VTT9103H
VTT9103H
    EXCELITASTECHNOLOGIES(埃赛力达)
    Radial
    SENSOR PHOTO TOP VIEW RADIAL
VTT9103H 数据手册
.040" NPN Phototransistors VTT9102H, 9103H Epoxy Lensed TO-106 Ceramic Package PACKAGE DIMENSIONS inch (mm) CASE 9 TO-106 (LENSED) CHIP TYPE: 40T PRODUCT DESCRIPTION ABSOLUTE MAXIMUM RATINGS A medium area high sensitivity NPN silicon phototransistor in a recessed TO-106 ceramic package. The chip is protected with a lens of clear epoxy. The base connection is brought out allowing conventional transistor biasing. These devices are spectrally matched to any of PerkinElmer IREDs. RoHS Compliant (@ 25°C unless otherwise noted) Maximum Temperatures Storage Temperature: Operating Temperature: Continuous Power Dissipation: Derate above 30°C: Maximum Current: Lead Soldering Temperature: (1.6 mm from case, 5 sec. max.) -20°C to 70°C -20°C to 70°C 100 mW 2.5 mW/°C 50 mA 260°C ELECTRO-OPTICAL CHARACTERISTICS @ 25°C (See also typical curves, pages 91-92) Light Current Dark Current Collector Breakdown Emitter Breakdown Saturation Voltage Rise/Fall Time lC lCEO VBR(CEO) VBR(ECO) VCE(SAT) tR/tF H=0 lC = 100 µA H=0 lE = 100 µA H=0 lC = 1.0 mA H = 400 fc lC = 1.0 mA RL = 100 Ω Part Number mA Min. Max. H fc (mW/cm2) VCE = 5.0 V Angular Response θ1/2 (nA) Max. VCE (Volts) Volts, Min. Volts, Min. Volts, Max. µsec, Typ. Typ. VTT9102H 6.0 — 100 (5) 100 5 30 4.0 0.55 6.0 ±42° VTT9103H 13.0 — 100 (5) 100 5 30 4.0 0.55 10.0 ±42° Refer to General Product Notes, page 2. Excelitas Technologies, 22001 Dumberry, Vaudreuil, QC, Canada J7V 8P7 Phone: 877-734-6786 Fax: 450-424-3413 101 www.excelitas.com
VTT9103H
1. 物料型号: - VTT9102H - VTT9103H
2. 器件简介: - 这些是中等面积、高灵敏度的NPN硅光电晶体管,封装在带有凹槽的TO-106陶瓷封装中。 - 芯片被透明环氧树脂透镜保护。 - 基极连接引出,允许传统的晶体管偏置。
3. 引脚分配: - 发射极(Emitter) - 基极(Base) - 集电极(Collector)
4. 参数特性: - 存储温度:-20°C至70°C - 工作温度:连续功率耗散 - 最大电流:50 mA - 引线焊接温度:260°C(1.6 mm处,最多5秒)
5. 功能详解: - 光电晶体管与PerkinElmer IREDs光谱匹配。 - 光电晶体管的电光特性在25°C时的参数,包括光电流、暗电流、集电极击穿电压、发射极击穿电压、饱和电压、上升/下降时间、角度响应等。
6. 应用信息: - 这些光电晶体管适用于需要高灵敏度和光谱匹配的应用。
7. 封装信息: - TO-106(带透镜)陶瓷封装。 - 封装尺寸:0.210英寸(5.33毫米)x 0.50英寸(12.7毫米)x 0.085英寸(2.16毫米)。
VTT9103H 价格&库存
很抱歉,暂时无法提供与“VTT9103H”相匹配的价格&库存,您可以联系我们找货
