AR14127CHSSL
AR14127CHSSL
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 浅灰色 铰链式门,盖 15.110" 长 x 12.920" 宽(383.79mm x 328.17mm) X 7.720"(196.09mm)
AR14127CHSSL 数据手册
AR14127CHSSL Order symbol: AR14127CHSSL EAN: 6418074066817 Product nbr: 8561030 El. number: Description: PC Enclosure Remarks: Hinged opaque cover w/S.S. Lockable latch • • • Finland: Denmark: Sweden: Including: Hinged cover. Base with 10-32 brass inserts, latched cover with formed in place PUR gasket, stainless hinge pin. Quick release latches. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample image Dimensions: Height Width Depth mm: 356 305 178 inch: 14 12 7 Accessories: ABP1412 Painted Steel Back Panel (325 x 274) Materials: Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: RAL 7035 -light grey Gasket material: Polyurethane Temperatures: Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Temperature °F (short term): -40 … 250 Temperature °F (continuous): -40 … 175 ASP1412 Aluminum Swing Panel (305 x 355.7 x 0) ASPHK14 Swing Panel Kit w/o Panel AMFL12 12" Mounting Flange Set ADFP1412 Dead Front Panel w/ screws (308 x 357.5 x 0) ALBP1412 Aluminum Back Panel (325 x 274) APBP1412 PVC Back Panel (325 x 274) ASPK1412 Swing Panel Kit incl. Panel Rating: Ingress protection (EN 60529): IP66; IP67; Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class NEMA 4, 4X, 12 and 13 Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022)
AR14127CHSSL 价格&库存
很抱歉,暂时无法提供与“AR14127CHSSL”相匹配的价格&库存,您可以联系我们找货
