TPIS 1T 1086 L5.5
TPIS 1T 1086 L5.5
    EXCELITASTECHNOLOGIES(埃赛力达)
    TO-39
    温度传感器 数字,红外(IR) 17 b TO-39
TPIS 1T 1086 L5.5 数据手册
TM CaliPile Infrared Sensing Solu�ons TPiS 1T 1086 L5.5 / 7452 Product Specifica�on Features • Isothermal TO-39 package • High sensitivity thermopile with 5◦ field-of-view • Integrated 50 µW low-power signal processing • I2 C interface, hardwareconfigurable address • Calibration data for ambient and object temperature sensing • Interrupt function for presence, motion, over-temperature and more The TPiS 1T 1086 L5.5 is a thermopile sensor with integrated signal processing. TM It provides as a member of the CaliPile family factory calibration data stored in the sensors EEPROM. It features a confined field of view in an isothermal TO-39 package which ensure fast adaptation to ambient temperature changes. The technology of a high sensitive thermopile combined with a smart data treatment allows for much more than the traditional temperature measurement of remote objects. Once configured via the I2 C interface an interrupt output can be used to monitor motion, presence or an over-temperature of remote objects. One typical application is a remote object temperature monitoring with the feature of a fast over-temperature security switch. The temperature calculation is performed on the host based on the calibration parameters but the over-temperature recognition is constantly monitored by the sensor it-self. Applications • Optimal for remote temperature measurement • Fast remote over-temperature protection • Near-field human presence sensing • Far-field human motion detection Contents 1 Dimensions and Connections 3 2 Optical Characteristics 4 3 Absolute Maximum Ratings 5 4 Device Characteristics 5 5 I2 C Interface Characteristics 5.1 START and STOP conditions . . 5.2 Clock low extension . . . . . . 5.3 Slave Address . . . . . . . . . 5.4 Protocol diagram description . 5.5 General Call . . . . . . . . . . 5.6 Reading Data from the Register 5.7 Writing Data to Register . . . . 5.8 Reading EEPROM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 8 9 9 9 9 10 10 11 6 Data processing characteristics 12 6.1 Control and Status Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 6.2 Control Register Details . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 7 Internal processing overview 7.1 Object and Ambient Temperatures . . . . . . . . 7.2 Presence detection . . . . . . . . . . . . . . . . 7.3 Motion detection . . . . . . . . . . . . . . . . . 7.4 Ambient temperature shock detection . . . . . . 7.5 Object temperature over or under limit detection 7.6 Hysteresis . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 17 17 18 19 20 20 8 Temperature Measurement 8.1 Calibration Conditions . . . . . . . . . 8.2 EEPROM content . . . . . . . . . . . . 8.3 EEPROM Details . . . . . . . . . . . . . 8.4 Calculation of the Ambient Temperature 8.5 Calculation of the Object Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 21 21 21 23 23 . . . . . . . . . . . . . . . . . . . . . . . . . 9 Integration instructions and recommendations 24 9.1 PCB layout and Wiring Patterns . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 9.2 Position . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 10 Packaging Specification 11 Statements 11.1 Patents . . . 11.2 Quality . . . 11.3 RoHS . . . . 11.4 Liability Policy 11.5 Copyright . . . . . . . . . . . . . . . . . 26 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 27 27 27 27 27 TPiS 1T 1086 L5.5 / 7452 Dimensions and Connections Figure 1: Mechanical Dimensions (in mm) and the pin configuration. The A0 output is internally bond to GND. A short description is given in table 1. 8,15 +- 0,1 0 5,46 +-0,15 5,5 +- 0,1 0,5 GND VDD INT 22,5° 9.3 max. 0,45 +- 0,05 max. 1 SCL SDA 6 +-1 A1 45° 0,7 +- 0,2 5,84 8,35 +- 0,2 Table 1: Pin descriptions. Further explanations follow in this document. Pin Symbol Pin Name and short Functional Description. Pin Type A0,A1 Address Inputs A0, A1: Setting the last 2 bits of the slave address. Setting a pin to GND corresponds to 0. Setting a pin to VDD corresponds to a 1. The device address with both pins set to GND is 0x0C. Input VSS Ground: The ground (GND) reference for the power supply should be set to the host ground. Power VDD Power Supply: The power supply for the device. Typical operating voltage is 3.3 V Power SDA Serial Data: The I2 C bidirectional data line. Open-drain driven and requires pull-up resistors to min. 1.8 V Input/Output SCL Serial Clock Input: The I2 C clock input for the data line. Up to 400 kHz are possible. The host must support clock stretching. Input/Output INT Interrupt Output: The open drain / active low Interrupt output to indicate a detected event. Reading the chip register out resets this output. Output 3 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 1 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 Product Specification 2 16/02/2017- Preliminary Optical Characteristics Table 2: Optical characteristics Parameter Symbol Focal length f Field of View X/Y FOV X/Y Min Typ 5.5 5 0 11.5:1 −3.7 Optical Axis Distance to Spot Max D:S Unit Remarks / Conditions mm unpolished ◦ 3.7 at 50 % intensity ◦ at 50 % intensity 6 1 4 0.8 2 FOV X/Y 0.6 0 0.4 −2 Relative Sensitivity 1 0.8 0.6 0.4 0.2 0 6 An 4 2 gle 0 6 2 2 4 ] Y −− 0 4 [°] −6 −4−2 X [° −6 Angle Angle Y [°] Relative Sensitivity Figure 2: Typical FoV measurement-result 0.2 −4 −6 −6 −4 −2 0 0 2 4 6 Angle X [°] Table 3: Filter properties Parameter Symbol Average Filter Transmittance TA Min Typ Max 52 Unit Remarks / Conditions % 7.5 µm < λ < 13.5 µm Transmittance [%] Figure 3: Filter transmittance, typical curve 100 90 80 70 60 50 40 30 20 10 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 Wavelength [µm] 4 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com TPiS 1T 1086 L5.5 / 7452 Absolute Maximum Ratings Table 4: Maximum Ratings Parameter Symbol Min Max Unit Electrical parameters may vary from specified values in accordance with their temperature dependence Avoid storage in humid environment Operating Temperature T0 −20 85 ◦C Storage Temperature Ts VDD 100 3.6 100 ◦C Supply Voltage −40 −0.3 −100 Current to any pin 4 Remarks / Conditions V mA One pin at a time Device Characteristics Device characteristics are given at 25 ◦C ambient temperature unless stated otherwise. Table 5: Power Supply Parameter Symbol Min Typ Max Unit Operating Voltage VDD 2.6 3.3 3.6 V Supply Current IDD 15 µA Remarks / Conditions VDD=3.3 V Table 6: Thermopile Parameter Symbol Min Sensitive Area A Sensitivity ∆counts/∆T Noise(peak-peak) τ Time constant Resolution 0.7 64 000 Sensitivity Offset Max. Object Temp. Tobjmax Typ Max 0.16 30 8 15 17 0.8 64 500 350 Unit Remarks / Conditions mm2 Absorber 0.41 × 0.41 mm2 counts/K counts Tobj=40 ◦C Tobj=40 ◦C ms Bits 0.9 65 000 µV/count counts ◦C Full FOV,  > 99 % Table 7: Ambient temperature sensor (PTAT) Parameter Symbol Min Slope Range Linearity Offset Noise(peak-peak) Typ 15 170 Resolution −20 −5 11 000 13 500 5 Max Unit Remarks / Conditions Bits counts/K 85 5 16 000 −20 ◦C to 85 ◦C ◦C % −20 ◦C to 85 ◦C counts counts The calculation of a temperature has to be performed on the host system and is described in section 8. Figure 4 shows calculated thermopile raw data U = TPobject as a function of the ambient temperature and object temperature based on typical characteristics of TPiS 1T 1086 L5.5 . The ASIC typically features a wider 5 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 3 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary 400 U=130000 counts U=120000 counts U=110000 counts U=100000 counts U= 90000 counts U= 80000 counts U= 70000 counts U= 60000 counts Tobj[°C] 300 200 100 0 -100 -50 0 50 100 150 200 Tamb[°C] T dynamic range as compared to the specified values in table 6 and 7. Values out of our specifications are not guaranteed. Table 8: Calibration Conditions and Temperature Measurement Specifications Parameter Symbol Distance to black body (BB) d Min Typ Max Unit 30 mm Calib. Temp. TBB=O bj 100 ◦C Calib. Temp. TAmb Accuracy TO bj 25 ◦C ±0.5 < 0.1 ±3 < 0.1 ±1 ◦C Precision TO bj Accuracy TO bj Precision TAmb Accuracy TAmb Remarks / Conditions @ Calib. Temp. ◦C ◦C 40 < TO bj [◦C] < 250 ◦C ◦C 10 < TAmb [◦C] < 80 Table 8 gives an overview on the accuracy and precision of a remote temperature measurement which can be achieved with the factory calibration. Accuracy is the mean deviation of a measured value from the true value. The precision is the statistical uncertainty (RMS) of a measurement. The calibration parameters and conditions are described in section 8. The performance in the application may vary due to physical constraints. Significantly better performance is possible. For that the device must be re-calibrated after assembly in the end-application. Please consult our local representative for more information. 6 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification Figure 4: Typical temperature dependence of the raw thermopile output TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary Product Specification Table 9: Digital Interface (SCL, SDA, INT, A0, A1) Parameter Symbol Input low voltage VI L VI H VO L VO H I LI I LO FS C L TH I G H TLOW Input high voltage Output low voltage Output high voltage Input leakage current Output leakage current SCL Frequency SCL high time SCL low time refresh time Min Typ Max Unit Remarks / Conditions - - 0.6 V 1.5 0.2 - - V - - V - - VDD V Open Drain −1 - µA - - VI = VDD/2 VO = VDD kHz - - 200 0.2 1 1 400 - - ns - - - 90* 3 ms µA µs *Slave clock stretching 7 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com TPiS 1T 1086 L5.5 / 7452 I2 C Interface Characteristics An I2 C serial interface is provided to read out the sensors data and for read and write access of configuration and status registers and to obtain calibration data from the EEPROM. TM The following chapters give detailed instructions to understand and to operate the I2 C interface of the CaliPile . For the complete I2 C specifications (version 2.1) refer to: www.i2c-bus.org. The SCL is a bidirectional input and output used as synchronization clock for serial communication. The SDA is a bidirectional data input and output for serial communication. The SCL and SDA outputs operate as open drain outputs only. External pull-up resistors are required. The pull-up resistor does all the work of driving the signal line high. All devices attached to the bus may only drive the SDA and SCL lines low. TM The I2 C interface allows connection of a master device (MD) and one or more slave devices (SD). The CaliPile can be operated as a SD only. The MD provides the clock signals and initiates the communication transfer by selecting a SD through a slave address (SA) and only the SD, which recognizes the SA should acknowledge (ACK), the rest of SDs should remain silent. The general data transfer format is illustrated in figure 5 Figure 5: Illustration of voltages during I2 C communication SDA SCL 1-7 S 8 slave addr 9 1-7 8 9 ACK ACK 1-7 8 9 ACK DATA P Start Condition S R/Wv TN)ACK P 5.1 Read = 1 / Writev = 0 TNot) Acknowledge; ACK = 0 , NACK = 1 Stop Condition START and STOP conditions Figure 6: START and STOP Condition SDA SCL S P START condition STOP condition Two unique bus situations define a message START and STOP condition which is shown in figure 6. 1. A high to low transition of the SDAT line while SCLK is high indicates a message START condition. 2. A low to high transition of the SDAT line while SCLK is high defines a message STOP condition. START and STOP conditions are always generated by the bus master. After a START condition the bus is considered to be busy. The bus becomes idle again after certain time following a STOP condition or after both the SCLK and SDAT lines remain high for more than tHIGH:MAX . 8 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 5 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 Product Specification 5.2 16/02/2017- Preliminary Clock low extension Figure 7: Clock low extension TLOW = 90μs max. SDA SCL Low extension TM The CaliPile may need some time to process received data or may not be ready yet to send the next byte. In this case the SD can pull the SCL clock low to extend the low period of SCL and to signal to the master that it should wait (see figure 7). Once the clock is released the master can proceed with the next byte. 5.3 Slave Address TM After power up the CaliPile responds to the General Call Address (0x00) only. Upon receipt of a general call, it loads its slave address from EEPROM (ESA). The slave address stored in the EEPROM consists of 7 address bits (6:0) and 1 address control bit (7). If the address control bit is set, the slave address read from the EEPROM is merged with the information from the slave address select pins A1 and A0. Table 10: Examples for the interplay between configuration pins and the EEPROM ESA state I2 C slave address 1000 1111 H:L 000 1110 1000 1100 H:L 000 1110 1000 1100 L:H 000 1101 0000 1100 L:H 000 1100 1ABC DEFG Y:Z ABC DEYZ 0ABC DEFG Y:Z ABC DEFG TM Some examples are given in table 10. The CaliPile in the standard configuration has enabled configuration pins. The standard EEPROM content is 1000 1100. The standard slave address is therefore dec12 or 000 1100 in binary representation when the address input pins A1,A0 are both connected to ground. Pulling A0 to a high level for example will result in the slave address dec13 or 000 1101. 5.4 Protocol diagram description In the following chapters, the communication protocol will be illustrated with diagrams. Figure 8 describes the meaning of those diagrams. 5.5 General Call In order to re-fresh the slave address from EEPROM the MD has to send a general call (0x00) followed by the reload command (0x04). The slave may require up to 300 µs for copying the slave address from EEPROM information into the register. 9 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary Product Specification Figure 8: Protocol diagram description 1 8 1 Register Address A 1 7 1 S Slave Address S Rd Wr A A P Start Condition Read 8bit value of 1) Write 8bit value of 0) ACK = Acknowledge 8bit value of 0) NACK = Not Acknowledge 8bit value of 1) Stop Condition Rd A 8 Data Byte 1 1 A P Master-to-Slave Slave-to-Master Continuation of Protocoll … Figure 9: General call format 5.6 1 7 S 0x00 1 1 Wr A Rd 8 1 1 0x04 A P Reading Data from the Register Each register can be read through the I2 C bus interface. The address information following Slave address points to the register to be read. The SD may require some time to load the data into the serial interface and therefore apply "clock stretching" after reception of the address byte. Once the data is ready for transmission to the MD, clock-stretching will be released and the MD can clock out the data byte. The address pointer on the SD will be automatically incremented to prepare for the next data byte to be fetched for transmission. The SD may apply "clock stretching" again to enforce a waiting time, before the next data byte is ready for transmission. The address pointer will wrap around to 0 once it exceeds address 63. Reading of data can be interrupted by the MD at any time by generating a stop or a new start condition or a "not acknowledge". This is illustrated in figure 10. Figure 10: Register read format 1 S 5.7 7 1 Slave Address 8 1 1 7 Register Address A Sr Slave Address 1 Wr A 1 1 Rd A 8 1 Data [Adr] A 8 1 8 1 8 1 8 1 1 Data [Adr+1] A Data [Adr+2] A Data [Adr+N-1] A Data [Adr+N] A P Writing Data to Register Each register can be written to through the I2 C bus interface. The address information following the Slave address specifies the location, where the next data byte is written to. The SD may require some time to write the data into the registers on chip and therefore apply "clock stretching" after reception of the data byte. Once the data is stored in the register, the slave will increment the address pointer and prepare for the next data byte to be received. The address pointer will wrap around when it exceeds 63. Writing of data can be interrupted at any time by generating a stop or a new start condition or a "not acknowledge". This is illustrated in figure 11. If the address points to a non-writable register, the register content remains unchanged. 10 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary 1 S 5.8 7 1 Slave Address 8 1 8 1 Register Address A Data [Adr] A 1 Wr A 8 1 Data [Adr+1] A 8 1 8 1 8 1 8 1 1 Data [Adr+2] A Data [Adr+3] A Data [Adr+N-1] A Data [Adr+N] A P Reading EEPROM A dedicated EEPROM control register (ECR) is provided to control access mode and to allow testing of EEPROM during production. Prior to reading EEPROM memory via I2C interface the control byte needs to be set accordingly. It is of importance to configure the EEPROM control register correctly as specified to ensure correct operation. In order to enable EEPROM reading, the ECR must be set to 0x80 as depicted in figure 12. Figure 12: Configuring register for EEPROM readout 1 7 S 1 Slave Address 1 Wr A 8 8 1 Reg. Address (0x1F) A 1 ECR (0x80) 1 P A Note: Configuring the ECR for EEPROM read access causes increase of the supply current during EEPROM read operation until ECR will be set to 0x00 again. Once the ECR has been setup correctly for read operation, the EEPROM cells can be addressed and read as drawn to figure 13. Figure 13: Reading EEPROM 1 S 1 7 Slave Address 8 1 1 7 1 1 8 1 Register Address A Sr Slave Address Rd A Data [Adr] A 1 Wr A 8 1 8 1 8 1 8 1 1 Data [Adr+1] A Data [Adr+2] A Data [Adr+N-1] A Data [Adr+N] A P The address information following the Slave address points to the EEPROM memory location to be read. The SD may require some time to load the data into the serial interface and therefore apply "clock stretching" after reception of the address byte. Once the data is ready for transmission to the MD, clock stretching will be released and the MD can clock out the data byte. The address pointer on the SD will be automatically incremented to prepare for the next data byte to be fetched for transmission. The SD may apply "clock stretching" again to enforce a waiting time, before the next data byte is ready for transmission. The address pointer will wrap around to 0 once it exceeds address 63. The EEPROM control register must be configured to 0x00 after the end of the EEPROM read operation to bring the supply current back to normal (lower) level. 11 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification Figure 11: Register write format TPiS 1T 1086 L5.5 / 7452 Data processing characteristics 6.1 Control and Status Registers Table 11: Register content Register # Size[bit] Access reserved 8 - 1-2,3[7] TPobject 17 Read 3[6:0],4 TPambient 15 Read 5-7[7:4] TPObjLP1 20 Read 7[3:0]-9 TPObjLP2 20 Read 10-11 TPambLP3 16 Read 12-14 0 Description TPObjLP2 frozen 24 Read 15 TPpresence 8 Read 16 TPmotion 8 Read 17 TPamb shock 8 Read 18[7:0] Interrupt Status 8 Read(Autoclear) 19[7:0] Chip Status 8 Read 20[3:0] SLP1 4 Write/Read 20[7:4] SLP2 4 Write/Read 21[3:0] SLP3 4 Write/Read 21[7:4] reserved 4 - 22 TPpresence threshold 8 Write/Read 23 TPmotion threshold 8 Write/Read 24 TPamb shock threshold 8 Write/Read 25[4:0] Interrupt Mask Register 5 Write/Read 25[7:5] reserved 3 - 26[1:0] Cycle time for Motion differentiation 2 Write/Read 26[3:2] SRC select for presence determination 2 Write/Read TPOT direction 1 Write/Read 26[7:5] reserved 3 - 27[7:0] Timer interrupt 8 Write/Read 28,29 26[4] TPOT threshold 16 Write/Read 30 reserved 8 - 31 EEPROM control 8 Write/Read 62:32 EEPROM content 248 Read 8 Read 63 Slave address TM The control and status registers in table 11 give access to the variables of the integrated CaliPile ASIC. Details on the registers are given in the following section 6.2. While some registers contain computed values other contain parameters to control the functionality of the chip which is described in section 7. The register control values are undefined after power-up and require an initialization procedure for TM a well-defined operation of the CaliPile . 12 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 6 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 Control Register Details TPobject Register #1[7:0] 7 6 5 4 3 2 Register #2[7:0] 1 0 7 6 5 4 3 2 Register #3[7] 1 0 7 - - - - - - - Contains the 17 bit TPobject raw ADC value in digits. This represents the current signal of the thermopile sensor element. TPambient Register #3[6:0] - 6 5 4 3 Register #4[7:0] 2 1 0 7 6 5 4 3 2 1 0 Contains the 15 bit TPambient raw value in digits. This represents the current signal of the ambient temperature sensor (PTAT). TPobjectLP1 Register #5[7:0] 7 6 5 4 3 2 Register #6[7:0] 1 0 7 6 5 4 3 2 Register #7[7:4] 1 0 7 6 5 4 - - - - Contains the 20 bit TPobjLP1 value in digits. This represents the low-pass-filtered value of the TPobject signal. To compare it with the 17 bit wide TPobject divide the value by 23 = 8. The filter time constant for this filter stage can be set with SLP1 . TPobjectLP2 Register #7[3:0] - - - - 3 2 Register #8[7:0] 1 0 7 6 5 4 3 2 Register #9[7:0] 1 0 7 6 5 4 3 2 1 0 Contains the 20 bit TPobjLP2 value in digits. This represents the low-pass-filtered value of the TPobject signal. To compare it with the 17 bit wide TPobject divide the value by 23 = 8. The filter time constant for this filter stage can be set with SLP2 . TPambLP3 Register #10[7:0] 7 6 5 4 3 Register #11[7:0] 2 1 0 7 6 5 4 3 2 1 0 Contains the 16 bit TPambLP3 value in digits. This represents the low-pass-filtered value of the TPambient signal. To compare it with the 15 bit wide TPambient divide the value by 21 = 2. The filter time constant for this filter stage can be set with SLP3 . TPobjectLP2 frozen Register #12[7:0] 7 6 5 4 3 2 Register #13[7:0] 1 0 7 6 5 4 3 2 Register #14[7:0] 1 0 7 6 5 4 3 2 1 0 Contains the 24 bit TPobjLP2 frozen value in digits. This represents the low-pass-filtered value of the TPobject signal when motion was detected. To compare it with the 17 bit wide TPobject divide the value by 27 = 128. See section 7.3 for more details on the motion detection algorithm. TPpresence Register #15[7:0] 7 6 5 4 3 2 1 0 Contains the 8 bit TPpresence value in digits. It is the unsigned difference between two values which combination is steered with the "source select". The sign of the value is contained in the "chip status". See section 7.2 for details. 13 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 6.2 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary Register #16[7:0] 7 6 5 4 3 2 1 0 Contains the 8 bit TPmotion value in digits. It is the unsigned difference between two consecutive values of TPobjectLP1 . The sign of the value is contained in the "chip status". The interval is steered with the "cycle time". See section 7.3 for details. TPamb shock Register #17[7:0] 7 6 5 4 3 2 1 0 Contains the 8 bit TPamb shock value in digits. It is the unsigned difference between TPambient and TPambL1 . The sign of the value is contained in the "chip status". See section 7.4 for details. Interrupt status Register #18[7:5] sign Register #18[4:0] flag 7 6 5 4 3 2 1 0 TPpresence TPmotion TPamb shock TPOT TPpresence TPmotion TPamb shock timer Each fulfilled interrupt condition between the last readout and the current one is stored here. See also "Chip status" for the current status of the interrupt conditions. Reading this register clears the register (setting it to 0x00) and resets the physical interrupt output (release to high). Sign is the sign bit to the corresponding unsigned 8 bit values when the interrupt condition of the corresponding interrupt calculation branches (see section 7) was fulfilled since the last readout of that register. A 0 represents a positive value and a 1 a negative value. Flag Contains a 1 when a condition of the corresponding interrupt calculation branches was fulfilled since the last readout of that register. Timer Contains a 1 when at least one period of the timer passed since the last readout of that register. Chip status Register #19[7:5] sign Register #19[4:0] flag 7 6 5 4 3 2 1 0 TPpresence TPmotion TPamb shock TPOT TPpresence TPmotion TPamb shock timer Sign is the sign bit to the corresponding unsigned 8 bit values. A 0 represents a positive value and a 1 a negative value. Flag represents the status of the corresponding interrupt calculation branches (see section 7). A 1 represents a full-filled condition for the interrupt. Timer represents a flag toggling with the double frequency of the "timer interrupt". This register is masked by the "Interrupt Mask" register to evaluate the condition for the physical interrupt TM output pin at the CaliPile . Low pass time constants SLP Register #20[7:4] LP2 7 6 5 Register #20[3:0] LP1 4 3 reserved - - - 2 1 0 Register #21[3:0] LP3 - 3 2 1 0 Contains the time constants for the three low-pass filters LP1, LP2 and LP3 (see section 7). The possible settings and the corresponding values are denoted in table 12. 14 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification TPmotion TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary Product Specification Table 12: Low pass settings for LP1, LP2 and LP3 fcut off [Hz] 6.4 × 10−1 3.2 × 10−1 1.5 × 10−1 7.9 × 10−2 3.9 × 10−2 1.9 × 10−2 9.9 × 10−3 4.9 × 10−3 2.5 × 10−3 1.2 × 10−3 6.2 × 10−4 3.1 × 10−4 1/(2πf )[s] 0.25 0.50 1 2 4 8 16 32 64 128 256 512 select code [hex] select code [bin] D 1101 C 1100 B 1011 A 1010 9 1001 8 1000 5 0101 4 0100 3 0011 2 0010 1 0001 0 0000 TPpresence threshold Register #22[7:0] 7 6 5 4 3 2 1 0 Contains the unsigned 8 bit threshold value for TPpresence in digits. Once the TPpresence signal exceeds this threshold the corresponding presence flag will be set in the "chip status" register. See section 7.2 for details. TPmotion threshold Register #23[7:0] 7 6 5 4 3 2 1 0 Contains the unsigned 8 bit threshold value for TPmotion in digits. Once the TPmotion signal exceeds this threshold the corresponding presence flag will be set in the "chip status" register. See section 7.3 for details. TPamb shock threshold Register #24[7:0] 7 6 5 4 3 2 1 0 Contains the unsigned 8 bit threshold value for TPamb shock in digits. Once the TPamb shock signal exceeds this threshold the corresponding presence flag will be set in the "chip status" register. See section 7.4 for details. Interrupt Mask reserved Register #25[4:0] - - - 4 3 2 1 0 - - - TPOT TPpresence TPmotion TPamb shock timer Contains the 5 bit mask value to activate the external interrupt output INT pin based on five different possible sources in the "chip status" register. The INT pin will be activated only if the corresponding mask flag inside the interrupt mask register is set to 1 and the corresponding interrupt occurs as signaled in the "chip status" register. Bit[4]: set to 1 activates the INT pin if the TPOT flag in register "chip status" has been set Bit[3]: set to 1 activates the INT pin if the TPpresence flag in register "chip status" has been set Bit[2]: set to 1 activates the INT pin if the TPmotion flag in register "chip status" has been set Bit[1]: set to 1 activates the INT pin if the TPamb shock flag in register "chip status" has been set Bit[0]: set to 1 activates the INT pin if the timer flag in register "chip status" has been set 15 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary Interrupt Mask Register #26 reserved - - TPOT dir - [3:2] SRC select 4 3 [1:0] cycle time 2 1 0 TPOT dir allows to select in which direction TPobject has to cross the TPOT threshold to create an interrupt. If 1, an interrupt is created if TPobject exceeds the TPOT threshold. If 0, an interrupt is created if TPobject falls below the TPOT threshold. SRC select allows to switch the signal sources to be used for the TPpresence calculation as explained further in section 7.2. Possible values are 00 = TPobject − TPobjLP2 01 = TPobjLP1 − TPobjLP2 10 = TPobject − TPobjLP2 frozen 11 = TPobjLP1 − TPobjLP2 frozen Cycle time is the time between these two consecutive TPobjLP1 points to determine TPmotion . This is explained further in section 7.3. Possible values are 00 = 30 ms 01 = 60 ms 10 = 120 ms 11 = 240 ms Timer interrupt Register #27[7:0] 7 6 5 4 3 2 1 0 Contains a timer overrun value from 30 ms up to 7.7 s in steps of 30 ms. Timer interval = (1 + Timer interrupt) · 30 ms TPOT threshold Register #28[7:0] 7 6 5 4 3 2 Register #29[7:0] 1 0 7 6 5 4 3 2 1 0 Contains the 16 bit TPOT threshold value in digits. To compare this value to the 17 bit wide TPobject please multiply this value by a factor of 21 = 2. More details are depicted in section 7.5. EEPROM control register Register #31[7:0] 7 6 5 4 3 2 1 0 Contains the EEPROM control bits. Set it to 0x80 in order to read the EEPROM through the register. It should be set to 0x00 in case of no access to the EEPROM. For more details please refer to section 5.8. 16 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification If more than one mask bit has been set the INT pin will be activated for whatever flag in the chip status register comes first (OR condition). The INT output will remain active until the host micro-controller reads the "interrupt status" register. Interrupts are set when conditions change from inactive (0) to active (1). TPiS 1T 1086 L5.5 / 7452 Internal processing overview TM In order to explore the complex functionalities of our CaliPile products, we recommend to obtain one of our Demonstration Kits. Please ask our local representative for further advice. Figure 14: A schematic overview on the internal processing paths and variables TPobject TPobject TPobjLP1 LP1 SLP1 TPobjLP2 LP2 source select 2 of 4 SLP2 SRC_select + TPpresence ABS TPpresence flag TPpresence treshold Tobj_LP1t - Tobj_LP1t-1 TPmotion ABS cycle time dt TPmotion flag TPmotion treshold TPobjLP2 frozen TPOT flag TPOT treshold TPOT direction interrupt mask register interrupt timer flag TPambient TPambient TPambLP3 LP3 SLP3 + TPamb_shock + ABS TPamb shock treshold TM TPamb_shock flag TM The Sketch 14 gives an overview on the internal CaliPile data processing algorithms. The CaliPile contains all functions required to allow an external micro-controller to detect activity and presence. The parameters which should lead for example to a wake-up of the host micro-controller can be programmed and adapted on the fly. The algorithm is based on various filter calculations of the sensor signals TPobject and TPambient , their differences and time derivatives. TM The CaliPile offers 4 basic functions which are "presence detection", "motion detection", "ambient temperature shock detection" and "over temperature detection". Those functions can be selected by the host microcontroller as an interrupt source for wakeup. The parameters used to calculate the current state of "presence", "motion" or "shock" can be changed by the host controller through control registers. This allows the host conTM troller to stay in sleep mode for most of the time and only be activated once the CaliPile detects a change which requires intervention. 7.1 Object and Ambient Temperatures TPobject and TPambient are the ADC raw data from the thermopile and the internal temperature reference PTAT. To calculate the actual object temperature and ambient temperature a calculation is required on the host sysTM tem based on the calibration constants from the CaliPile ’s EEPROM. Details are described in section 8. All other functionalities of the chip do not require an explicit knowledge of the actual temperatures as only relative changes TM are being processed. This allows a continuous operation of the CaliPile at a low power power consumption. 7.2 Presence detection Presence detection is accomplished by observing the difference between two user selectable signal paths which will be calculated from the thermopile raw signal TPobject (see chart 15). In order to select the optimal application specific solution for presence detection, four signal path combinations are available for selection. 17 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 7 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary 𝑇𝑃𝑜𝑏𝑗 𝑒𝑐𝑡 LP1 𝑇𝑃𝑜𝑏𝑗 𝐿𝑃1 𝑆𝐿𝑃1 LP2 𝑇𝑃𝑜𝑏𝑗 𝐿𝑃2 Source select - 2 of 4 𝑆𝐿𝑃2 + 𝑇𝑃𝑝𝑟𝑒𝑠𝑒𝑛𝑐𝑒 ABS 𝑇𝑃𝑜𝑏𝑗 𝐿𝑃2_𝑓𝑟𝑜𝑧𝑒𝑛 𝑇𝑃𝑝𝑟𝑒𝑠𝑒𝑛𝑐𝑒 𝑓𝑙𝑎𝑔 𝑆𝑅𝐶_𝑠𝑒𝑙𝑒𝑐𝑡 𝑇𝑃𝑝𝑟𝑒𝑠𝑒𝑛𝑐𝑒 𝑡𝑟𝑒𝑠ℎ𝑜𝑙𝑑 The original TPobject data as provided by the thermopile, two signals, which have been processed by low pass filters LP1 and LP2 with different user programmable time constants (SLP1 ,SLP2 ). TPobjLP1 (x ) = TPobject (x ) · S LP1 + TPobjLP1 (x − 1) · (1 − S LP1 ) TPobjLP2 (x ) = TPobject (x ) · S LP2 + TPobjLP2 (x − 1) · (1 − S LP2 ) The signal TPObjLP2 frozen which is the TPObjLP2 output, that was saved at the moment the last motion event was detected. Thus various calculations for presence detection are possible and can be adapted to the actual conditions e.g.: TPpresence = TPobject − TPobjLP2 TPpresence = TPobjLP1 − TPobjLP2 TPpresence = TPobject − TPobjLP2 frozen TPpresence = TPobjLP1 − TPobjLP2 frozen The difference of those two selected signals paths is then compared with a programmable threshold TPpresence threshold . The TPpresence flag is set once the difference of the two signals exceeds the threshold. Recommended settings to start the evaluation with are: variable value meaning SLP1 bin 1011 1s 8s SLP2 SRC select TPpresence threshold Interrupt Mask bin 1000 bin 01 TPobjLP1 − TPobjLP2 dec 50 ±50 counts bin 0000 1000 TPpresence Other register values are not important for that parameter set. 7.3 Motion detection Motion detection is accomplished by observing the difference between two consecutive samples of TPobjLP1 with a programmable time interval d t . This is comparable to the 1st derivative of TPobjLP1 . TPmotion = d TPobjLP1 dt The difference of the two signals paths is then compared with a programmable threshold TPmotion threshold . The TPmotion flag is set once the difference exceeds the threshold. This is illustrated in figure 16. 18 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification Figure 15: Presence detection algorithm chart TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary 𝑇𝑃𝑜𝑏𝑗 𝐿𝑃1 (𝑡) - + 𝑇𝑃𝑚 𝑜𝑡𝑖𝑜𝑛 𝑇𝑃𝑚 𝑜𝑡𝑖𝑜𝑛 𝑓𝑙𝑎𝑔 || ABS 𝑇𝑃𝑜𝑏𝑗 𝐿𝑃1 (𝑡 − 1) 𝑇𝑃𝑚 𝑜𝑡𝑖𝑜𝑛 𝑡𝑟𝑒𝑠ℎ𝑜𝑙𝑑 At the moment the TPmotion flag is set, the current value of TPobjLP2 will be saved as TPobjLP2 frozen for further use in the presence detection algorithm. Recommended settings to start the evaluation with are: variable value meaning SLP1 bin 1100 bin 10 0.5 s 120 ms ±10 counts bin 0000 0100 TPmotion cycle time TPmotion threshold Interrupt Mask dec 10 Other register values are not important for that parameter set. It should be noticed that motion detection requires a fast change in the signal. It is thus suitable for small field-of-views in case of large distances to the sensor. To reduce the field-of-view of a sensor apply lens or aperture optics. 7.4 Ambient temperature shock detection Figure 17: Ambient Temperature shock detection algorithm chart 𝑇𝑃𝑎𝑚 𝑏𝑖𝑒𝑛𝑡 𝑇𝑃𝑎𝑚 𝑏_𝐿𝑃3 - + 𝑇𝑃𝑎𝑚 𝑏_𝑠ℎ𝑜𝑐𝑘 𝑇𝑃𝑎𝑚 𝑏_𝑠ℎ𝑜𝑐𝑘 𝑓𝑙𝑎𝑔 || ABS LP3 𝑆𝐿𝑃3 𝑇𝑃𝑎𝑚 𝑏_𝑠ℎ𝑜𝑐𝑘 𝑡𝑟𝑒𝑠ℎ𝑜𝑙𝑑 As shown in figure 17 the ambient temperature shock detection is accomplished by observing the difference between TPambient and the low pass filtered TPamb LP3 . The difference of the two signals will then compared with a programmable threshold TPamb shock threshold. The TPamb shock flag is set once the difference exceeds the threshold to indicate a sudden change in the ambient temperature. Recommended settings to start the evaluation with are: variable value meaning SLP3 bin 1010 2s ±10 counts bin 0000 0010 TPamb shock TPamb shock threshold Interrupt Mask dec 10 Other register values are not important for that parameter set. 19 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification Figure 16: Motion detection algorithm chart TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary 𝑇𝑃𝑜𝑏𝑗 (16 𝑏𝑖𝑡) 𝑇𝑃𝑂𝑇 𝑓𝑙𝑎𝑔 𝑇𝑃𝑂𝑇 𝑡𝑟𝑒𝑠ℎ𝑜𝑙𝑑 𝑇𝑃𝑂𝑇 𝑑𝑖𝑟𝑒𝑐𝑡𝑖𝑜𝑛 7.5 Object temperature over or under limit detection The TPobject raw data is compared against the value specified in the object temperature threshold TPOT threshold. This is illustrated in figure 18. An event is generated whenever the object temperature crosses the threshold. The user can select by the use of the corresponding control registers, the condition which should lead to an interrupt: Exceeding the limit or falling below the limit. The interrupt is cleared when the micro-controller reads the interrupt status register. A new interrupt can only be generated with a new event (object temperature crosses the threshold). To ensure correct system start up, the over temperature flag is set and the interrupt output is switched active after the device has been powered up. This feature is achieved with an on chip power on reset. Note that TPobject is the thermopile raw value which does not necessarily correspond to one fixed object temperature. This is specially the case when the ambient temperature changes. See also figure 4 for an illustration. To determine TPobject and/or a threshold for a given object temperature, refer to section 8. 7.6 Hysteresis The calculations for TPpresence TPmotion and TPamb shock apply a hysteresis of 12.5 % of the actual threshold value. The minimum hysteresis value is fixed to 5 counts. That means that the actual value must fall below the threshold by 12.5 % of the threshold or at least by 5 counts in order to change the corresponding "chip status" bit to 0. For the object temperature over/under limit detection TPOT threshold there is a fixed hysteresis of 64 counts built into the threshold comparator. This is large enough to suppress the noise on the signals and to prevent false or frequent triggering of the corresponding flags if the signal is close to the threshold. It may lead to confusion when for example extremely small amplitudes are being evaluated which in turn require small thresholds. 20 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification Figure 18: Object temperature over or under limit detection algorithm chart TPiS 1T 1086 L5.5 / 7452 Temperature Measurement 8.1 Calibration Conditions The thermopile output is related to the net IR-radiation. The net IR-radiation can be correlated with the object temperature for a specific fixed set-up. The set-up valid for the factory calibration constants is shown in sketch 19. Figure 19: Calibration conditions Black Body Jig FoV Sensor d A silicon-oil immersed hollow black body with an inner diameter of 55 mm and an emissivity of better than 99 % has a temperature Tobj . A temperature controlled jig with a inner diameter of 35 mm has a temperature Tamb and is coated with a black paint for an emissivity of better than 96 %. The jig contains the TPiS 1T 1086 L5.5 sensor at a distance d to the black body.Numbers are specified in table 8. Conditions other than described in this document generally require a customized object calibration. Otherwise sensor performance may be different than specified here. Please contact our local representative for more details. 8.2 EEPROM content Table 13: EEPROM content Register# EEPROM# Name 32 33,34 0 1,2 PROTOCOL EEPROM Protocol number 3 CHKSUM Checksum of all EEPROM contents excluding cell 1,2 - 35 .. 40 41 42,43 44,45 46,47 48,49 50 51 .. 62 63 3 .. 8 9 10,11 12,13 14,15 16,17 18 19 .. 30 31 reserved reserved - LOOKUP# Identifier for look-up-table 8.3 PTAT25 M U0 U OUT1 TOBJ1 reserved SLAVE ADD Description Content Example 2 13 500 17 200 31 732 32 475 100 Tamb output in digits at 25 ◦C PTAT slope [digits/K]×100 TP offset, U 0 − 32768 TP output for TOBJ1 at 25 ◦C, U out /2 TOBJ value in ◦C for U OUT1 reserved - I2 C slave address with external addressing bit 140 EEPROM Details PROTOCOL Register #32[7:0] 7 6 5 4 3 2 1 0 Contains the 8 bit EEPROM Protocol number as an unique identifier. The default protocol number is 3. 21 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 8 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary Register #33[7:0] 7 6 5 4 3 2 Register #34[7:0] 1 0 7 6 5 4 3 2 1 0 Contains the 16 bit checksum in digits. The checksum is computed as a sum of all EEPROM cells excluding the checksum cells themselves (cell# 1,2). LOOKUP# Register #41[7:0] 7 6 5 4 3 2 1 0 Contains the 8 bit look-up-table identifier which defines the functional behaviour of that specific device. The default value for that product type is 2. For details please refer to section 8.5. PTAT25 Register #42[6:0] - 6 5 4 3 2 Register #43[7:0] 1 0 7 6 5 4 3 2 1 0 Contains the 15 bit TPambient value of the internal PTAT in digits at an ambient temperature of 25 ◦C. The first bit is unused and always 0. A typical value is 13 500 counts. For details please refer to section 8.4. M Register #44[7:0] 7 6 5 4 3 2 Register #45[7:0] 1 0 7 6 5 4 3 2 1 0 1 0 1 0 Contains the 16 bit slope value of the internal PTAT in digits per Kelvin scaled by a factor of 100. M = RegVal/100 A typical slope is 172 counts/K. For details please refer to section 8.4. U0 Register #46[7:0] 7 6 5 4 3 2 Register #47[7:0] 1 0 7 6 5 4 3 2 Contains the 16 bit TPobject offset value of the thermopile subtracted by 32 768 counts. U 0 = RegVal + 32768 A typical offset is 64 500 counts. For details please refer to section 8.5. U OUT1 Register #48[7:0] 7 6 5 4 3 2 Register #49[7:0] 1 0 7 6 5 4 3 2 Contains the 16 bit TPobject value of the thermopile divided by a factor of 2 when facing a black body with a temperature of TOBJ1 at an ambient temperature of 25 ◦C. U OUT1 = RegVal · 2 A typical value is 32 475 counts. For details please refer to section 8.5. TOBJ1 Register #50[7:0] 7 6 5 4 3 2 1 0 22 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification CHSUM TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary SLAVE ADD Register #63 [7] 7 [6:0] 6 5 4 3 2 1 0 I2 C base address ADD PIN Contains the 7 bit I2 C base address which is completed by the A0,A1 external pin settings when ADD PIN is set to 1. For details please refer to section 5.3. 8.4 Calculation of the Ambient Temperature For a correct object temperature calculation the ambient temperature must be known. The temperature should be calculated in Kelvin and not ◦C. To calculate the ambient temperature out of TPambient the following formula can be applied. Tamb [K] = (25 + 273.15) + (TPambient − PTAT25) · (1/M ) using the calibration constants PTAT25 and M from the EEPROM. The inverse to calculate an expected PTAT value for a given temperature Tamb is given by TPambient [counts] = [Tamb − (25 + 273.15)] · M + PTAT25 8.5 Calculation of the Object Temperature The thermopile output signal TPobject is not only depending on the objects temperature but also on the ambient temperature Tamb as demonstrated in figure 4. To obtain the object temperature Tobj calculate " Tobject [K] = F TPobject − U 0 k # + f (Tamb ) where Tamb is obtained as discussed in section 8.4. k is a scaling/calibration factor given by k = U out1 − U 0 [f (Tobj1 ) − f (25 + 273.15)] and contains the emissivity  of the object as well as the field-of-view coverage factor Θ. Since our devices are calibrated for a full FOV coverage (Θ = 1) and an object emissivity of nearly  = 1, this factor has to be scaled properly to adjust for a different object property in the application by k 7−→ k · ( · Θ) with  and Θ in the range of 0 to 1. f (x ) is in the simplest case an exponential with the exponent defined by the identifier LOOKUP#. f (x ) = x 4.2 if LOOKUP# = 2 It’s reverse function F (x ) is then F (x ) = √ 4.2 x if LOOKUP# = 2 Moreover U 0 , U out1 and Tobj1 are calibration parameters from the EEPROM. To predict a thermopile output based on the object temperature Tobject and ambient temperature Tamb calculate   TPobject [counts] = k · f (Tobject ) − f (Tamb ) + U 0 Since exponents and roots are heavy operations to be performed on a micro-controller based system, we recommend to implement f (x ) as a lookup table. An implementation in Object-C language can be provided upon request. You may contact our local representative for more details. 23 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification Contains the 8 bit value in ◦C for the black body giving the response of U OUT1 . A typical value is 100 ◦C. For details please refer to section 8.5. TPiS 1T 1086 L5.5 / 7452 9.1 Integration instructions and recommendations PCB layout and Wiring Patterns In general, the wiring must be chosen such that crosstalk and interference to/from the bus lines is minimized. The bus lines are most susceptible to crosstalk and interference at the high levels because of the relatively high impedance of the pull-up devices. If the length of the bus line on a PCB or ribbon cable exceeds 5 cm and includes the VDD and VSS lines, the wiring pattern must be: SDA - VDD - VSS - SCL and only if the VSS line is included we recommend SDA - VSS - SCL as a pattern. THese wiring patterns also result in identical capacitive loads for the SDA and SCL lines. The VSS and VDD lines can be omitted if a PCB with a VSS and/or VDD layer is used. If the bus lines are twisted-pairs, each bus line must be twisted with a VSS return. Alternatively, the SCL line can be twisted with a VSS return, and the SDA line twisted with a VDD return. In the latter case, capacitors must be used to decouple the VDD line to the VSS line at both ends of the twisted pairs. If the bus lines are shielded (shield connected to VSS), interference will be minimized. However, the shielded cable must have low capacitive coupling between the SDA and SCL lines to minimize crosstalk. The PCB design requires, an optimization procedure to achieve the best signal quality. As a starting point sketch 20 is given. Values for pull-up resistors must be replaced by matching ones, fitting the capacitive load of lines. In case of strong EMI observations additional RC-filtering components might be required at the sensor inputs and outputs which is not depicted in the sketch. Figure 20: Exemplary wiring layout CaliPile 2k� 2k� 2k� 3.3V SDA SDA VDD VDD VSS VSS SCL SCL INT INT A1 A0 100nF 9.2 GND Position In order to obtain the highest possible performance it is possible to operate the sensor without a (protecting) front window. To measure a temperature based on Excelitas calibration constants no window between the sensor and the object must be used. Excelitas calibration values are only valid when the bare sensor is exposed to the object. As the device is equipped with a highly sensitive infra-red detector. It is sensitive any source of heat, direct or indirect. For a proper temperature measurement the device must be at the same temperature as the ambient. Sudden temperature changes will directly affect the behaviour of the internal calculations such as motion, presence and over-/under-temperature recognition. While slow variations of the sensor and ambient temperature 24 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 9 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 16/02/2017- Preliminary 25 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification may be tolerated for a proper function of the motion and presence features, a drift in the ambient temperature needs to be compensated for the over-/under-temperature feature as mentioned in the corresponding section. This device is equipped with a highly sensitive ADC and integrated circuits. Common rules of electronics integration apply. We recommend to place strong EMI sources far apart and/or to shield those. TPiS 1T 1086 L5.5 / 7452 Packaging Specification The Excelitas Technologies tube packaging system protects the product from mechanical and electrical damage and is designed for manual unloading. The system consists of tubes which are protected against ESD. The devices are loaded sequentially and fixed with stoppers. Up to 50 parts are filled into one tube. In total up to 20 tubes are placed in one paper box. Information labels, ESD labels and bar-code Labels (optional) are placed on the box. Figure 21 shows the basic outline. Figure 21: Tube packaging system for manual unload. Stopper Tube with ESD protection Sensor 50 pcs. / tube Stopper 20 Tubes / box Box Box Label Tape 26 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 10 16/02/2017- Preliminary TPiS 1T 1086 L5.5 / 7452 11.1 Statements Patents TM For several features of the CaliPile patents are pending. 11.2 Quality Excelitas Technologies is an ISO 9001 certified manufacturer. All devices employing PCB assemblies are manufactured according IPC-A-610 guidelines. 11.3 RoHS This sensor is a lead-free component and complies with the current RoHS regulations, especially with existing road-maps of lead-free soldering. 11.4 Liability Policy The contents of this document are subject to change without notice and customers should consult with Excelitas Technologies sales representatives before ordering. Customers considering the use of Excelitas Technologies thermopile devices in applications where failure may cause personal injury or property damage, or where extremely high levels of reliability are demanded, are requested to discuss their concerns with Excelitas Technologies sales representatives before such use. The Company’s responsibility for damages will be limited to the repair or replacement of defective product. As with any semiconductor device, thermopile sensors or modules have a certain inherent rate of failure. To protect against injury, damage or loss from such failures, customers are advised to incorporate appropriate safety design measures into their product. 11.5 Copyright This document and the product to which it relates are protected by copyright law from unauthorized reproduction. Notice to U.S. Government End Users The Software and Documentation are "Commercial Items", as that term is defined at 48 C.F.R. 2.101, consisting of "Commercial Computer Software" and "Commercial Computer Software Documentation," as such terms are used in 48 C.F.R. 12.212 or 48 C.F.R. 227.7202, as applicable. Consistent with 48 C.F.R. 12.212 or 48 C.F.R. 227.7202-1 through 227.7202-4, as applicable, the Commercial Computer Software and Commercial Computer Software Documentation are being licensed to the U.S. Government end users (a) only as Commercial Items and (b) with only those rights as are granted to all other end users pursuant to the terms and conditions herein. Unpublished rights reserved under the copyright laws of the United States. 27 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 0 Fax.: +49 (0) 611 492 177 www.excelitas.com Product Specification 11 16/02/2017- Preliminary
TPIS 1T 1086 L5.5 价格&库存
很抱歉,暂时无法提供与“TPIS 1T 1086 L5.5”相匹配的价格&库存,您可以联系我们找货
TPIS 1T 1086 L5.5
    • 1+153.32760
    • 200+61.18200
    • 500+59.14080
    • 1000+58.12560
