CR17335SET-FT
CR17335SET-FT
    FDK
    BATTERY LITHIUM 3V CR17335
CR17335SET-FT 数据手册
Cell Type CR17335SE Specifications Nominal Capacity*1 Nominal Voltage Standard Discharge Current Continuous *2 Max. Discharge Current Pulse*3 Temperature Range Weight D D H d Dimensions H 1800mAh 3V 1.0mA 8mA 100mA -40℃~85℃ 17g 17.0mm 33.5mm 7mm *1 Nominal capacity is determined to an end voltage of 2.0V when the battery is allowed to discharge at a standard current level at 23oC. *2 Current value is determined to be the level at which 50% of the nominal capacity is obtained with an end voltage of 2.0V at 23 oC. *3 Current value for obtaining 2.0V cell voltage when pulse is applied for 15seconds at 50% discharge depth at 23 oC. d Typical Characteristics Discharge Characteristics of CR17335SE Discharge Characteristics of CR17335SE 3.5 3.5 80 o C Load: 280ohm(=9mA) 3.0 Load: 5.6kohm(=505uA) 60 o C 3.0 Cell Voltage(V) Cell Voltage(V) 80 o C 2.5 23 o C 0 oC 2.0 1.5 1.0 0 20 40 60 80 100 120 140 Duration(hour) 160 180 200 220 3.5 60 o C -20 o C 2.0 o -40 C 1.5 1.0 240 Discharge Characteristics of CR17335SE 23 o C 2.5 0 20 40 60 80 100 Duration(day) 120 140 160 180 Discharge Load vs. Capacity of CR17335SE 23 o C Load: 150kohm(=20uA) 2000 80 o C 1500 -20 o C -40 o C 2.5 Capacity(mAh) Cell Voltage(V) 3.0 23 o C 2.0 1.5 -20 o C 60 o C 1000 -40 o C 500 end voltage:2.0V 0 1.0 0 1 2 3 4 5 6 Duration(year) 7 8 9 10 11 Discharge Load vs. Operating Voltage of CR17335SE 0.1 12 0.3 1 3 10 30 100 Discharge Load(kohm) Discharge Characteristics of CR17335SE 3.4 3.5 Load: 2.7kohm(=1mA) Temp.: 23 oC 3.0 80 o C 3.0 Cell Voltage(V) Cell Voltage(V) 3.2 60 o C 2.8 23 o C -20 o C 2.6 -40 o C 2.4 2.5 Initial after 50days storage at 80 oC 2.0 1.5 Operating voltage at half capacity 2.2 1.0 1 3 10 30 Discharge Load(kohm) 100 300 0 10 20 30 40 50 Duration(day) 60 70 80 90
CR17335SET-FT 价格&库存
很抱歉,暂时无法提供与“CR17335SET-FT”相匹配的价格&库存,您可以联系我们找货
