FTLF8538P4BCV
FTLF8538P4BCV
    II-VI
    850NM OXIDE VCSEL 25GBE 25.78 G
FTLF8538P4BCV 数据手册
Product Specification 25.78Gb/s 10GE RoHS Compliant Short Wavelength SFP+ Transceiver FTLF8538P4BCV PRODUCT FEATURES  Up to 25.78 Gb/s bi-directional data links  Hot-pluggable SFP+ footprint  Built-in digital diagnostic functions  850nm Oxide VCSEL laser transmitter  Duplex LC connector  RoHS compliant  100m over M5F MMF (50/125 um OM4)  70m over M5E MMF (50/125um OM3)  20m on MMF (50/125m OM2)  Metal enclosure, for lower EMI  1.2W maximum power consumption  Single 3.3V power supply  25GE SR, 10GE SR Lite  Operating temperature range:  100G SR4 fan out to 4x25GE SR  eCPRI 0°C to 70°C APPLICATIONS Finisar’s FTLF8538P4BCV SFP+ transceivers are designed for use in 25Gb/s data rate over multimode fiber. They are compliant to IEEE802.3by, SFF-8472 Rev 12.2b and SFF-8402g, and compatible with SFF-8432a and applicable portions of SFF-8431 Rev. 4.1c. The transceiver is RoHS compliant and per Directive 2011/65/EUd . See Finisar Application Note AN-2038 for more details. PRODUCT SELECTION FTLF8538P4BCV  Finisar Corporation - Apr 2017 Rev B Finisar Confidential Page 1 FTLF8538P4BCV Product Specification I. Pin Descriptions Pin 1 2 3 4 5 6 7 Symbol VEET TFAULT TDIS SDA SCA MOD_ABS RS0 8 9 LOS RS1 10 11 12 13 14 15 16 17 18 19 20 VEER VEER RDRD+ VEER VCCR VCCT VEET TD+ TDVEET Name/Description Transmitter Ground (Common with Receiver Ground) Transmitter Fault. Transmitter Disable. Laser output disabled on high or open. 2-wire Serial Interface Data Line (MOD-DEF2) 2-wire Serial Interface Clock (MOD-DEF1) Module Absent, connected to VEET or VEER Rx Rate Select: Open or Low = 10.3 Gb/s Ethernet (Low Bandwidth) High = 25.78 Gb/s Ethernet (High Bandwidth) Loss of Signal indication. Logic 0 indicates normal operation. Rx Rate Select: Open or Low = 10.3 Gb/s Ethernet (Low Bandwidth) High = 25.78 Gb/s Ethernet (High Bandwidth) Receiver Ground (Common with Transmitter Ground) Receiver Ground (Common with Transmitter Ground) Receiver Inverted DATA out. AC Coupled Receiver Non-inverted DATA out. AC Coupled Receiver Ground (Common with Transmitter Ground) Receiver Power Supply Transmitter Power Supply Transmitter Ground (Common with Receiver Ground) Transmitter Non-Inverted DATA in. AC Coupled. Transmitter Inverted DATA in. AC Coupled. Transmitter Ground (Common with Receiver Ground) Ref. 1 2 3 4 4 4 5 6 5 1 1 1 1 1 Notes: 1. Circuit ground is internally isolated from chassis ground. 2. TFAULT is an open collector/drain output, which should be pulled up with a 4.7k – 10k Ohms resistor on the host board if intended for use. Pull up voltage should be between 2.0V to Vcc + 0.3V. A high output indicates a transmitter fault caused by either the TX bias current or the TX output power exceeding the preset alarm thresholds. A low output indicates normal operation. In the low state, the output is pulled to 2.0V or open, enabled on TDIS
FTLF8538P4BCV 价格&库存
很抱歉,暂时无法提供与“FTLF8538P4BCV”相匹配的价格&库存,您可以联系我们找货
