LN60E
LN60E
    FANSTEL
    手机 LTE-M/NB-IoT RF 收发器模块 不含天线,U.FL 卡边
LN60E 数据手册
Ver 1.00 Aug. 2021 LN60G840F Series modules integrate a Nordic nRF9160 LTE SIP module with a Fanstel BLE 5.2/Thread/Zigbee module, with an u.Fl connector for external LTE antenna, an integrated GPS antenna with amplifier or an u.FL for external GPS antenna, a SIM card connector. It allows faster time to market with reduced development cost. An M.2 connector, B key is used to connect to the host processor. LTE Speci cations:
 • BT840XE, max. TX at +21 dBm, range over 4500 meters in free space at 125 Kbps. • BT40F with dual core Cortex M33, up to 128 MHz • USB interface • UART interface • 37 GPIOs Miscellaneou • Operation temperature: -40°C to +85°C • All necessary clock sources integrated • Size: 30x42mm. • Package: for M.2 connector, B Key, 67 pins. • EV board: EV-LN60G Microcontroller: • ARM® Cortex® -M33 • 1 MB ash, 256 kB low leakage RAM • ARM® Trustzone® • ARM® Cryptocell 310 • 2x UART (CTS/RTS) • 11 GPIOs • SIM card interface for external ESIM. • On board nano SIM card connector LTE modem: • Transceiver and baseband • 3GPP LTE release 13 Cat-M1 and Cat-NB1 compliant ◦ 3GPP release 13 coverage enhancement • 3GPP LTE release 14 Cat-NB2 compliant • GPS receiver ◦ GPS L1 C/A supported ◦ GPS antenna and ampli er integrated • RF transceiver for global coverage ◦ Up to 23 dBm output power ◦ -108 dBm sensitivity (LTE-M) for low band, -107 dBm for mid band ◦ An u.FL connector for external LTE antenna • LTE band support in hardware: ◦ Cat-M1: B1, B2, B3, B4, B5, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B66 ◦ Cat-NB1/NB2: B1, B2, B3, B4, B5, B8, B12, B13, B17, B18, B20, B25, B26, B28, B66 • IP v4/v6 stack • Secure socket (TLS/DTLS) API Hardware for Development • EV board: EV-LN60G, a base board with an M.2 connector, a at cable, and an USB cable. • Programming Kit: PK-BLG840G, an USB to UART bridge board for interfacing and monitoring UART. • Nordic nRF9160DK • Nordic nRF5340DK for LN60G40F/E. Bluetooth Speci cation • BLE 5.2 modules with nRF52840, nRF5340 LN Modules Supporting LTE and BL Module BLE module BLE antenna LTE module LTE antenna GPS antenna Certifications QDID Availability LN60G40F BT40F Integrated nRF9160 SICA u.FL Integrated LN60G40X BT40X u.FL+u.FL nRF9160 SICA u.FL Integrated LN60E840E BT840E u.FL nRF9160 SICA u.FL u.FL 119517 Production LN60G840F BT840F Integrated nRF9160 SICA u.FL Integrated E s fi fi s fi fl LN60G840XE BT840XE PA + u.FL nRF9160 SICA u.FL Integrated LN60G LN60E nRF9160 SICA nRF9160 SICA u.FL u.FL Integrated u.FL 108621 108621 108621 Production Production Production Production 1 fl LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Production LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Table Of Contents 1. Introduction........................................................................................................................................................3 LN60G Series, LTE with Optional BLE 5.2 Modules .........................................................................................3 Available LN60G Series Modules ......................................................................................................................5 2. Product Descriptions .........................................................................................................................................6 nRF9160 Specifications .....................................................................................................................................6 BT840F ..............................................................................................................................................................7 BT840XE ...........................................................................................................................................................8 Mechanical Drawings ........................................................................................................................................9 M.2 Connector Pin Assignments ......................................................................................................................11 Pin Function .....................................................................................................................................................13 3. Codes Development Using Nordic Tools .........................................................................................................16 Over-The-Air DFU ...........................................................................................................................................16 SoftDevices .....................................................................................................................................................16 Development Tools ..........................................................................................................................................16 Control nRF21540 in BT40X ...........................................................................................................................17 Control Skyworks Power Amplifier in BT840X .................................................................................................17 4. Application Examples ......................................................................................................................................18 BLG840F, BLE to LTE Gateway ......................................................................................................................18 LEW840X, BLE-LoRa to LTE, WiFi, PoE Ethernet Gateway ...........................................................................19 5. Establishing Cloud Connection and Programming .........................................................................................20 PK-BLG840F, the LTE Monitor Board ..............................................................................................................20 EV-LN60G .......................................................................................................................................................21 EV-LN60G840F ...............................................................................................................................................22 Download and set up Basic Software tools for LN60E40F...........................................................................22 Establishing an LTE Connection to a Cloud Server .....................................................................................22 Relaying Sensor Data to a Cloud Server .....................................................................................................25 Using Android OS ........................................................................................................................................26 Programming the nRF9160. .........................................................................................................................27 EV-LN60G EvaluationBoard Schematics ........................................................................................................31 Packaging and Lot Number .............................................................................................................................33 FCC Label .......................................................................................................................................................33 Revision History ..................................................................................................................................................34 Contact Us ..........................................................................................................................................................35 2 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 1. Introduction LN60G840F Series modules are powerful, highly flexible, ultra low power wireless modules integrating Nordic nRF9160 SIP module and Fanstel BT40F Series BLE 5.1 or BT840F Series BLE 5 module. With an ARM CortexTM M33F MCU, 1MB flash, 256KB RAM, embedded LTE-M and NB-IoT transceiver, an u.FL connector for external LTE antenna, integrated GPS antenna and amplifier or an u.FL for external GPS antenna, it allows faster time to market with reduced development cost. This Series of modules for M.2 connector is referred as the LN (LTE-M/NB-IoT) Module. LN60G Series, LTE with Optional BLE 5.2 Modules The following is a block diagram of LN60G840F. Module can be standalone, needing only DC power supply and cross-connect UART on host board. Or, a host processor can control Bluetooth and LTE interfaces through M.2 connector pins. LN60E and LN60G are without Bluetooth module. 3 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Modules available in the LN60G40F Series. LN60E • nRF9160 SICA SIP module supporting LTE-M and NB-IoT at +23 dBm TX • An u.FL connector for an external LTE antenna • An u.FL connector for an external GPS antenna • Cortex M33 MCU 1MB flash, 256 KB RAM LN60G • nRF9160 SICA SIP module supporting LTE-M and NB-IoT at +23 dBm TX • An u.FL connector for an external LTE antenna • GPS receiver with integrated amplifier and antenna • Cortex M33 MCU 1MB flash, 256 KB RAM LN60G40X • nRF9160 SICA SIP module supporting LTE-M and NB-IoT at +23 dBm TX • U.FL connector for an external LTE antenna • GPS receiver with an integrated antenna. • Cortex M33 MCU 1MB flash, 256 KB RAM • nRF5340 BLE 5.2 module, BT40X with PA, an integrated PCB trace antenna, an u.FL for external antenna. • Dual code Cortex M33, application core up to 128 MHz. LN60E40F • nRF9160 SICA SIP module supporting LTE-M and NB-IoT at +23 dBm TX • U.FL connector for an external LTE antenna • GPS receiver with an u.FL connector for an external antenna. • Cortex M33 MCU 1MB flash, 256 KB RAM • nRF5340 BLE 5.2 module, BT40F with an integrated antenna. • Dual code Cortex M33, application core up to 128 MHz. LN60E840E • nRF9160 SICA SIP module supporting LTE-M and NB-IoT at +23 dBm TX • U.FL connector for an external LTE antenna • GPS receiver with integrated amplifier and antenna • Cortex M33 MCU 1MB flash, 256 KB RAM • BT840E with u.FL for an external antenna. • Bluetooth range with ANT060, 6 dBi antenna, is measured >3400 meters at 125 Kbps. LN60G840F • nRF9160 SICA SIP module supporting LTE-M and NB-IoT at +23 dBm TX • U.FL connector for an external LTE antenna • GPS receiver with integrated amplifier and antenna • Cortex M33 MCU 1MB flash, 256 KB RAM 4 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector • BT840F with Integrated PCB trace antenna. • Bluetooth range is measured 2300 meters Ver 1.00 Aug. 2021 LN60G840XE • nRF9160 SICA SIP module supporting LTE-M and NB-IoT at +23 dBm TX • U.FL connector for an external LTE antenna • GPS receiver with an integrated antenna • Cortex M33 MCU 1MB flash, 256 KB RAM • BT840XE with an u.FL for external antenna. • Bluetooth range is measured >4500 meters or 2.8 miles at 125 Kbp. Available LN60G Series Modules The following table is a list of available LN Series modules. LN Module LTE module GPS antenna BLE module Description LN60G nRF9160 SICA Integrated None nRF9160 LTE module with an integrated GPS antenna. LN60E nRF9160 SICA u.FL None nRF9160 LTE module with an u.fl for an external GPS antenna. LN60G840F nRF9160 SICA Integrated BT840F nRF9160-BT840F, LTE-BLE module, integrated BLE antenna. GPS LN60G840E nRF9160 SICA Integrated BT840E nRF9160-BT840E, LTE-BLE module, u.FL for external BLE antenna. GPS LN60G840X nRF9160 SICA Integrated BT840X nRF9160-BT840X, LTE-BLE+PA module, integrated BLE antenna. GPS LN60G840XE nRF9160 SICA Integrated BT840XE nRF9160-BT840XE, LTE-BLE+PA module, u.FL for ext. BLE antenna. GPS LN60E840F nRF9160 SICA u.FL BT840F nRF9160-BT840F, LTE-BLE module, integrated BLE antenna. LN60E840E nRF9160 SICA u.FL BT840E nRF9160-BT840E, LTE-BLE module, u.FL for external BLE antenna. LN60E840X nRF9160 SICA u.FL BT840X nRF9160-BT840X, LTE-BLE+PA module, integrated BLE antenna. LN60E840XE nRF9160 SICA u.FL BT840XE nRF9160-BT840XE, LTE-BLE+PA module, u.FL for external BLE antenna. LN60G40F nRF9160 SICA Integrated BT40F nRF9160-BT40F, LTE-BLE module, integrated BLE antenna. GPS LN60G40E nRF9160 SICA Integrated BT40E nRF9160-BT40E, LTE-BLE module, u.FL for external BLE antenna. GPS LN60E40F nRF9160 SICA u.FL BT40F nRF9160-BT40F, LTE-BLE module, integrated BLE antenna. LN60E40E nRF9160 SICA u.FL BT40E nRF9160-BT40E, LTE-BLE module, u.FL for external BLE antenna. LN60G40X nRF9160 SICA Integrated BT40X nRF9160-BT40X, LTE-BLE module, BLE + PA +uFL+ PCB antenna. GPS. LN60E40X nRF9160 SICA u.FL BT40X nRF9160-BT40X, LTE-BLE module, BLE + PA +uFL+ PCB antenna. 5 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector 2. Product Descriptions nRF9160 Specifications nRF9160 SIP module Product Specifications can be downloaded from. https://infocenter.nordicsemi.com/index.jsp? topic=%2Fug_nrf91_dk%2FUG%2Fnrf91_DK%2Fintro.html&cp=2_0_2 Block diagram of nRF9160 is shown below. 6 Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 BT840F BT840F is a long range nRF52840 module. Product Specifications of nRF52840 can be downloaded from. https://infocenter.nordicsemi.com/index.jsp? topic=%2Fug_nrf91_dk%2FUG%2Fnrf91_DK%2Fintro.html&cp=2_0_2 The following is a block diagram of Nordic nRF52840 Bluetooth Low Energy (BLE) SoC. Arrows with white heads indicate signals that share physical pins with other signals. . 7 Ver 1.00 Aug. 2021 BT840F data sheets can be downloaded from: https://www.fanstel.com/download-document BT840XE A Skyworks power amplifier SKY66112 is integrated with nRF52840 in BT840XE. A block diagram is shown below. nRf52840 codes to control SKY66112 are included in this data sheets. They can be downloaded from Fanstel webpage. https://www.fanstel.com/download-document 8 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Mechanical Drawings Size of LN60E840F is 30x42mm. 9 Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector The following is detailed drawing of the M.2 connector. 10 Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 M.2 Connector Pin Assignments The followings are LN60E40F M.2 connector pin assignment. Pin functions are in a table in next section. Please refer to Nordic nRF9160, nRF5340, and nRF52840 Product Specifications for detailed descriptions and features supported. Pin names begin with BLE are Bluetooth module pins. If you are working on a design accommodating both nRF52840 and nRF5340 modules, • Blue color port names inside the rectangular are for nRF52840 modules. • Green color port names outside the rectangular are for nRF5340 modules. • Red color port names outside the rectangular are for nRF9160 module. 11 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Pin assignments with nRF52840 module. 12 Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Pin Function M.2 9160 BT840F BT840F/9160 BT40F BT40F/9160 pin# pin# pin# Name pin# Name Descriptions 5V IN DC input for 3.3V regulator; 3.2V to 15V. 4.35V minimum if connected to USB-VBUS externally. BLE-VDDH High voltage input for nRF52840/nRF5340, 2.5V to 5.5V 5V IN DC input for 3.3V regulator; 3.2V to 15V. 4.35V minimum if connected to USB-VBUS externally. 1 2 F4 BLE-VDDH F4 3 4 9 VDD-3V3 9 VDD-3V3 Regulated 3.3V DC input, 800 mA minimum 5 F6 USB-VBUS F6 USB-VBUS USB power supply, 4.35V to 5.5V. 6 9 VDD-3V3 9 VDD-3V3 Regulated 3.3V DC input, 800 mA minimum 7 E4 USB DP E4 USB DP USB data pin 8 15 BLE-SWDCLK 15 BLE-SWDCLK Serial Wire Debug clock input for BLE 9 E5 USB DN E5 USB DN USB data pin 10 16 BLE-SWDIO 16 BLE-SWDIO Serial Wire Debug data for BLE 11 10 GND 10 GND Ground GND Ground P009 BLE GPIO GND Ground 12 13 14 15 16 17 18 19 20 21 GND 11 22 P011 11 GND 23 12 P100 12 P011 BLE GPIO 24 13 P013 13 P030 BLE GPIO 25 E6 P012 E6 P010 BLE GPIO 26 D5 P101 D5 P022 BLE_UART RXD 27 E3 P109 E3 P107 BLE GPIO 28 14 P018/RESET 14 RESET Reset for BT40F, Reset or P018 for BT840F 29 E2 P021 E2 P106 BLE GPIO 30 D4 P014 D4 P029 BLE GPIO 31 D1 P023 D1 P026 BLE GPIO 32 D3 P016 D3 P028 BLE-OTA 33 C1 P024 C1 P031 BLE GPIO 13 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 34 D2 P019 D2 P027 BLE GPIO 35 C5 P102 C5 P020 BLE_UART-TXD 36 C4 P015 C4 P023 BLE GPIO 37 C2 P022 C2 P021 BLE GPIO 38 C3 P017 C3 P024 BLE GPIO 39 B5 P008 B5 P012 BLE GPIO 40 E1 P020 E1 P105 BLE GPIO 41 B4 P006 B4 P015 BLE GPIO 42 B3 P031 B3 P014 BLE GPIO 43 A6 P108 A6 P108 BLE GPIO 44 B2 P030 B2 P017 BLE GPIO 45 A5 P007 A5 P100 BLE GPIO 46 B1 P025 B1 P019 BLE GPIO 47 A4 P005 A4 P016 BLE GPIO P0.14 LTE_UART_APP2-RTS P008 BLE GPIO P0.15 LTE_UART_APP2-CTS P007 BLE GPIO LTE-RESET LTE reset, Active low P006 BLE GPIO LTE-SWDCLK LTE-Single Wire Debug clock input P102 BLE_I2C, SDA LTE-SWDIO LTE-Single Wire Debug data P103 BLE_I2C, SCL SIM-RESET LTE_SIM reset P003 BLE_GPIO, NFC2 SIM-DET LTE_SIM detect P002 BLE_GPIO, NFC1 SIM-CLK LTE_SIM clock P005 BLE_GPIO, AIN1 SIM-IO LTE_SIM data P004 BLE_GPIO, AIN 0 48 24 49 50 A3 25 51 52 32 56 33 58 34 60 43 62 45 64 46 P026 1 P027 2 P010 8 P009 7 SIM-CLK 6 48 65 P006 SIM-DET 7 63 P028 SIM-RESET 8 61 A2 LTE-SWDIO 2 59 P029 LTE-SWDCLK 1 57 A3 LTE-RESET A1 55 P004 P0.15 A2 53 54 P0.14 P003 6 SIM-IO 5 P002 5 66 47 SIM-1V8 SIM-1V8 LTE_SIM 1.8V power supply 67 95 P0.00 P0.00 LTE_UART_APP2-RXD 68 83 P0.26 P0.26 LTE_UART_APP1-CTS 69 96 P0.01 P0.01 LTE_UART_APP2_TXD 70 84 P0.27 P0.27 LTE_UART_APP1-RTS 14 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 71 97 P0.02 P0.02 LTE-GPIO 72 86 P0.28 P0.28 LTE_UART_APP1-RXD 73 99 P0.03 P0.03 LTE-GPIO 74 87 P0.29 P0.29 LTE_UART_APP1-TXD 75 3 P0.06 P0.06 LTE-OTA 15 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 3. Codes Development Using Nordic Tools Development tools by Nordic and other third party development tools recommended by Nordic should be used. Nordic development environment for nRF52840 offers a clean separation between application code development and embedded protocol stacks. This means compile, link and run time dependencies with the embedded stack and associated debugging challenges are removed. The Bluetooth low energy and ANT stack is a pre-compiled binary, leaving application code to be compiled stand-alone. The embedded stack interface uses an asynchronous and event driven model removing the need for RTOS frameworks. Over-The-Air DFU The nRF52840 is supported by an Over-The-Air Device Firmware Upgrade (OTA DFU) feature. This allows for in the field updates of application software and SoftDevice. SoftDevices The Nordic protocol stacks are known as SoftDevices and complement the nRF52 Series SoCs. All nRF52 Series are programmable with software stacks from Nordic. This bring maximum exibility to application development and allows the latest stack version to be programmed into the SoC. SoftDevices available from Nordic: S140: Bluetooth low energy concurrent central/peripheral/observer/broadcaster stack. Development Tools Nordic Semiconductor provides a complete range of hardware and software development tools for the nRF52 Series devices. nRF52 DK board is recommended for rmware development. Nordic software development tools can be downloaded from the following webpage. http://infocenter.nordicsemi.com/index.jsp?topic=/com.nordic.infocenter.nrf52/dita/nrf52/development/ nrf52_dev_kit.html&cp=1_1 fl fi 16 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Control nRF21540 in BT40X To be provided. Control Skyworks Power Amplifier in BT840X BT840X in LN60E840X uses SKYWORKS SKY66112-11 power amplifier. A firmware example to control Skyworks SKY66112 power amplifier is below. This firmware file can be downloaded from http://www.fanstel.com/download-document/. Settings for BT840F and BT840E: • nRF52840 SoC TX power is set to +8dBm for FCC, ISED, CE, RCM, and TELEC certification testings. • BT840E passes FCC and ISED certification testings with ANT060, a 6 dBi antenna. • BT840E passes CE, RCM, and TELEC certification testings with ANT000 antenna. • VDD is set to 3.3V with DCDC converter enabled. Settings for BT840X and BT840XE: • nRF52840 SoC TX is set to +2dBm for FCC and ISED testings. • nRF52840 SoC TX is set to -4 dBm for CE and RCM testings. • BT840XE passes FCC, ISED, CE, and RCM certification testings with ANT000, a 0dBi antenna. • VDD is set to 3.3V. Please refer to BT840F Product Specifications for firmware to control SKY66112 power amplifier in BT840X and BT840XE. 17 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 4. Application Examples BLG840F, BLE to LTE Gateway In this basic BLE 5/802.15.4 to LTE-NB-IoT gateway design: • The bold, gray rectangular box is the boundary of M.2 connector, B Key. • Most of free GPIOs on M.2 connector are from BLE module. • nRF9160 is connected to BT840F/BT40F through host board using UART. • Optional flash memory can be installed for BLE module without SKY66112 power amplifier. QSPI pins are used for PA control inside BT840X/XE. • Nano SIM connector is on the LN module. eSIM interface is available on M.2 connector to install eSIM on host board. • The M.2 module in the following block diagram is an LN60G840F. 18 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 LEW840X, BLE-LoRa to LTE, WiFi, PoE Ethernet Gateway This application example supports multiple network interfaces and multiple protocols. • PoE Ethernet and 802.11 b/g/n WiFi circuitry is on gateway host board. • An LN60G, LN module for LTE/NB-IoT network expansion • An M262X840XE, M2 module to support Bluetooth, Thread, Zigbee, LoRa device interfaces. • Data from sensors and other devices can be processed in the host board MCU (ESP32) before sending to cloud server. 19 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 5. Establishing Cloud Connection and Programming PK-BLG840F, the LTE Monitor Board PK-BLG840F can be used: • to interface with the BLE module or the LTE module on LN60G Series M.2 modules or BLG840F Series gateways. • To monitor UART data traf c to the LTE module or the BLE module. It contains: • an UART to USB bridge board, called LTE Monitor board, • a 10-pin at cable, • and an USB cable. There are three 12-pins square connectors on the LTE Monitor board. • JS5-BLE for connection to the BLE module on LN60G840F module or in BLG840F gateway. • JS6-LTE for connection to the LTE module on LN60G840F module or in BLG840F gateway. • JS7-RXD for monitor UART data to the receiver of the BLE or the LTE module. It can be selected by the SW3 switch on the back side. fi
 fl 20 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 EV-LN60G An evaluation board consists of the followings: • Micro USB cable • Evaluation board • 10-conductor cable for connection to Nordic nRF52840 DK (DK is not included) • A screw for locking the M.2 module on the EV board. An EV-LN60G can be used to evaluate any Fanstel M.2 module. • An M.2 module is not included. • An LN module (for example, an LN60G840F) has a nano SIM crd connector. A nano SIM card is not included. The following photo is for an LN60G840F module installed on the EV-LN60G. 21 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 EV-LN60G840F After installing LN60G840F module into EV-LN60G evaluation board, it is called EV-LN60G840F. The LN60G840F module is pre-loaded Nordic modem mfw_nrf9160_1.2.3 and MQTT application. MQTT tool or MQTT APPMQTT broker LN60E40F BLE Sensor The default application is for NB IoT. If you need to run CAT M. Please download the HEX le from Fanstel website. The LN60G840F preloaded rmware will send the temperature and humidity preset data to Fanstel MQTT server. One can use Fanstel MQTT PC tool or mobile APP to monitor data. Download and set up Basic Software tools for LN60E40F. nRF command line tool 10.2.1 or newer. https://www.nordicsemi.com/Software-and-Tools/Development-Tools/nRF-Command-Line-Tools/Download nRF Connect desktop 3.2.0 or newer. https://www.nordicsemi.com/Software-and-Tools/Development-Tools/nRF-Connect-for-desktop Fanstel MQTT PC tool to test default rmware. https://www.dropbox.com/s/27xzy1kytb8t918/MQTT_PC_Tool190916.rar?dl=0 Fanstel LTE PC tool to test default rmware. https://www.dropbox.com/s/beyhbh78lowlzal/LTE_PC_Tool190718.rar?dl=0 Establishing an LTE Connection to a Cloud Server The following example establishes a connection between nRF9160 on LN60G840F and Fanstel development server. You will enter arti cial temperature and humidity data for uploading to the Fanstel MQTT server. Programming the nRF9160 only HEX code. • Connect the external antenna. • Connect the small JS7 board to JS-LTE connector. • Connect the micro USB port to a PC with an USB cable. fi fi fi fi fi 22 • Open Fanstel LTE monitor and MQTT listener PC tools. • Select the COM port. • Reset the BLG840F, the log appears. • Con gure Publish ID and arti cial temperature. fi 23 fi LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 When nRF9160 module is connected to the MQTT server, you will see the temperature and humidity data uploaded. • Open the MQTT PC tool and enter the same Publish ID you just setup. • Press start icon. • The data from nRF9160 is displayed. 24 Ver 1.00 Aug. 2021 Relaying Sensor Data to a Cloud Server This application example relays temperature and humidity sensor data from Fanstel sensors through a LTE connection to Fanstel louder server. • Programming mqtt9160NB_210115.HEX code. • Remove the small JS7 board. • Insert the JS7 connector of the LTE Monitor board (the USB to UART bridge board included in PKBLG840F) to JS-LTE connector of EV-LN60G board. • Use SW3 on the LTE Monitor board to select monitoring the UART data to the BLE or to the LTE receiver. • Check both nRF9160 and nRF52840 UART logs, running normally. You can use this set up to monitor traf c at the UART interface when developing your own code. After checking the log, insert the small JS7 board back to JS-LTE. fi 25 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Using Android OS Download and install nRF Connect mobile App. https://play.google.com/store/apps/details?id=no.nordicsemi.android.mcp&hl=zh-TW Open the nRF Connect mobile App when a Fanstel sensor is powered up nearby. The sensor is advertising the 6 bytes ID. Enter the sensor ID into Fanstel MQTT tool.The real sensor data are displayed on the tool. 26 Programming the nRF9160. • Connected PCA10090 debug out to EVLN60G840F JS2-9160 • Open the command line and go to the folder where the HEX le located. • Execute the programming command “nrfjprog --program mqtt9160NB_190904.hex --chiperase -f nrf91 –reset” fi 27 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Ver 1.00 Aug. 2021 Note: The voltage supported by external debugging/programming is the VDD voltage. This voltage can be selected to 1.8 V or 3 V using slide switch SW11. Make sure the voltage level of the external board matches the VDD of the nRF9160 DK. Please select 3V if programming the BLG840F gateway. Programming the nRF9160 with nRF Connect for desktop. Upgrade modem. 28 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Upgrade application Programming the BT840F HEX code. • Connected PCA10090 debug out to EV-LN60G840F JS4-BLE. • Set SW10 slide switch of the PCA10090 to nRF52. • Set SW9 slide switch of the PCA10090 to 3V. 29 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Open nRF connect\programmer and load the HEX code. Execute Erase & Write. The log will show write success. 30 Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector EV-LN60G EvaluationBoard Schematics Evaluation board schematics and Gerber files can be downloaded from http://www.fanstel.com/download-document/ 31 Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Page 2 of EV-LN60G schematics. EV board schematics can be used as a reference design for using modules. 32 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Ver 1.00 Aug. 2021 Packaging and Lot Number LN60G840F Series module is individual packed. FCC LABEL The Original Equipment Manufacturer (OEM) must ensure that the OEM modular transmitter must be labeled with its own FCC ID number. This includes a clearly visible label on the outside of the final product enclosure that displays the contents shown below. If the FCC ID is not visible when the equipment is installed inside another device, then the outside of the device into which the equipment is installed must also display a label referring to the enclosed equipment The end product with this module may subject to perform FCC part 15 unintentional emission test requirement and be properly authorized. This device is intended for OEM integrator only. 33 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Revision History • Aug. 2020, Ver. 0.60: Initial draft release • Sep. 2020, Ver. 0.61: Draft update • Jan. 2021, Ver.0.90: Draft revision • April 2021, Ver. 0.91: Draft revision • Aug. 2021, Ver. 1.00: Initial release. 34 Ver 1.00 Aug. 2021 LTE-BLE 5.2, 802.15.4 Modules, M.2 Connector Contact Us United States: Fanstel Corp. 7466 E. Monte Cristo Ave. Scottsdale AZ 85260 Tel. 1 480-948-4928 Fax. 1-480-948-5459 Email: info@fanstel.com Website: www.fanstel.com Taiwan: Fanstel Corp. 10F-10, 79 Xintai Wu Road Xizhu, New Taipei City, Taiwan 22101 !"#$ %&'()*+,-(%./790101210, 22101 Tel. 886-2-2698-9328 Fax. 886-2-2698-4813 Email: info@fanstel.com Website: www.fanstel.com China: Fanstel Technologies Corp. 11 Jiale Street Ping-Dih, Long-Gang, Shen Zhen, GD 518117 !"345(67)89#$ :;'67*?@ABC110 Tel. 86-755-8409-0928 Fax. 86-755-8409-0973 QQ. 3076221086 Email: info@fanstel.com Website: www.fanstel.com 35 Ver 1.00 Aug. 2021
LN60E 价格&库存
很抱歉,暂时无法提供与“LN60E”相匹配的价格&库存,您可以联系我们找货
