UL PC 150/125 LT
UL PC 150/125 LT
    FEIGELECTRONIC
    塑料 - 聚碳酸酯 盒 灰色,透明外盖/门 包含盖 7.100" 长 x 5.100" 宽(180.34mm x 129.54mm) X 4.900"(124.46mm)
UL PC 150/125 LT 数据手册
PC 150/125 LT Order symbol: PC 150/125 LT EAN: 6418074052162 Product nbr: 6012917 El. number: UL Code: 6412917 UL Name: UL PC 150/125 LT • • • Finland: 3435210 Denmark: 8212027640 Sweden: Description: Enclosure. PC Remarks: Smoked transparent cover Including: Base with TPE gasket. screws for mounting plate/DIN-rail and cover with polyamide cover screws. Sample image Dimensions: Height Width Depth mm: 180 130 125 Accessories: MIV 10 DIN-35 Mounting rail. for enclosures: (100 x 35 x 1) FP A 150/180 Front panel (Aluminum). for enclosures: (170 x 112 x 1) HFP 180 Front panel hinge series MIV 150 Back Panel (Galvanized steel). for enclosures: (148 x 98 x 1) MIN 15 DIN-15 Mounting rail. for enclosures: (150 x 15 x 1) MIN 10 DIN-15 Mounting rail. for enclosures: (100 x 15 x 1) MIV 15 DIN-35 Mounting rail. for enclosures: (150 x 35 x 1) FP 22046 Mounting foot kit (4 pcs) inch: Materials: Material: Polycarbonate Base colour: RAL 7035 -light grey Cover colour: Clear transparent Gasket material: Polyurethane Temperatures: Temperature °C (short term):: -40 … 120 Temperature °C (continuous): -40 … 80 Temperature °F (short term): -40 … 250 Temperature °F (continuous): -40 … 175 Rating: Ingress protection (EN 60529): IP66; IP67; Impact Resistance (EN 62262): IK08; Electrical insulation: Totally insulated Halogen free (DIN/VDE 0472, Part 815): 1 UV resistance: UL 508 Flammability Rating: UL 746C 5" Glow Wire Test (IEC 695-2-1) °C: 960 °C NEMA Class Certificates: Certificate FI 40847 © Fibox Oy, Data subject to change without notice (printed: 05.08.2022)
UL PC 150/125 LT 价格&库存
很抱歉,暂时无法提供与“UL PC 150/125 LT”相匹配的价格&库存,您可以联系我们找货
