AR181610CHSC
AR181610CHSC
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 浅灰色 铰链式门,盖 19.400" 长 x 17.110" 宽(492.76mm x 434.59mm) X 10.690"(271.53mm)
AR181610CHSC 数据手册
AR181610CHSC Order symbol: AR181610CHSC EAN: 6418074066657 Product nbr: 8561068 El. number: Description: PC Enclosure • • • Remarks: Hinged opaque screw cover Finland: Denmark: Sweden: Including: Hinged screw cover. Base with 10-32 brass inserts, cover with formed in place PUR gasket, stainless hinge pin and 2 cover screws. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample image Dimensions: Height Width Depth mm: 457 406 254 inch: 18 16 10 Accessories: APBP1816 PVC Back Panel (424 x 378) ABP1816 Painted Steel Back Panel Materials: (424 x 378) Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: RAL 7035 -light grey Gasket material: Polyurethane Temperatures: Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Temperature °F (short term): -40 … 250 Temperature °F (continuous): -40 … 175 ASP1816 Aluminum Swing Panel (410 x 465 x 0) ALBP1816 Aluminum Back Panel (424 x 378) ADFP1816 Dead Front Panel w/ screws (412 x 465 x 0) AMFL16 16" Mounting Flange Set ASPK1816 Swing Panel Kit incl. Panel Rating: Ingress protection (EN 60529): IP66; IP67; Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class NEMA 4, 4X, 12 and 13 Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022)
AR181610CHSC 价格&库存
很抱歉,暂时无法提供与“AR181610CHSC”相匹配的价格&库存,您可以联系我们找货
