AR664CHSSL
AR664CHSSL
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 浅灰色 铰链式门,盖 7.160" 长 x 7.040" 宽(181.86mm x 178.82mm) X 4.720"(119.89mm)
AR664CHSSL 数据手册
AR664CHSSL Order symbol: AR664CHSSL EAN: 6418074066671 Product nbr: 8561026 El. number: Description: PC Enclosure Remarks: Hinged opaque cover w/S.S. Lockable latch • • • Finland: Denmark: Sweden: Including: Hinged cover. Base with 10-32 brass inserts, latched cover with formed in place PUR gasket, stainless hinge pin. Quick release latches. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample image Dimensions: Height Width Depth Accessories: mm: 152 152 102 AMFL6 6" Mounting Flange Set inch: 6 6 4 ABP66 Painted Steel Back Panel Materials: (124 x 124) Material: Polycarbonate ASPHK6 Swing Panel Kit w/o Panel Base colour: RAL 7035 -light grey ASPK66 Swing Panel Kit incl. Panel Cover colour: RAL 7035 -light grey ALBP66 Gasket material: Polyurethane Aluminum Back Panel (124 x 124) APBP66 PVC Back Panel (124 x 124) ASP66 Aluminum Swing Panel (153 x 154 x 0) ADFP66 Dead Front Panel w/ screws (155 x 157 x 0) Temperatures: Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Temperature °F (short term): -40 … 250 Temperature °F (continuous): -40 … 175 Rating: Ingress protection (EN 60529): IP66; IP67; Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class NEMA 4, 4X, 6, 6P, 12, 12K and 13 Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022)
AR664CHSSL 价格&库存
很抱歉,暂时无法提供与“AR664CHSSL”相匹配的价格&库存,您可以联系我们找货
