AR12106CHL
AR12106CHL
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 浅灰色 铰链式门,盖 13.090" 长 x 10.980" 宽(332.49mm x 278.89mm) X 6.710"(170.43mm)
AR12106CHL 数据手册
AR12106CHL Order symbol: AR12106CHL EAN: 6418074066930 Product nbr: 8561024 El. number: Description: PC Enclosure Remarks: Hinged opaque cover w/Plastic quick release latch • • • Finland: Denmark: Sweden: Including: Hinged cover. Base with 10-32 brass inserts, latched cover with formed in place PUR gasket, stainless hinge pin. Quick release latches. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample image Dimensions: Height Width Depth Accessories: mm: 305 254 152 ASPHK12 Swing Panel Kit w/o Panel inch: 12 10 6 ALBP1210 Aluminum Back Panel Materials: (274 x 226) Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: RAL 7035 -light grey Gasket material: Polyurethane Temperatures: Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Temperature °F (short term): -40 … 250 Temperature °F (continuous): -40 … 175 ASP1210 Aluminum Swing Panel (254.5 x 305.7 x 0) ASPK1210 Swing Panel Kit incl. Panel ADFP1210 Dead Front Panel w/ screws (257.5 x 307.5 x 0) APBP1210 PVC Back Panel (274 x 226) AMFL10 10" Mounting Flange Set ABP1210 Painted Steel Back Panel (274 x 226) Rating: Ingress protection (EN 60529): IP66; IP67; Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class NEMA 4, 4X, 6, 6P, 12, 12K and 13 Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022)
AR12106CHL 价格&库存
很抱歉,暂时无法提供与“AR12106CHL”相匹配的价格&库存,您可以联系我们找货
