VTP9412H
VTP9412H
    EXCELITASTECHNOLOGIES(埃赛力达)
    DIP2
    SENSOR PHOTODIODE
VTP9412H 数据手册
VTP Process Photodiodes VTP9412H PACKAGE DIMENSIONS inch (mm) CASE 20 6 mm CERAMIC CHIP ACTIVE AREA: .0025 in2 (1.6 mm2) PRODUCT DESCRIPTION ABSOLUTE MAXIMUM RATINGS Small area planar silicon photodiode in a recessed ceramic package. Chip is coated with a protective layer of clear epoxy. These diodes exhibit low dark current under reverse bias and fast speed of response. Storage Temperature: Operating Temperature: -20°C to 75°C -20°C to 75°C ELECTRO-OPTICAL CHARACTERISTICS @ 25°C (See also VTP curves, pages 45-46) SYMBOL ISC TC ISC VOC TC VOC ID CHARACTERISTIC Short Circuit Current VTP9412H TEST CONDITIONS H = 100 fc, 2850 K UNITS Min. Typ. Max. 10 17 µA ISC Temperature Coefficient 2850 K .20 %/°C Open Circuit Voltage H = 100 fc, 2850 K 350 mV VOC Temperature Coefficient 2850 K -2.0 Dark Current H = 0, VR = 50 V mV/°C 7 RSH Shunt Resistance H = 0, V = 10 mV CJ Junction Capacitance H = 0, V = 15 V Re Responsivity 940 nm .011 A/(W/cm2) SR Sensitivity @ Peak .55 A/W λrange Spectral Application Range λp Spectral Response - Peak VBR Breakdown Voltage θ1/2 Angular Resp. - 50% Resp. Pt. NEP D* .4 nA GΩ 6 400 1150 925 nm nm 140 V ±50 Degrees Noise Equivalent Power 8.7 x 10-14 (Typ.) Specific Detectivity 1.5 x 10 12 (Typ.) W ⁄ Hz cm Hz ⁄ W Excelitas Technologies, 22001 Dumberry, Vaudreuil, Canada J7V 8P7 50 pF Phone: 877-734-6786 Fax: 450-424-3413 65 www.excelitas.com
VTP9412H 价格&库存
很抱歉,暂时无法提供与“VTP9412H”相匹配的价格&库存,您可以联系我们找货
