AR865SCT
AR865SCT
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 浅灰色 铰链式门,盖 9.170" 长 x 7.060" 宽(232.92mm x 179.32mm) X 5.710"(145.03mm)
AR865SCT 数据手册
AR865SCT Order symbol: AR865SCT EAN: 6418074066305 Product nbr: 8561012 El. number: Description: PC Enclosure Remarks: Transparent screw cover • • • Finland: Denmark: Sweden: Including: Screw cover. Base with 10-32 brass inserts, cover with formed in place PUR gasket and 4 stainless cover screws. Enclosure mounting foot kit. Accessory 10-32 screws for panel mounting. Sample image Dimensions: Height Width Depth Accessories: mm: 203 152 127 AMFL6 6" Mounting Flange Set inch: 8 6 5 ASP86 Aluminum Swing Panel (154.4 x 204.5 x 0) ASPK86 Swing Panel Kit incl. Panel APBP86 PVC Back Panel (175 x 124) ASPHK8 Swing Panel Kit w/o Panel ABP86 Painted Steel Back Panel (175 x 124) ALBP86 Aluminum Back Panel (175 x 124) ADFP86 Dead Front Panel w/ screws (157 x 205.5 x 0) Materials: Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: Transparent Gasket material: Polyurethane Temperatures: Temperature °C (short term):: -40 … 140 Temperature °C (continuous): -40 … 80 Rating: Temperature °F (short term): -40 … 250 Ingress protection (EN 60529): IP66; IP67; Temperature °F (continuous): -40 … 175 Impact Resistance (EN 62262): IK09; Electrical insulation: Not insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 508 Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class NEMA 4, 4X, 6, 6P, 12, 12K and 13 Certificates: ARCA_CertificateofCompliance © Fibox Oy, Data subject to change without notice (printed: 20.07.2022)
AR865SCT 价格&库存
很抱歉,暂时无法提供与“AR865SCT”相匹配的价格&库存,您可以联系我们找货
