FINF050-100WCLL2
FINF050-100WCLL2
    II-VI
    INTERLEAVER 50-100G C-BAND LC/PC
FINF050-100WCLL2 数据手册
Finisar 50GHz WB Interleaver Features: ● Wide passband and low dispersion ● Passively athermalized ● High isolation and low insertion loss ● Fully qualified to Telcordia 1209/1221 The Finisar 50GHz Wide Band interleaver efficiently demultiplexes (or multiplexes) 50GHz spaced channels into two sets of 100GHz spaced channels, which is the best solution to upgrade the existing 100GHz spacing system and cost saving to the equipment manufacturer. This passively athermalized interleaver offers exceptional performance in an ultra-compact form factor. ● Compact size ● RoHS compliance Specifications: Parameter Wavelength range Channel spacing Unit Minimum Typical Maximum nm 1528.77 C band 1566.72 nm 1 0.5 dB Passband relative to ITU grid 1 GHz GHz GHz 1 GHz 1 dB Passband relative to ITU grid 1 3 dB Passband relative to ITU grid 25dB Stopband relative to ITU grid 1,2 IL over passband IL uniformity within port 1 IL uniformity all ports1 50GHz ± 13.5 ± 14 ± 15 ± 19 ± 10 ± 20 dB dB 2.2 0.5 dB 1 1 dB Isolation over stopband 1 dB Polarization dependent loss* (PDL) dB 0.3 0.5 Polarization mode dispersion (PMD) ps 0.2 0.4 +35 IL ripple over passband Dispersion over passband 0.3 25 ps/nm -35 20 Return loss dB 40 45 Directivity dB Thermal stability (center λ drift) Operating temperature range Optical power handling pm/ C 0.2 C -5 mW 500 +70 - SC/PC or LC/PC, others upon request m 1.0±0.1, others upon request mm 92x42x10.6 Connector type Pigtail length Dimensions (L x W x H) Note#1: Over all operating temperatures Note#2: Connector loss included Note#3: Specification change without notice. 55 o o 0.5 Finisar Shanghai Inc. No. 66 Huiqing Rd., East Zhangjiang Hi-Tech Park, Shanghai, China 201201 Main: +86-21-38559200 Fax: +86-21-68919894 Website: www.finisar.com Finisar Corporation 1389 Moffett Park Drive, Sunnyvale, CA 94089-1134, USA Main: (408) 548-1000 Fax: (408)541-6129 Email: sales@finisar.com Website: www.finisar.com Aug 2011 Rev. A Finisar Package Dimensions: (Unit: mm) Definition of the Optical Parameters: Ordering Information Part Number Description FINF050-100WCLL1 50/100GHZ interleaver, C band, SC/PC connector FINF050-100WCLL2 50/100GHZ interleaver, C band, LC/PC connector Finisar Shanghai Inc. No. 66 Huiqing Rd., East Zhangjiang Hi-Tech Park, Shanghai, China 201201 Main: +86-21-38559200 Fax: +86-21-68919894 Website: www.finisar.com Finisar Corporation 1389 Moffett Park Drive, Sunnyvale, CA 94089-1134, USA Main: (408) 548-1000 Fax: (408)541-6129 Email: sales@finisar.com Website: www.finisar.com Aug 2011 Rev. A
FINF050-100WCLL2 价格&库存
很抱歉,暂时无法提供与“FINF050-100WCLL2”相匹配的价格&库存,您可以联系我们找货
