FTL4P1QM1C
FTL4P1QM1C
    II-VI
    TRANSCEIVER QSFP, 10KM, 4X10GBAS
FTL4P1QM1C 数据手册
Finisar Preliminary Product Specification 4x10GBASE-LR/W & OTN QSFP+ Optical Transceiver Module FTL4P1QM1C 9B PRODUCT FEATURES  Hot-pluggable QSFP+ form factor  Supports 4 independent streams of 10G Ethernet or OTN data  Power dissipation < 2.5W  RoHS-6 compliant  Commercial case temperature range 0°C to 70°C  Single 3.3V power supply  Maximum link length of 10km on Single Mode Fiber (SMF) APPLICATIONS  XLPPI electrical interface  10GBASE-LR/LW 10G Ethernet  MPO12 receptacle  OTU2, OTU1e, OTU2e 1 1  Built-in digital diagnostic functions, including Tx/Rx power monitoring Finisar’s FTL4P1QE1C QSFP+ transceiver modules are designed for use in high density 10 Gigabit Ethernet links over single mode fiber. They are compliant with the QSFP+ MSA1,2, IEEE 802.3ae 10GBASE-LR/LW3, and OTN data rates OTU2, OTU1e, and OTU2e per the ITU4. Digital diagnostics functions are available via an I2C interface, as specified by the QSFP+ MSA. The transceiver is RoHS compliant per Directive 2011/65/EU5 and Finisar Application Note AN-20386. 3B PRODUCT SELECTION FTL4P1QM1C 4: P1: Q: M: 1: C:  Finisar Corporation – 12-Jan-15 Rev A7 4 channel module Parallel single mode QSFP+ form factor Multiprotocol optical interface First generation product Commercial temperature range Finisar Confidential Page 1 FTL4P1QM1C PRELIMINARY Product Specification – January 2015 I. Finisar Pin Descriptions Figure 1 – QSFP+ MSA-compliant 38-pin connector Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Symbol GND Tx2n Tx2p GND Tx4n Tx4p GND ModSelL ResetL Vcc Rx SCL SDA GND Rx3p Rx3n GND Rx1p Rx1n GND GND Rx2n Rx2p GND Rx4n Rx4p 6B Name/Description Ground Transmitter Inverted Data Input Transmitter Non-Inverted Data Input Ground Transmitter Inverted Data Input Transmitter Non-Inverted Data Input Ground Module Select Module Reset +3.3 V Power supply receiver 2-wire serial interface clock 2-wire serial interface data Ground Receiver Non-Inverted Data Output Receiver Inverted Data Output Ground Receiver Non-Inverted Data Output Receiver Inverted Data Output Ground Ground Receiver Inverted Data Output Receiver Non-Inverted Data Output Ground Receiver Inverted Data Output Receiver Non-Inverted Data Output  Finisar Corporation – 12-Jan-15 Rev A7 Finisar Confidential Notes 1 1 1 1 1 1 1 1 Page 2 Finisar FTL4P1QM1C PRELIMINARY Product Specification – January 2015 26 27 28 29 30 31 32 33 34 35 36 37 38 GND ModPrsL IntL Vcc Tx Vcc1 LPMode GND Tx3p Tx3n GND Tx1p Tx1n GND Ground Module Present Interrupt +3.3 V Power supply transmitter +3.3 V Power Supply Low Power Mode Ground Transmitter Non-Inverted Data Input Transmitter Inverted Data Input Ground Transmitter Non-Inverted Data Input Transmitter Inverted Data Input Ground 1 1 1 1 Notes 1. Circuit ground is internally isolated from chassis ground. U II. 0B General Product Characteristics Parameter Module Form Factor Maximum Aggregate Data Rate Maximum Data Rate per Lane Protocols Supported Electrical Interface and Pin-out Value QSFP+ 44.4 11.095 10G Ethernet 38-pin edge connector Unit Maximum Power Consumption Management Interface 2.5 Serial, I2C-based, 400 kHz maximum frequency Watts Data Rate Specifications Bit Rate per Lane Bit Error Ratio Link distance on SMF-28 Symbol BR BER d Min 9.95 Notes Gb/s Gb/s Pin-out as defined by the QSFP+ MSA As defined by the QSFP+ MSA Typ Max 11.10 10-12 10 Units Gb/sec Ref. 1 2 kilometers Notes : 1. Compliant with 10GBASE-LR/LW, OTU2, OTU1e, and OTU2e and XLPPI. 2. Tested with a PRBS 231-1 test pattern. U U  Finisar Corporation – 12-Jan-15 Rev A7 Finisar Confidential Page 3 Finisar FTL4P1QM1C PRELIMINARY Product Specification – January 2015 III. Absolute Maximum Ratings 1 Parameter Maximum Supply Voltage Storage Temperature Case Operating Temperature Relative Humidity Damage Threshold, per Lane Symbol Vcc1, VccTx, VccRx TS TOP RH DT Min -0.5 Typ Max 3.6 Unit V 85 70 85 C C % dBm -40 0 0 3.4 Ref. 1 Notes : 1. Non-condensing. U IV. U Electrical Characteristics (TOP = 0 to 70C, VCC = 3.1 to 3.47 Volts) 1B Parameter Supply Voltage Supply Current Link turn-on time Transmit turn-on time Transmitter (per Lane) Single ended input voltage tolerance Differential data input swing Differential input threshold AC common mode input voltage tolerance (RMS) Differential input return loss Symbol Vcc1, VccTx, VccRx Icc VinT Vin,pp 3.1 Max Unit 3.47 V TBD A  ms  V mVpp mV -0.3 120 4.0 1200 50 15 Jt2 Jt9 DDPWS Differential data output swing Vout,pp AC common mode output voltage (RMS) Termination mismatch at 1 MHx Differential output return loss Common mode output return loss  Finisar Corporation – 12-Jan-15 Rev A7 Typ 2000 J2 Jitter Tolerance J9 Jitter Tolerance Data Dependent Pulse Width Shrinkage Eye mask coordinates {X1, X2 Y1, Y2} Receiver (per Lane) Single-ended output voltage Output transition time, 20% to 80% J2 Jitter output J9 Jitter output Min Jo2 Jo9 Finisar Confidential Per IEEE P802.3ba, Section 86A.4.1.1 0.17 0.29 0.07 0.11, 0.31 95, 350 -0.3 200 300 400 600 4.0 400 600 800 1200 7.5 5 Per IEEE P802.3ba, Section 86A.4.2.1 Per IEEE P802.3ba, Section 86A.4.2.2 28 0.42 0.65 Ref. 1 2 3 mV dB 4 UI UI UI UI mV  V mVpp 5 6,7 mV % dB 4 dB 4 ps UI UI Page 4 Finisar FTL4P1QM1C PRELIMINARY Product Specification – January 2015 Eye mask coordinates #1 {X1, X2 0.29, 0.5 UI Y1, Y2} 150, 425 mV Power Supply Ripple Tolerance PSR 50 mVpp Notes : 1. Maximum total power value is specified across the full temperature and voltage range. 2. From power-on and end of any fault conditions. 3. After internal AC coupling. Self-biasing 100 differential input. 4. 10 MHz to 11.1 GHz range. 5. Hit ratio = 5 x 10E-5. 6. AC coupled with 100 differential output impedance. 7. Output voltage settable in four discrete ranges via I2C command. U 5 U V. Optical Characteristics (TOP = 0 to 70C, VCC = 3.1 to 3.47 Volts) Parameter Transmitter Signaling Speed per Lane Lane center wavelength Transmit OMA per Lane Transmitter and Dispersion Penalty Average Launch Power per Lane Tranmit OMA per lane minus TDP Optical Extinction Ratio Sidemode Suppression ratio Average launch power of OFF transmitter, per lane Relative Intensity Noise Tx Jitter Transmitter Reflectance Transmitter eye mask definition Receiver Signaling Speed per Lane Lane center wavelength Average Receive Power per Lane Receiver Sensitivity (OMA) per Lane Stressed Receiver Sensitivity (OMA) per Lane Damage Threshold per Lane Return Loss Receive electrical 3 dB upper cutoff frequency, per lane LOS De-Assert LOS Assert LOS Hysteresis Symbol λ TxOMA TDP TXPx ER SSRmin Min Typ 9.95 1290 -5.2 Max 10.095 1330 3.0 3.2 -1.0 -6.0 -6.2 6.0 30 -30 RIN Txj λ RXPx Rxsens SRS -128 20 -12 Per 802.3ae, G.693, and G.691 9.95 1260 -14.4 PMAX RL LOSD LOSA -30 0.5 Unit  GBd Ref. 1 dBm dB dBm dBm dB dB dBm 2 dB/Hz dB dB 3  GBd 10.095 1355 0.5 -12.6 -10.3 dBm dBm dBm 1.5 -14 12.3 dBm dB GHz -14 -17 dBm dBm dB 4 5 Notes : 1. Transmitter consists of 4 lasers operating between 9.95 and 11.10 Gb/s each. 2. Minimum value is informative. 3. RIN is scaled by 10*log(10/4) to maintain SNR outside of transmitter. 4. Receiver consists of 4 photodetectors operating between 9.95 and 11.10 Gb/s each. 5. Minimum value is informative, equals min TxOMA with infinite ER and max channel insertion loss. U U  Finisar Corporation – 12-Jan-15 Rev A7 Finisar Confidential Page 5 Finisar FTL4P1QM1C PRELIMINARY Product Specification – January 2015 VI. Digital Diagnostic Specifications FTL4P1QM1C transceivers can be used in host systems that require either internally or externally calibrated digital diagnostics. 5 Notes: 1. Accuracy of measured Tx bias current is 10% of the actual bias current from the laser driver to the laser. VII. Memory Map and Control Registers Compatible with SFF-8436 (QSFP+). Please see Finisar Application Note AN-21047. VIII. Environmental Specifications Finisar FTL4P1QM1C transceivers have an operating temperature range from 0°C to +70°C case temperature. Environmental Specifications Case Operating Temperature Storage Temperature  Finisar Corporation – 12-Jan-15 Rev A7 Symbol Min Top Tsto 0 -40 Finisar Confidential Typ Max Units 70 85 °C °C Ref. Page 6 FTL4P1QM1C PRELIMINARY Product Specification – January 2015 IX. Finisar Regulatory Compliance Finisar FTL4P1QM1C transceivers are RoHS-6 Compliant. Copies of certificates are available at Finisar Corporation upon request. FTL4P1QM1C transceiver modules are Class 1 laser eye safety compliant per IEC 60825-1. X. Mechanical Specifications The FTL4P1QM1C mechanical specifications are compliant to the QSFP+ MSA transceiver module specifications. Figure 2 – FTL4P1QM1C mechanical drawing The FTL4P1QM1C pull tab color is dark blue Pantone 2748.  Finisar Corporation – 12-Jan-15 Rev A7 Finisar Confidential Page 7 FTL4P1QM1C PRELIMINARY Product Specification – January 2015 Finisar Figure 3 – FTL4P1QM1C label (not to scale) The FTL4P1QM1C optical interface accepts an 8º angled MPO connector, with lane assignments as shown in Figure 4. Figure 4 – FTL4P1QM1C optical lane assignment (front view of MPO receptacle)  Finisar Corporation – 12-Jan-15 Rev A7 Finisar Confidential Page 8 FTL4P1QM1C PRELIMINARY Product Specification – January 2015 XI. Finisar References 1. SFF-8436 – Specification for QSFP+ 10 Gbs 4x Pluggable Transceiver, Rev 4.8, October 2013. 2. SFF-8636 – Specification for Common Management Interface, Rev 1.7, January 2014. 3. 802.3-2012, IEEE Standard for Ethernet, Section 4, Clause 52, PMD Types 10GBASE-LR/LW. 4. ITU-T G.959.1 – Optical Transport Network Phusical Layer Interfaces, 02/2012 and ITU-T G.709/Y.1331 – Interfaces for the Optical Transport Network (OTN), 02/2012 5. Directive 2011/65/EU of the European Council Parliament and of the Council, “on the restriction of the use of certain hazardous substances in electrical and electronic equipment,” June 8, 2011, which supercedes the previous RoHS Directive 2002/95/EC. 6. “Application Note AN-2038: Finisar Implementation of RoHS Compliant Transceivers”, Finisar Corporation, January 21, 2005. 7. “Application Note AN-2104: QSFP+ 40G LR4 Transceiver EEPROM Mapping,” Rev. A, Finisar Corporation, June, 2013. XII. For More Information Finisar Corporation 1389 Moffett Park Drive Sunnyvale, CA 94089-1133 Tel. 1-408-548-1000 Fax 1-408-541-6138 sales@finisar.com www.finisar.com U U U U  Finisar Corporation – 12-Jan-15 Rev A7 Finisar Confidential Page 9
FTL4P1QM1C 价格&库存
很抱歉,暂时无法提供与“FTL4P1QM1C”相匹配的价格&库存,您可以联系我们找货
