ZS1052 S HT(H)
ZS1052 S HT(H)
    EXCELITASTECHNOLOGIES(埃赛力达)
    Xenon 触发线圈
ZS1052 S HT(H) 数据手册
DATA SHEET 1. MECHANICAL DATA Dimensions (mm) 8.5 ± 0.3 {02}{04} *a : 1.1 ref. {02} b : *c *d e : : : f : Remarks 1. * 5.0 ± 0.2 17.9 ± 0.3 {02}{04} 0.3 ref. 17.2 ref. {02} : 19.0 ± 0.3 {06} 7.9 max. {01}{02}{04}{07} *g h *i j *k : : : : : 6.1 ± 0.2 0.5 ref. 0.1 +0.20 / -0.10 {07}{08} l r : : 0.4 ref. R0.5 ref. {01} Key dimensions {03} NAME DATE DRAWN MAUNG TT 11.06.2012 ENGINEERING CHECKED MAUNG TT 11.06.2012 ENGINEERING 09 -5X05X2 17.02.15 MAUNG TT 08 -1,4&5/08X3 26.12.14 MAUNG TT 07 -1/07X2 25.03.14 MAUNG TT 06 -1/06X1 16.01.14 MAUNG TT DESCRIPTION 05 -1/05X1 27.11.13 MAUNG TT 04 -1/04X3 19.11.13 MAUNG TT 03 -1/03X2 15.01.13 MAUNG TT REV CHANGE DATE NAME DEPARTMENT ZS 1052-S HT(H) 8 TRACTOR ROAD SINGAPORE 627969 PAGE 1 OF 5 DATA SHEET 2. WINDING STRUCTURE Winding 3. Terminal Enamelled Wire Turns Secondary 4-1 Ø0.05 2 uew 1250 Ts Primary 2-1 Ø0.18 1 uew 34.5 Ts TESTING CIRCUIT NAME DATE DEPARTMENT DRAWN MAUNG TT 11.06.2012 ENGINEERING CHECKED MAUNG TT 11.06.2012 ENGINEERING DRAWN ZS 1052-S HT(H) 8 TRACTOR ROAD SINGAPORE 627969 PAGE 2 OF 5 DATA SHEET 4. ELECTRICAL PERFORMANCE Item Primary Secondary Resistance 325 mohm max. 230 ± 15 ohm Primary Voltage, Uzp 300 V --- Primary Capacitance, Cz 0.047 µF --- Secondary Voltage, Uz (unload) --- 9 KV min. Polarity of 1 Peak --- 1 peak negative Inductance, 1 KHz 20 ± 5 µH 18 ± 5 mH Thyristor CR02AM-8 --- Insulation Resistance DC 500V Pri to Core: 100 Mohm min. Sec to Core: 100 Mohm min. st st Measuring Conditions: 1. Oscilloscope – Tektronix 3012B 2. Voltage distributor – Tektronix P6015A 1000x3.0pF 100 Mohm 3. Test fixture : Excelitas standard trigger card 4. S.C.R. : 2N5064 5. T.C. : 0.047 µF PPS capacitor Operating temperature : -40 to +85 °C {05} Reference Waveform (Unload) NAME DATE DEPARTMENT DRAWN MAUNG TT 11.06.2012 ENGINEERING CHECKED MAUNG TT 11.06.2012 ENGINEERING DRAWN ZS 1052-S HT(H) 8 TRACTOR ROAD SINGAPORE 627969 PAGE 3 OF 5 DATA SHEET {08} 5. RECOMMENDED REFLOW TEMPERATURE NAME DATE DEPARTMENT DRAWN MAUNG TT 11.06.2012 ENGINEERING CHECKED MAUNG TT 11.06.2012 ENGINEERING DRAWN ZS 1052-S HT(H) 8 TRACTOR ROAD SINGAPORE 627969 PAGE 4 OF 5 DATA SHEET {08} 6. PACKING Every box of trigger coils shall be labeled for identification and traceability purpose. Type : Product name, e.g. ZS 1052-S HT (H) Quantity : Quantity of trigger coils packed in reel Batch : Calendar week, Year QA No. : Number signed at QA Outgoing acceptance P/No. : Customer Part Number, if applicable Bau No. : Product code for Excelitas Date : Date on which the product is accepted by QA for shipment A “Passed QA” sign is stamped on the label to indicate conformance to specification. This label is for each reel. Item Reel Length of Carry Tape Data 13” 8.64 m / reel {09} Quantity Per Reel Diameter of Reel Axis Carry Tape Cover Tape 500 pcs / reel {09} 100 mm PS ESD PE NAME DATE DEPARTMENT DRAWN MAUNG TT 11.06.2012 ENGINEERING CHECKED MAUNG TT 11.06.2012 ENGINEERING DRAWN ZS 1052-S HT(H) 8 TRACTOR ROAD SINGAPORE 627969 PAGE 5 OF 5
ZS1052 S HT(H) 价格&库存
很抱歉,暂时无法提供与“ZS1052 S HT(H)”相匹配的价格&库存,您可以联系我们找货
