better resolution, and shallower depth-of-field. Zoom and Function Modules Upper Zoom Modules Lower Function Modules The specific Upper Zoom Module selected will determine the type of zoom operation for your Zoom 70XL System. When configuring your Zoom 70XL Lens System, choose from the following Lower Modules to specify the lighting and focus functions of your systems: • Basic Module Manual Zoom Module – Provides basic hand-driven 7:1 zoom function. • Internal Focus Module (motor avail.) • Coaxial Illumination Module • Internal Focus Coaxial Module (motor avail.) Iris Diaphragm Module – Provides manual 7:1 zoom with manual iris illumination control for increased depth-of-field and/or maintain consistent image brightness across your entire field. If you require specialized optical performance, select from these special Lower Function Modules to boost magnification or provide flexible working distance. Detent Module – Obtain specific and repeatable magnification stops throughout the 7:1 zoom range without the complexity and cost of motorization. Detents are ideal for metrology applications where each position can be calibrated. Factory-set stops are located at 0.75X, 1.0X, 1.5X, 2.0X, 3.0X, 4.0X, and 5.0X Objective Modules - Integrate Infinity-Corrected Objectives utilizing one of four Objective Lower Function Modules. All are equipped with M26 x 36T threads to accept Optem and Mitutoyo Objectives. An RMS thread adapter is available for Nikon and Olympus Objectives (See p. 9 for Objectives performance). Motorized Zoom Module – Provides automated zoom function in either DC or Stepper Motorized versions. All Stepper Motorized Models come complete with homing and limit sensors. Variable Working Distance Auxiliary Lens Intended for applications requiring working distances between 127mm (5”) and 432mm (17”). Covers magnification factors 0.288X at 127mm, and 0.109X at 432mm (See p. 9 for VWD factors). Resolution: The ability to distinguish or separate fine detail. Expressed in line pairs per millimeter (lp/mm). Numerical Aperture (NA) is the controlling factor over resolution... the higher the NA, the brighter the image, and the better the resolution. Vignetting: The blockage of rays from off-axis object points by constraining apertures. Vignetting results in the darkening of the corners on your monitor. Visual Resolution (lp/mm) = 3000 X NA 1 ÷ lp/mm = Approx. microns (µ) resolved 03 Illumination Options Illumination Options The Zoom 70XL Lens System offers a variety of illumination options to meet a variety of imaging requirements. 04 You have two basic illumination options which can be integrated with your Zoom 70XL System... coaxial illumination or oblique ring light illumination. Coaxial Illumination Options Coaxial (or vertical) illumination is most useful on highly reflective objects. Optem’s Coaxial Illuminators project cool, white light perpendicularly onto the specimen for exceptional contrast and field uniformity. Select from one of several coaxial-equipped Lower Function Modules when specifying your Zoom 70XL lens system and integrate one of the three following options of coaxial illumination. Fiber Optic Coaxial Illuminators – Integrate coaxial illumination from you choice of either 110V or 220V Optem VSI Fiber Optic Illuminators using flexible 40- or 60-inch flexible fiber bundles. LED Coaxial Illuminators – Programmable 1-Watt LED Coaxial Illuminators offer reduced power requirements and heat generation with substantial service life gains. LED Coaxial illuminators are available in straight and right-angle configurations to meet your specific space requirements, and feature compact designs and simplified cable management. These can be driven by stand-alone, single-channel programmable controllers. Coaxial LEDs emit brilliant cool light in the visible spectrum and deliver virtually identical optical performance to our traditional Fiber Optic Coaxial Illuminator. 10W halogen Coaxial Illuminators – When economy is high priority, Halogen light sources are available with a 6V Variable Transformer (110V / 220V) (see System Diagram p. 10-11). Polarized Light – When imaging highly reflective subjects, Polarizer Modules with built-in Analyzers are available to introduce polarization to both LED and Fiber Optic Coaxial Illumination paths. Oblique Ring Light Options Dark Field Illumination is generally used on 3-D objects to cast light rays at an angle onto an object, thus better defining its surface profile. Optem offers the following dark field illuminators for the Zoom 70XL System. Fiber Optic Ring Lights – Ring light Illuminators are ideal to better define features of dimensionrich subjects. Driven with the same VSI Fiber Optic Illuminator as conventional coaxial systems. Qioptiq offers Ring lights specifically designed for a variety of configurations, including integration of objectives (see System Diagram p. 10-11). Motorization & Configuration Accessories Configuration Accessories In addition to modifying the physical configuration and orientation of your imaging path utilizing Right-Angle and U-bend TV Tubes (see System Diagram p. 10-11), you can extend the versatility of your Zoom 70XL Lens System with two new innovations in form and function. Motorizing Lens System Optem Lens Systems can be specified with motorized zoom and/or focus functions. STEPPER MOTOR – The stepper motors provide accurate repeatability of zoom magnification and/ or focus using a Hall-effect sensor to set repeatable home position. A desktop rocker switch controller offers manual control and features an RS-232 port for automated computer control. Includes controller instructions with a list of RS-232 control commands, a Windows® control program, and startup LabVIEW control program. An OEM controller board version is available for streamlined integration. 301730-802 (DB-25) 301730-803 (DB-9) 30-17-74-000 30-17-31-000 Junction Box (110V 60Hz) 30-17-75-000 ZOOM OEM Controller Board 30-17-36-000 (EURO) 30-17-32-000 (230V 50Hz) 30-17-33-000 (U.K.) To Computer Com Port DC MOTOR – DC motors provide continuous control of zoom magnification and/or focus. A desktop joystick controller offers simultaneous control of both zoom and focus functions. Mid-System, Right-Angle Module – This accessory allows the introduction of a 90° of your optical axis at the mid-body point of your Zoom 70XL Lens System. Users can now integrate any Zoom 70XL Lower Function Module below the right-angle turn, maintaining full working distance and affording greater configuration flexibility. NOTE: the Mid-System Right-Angle Module produces a mirror (reversed) image. Dual-Magnification Module – Simultaneously integrate two Zoom 70XL Zoom Modules with TV Tube, and/or Optem FMOS Fixed Tubes over a single subject. This permits real-time dual fixed and/or zoom imaging of your object of interest with your choice of magnifications, FOVs, camera formats and camera types. Integrate any of the full range of FMOS, Zoom 70XL and Zoom 125C Lower Function Modules below the Dual-Mag Module, or integrate vertical illumination through the compact DualMag coaxial block. 05 94.8 130 1/2" 2/3" 13 71.1 97.8 142 1/2" 2/3" 1" 13 53.3 73.3 107 1/2" 2/3" 1" 48.9 71.1 2/3" 1" x x x x 31 x 17.8 23.7 32.6 47.4 Mag DOF (mm) 1/3" 1/2" 2/3" 1" 63.2 43.5 31.6 23.7 31 x 13.3 17.8 24.4 35.6 Mag DOF (mm) 1/3" 1/2" 2/3" 1" 5.13 3.53 2.56 1.92 160 mm ø 47.4 32.6 23.7 17.8 6.84 4.70 3.42 2.56 10.3 7.05 5.13 3.85 15.4 10.6 7.69 5.77 20.5 14.1 10.3 7.69 18.8 13.7 10.3 x x x x 2.5 1.9 45 0.015 x x x x 2.5 1.4 45 0.015 x x x x 2.5 0.94 45 0.015 x x x x 2.5 0.62 45 0.015 x x x x 2.5 0.47 45 0.015 x x x 2.5 0.35 45 0.015 6.84 4.70 3.42 2.56 9.12 6.27 4.56 3.42 13.7 9.40 6.84 5.13 20.5 14.1 10.3 7.69 27.4 18.8 13.7 10.3 25.1 18.2 13.7 High Mag x x x 125 91.0 68.3 x x x x 137 93.9 68.3 51.2 x x x x 102 70.4 51.2 38.4 x x x x 68.3 46.9 34.1 25.6 x x x x 45.5 31.3 22.8 17.1 25.6 17.6 12.8 9.60 x x x x 16 0.38 18 3.69 2.54 1.85 1.38 4.92 3.38 2.46 1.85 7.38 5.08 3.69 2.77 11.1 7.61 5.54 4.15 14.8 10.2 7.38 5.54 13.5 9.8 7.38 x x x x 1.4 2.6 60 0.020 x x x x 1.4 2.0 60 0.020 x x x x 1.4 1.3 60 0.020 x x x x 1.4 0.87 60 0.020 x x x x 1.4 0.65 60 0.020 x x x 1.4 0.49 60 0.020 4.92 3.38 2.46 1.85 6.56 4.51 3.28 2.46 9.85 6.77 4.92 3.69 14.8 10.1 7.38 5.54 19.7 13.5 9.85 7.38 18.1 13.1 9.8 High Mag 110 mm ø 34.1 23.5 17.1 12.8 0.0060 34.1 23.5 17.1 12.8 16 0.28 18 0.0060 51.2 35.2 25.6 19.2 16 0.19 18 0.0060 76.8 52.8 38.4 28.8 16 0.13 18 0.0060 102 70.4 51.2 38.4 16 0.094 18 0.0060 93.9 68.3 51.2 16 0.070 18 0.0060 Low Mag 29-20-09-000 WD: 310 mm 0.25X Aux Lens 12.8 8.80 6.40 4.80 17.1 11.7 8.53 6.40 25.6 17.6 12.8 9.60 38.4 26.4 19.2 14.4 51.2 35.2 25.6 19.2 46.9 34.1 25.6 x x x x 3.9 0.75 36 0.012 x x x x 3.9 0.56 36 0.012 x x x x 3.9 0.38 36 0.012 x x x x 3.9 0.25 36 0.012 x x x x 3.9 0.19 36 0.012 x x x 3.9 0.14 36 0.012 1.85 1.27 0.92 0.69 2.46 1.69 1.23 0.92 3.69 2.54 1.85 1.38 5.54 3.81 2.77 2.08 7.38 5.08 3.69 2.77 6.77 4.92 3.69 x x x x 0.35 5.2 120 0.040 x x x x 0.35 3.9 120 0.040 x x x x 0.35 2.6 120 0.040 x x x x 0.35 1.7 120 0.040 x x x x 0.35 1.3 120 0.040 x x x 0.35 0.98 120 0.040 2.46 1.69 1.23 0.92 3.28 2.26 1.64 1.23 4.92 3.38 2.46 1.85 7.38 5.07 3.69 2.77 9.85 6.77 4.92 3.69 9.03 6.56 4.92 High Mag 56 mm ø 17.1 11.7 8.53 6.40 22.8 15.6 11.4 8.53 34.1 23.5 17.1 12.8 51.2 35.2 25.6 19.2 68.3 46.9 34.1 25.6 62.6 45.5 34.1 Low Mag 29-20-38-000 WD: 178 mm 0.5X Aux Lens 8.53 5.87 4.27 3.20 11.4 7.82 5.69 4.27 17.1 11.7 8.53 6.40 25.6 17.6 12.8 9.60 34.1 23.5 17.1 12.8 31.3 22.8 17.1 x x x x 1.8 1.1 54 0.018 x x x x 1.8 0.84 54 0.018 x x x x 1.8 0.56 54 0.018 x x x x 1.8 0.38 54 0.018 x x x x 1.8 0.28 54 0.018 x x x 1.8 0.21 54 0.018 1.23 0.85 0.62 0.46 1.64 1.13 0.82 0.62 2.46 1.69 1.23 0.92 3.69 2.54 1.85 1.38 4.92 3.38 2.46 1.85 4.51 3.28 2.46 x x x x 0.16 7.8 180 0.060 x x x x 0.16 5.9 180 0.060 x x x x 0.16 3.9 180 0.060 x x x x 0.16 2.6 180 0.060 x x x x 0.16 2.0 180 0.060 x x x 0.16 1.5 180 0.060 1.64 1.13 0.82 0.62 2.19 1.50 1.09 0.82 3.28 2.26 1.64 1.23 4.92 3.38 2.46 1.85 6.56 4.51 3.28 2.46 6.02 4.38 3.28 High Mag 37 mm ø 11.4 7.82 5.69 4.27 15.2 10.4 7.59 5.69 22.8 15.6 11.4 8.53 34.1 23.5 17.1 12.8 45.5 31.3 22.8 17.1 41.7 30.3 22.8 Low Mag 29-20-39-000 WD: 114 mm 0.75X Aux Lens 6.40 4.40 3.20 2.40 8.53 5.87 4.27 3.20 12.8 8.80 6.40 4.80 19.2 13.2 9.60 7.20 25.6 17.6 12.8 9.60 23.5 17.1 12.8 x x x x 0.98 1.5 72 0.024 x x x x 0.98 1.1 72 0.024 x x x x 0.98 0.75 72 0.024 x x x x 0.98 0.50 72 0.024 x x x x 0.98 0.38 72 0.024 x x x 0.98 0.28 72 0.024 0.92 0.63 0.46 0.35 1.23 0.85 0.62 0.46 1.85 1.27 0.92 0.69 2.77 1.90 1.38 1.04 3.69 2.54 1.85 1.38 3.38 2.46 1.85 x x x x 0.089 10 240 0.080 x x x x 0.089 7.8 240 0.080 x x x x 0.089 5.2 240 0.080 x x x x 0.089 3.5 240 0.080 x x x x 0.089 2.6 240 0.080 x x x 0.089 1.95 240 0.080 1.23 0.85 0.62 0.46 1.64 1.13 0.82 0.62 2.46 1.69 1.23 0.92 3.69 2.54 1.85 1.38 4.92 3.38 2.46 1.85 4.51 3.28 2.46 High Mag 28 mm ø 8.53 5.87 4.27 3.20 11.4 7.82 5.69 4.27 17.1 11.7 8.53 6.40 25.6 17.6 12.8 9.60 34.1 23.5 17.1 12.8 31.3 22.8 17.1 Low Mag No Aux Lens required WD: 89 mm Base Configuration 4.27 2.93 2.13 1.60 5.69 3.91 2.84 2.13 8.53 5.87 4.27 3.20 12.8 8.80 6.40 4.80 17.1 11.7 8.5 6.40 15.6 11.4 8.53 x x x x 0.44 2.3 108 0.036 x x x x 0.44 1.7 108 0.036 x x x x 0.44 1.1 108 0.036 x x x x 0.44 0.75 108 0.036 x x x x 0.44 0.56 108 0.036 x x x 0.44 0.42 108 0.036 0.62 0.42 0.31 0.23 0.82 0.56 0.41 0.31 1.23 0.85 0.62 0.46 1.85 1.27 0.92 0.69 2.46 1.69 1.23 0.92 2.26 1.64 x x x x 0.039 16 360 0.12 x x x x 0.039 12 360 0.12 x x x x 0.039 7.8 360 0.12 x x x x 0.039 5.2 360 0.12 x x x x 0.039 3.9 360 0.12 x x x 0.039 2.9 360 0.12 0.82 0.56 0.41 0.31 1.09 0.75 0.55 0.41 1.64 1.13 0.82 0.62 2.46 1.69 1.23 0.92 3.28 2.26 1.64 1.23 3.01 2.19 1.64 High Mag 1.23 19 mm ø 5.69 3.91 2.84 2.13 7.59 5.21 3.79 2.84 11.4 7.82 5.69 4.27 17.1 11.7 8.53 6.40 22.8 15.6 11.4 8.5 20.9 15.2 11.4 Low Mag 29-20-40-000 WD: 52 mm 1.5X Aux Lens Oblique/Substage Illumination -- FOV Limited by vignetting at low mags. Approximate maximum illuminated FOV given as diameter above. x x x 13 0.27 Res (lp/mm) 0.0043 x x x 13 0.20 Res (lp/mm) NA 94.8 65.2 47.4 35.6 0.0043 35.6 1/2" NA 26.7 1/3" 31 13 0.14 Mag DOF (mm) 142 97.7 71.1 53.3 0.0043 x x Res (lp/mm) NA x 40.0 1/3" x 31 0.090 DOF (mm) Mag Res (lp/mm) 190 130 94.8 71.1 0.0043 x x x x 53.3 1/3" 0.068 31 NA 174 126 94.8 0.0043 x DOF (mm) Mag Res (lp/mm) NA x 71.1 1/3" x 31 0.051 13 0.0043 Low Mag 29-20-09-000 (No Spacer) WD: 468 mm DOF (mm) Mag Max FOV at Low Mag (Dia.): TV Tube 2.0X TV Tube 1.5X TV Tube 1.0X TV Tube 0.67X TV Tube 0.5X TV Tube FOV (mm) FOV (mm) FOV (mm) 0.375X NA Res (lp/mm) FOV (mm) FOV (mm) FOV (mm) 0.18X Aux Lens Optical Performance - Cam Format Cam Format Cam Format Cam Format Cam Format Cam Format 06 3.20 2.20 1.60 1.20 4.27 2.93 2.13 1.60 6.40 4.40 3.20 2.40 9.60 6.60 4.80 3.60 12.8 8.80 6.40 4.80 11.7 8.53 6.40 x x x x 0.25 3.0 144 0.048 x x x x 0.25 2.3 144 0.048 x x x x 0.25 1.5 144 0.048 x x x x 0.25 1.0 144 0.048 x x x x 0.25 0.75 144 0.048 x x x 0.25 0.56 144 0.048 0.46 0.32 0.23 0.17 0.62 0.42 0.31 0.23 0.92 0.63 0.46 0.35 1.38 0.95 0.69 0.52 1.85 1.27 0.92 0.69 1.69 1.23 x x x x 0.022 21 480 0.16 x x x x 0.022 16 480 0.16 x x x x 0.022 10 480 0.16 x x x x 0.022 6.9 480 0.16 x x x x 0.022 5.2 480 0.16 x x x 0.022 3.9 480 0.16 0.62 0.42 0.31 0.23 0.82 0.56 0.41 0.31 1.23 0.85 0.62 0.46 1.85 1.27 0.92 0.69 2.46 1.69 1.23 0.92 2.26 1.64 1.23 High Mag 0.92 14 mm ø 4.27 2.93 2.13 1.60 5.69 3.91 2.84 2.13 8.53 5.87 4.27 3.20 12.8 8.80 6.40 4.80 17.1 11.7 8.53 6.40 15.6 11.4 8.53 Low Mag 29-20-41-000 WD: 32 mm 2.0X Aux Lens -- -- 2/3" 1" -- 1" 8.53 11.7 -- 1/2" 2/3" 1" 1.8 x 4.27 5.69 7.82 11.4 DOF (mm) 1/3" 1/2" 2/3" 1" 1.8 x 3.20 4.27 5.87 8.53 DOF (mm) 1/3" 1/2" 2/3" 1" -- -- 1.23 0.85 0.62 0.46 1.64 1.13 0.82 0.62 1.69 -- 1.23 0.92 -- -- -- 1.38 -- -- -- -- -- -- 8.9 mm ø 11.4 7.82 5.69 4.27 15.2 10.4 7.59 5.69 15.6 -- 11.4 8.53 -- -- -- 12.8 -- -- -- -- -- -- x x x x 0.16 7.8 180 0.060 x x x x 0.16 5.9 180 0.060 x x x 0.16 3.9 180 0.060 x 0.16 2.6 180 0.060 0.16 2.0 180 0.060 0.16 1.5 180 0.060 1.64 1.13 0.82 0.62 2.19 1.50 1.09 0.82 2.26 -- 1.64 1.23 -- -- -- 1.85 -- -- -- -- -- -- -- High Mag 6.40 4.40 3.20 2.40 8.53 5.87 4.27 3.20 8.80 12.8 6.40 4.80 -- 13.2 9.60 7.20 -- -- 12.8 9.60 -- -- 12.8 x x x x 0.98 1.5 72 0.024 x x x x 0.98 1.1 72 0.024 x x x x 0.98 0.75 72 0.024 x x x 0.98 0.50 72 0.024 x x 0.98 0.38 72 0.024 x 0.98 0.28 72 0.024 0.92 0.63 0.46 0.35 1.23 0.85 0.62 0.46 1.27 1.85 0.92 0.69 -- 1.90 1.38 1.04 -- -- 1.85 1.38 -- -- 1.85 x x x x 0.089 10 240 0.080 x x x x 0.089 7.80 240 0.080 x x x x 0.089 5.2 240 0.080 x x x 0.089 3.5 240 0.080 x x 0.089 2.6 240 0.080 x 0.089 1.95 240 0.080 1.23 0.85 0.62 0.46 1.64 1.13 0.82 0.62 1.69 2.46 1.23 0.92 -- 2.54 1.85 1.38 -- -- 2.46 1.85 -- -- 2.46 High Mag 12 mm ø 8.53 5.87 4.27 3.20 11.4 7.82 5.69 4.27 11.7 17.1 8.53 6.40 -- 17.6 12.8 9.60 -- -- 17.1 12.8 -- -- 17.1 Low Mag No Aux Lens Required WD: 89 mm Base Configuration 8.53 4.27 2.93 2.13 1.60 5.69 3.91 2.84 2.13 5.87 8.53 4.27 3.20 12.8 8.80 6.40 4.80 17.1 11.7 8.53 6.40 15.6 11.4 x x x x 0.44 2.3 108 0.036 x x x x 0.44 1.7 108 0.036 x x x x 0.44 1.1 108 0.036 x x x x 0.44 0.75 108 0.036 x x x x 0.44 0.56 108 0.036 x x x 0.44 0.42 108 0.036 1.23 0.62 0.42 0.31 0.23 0.82 0.56 0.41 0.31 0.85 1.23 0.62 0.46 1.85 1.27 0.92 0.69 2.46 1.69 1.23 0.92 2.26 1.64 x x x x 0.039 16 360 0.12 x x x x 0.039 12 360 0.12 x x x x 0.039 7.8 360 0.12 x x x x 0.039 5.2 360 0.12 x x x x 0.039 3.9 360 0.12 x x x 0.039 2.9 360 0.12 0.82 0.56 0.41 0.31 1.09 0.75 0.55 0.41 1.13 1.64 0.82 0.62 2.46 1.69 1.23 0.92 3.28 2.26 1.64 1.23 3.01 2.19 1.64 High Mag 13 mm ø 5.69 3.91 2.84 2.13 7.59 5.21 3.79 2.84 7.82 11.4 5.69 4.27 17.1 11.7 8.53 6.40 22.8 15.6 11.4 8.53 20.9 15.2 11.4 Low Mag 29-20-40-000 WD: 52 mm 1.5X Aux Lens 6.40 x x x x x 0.25 3.0 144 0.048 x x x x 0.25 2.3 144 0.048 x x x x 0.25 1.5 144 0.048 x x x x 0.25 1.0 144 0.048 x x x x 0.25 0.75 144 0.048 x x 8.53 0.92 0.46 0.32 0.23 0.17 0.62 0.42 0.31 0.23 0.63 0.92 0.46 0.35 1.38 0.95 0.69 0.52 1.85 1.27 0.92 0.69 1.69 1.23 10 mm ø 4.27 2.93 2.13 1.60 5.69 3.91 2.84 2.13 5.87 8.53 4.27 3.20 12.8 8.80 6.40 4.80 17.1 11.7 8.53 6.40 15.6 11.4 x x x x 0.022 21 480 0.16 x x x x 0.022 16 480 0.16 x x x x 0.022 10 480 0.16 x x x x 0.022 6.9 480 0.16 x x x x 0.022 5.2 480 0.16 x x x 0.022 3.9 480 0.16 0.62 0.42 0.31 0.23 0.82 0.56 0.41 0.31 0.85 1.23 0.62 0.46 1.85 1.27 0.92 0.69 2.46 1.69 1.23 0.92 2.26 1.64 1.23 High Mag Auxiliary Lens Mag. 0.288 0.253 0.226 0.202 0.184 0.169 0.158 0.147 0.138 0.130 0.123 0.116 0.109 Working Distance 5” 6” 7” 8” 9” 10” 11” 12” 13” 14” 15” 16” 17” Variable Working Distance Lower Module Optical Performance -- Not recommended due to significant illumination losses throughout entire zoom range. 3.20 2.20 1.60 1.20 4.27 2.93 2.13 1.60 4.40 6.40 3.20 2.40 9.60 6.60 4.80 3.60 12.8 8.80 6.40 4.80 11.7 8.53 0.25 0.56 144 0.048 Low Mag 29-20-41-000 WD: 32 mm 2.0X Aux Lens Coaxial Illumination -- FOV Limited by illumination at low mags. Approximate maximum illuminated FOV given as diameter above. x x x 54 1.1 Mag 0.018 x x Res (lp/mm) NA 0.84 Mag x 54 0.018 x x x 1.8 Res (lp/mm) NA 6.40 1/3" DOF (mm) 54 0.56 Mag 0.018 Res (lp/mm) NA -- x 9.60 1/3" -- 1.8 DOF (mm) 1/2" 0.38 Mag 2/3" 54 0.018 Res (lp/mm) NA -- -- 1/3" 1.8 DOF (mm) 1/2" 54 0.28 Mag 0.018 Res (lp/mm) Max FOV at Low Mag (Dia.): TV Tube 2.0X TV Tube 1.5X TV Tube 1.0X TV Tube 0.67X TV Tube 0.5X -- 2/3" NA -- -- 1/3" 1/2" 1.8 DOF (mm) FOV (mm) FOV (mm) FOV (mm) FOV (mm) FOV (mm) FOV (mm) TV Tube Cam Format Cam Format Cam Format Cam Format Cam Format 0.375X 0.21 Mag 0.018 Low Mag 29-20-39-000 WD: 114 mm 0.75X Aux Lens 54 Cam Format Res (lp/mm) NA NOTE: 0.18X, 0.25X and 0.5X Aux Lenses are not recommended for use with coaxial illumination Optical Performance - 07 Long-Working Distance Objectives Achieve significantly higher magnifications and increased resolution. Combine your Zoom 70XL with the expanded line of Optem LWD Infinity-Corrected Objectives. 08 When integrating objectives onto your Zoom 70XL Lens System, You will need to specify one of four Objective Lower Function Modules (see System Diagram p. 10-11). Optem M-Plan APO, LWD Objectives Eliminate chromatic aberration across exceptionally flat fields for the ultimate in high-magnification accuracy. Select from 2X, 5X, 10X, and 20X LongWorking Distance Objectives. These objectives are exact replacements for Mitutoyo 378 series objectives and are ideal for metrology applications. LWD Infinity-Corrected M-Plan APO Objectives • 2X M Plan APO, LWD................... 28-21-02-000 • 5X M Plan APO, LWD .................. 28-21-05-000 • 10X M Plan APO, LWD ................ 28-21-10-000 • 20X M Plan APO, LWD................. 28-21-11-000 Optem High-Resolution, LWD Objectives Specifically designed to capture maximum resolution at the high-end magnifications of Optem Zoom Lenses, the 5X, 10X and 20X Optem HR Objectives are ideal for applications where distinguishing every finite detail is critical. LWD Infinity-Corrected Hi Res Objectives • 5X High-Resolution, LWD............. 28-20-44-000 • 10X High-Resolution, LWD........... 28-20-45-000 • 20X High-Resolution, LWD........... 28-20-46-000 0.5X 13.3 -- 1/2" 2/3" 13.3 1.44 13.7 2/3" 1" 6.67 9.17 13.3 2/3" 1" 4.44 6.11 8.89 1/2" 2/3" 1" 2.50 3.33 4.58 6.67 1/2" 2/3" 1" 0.96 0.66 0.48 0.36 1.28 0.88 0.64 0.48 1.92 1.32 0.96 0.72 -- 1.98 1.44 14 mm ø 8.89 6.11 4.44 3.33 11.9 8.15 5.93 4.44 17.8 12.2 8.89 6.67 -- 18.3 13.3 x x x x 0.19 10 165 0.055 x x x x 0.19 7.5 165 0.055 x x x x 0.19 5.0 165 0.055 x x x 1.28 0.88 0.64 0.48 1.71 1.18 0.85 0.64 2.56 1.76 1.28 0.96 -- 2.64 1.92 1.44 -- 2.56 1.92 2.67 1.83 1.33 1.00 3.56 2.44 1.78 1.33 5.33 3.67 2.67 2.00 8.00 5.50 4.00 3.00 7.33 5.33 4.00 x x x x 0.16 3.6 180 0.060 x x x x 0.16 2.7 180 0.060 x x x x 0.16 1.8 180 0.060 x x x x 0.16 1.2 180 0.060 x x x 0.16 0.90 180 0.060 0.38 0.26 0.19 0.14 0.51 0.35 0.26 0.19 0.77 0.53 0.38 0.29 1.15 0.79 0.58 0.43 1.06 0.77 0.58 x x x x 0.029 25 420 0.14 x x x x 0.029 19 420 0.14 x x x x 0.029 12 420 0.14 x x x x 0.029 8.3 420 0.14 x x x 0.029 6.2 420 0.14 0.51 0.35 0.26 0.19 0.68 0.47 0.34 0.26 1.03 0.71 0.51 0.38 1.54 1.06 0.77 0.58 1.41 1.03 0.77 High Mag 6.1 mm ø 3.56 2.44 1.78 1.33 4.74 3.26 2.37 1.78 7.11 4.89 3.56 2.67 10.7 7.33 5.33 4.00 9.78 7.11 5.33 Low Mag 28-21-05-000 WD: 34 mm 5X M Plan APO LWD Objective 1.33 0.92 0.67 0.50 1.78 1.22 0.89 0.67 2.67 1.83 1.33 1.00 -- 2.75 2.00 1.50 3.67 2.67 2.00 x x x x 0.039 7.2 360 0.12 x x x x 0.039 5.4 360 0.12 x x x x 0.039 3.6 360 0.12 x x x 0.039 2.4 360 0.12 x x x 0.039 1.8 360 0.12 0.19 -- Not recommended due to significant illumination losses throughout entire zoom range. 25 900 0.30 x x x x x x x 0.34 0.24 0.17 0.13 0.51 0.35 0.26 0.19 -- 0.53 0.38 0.29 0.71 0.51 0.38 0.26 0.18 0.13 0.096 0.0063 50 900 0.30 x x x x 0.0063 37 900 0.30 x x x x 0.0063 0.096 0.13 17 900 0.30 x x x 0.0063 0.072 0.26 0.18 0.13 0.10 0.38 0.26 0.19 0.14 -- 0.40 0.29 0.22 0.53 0.38 0.29 0.0063 12 900 0.30 High Mag 2.8 mm ø 1.78 1.22 0.89 0.67 2.37 1.63 1.19 0.89 3.56 2.44 1.78 1.33 -- 3.66 2.67 2.00 4.89 3.56 2.67 Low Mag 28-21-10-000 WD: 34 mm 10X M Plan APO LWD Objective 0.67 0.46 0.33 0.25 0.89 0.61 0.44 0.33 1.33 0.92 0.67 0.50 -- 1.37 1.00 0.75 -- 1.33 1.00 x x x x 0.010 14 720 0.24 x x x x 0.010 11 720 0.24 x x x x 0.010 7.2 720 0.24 x x x 0.010 4.8 720 0.24 x x 0.010 3.6 720 0.24 0.096 0.066 0.048 0.036 0.13 0.088 0.064 0.048 0.19 0.13 0.096 0.072 -- 0.20 0.14 0.11 -- 0.19 0.14 x x x x 0.0032 100 1260 0.42 x x x x 0.0032 75 1260 0.42 x x x x 0.0032 50 1260 0.42 x x x 0.0032 33 1260 0.42 x x 0.0032 25 1260 0.42 0.13 0.088 0.064 0.048 0.17 0.12 0.085 0.064 0.26 0.18 0.13 0.096 -- 0.26 0.19 0.14 -- 0.26 0.19 High Mag 1.1 mm ø 0.89 0.61 0.44 0.33 1.19 0.81 0.59 0.44 1.78 1.22 0.89 0.67 -- 1.83 1.33 1.00 -- 1.78 1.33 Low Mag 28-21-11-000 WD: 20 mm 20X M Plan APO LWD Objective 2.67 1.83 1.33 1.00 3.56 2.44 1.78 1.33 5.33 3.67 2.67 2.00 -- 5.50 4.00 3.00 -- 5.33 4.00 x x x x 0.16 3.6 180 0.060 x x x x 0.16 2.7 180 0.060 x x x x 0.16 1.8 180 0.060 x x x 0.16 1.2 180 0.060 x x 0.16 0.90 180 0.060 0.58 0.79 -- 0.29 0.38 0.53 0.77 0.19 0.26 0.35 0.51 0.144 0.19 0.26 0.38 5.33 7.33 -- 2.67 3.56 4.89 7.11 1.78 2.37 3.26 4.74 1.33 1.78 2.44 3.56 5.3 mm ø 0.43 4.00 x x x 0.51 0.35 0.26 1.33 0.92 0.67 0.50 x x x x 0.039 0.016 0.19 7.2 x 360 25 x x 570 1.78 1.22 x x 0.12 0.68 0.47 0.89 0.67 0.19 x x x 0.34 0.039 0.016 0.26 5.4 x 360 19 x x 570 2.67 1.83 x x 0.12 1.03 0.71 1.33 1.00 0.19 x x x 0.51 0.039 0.016 0.38 3.6 x 360 12 x x x 570 -- 2.75 2.00 1.50 0.12 -- 1.06 0.77 0.58 0.19 x x x 0.19 50 1170 0.39 x x x x x x x x 0.0037 0.096 0.13 37 1170 0.39 x x x x 0.0037 0.072 0.26 0.18 0.13 25 1170 0.39 x x x 0.0037 0.096 0.38 0.26 0.19 0.14 -- 0.40 0.29 0.22 2.0 mm ø 1.78 1.22 0.89 0.67 2.37 1.63 1.19 0.89 3.56 2.44 1.78 1.33 -- 3.66 2.67 2.00 17 0.0037 2.4 0.39 x x 0.039 -- 0.38 0.29 8.3 -- 3.56 2.67 0.016 x x 1170 -- 2.67 2.00 360 -- 1.03 0.77 0.12 -- -- x x 570 0.77 0.0037 0.19 0.58 12 1.8 0.039 6.2 0.016 7.11 1170 360 570 0.39 0.12 0.26 0.18 0.13 0.096 0.34 0.24 0.17 0.13 0.51 0.35 0.26 0.19 -- 0.53 0.38 0.29 -- 0.51 0.38 High Mag Low Mag 0.19 28-20-45-000 WD: 19 mm 10X High-Res* LWD Objective High Mag 5.33 Low Mag 28-20-44-000 WD: 34 mm 5X High-Res* LWD Objective * Zoom 70XL does not pass full NA of Optem 5X and 10X HR Objectives 0.67 0.46 0.33 0.25 0.89 0.61 0.44 0.33 1.33 0.92 0.67 0.50 -- 1.37 1.00 0.75 1.83 1.33 1.00 x x x x 0.0098 14 720 0.24 x x x x 0.0098 11 720 0.24 x x x x 0.0098 7.2 720 0.24 x x x 0.0098 4.8 720 0.24 x x x 0.0098 3.6 720 0.24 75 1800 0.60 x x x x 100 1800 0.60 x x 0.036 0.096 0.066 0.048 x x x x 0.26 0.18 0.13 0.13 0.088 0.064 0.048 0.17 0.12 0.085 0.064 0.0016 0.088 x x -- 0.26 0.19 0.14 0.35 0.26 0.19 0.096 0.0016 0.064 0.13 50 1800 0.60 x x x 0.0016 0.048 0.19 0.13 0.10 33 1800 0.60 x x x 0.0016 0.072 -- 0.20 0.14 0.11 0.26 0.19 0.14 1.4 mm ø 0.89 0.61 0.44 0.33 1.19 0.81 0.59 0.44 1.78 1.22 0.89 0.67 -- 1.83 1.33 1.00 2.44 1.78 1.33 0.0016 25 1800 0.60 High Mag 28-20-46-000 WD: 13 mm 20X High-Res LWD Objective Low Mag Objectives with coaxial Illumination -- FOV Limited by illumination at low mags. Approximate maximum illuminated FOV given as diameter above. x x x x 0.98 DOF (mm) 1/3" 72 1.44 Mag 0.024 x x x x 0.98 Res (lp/mm) NA 3.33 1/3" DOF (mm) 72 1.1 Mag 0.024 x x x x Res (lp/mm) NA 5.00 1/2" 0.98 DOF (mm) 1/3" 72 0.72 Mag 0.024 x x x Res (lp/mm) NA 10.0 1/2" -- 7.50 1/3" 3.3 0.98 0.19 0.48 0.055 x x Mag 1.08 -- 1.92 DOF (mm) 10.0 -- 17.8 165 0.024 x x 72 Res (lp/mm) NA 10.0 1/3" 2.5 0.98 0.19 0.36 Mag 0.055 DOF (mm) Max FOV at Low Mag (Dia.): TV Tube 2.0X TV Tube 1.5X TV Tube 1.0 TV Tube 0.67X TV Tube FOV (mm) FOV (mm) FOV (mm) High Mag 165 0.024 Low Mag 28-21-02-000 WD: 34 mm 72 NA Res (lp/mm) Cam Format Cam Format Cam Format Cam Format Cam Format NOTE: 0.375X TV Tube is not recommended for use with Optem Objectives FOV (mm) FOV (mm) 2x M Plan APO LWD Objective Optical Performance - 09 Zoom 70XL Lens System Diagram Mini TV Tubes Tube Clamp Mounts Right-Angle TV Tubes 29-50-10-000 UNIVERSAL CLAMP (top view) 29-90-86-000 – 0.5X RA 29-90-87-000 – 0.67X RA 29-90-74-000 – 1.0X RA 29-90-88-000 – 1.5X RA 29-90-89-000 – 2.0X RA 30-25-76-000 76mm O.D. TUBE CLAMP (OLYMPUS, NIKON, LEICA) 30-25-82-000 82mm O.D. TUBE CLAMP (UNITRON) 39-15-34-000 FLAT MOUNT (for Motorized versions) 29-90-81-000 1.0X U-BEND TV TUBE 29-90-26-000 0.5X MINI TV TUBE NOTE: Right-Angle TV Tubes yield a reversed image U-Bend TV Tube 30-25-83-000 83mm O.D. TUBE CLAMP (GENERIC) 29-90-27-000 0.67X MINI TV TUBE 29-90-28-000 1.5X MINI TV TUBE 29-90-90-000 1.0X MINI TV TUBE 30-25-84-000 84mm O.D. TUBE CLAMP (MEIJI) Upper Zoom Modules 29-60-83-000 10 VSI 110 ILLUMINATOR 110 VOLT / 150 WATT 399510-309 399610-309 39-19-40-000 29-60-84-000 70XL UPPER MANUAL 70XL UPPER IRIS 70XL UPPER DETENTED VSI 220 ILLUMINATOR 220VOLT / 150 WATT 30-16-40-000 40” FLEX BUNDLE 30-16-60-000 60” FLEX BUNDLE 33-04-00-000 LOW PROFILE, R.A. COAXIAL LAMPHOUSE (Replaces standard bottom module lamphouse) 30-16-01-000 10MM ADAPTER Illumination 396010-810 SINGLE-CHANNEL PROGRAMMABLE LED CONTROLLER 30-16-01-000 10MM ADAPTER 29-65-14-000 STANDARD COAXIAL LAMPHOUSE 39-60-10-000 STRAIGHT 1-WATT COAXIAL LED 396010-810 SINGLE-CHANNEL PROGRAMMABLE LED CONTROLLER Lower Function Modules 39-60-10-000 STRAIGHT 1-WATT COAXIAL LED 29-25-15-000 ZOOM 70XL VARIABLE AUXILIARY LENS 299510-310 299591-310 296515-310 296591-310 BASIC MODULE INTERNAL FOCUS MODULE COAX ILLUM. MODULE COAX ILLUM. & FOCUS MODULE 39-60-20-000 RIGHT-ANGLE 1-WATT COAXIAL LED 33-03-03-000 RING LIGHT ADAPTER 27-60-07-000 110/6 VOLT VARIABLE 27-60-17-000 29-20-09-000 220/6 VOLT VARIABLE 0.18X / 0.25X CONVERTIBLE AUX LENS 29-60-09-000 10 WATT HALOGEN LAMP 29-60-81-000 HORIZONTAL RING LIGHT 29-60-31-000 MINI-ANNULAR RING PROBE 29-20-38-000 0.5X AUX LENS 29-20-39-000 0.75X AUX LENS 29-20-40-000 1.5X AUX LENS CAMERA Standard TV Tubes 29-90-29-000 2.0X MINI TV TUBE 29-90-82-000 0.38X TV TUBE 29-90-70-000 0.5X TV TUBE 29-90-73-000 1.5X 29-90-72-000 TV TUBE 1.0X 29-90-71-000 TV TUBE 0.67X TV TUBE Non-Inverting Right-Angle TV Tubes 29-90-80-000 2.0X TV TUBE 29-90-92-000 – 0.5X NIRA 29-90-93-000 – 0.67X NIRA 29-90-94-000 – 1.0X NIRA 29-90-95-000 – 1.5X NIRA 29-90-96-000 – 2.0X NIRA Motorization Control & Power Supply 39-19-37-000 39-19-20-000 28-80-18-000 110V TRANSFORMER 70XL UPPER STEPPING MOTOR HALL EFFECT SENSOR 28-80-19-000 220V TRANSFORMER DC MOTOR 30-17-20-000 DC MOTOR DRIVER 11 SEN SO R1 70XL UPPER DC MOTOR 391937 29-90-66-000 LONG WORKING RIGHT-ANGLE MODULE 30-17-70-000 STEPPING MOTOR DRIVER Can also integrate FMOS Upper Fixed Tubes. Refer to Optem FMOS Brochure 30-17-74-000 HALL EFFECT SENSOR JUNCTION BOX 29-90-67-000 NOTE: Long-Working Right-Angle Module yields a reversed image DUAL MAGNIFICATION MODULE STEPPER MOTOR 30-17-31-000 UNIV. TRANSFORMER (100-240V, 50-60Hz) 30-17-37-000 30-17-75-000 STEPPING MOTOR O.E.M. BOARD 299067-310 COAX MODULE (N. AMER CORD) 30-17-36-000 (EUR CORD) 30-17-33-000 (UK CORD) 299066-306 299066-304 FMOS / ZOOM 70 LOWER MODULE COUPLER 296084-310 296085-310 COAX ILLUM. OBJ. DUAL FOCUS COAX ILLUM. OBJECTIVE MODULE ZOOM 125 LOWER MODULE COUPLER 299066-302 M25x0.75 ADAPTER Integrates with Optem Zoom 125 Lower Function Modules. Refer to Zoom 125 Brochure 299084-310 OBJECTIVE DUAL FOCUS MODULE 299066-303 OPTEM / MITU. OBJECTIVES COUPLER 299066-305 NIKON / OLY OBJECTIVES COUPLER 299085-310 OBJECTIVE ADAPTER MODULE Color Key Optical Path Illumination Path Electrical 29-20-31-000 2X CONVERSION LENS Auxiliary Lenses 29-20-41-000 2.0X AUX LENS 30-17-01-000 30-17-02-000 0.5X R. A. AUX LENS 29-20-32-000 0.75X R. A. AUX LENS ® MITUTOYO 29-90-59-000 Optem LWD Objectives 28-20-44-000 - 5X HIGH-RES 28-20-45-000 - 10X HIGH-RES 28-20-46-000 - 20X HIGH-RES Optem® LWD Objectives 28-21-02-000 - 2X M PLAN APO 28-21-05-000 - 5X M PLAN APO 28-21-10-000 - 10X M PLAN APO 28-21-11-000 - 20X M PLAN APO RMS ADAPTER NIKON/OLYMPUS RIGHT ANGLE ADAPTER NOTE: Yields a reversed image, and reduces effective working distance by 48mm 30-16-50-000 OBJECTIVE RING LIGHT Zoom 70 XL - 03/11/11 Your Key to Photonic Innovation... Qioptiq serves a wide variety of applications across the industrial manufacturing sector. With a rich history of delivering innovative photonic components, modules and instruments to integrators, engineers and OEMs, we also offer custom-tailored photonic solutions to maximize the potential and capabilities of tomorrow’s many processes and industrial manufacturing systems. ...and Manufacturing Advancement For technical information Qioptiq www.qioptiq.com photonics@qioptiq.com North America Qioptiq, Inc. Fairport, NY USA Toll free: 800-724-4274 Tel: (585) 223-2370 Europe Qioptiq Photonics GmbH Göttingen, Germany Tel: +49 551 6935-0 Asia Pacific Qioptiq Pte Ltd. Singapore Tel: +65 6499 7766 Copyright ©2011 Qioptiq, Inc. All rights reserved. 399510-309-450, ed 7.0-1.5k • Printed in the USA Due to our on-going commitment to excellence in serving our customers, all specifications herein are subject to change without notice.
29-20-32-000 价格&库存
很抱歉,暂时无法提供与“29-20-32-000”相匹配的价格&库存,您可以联系我们找货
  • 10+1088.2591610+140.59460
