CR12600SE
CR12600SE
    FDK
    BATTERY LITHIUM 3V CR12600
CR12600SE 数据手册
Cell Type CR12600SE Specifications Nominal Capacity*1 Nominal Voltage Standard Discharge Current Continuous *2 Max. Discharge Current Pulse*3 Temperature Range Weight H D 1500mAh 3V 1.0mA 15mA 250mA -40℃~85℃ 15g 12.0mm 60.0mm 3mm D H d Dimensions *1 Nominal capacity is determined to an end voltage of 2.0V when the battery is allowed to discharge at a standard current level at 23oC. *2 Current value is determined to be the level at which 50% of the nominal capacity is obtained with an end voltage of 2.0V at 23 oC. *3 Current value for obtaining 2.0V cell voltage when pulse is applied for 15seconds at 50% discharge depth at 23 oC. d Typical Characteristics Discharge Characteristics of CR12600SE Discharge Characteristics of CR12600SE 3.5 3.5 80 o C Load: 180ohm(=14mA) 60 o C 23 o C 2.5 0 oC 2.0 1.5 1.0 0 10 20 30 40 50 60 Duration(hour) 70 80 -40 o C 2.0 1.5 0 20 40 60 80 100 Duration(day) 120 140 160 180 Discharge Load vs. Capacity of CR12600SE 3.5 3.5 60 o C Load: 560ohm(=5mA) Temp.: 23oC Load: 150kohm(=20uA) 23 o C 3.0 3.0 -20 o C 2.5 Cell Voltage(V) Cell Voltage(V) 23 o C -20 o C 2.5 1.0 90 Discharge Characteristics of CR12600SE -40 o C 2.0 1.5 1.0 0 1 2 3 4 5 6 7 8 9 10 11 2.5 Initial after 5years storage at 23 oC after 9years storage at 23 oC 2.0 1.5 1.0 12 0 2 4 Duration(year) 6 8 10 12 14 16 18 Duration(day) Discharge Load vs. Operating Voltage of CR12600SE Discharge Characteristics of CR12600SE 3.2 2000 80 o C 3.0 60 o C 80 o C 1500 23 o C 2.8 Capacity(mAh) Cell Voltage(V) Load: 5.6kohm(=505uA) 60 o C 3.0 Cell Voltage(V) Cell Voltage(V) 3.0 -20 o C 2.6 -40 o C 2.4 60 o C 1000 23 o C -40 o C -20 o C 500 2.2 operating voltage at half capacity end voltage:2.0V 2.0 0 1 3 10 30 100 Discharge Load(kohm) 300 1000 0.1 0.3 1 3 Load(kohm) 10 30 100
CR12600SE 价格&库存
很抱歉,暂时无法提供与“CR12600SE”相匹配的价格&库存,您可以联系我们找货
