AR16148CHSST
AR16148CHSST
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 浅灰色 铰链式门,盖 17.440" 长 x 15.120" 宽(442.98mm x 384.05mm) X 8.720"(221.49mm)
AR16148CHSST 数据手册
AR16148CHSST Order symbol: AR16148CHSST Product nbr: 8561077 Description: PC Enclosure Remarks: Hinged transparent cover w/S.S. Quick release latch EAN: 6418074067258 El. number: • • • Finland: Denmark: Sweden: Including: Hinged cover. Base with 10-32 brass inserts, latched cover with formed in place PUR gasket, stainless hinge pin. Quick release latches. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample image Dimensions: Height Width Depth mm: 406 356 203 inch: 16 14 8 Accessories: ALBP1614 Aluminum Back Panel (375 x 327) ASPHK16 Swing Panel Kit w/o Panel ADFP1614 Dead Front Panel w/ screws (362 x 415 x 0) APBP1614 PVC Back Panel (375 x 327) ABP1614 Painted Steel Back Panel (375 x 327) AMFL14 14" Mounting Flange Set ASPK1614 Swing Panel Kit incl. Panel Materials: Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: Transparent Gasket material: Polyurethane Temperatures: Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Temperature °F (short term): -40 … 250 Temperature °F (continuous): -40 … 175 Rating: Ingress protection (EN 60529): IP66; IP67; Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class NEMA 4, 4X, 12 and 13 Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022)
AR16148CHSST 价格&库存
很抱歉,暂时无法提供与“AR16148CHSST”相匹配的价格&库存,您可以联系我们找货
