SC833AF
SC833AF
    FANSTEL
    RF 网关 802.15.4 Zigbee,蓝牙 v5.2 USB 125kbps
SC833AF 数据手册
SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 OpenSource with Market Ready Enclosure Miscellaneous SC833F wireless sensor and SC833AF beacon support Bluetooth 5.2, Thread, or Zigbee radio protocols. They are in market ready enclosure and pre-certified. OpenSource codes are available to expedite your firmware development. • Supports BLE 5.1 directional finding • Supports BLE 5.2, 802.15.4 radio protocols • Supports BLE 5.0 long range or CODED-PHY. • BC833F with AMS ENS 210 temperature and humidity sensor, and ST Micro LIS3DH 3-axis motion sensor. • Preloaded with iBeacon and Eddystone • • Sensor size: 60x60x22 mm. Includes a wall mount bracket. Development Kit A Development Kit (DK) includes a 10-pin J-Link connector and cable. Loading program into a DK is much easier. We recommend using DKs for small volume deployment. Nordic nRF52 Development Environment SE832AF-210 BLE 5 Sensor Nordic nRF52 development environment is used to develop BT832AF, BT840F/X codes. Open source codes are available http://www.fanstel.com/download-opensource/ SE832AF integrates BT832AF Bluetooth 5 module with AMS ENS210 temperature and humidity sensor. It is a low power, low cost, long range sensor.m Wireless Sensor Summaries SC833F SC833AF BLE module BM833F BM833AF Radio protocols Bluetooth, Thread, Zigbee Bluetooth, Thread, Zigbee Power supply CR2032, not included CR2032, not included Temperature, humidity sensor AMS ENS 210 None Motion sensor ST Micro LIS3DH None QDID 1 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 Table Of Contents 1. Introduction........................................................................................................................................................3 2. Hardware Description ........................................................................................................................................4 SC833AF ...........................................................................................................................................................4 SC833F .............................................................................................................................................................4 3. Firmware Development and Testing ..................................................................................................................5 Preloaded Firmware ..........................................................................................................................................5 Set up for Programming DK-SE840F ...............................................................................................................8 Set up for Programming SE840F Sensor ..........................................................................................................8 Nordic Development Environment .....................................................................................................................9 Revision History ..................................................................................................................................................10 Contact Us ...........................................................................................................................................................11 2 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 1. Introduction SE840F Series wireless sensors Fanstel long range wireless module BT840F, BT840X, or BT832AF and an AMS ENS210 temperature and humidity sensors. All products are referred as SE840F Series in this user’s manual. SE840F integrates BT840F (nRF52840) module with 2300 meter range at 125 Kbps. SE840X integrates BT840X (nRF52840 + SKY66112 PA) with >4500 meter range at 125 Kbps. SE832AF uses long range lost cost module, BT832AF. It supports Bluetooth 5 radio protocol but not Thread or Zigbee. 3 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 2. Hardware Description The same host board design is used for all wireless sensors and development kits. Additional connector is installed. 10-pin J-Link cable is included for connection to a Nordic development Kit. You can load codes into SE840F by using a Tag Connect cable. You can download DK-SE840F development kit schematics from this webpage. https://www.fanstel.com/download-opensource SE840F, SE840X, and SE832AF use the same enclosure and host PCB. The only difference is Bluetooth 5 module installed. Sensor can be desk mounted. A wall mount bracket in included for wall mounting. Additional external hardwire features: • A battery compartment for 2 AAA batteries. • Two user definable LED indicators, red and blue. • A micro USB connector for powering sensor • A push button for OTA DFU. Size of gateway is 60x60x22mm. SC833AF SC833AF contains an nRF52811 BLE 5.1 module BT833AF with an integrated high performance PCB antenna. It is powered by a CR2032 battery (not included). SC833F SC833F contains an nRF52833 BLE 5.1, Thread, Zigbee module BM833F and an AMS ENS210 temperature and humidity sensor, a ST Micro LIS3DH 3-axis motion sensor. It is powered by a CR2032 battery (not included). 4 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 3. Firmware Development and Testing Preloaded Firmware SE840F-210 included temperature and humidity sensor ENS210. The device is preloaded with ENS210 driver. After powering up, the device advertises name “Bsensor”. • • • Use nRF Connect APP with the device. The APP will receive sensor data every 5 seconds in HEX format. The following screenshot shows temperature is 24 degrees(byte 12, 0X18 = 24) and humidity is 60 (byte 14, 0X3C = 60). 5 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 SE840F-210 supports thermistor thermometer. Thermistor data are not sent out via the BLE. User can check the data by RTT viewer. 6 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 When the sensor connected the Fanstel gateway BLG840F or BWG832F, BWG840F. The gateway will upload the raw data to Fanstel MQTT server. You can use your Android phone to check the data. Please download the gateway user guide if you need the detail of sequences for setup gateway. 7 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 Set up for Programming DK-SE840F 10-pin J-Link connector is installed. 10-conductor J-Link cable I included. DK-SE840F can be connected to an nRF52840DK easily for programming. Set up for Programming SE840F Sensor To program BT840F/X module, connect Debug out of PCA10056 (nRF52840DK) to JS3 (Debug in) of DKSE840F by a Tag Connect cable TC2050-IDC-NL-050-ALL. You need to insert 2 AAA batteries into the battery compartment and make sure that sensor PCBA is not separated from bottom enclosure. 8 SC833F, SC832AF Open Source BLE 5.2 Sensors Dra$ Ver 0.50 August 2020 Nordic Development Environment Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for firmware development. Document and Software development tools can be downloaded by the following links. Get start with Nordic chip and all online documents. http://infocenter.nordicsemi.com/index.jsp?topic=/com.nordic.infocenter.nrf52/dita/nrf52/ development/nrf52_dev_kit.html&cp=1_1 Nordic SDK with many example projects. https://developer.nordicsemi.com/nRF5_SDK/ Nordic development zone. You can search or ask a quesGon there. https://devzone.nordicsemi.com/tutorials/b/getting-started/posts/development-with-gcc-andeclipse Programming the Nordic chip Download and install Nrf5x-Command-Line Tools https://www.nordicsemi.com/eng/nordic/Products/nRF52840/nRF5x-Command-Line-ToolsWin32/58850 Download and install nRF Connect https://www.nordicsemi.com/?sc_itemid={B935528E-8BFA-42D9-8BB5-83E2A5E1FF5C} 9 SC833F, SC832AF Open Source BLE 5.2 Sensors Revision History • Aug 2020, Ver. 0.50: Initial draft release 10 Dra$ Ver 0.50 August 2020 SC833F, SC832AF Open Source BLE 5.2 Sensors Contact Us United States: Fanstel Corp. 7466 E. Monte Cristo Ave. Scottsdale AZ 85260 Tel. 1 480-948-4928 Fax. 1-480-948-5459 Email: info@fanstel.com Website: www.fanstel.com Taiwan: Fanstel Corp. 10F-10, 79 Xintai Wu Road Xizhu, New Taipei City, Taiwan 22101 泛世公司 臺灣省新北市汐止區新臺五路79號10樓之10, 22101 Tel. 886-2-2698-9328 Fax. 886-2-2698-4813 Email: info@fanstel.com Website: www.fanstel.com China: Fanstel Technologies Corp. 11 Jiale Street Ping-Dih, Long-Gang, Shen Zhen, GD 518117 泛世康科技(深圳)有限公司 廣東省深圳市龍崗區坪地鎮佳樂街11號 Tel. 86-755-8409-0928 Fax. 86-755-8409-0973 QQ. 3076221086 Email: info@fanstel.com Website: www.fanstel.com 11 Dra$ Ver 0.50 August 2020
SC833AF 价格&库存
很抱歉,暂时无法提供与“SC833AF”相匹配的价格&库存,您可以联系我们找货
