FTLX8574D3BCV
FTLX8574D3BCV
    II-VI
    收发器模块 以太网 10.3Gbps 850nm 3.3V LC 双工 可插入式,SFP+
FTLX8574D3BCV 数据手册
Product Specification 1G/10G 850nm Multimode Datacom SFP+ Transceiver FTLX8574D3BCV PRODUCT FEATURES • Hot-pluggable SFP+ footprint • Supports rate selectable 1.25 Gb/s or 9.95 to 10.3 Gb/s bit rates • Power dissipation < 1W • RoHS-6 compliant (lead-free) • Commercial temperature range -5°C to 70°C • Single 3.3V power supply • Maximum link length of 400m on OM4 MMF • Uncooled 850nm VCSEL laser • Receiver limiting electrical interface . APPLICATIONS • 1000BASE-SX 1G Ethernet • • Duplex LC connector • Built-in digital diagnostic functions 10GBASE-SR/SW 10G Ethernet Finisar’s FTLX8574D3BCV 1G/10G Dual-Rate SFP+ transceivers are designed for use in 1-Gigabit and 10-Gigabit Ethernet links over multimode fiber. They are compliant with SFF-84311, IEEE 802.3-2012 10GBASE-SR/SW2 and 1000BASE-SX3. Digital diagnostics functions are available via a 2-wire serial interface, as specified in SFF84724. The FTLX8574D3BCV is a “limiting module”, i.e., it employs a limiting receiver. Host board designers using an EDC PHY IC should follow the IC manufacturer’s recommended settings for interoperability with an SFP+ limiting module. This product is for applications specifically designed for 10G SFP+ ports and 1G/10G SFP+ ports and not native 1G SFP ports. The optical transceiver is compliant per the RoHS Directive 2011/65/EU5. See Finisar Application Note AN-20386 for more details. PRODUCT SELECTION FTLX8574D3BCV  Finisar Corporation - June 2015 Rev. B Page 1 FTLX8574D3BCV Product Specification I. Pin Descriptions Pin 1 2 3 4 5 6 Symbol VEET TFAULT TDIS SDA SCL MOD_ABS 7 RS0 8 9 10 11 12 13 14 15 16 17 18 19 20 Notes: 1. 2. RX_LOS RS1 VEER VEER RDRD+ VEER VCCR VCCT VEET TD+ TDVEET Name/Description Transmitter Ground (Common with Receiver Ground) Transmitter Fault. Transmitter Disable. Laser output disabled on high or open. 2-wire Serial Interface Data Line 2-wire Serial Interface Clock Line Module Absent. Grounded within the module RS0 for Rate Select: Open or Low = Module supports 1.25 Gb/s High = Module supports 9.95 Gb/s to 10.3125 Gb/s Loss of Signal indication. Logic 0 indicates normal operation. No connection required Receiver Ground (Common with Transmitter Ground) Receiver Ground (Common with Transmitter Ground) Receiver Inverted DATA out. AC Coupled Receiver Non-inverted DATA out. AC Coupled Receiver Ground (Common with Transmitter Ground) Receiver Power Supply Transmitter Power Supply Transmitter Ground (Common with Receiver Ground) Transmitter Non-Inverted DATA in. AC Coupled. Transmitter Inverted DATA in. AC Coupled. Transmitter Ground (Common with Receiver Ground) Ref. 1 2 3 4 4 4 5 6 1 1 1 1 1 Circuit ground is internally isolated from chassis ground. T is an open collector/drain output, which should be pulled up with a 4.7k – 10k Ohms resistor on the host board FAULT if intended for use. Pull up voltage should be between 2.0V to Vcc + 0.3V. A high output indicates a transmitter fault caused by either the TX bias current or the TX output power exceeding the preset alarm thresholds. A low output indicates normal operation. In the low state, the output is pulled to 2.0V or open, enabled on TDIS
FTLX8574D3BCV 价格&库存
很抱歉,暂时无法提供与“FTLX8574D3BCV”相匹配的价格&库存,您可以联系我们找货
