FTLX8574D3BNL
FTLX8574D3BNL
    II-VI
    收发器模块 以太网,光纤通道 10.5Gbps 850nm 3.3V LC 双工 可插入式,SFP+
FTLX8574D3BNL 数据手册
Product Specification Extended Temperature 10Gb/s 850nm SFP+ Datacom Transceiver FTLX8574D3BNL PRODUCT FEATURES • Hot-pluggable SFP+ footprint • Supports 9.95 to 10.5 Gb/s bit rates* • Power dissipation < 1W • RoHS-6 compliant (lead-free) • Commercial temperature range -5°C to 85°C • Single 3.3Vpower supply • Maximum link length of 400m on OM4 MMF • Uncooled 850nm VCSEL laser • Receiver limiting electrical interface • Duplex LC connector • Built-in digital diagnostic functions APPLICATIONS • 10GBASE-SR/SW 10G Ethernet • 1200-Mx-SN-I 10G Fibre Channel Finisar’s FTLX8574D3BNL Extended Temperature 10Gb/s SFP+ transceivers are designed for use in 10-Gigabit Ethernet links over multimode fiber. They are compliant with SFF-84311, SFF-84322, IEEE 802.3-2012 10GBASE-SR/SW3 and 10G Fibre Channel 1200-Mx-SN-I4. Digital diagnostics functions are available via a 2-wire serial interface, as specified in SFF-84725. The FTLX8574D3BNL is a “limiting module”, i.e., it employs a limiting receiver. Host board designers using an EDC PHY IC should follow the IC manufacturer’s recommended settings for interoperating the host-board EDC PHY with a limiting receiver SFP+ module. The optical transceiver is compliant per the RoHS Directive 2011/65/EU6. See Finisar Application Note AN-20387 for more details. PRODUCT SELECTION FTLX8574D3BNL *Contact Finisar for higher data-rate support up to 11.1Gbps.  Finisar Corporation - April 2015 Rev. A1 Page 1 FTLX8574D3BNL Product Specification I. Pin Descriptions Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Symbol VEET TFAULT TDIS SDA SCL MOD_ABS RS0 RX_LOS RS1 VEER VEER RDRD+ VEER VCCR VCCT VEET TD+ TDVEET Name/Description Transmitter Ground (Common with Receiver Ground) Transmitter Fault. Transmitter Disable. Laser output disabled on high or open. 2-wire Serial Interface Data Line 2-wire Serial Interface Clock Line Module Absent. Grounded within the module No connection required Loss of Signal indication. Logic 0 indicates normal operation. No connection required Receiver Ground (Common with Transmitter Ground) Receiver Ground (Common with Transmitter Ground) Receiver Inverted DATA out. AC Coupled Receiver Non-inverted DATA out. AC Coupled Receiver Ground (Common with Transmitter Ground) Receiver Power Supply Transmitter Power Supply Transmitter Ground (Common with Receiver Ground) Transmitter Non-Inverted DATA in. AC Coupled. Transmitter Inverted DATA in. AC Coupled. Transmitter Ground (Common with Receiver Ground) Ref. 1 2 3 4 4 4 5 1 1 1 1 1 Notes: 1. Circuit ground is internally isolated from chassis ground. is an open collector/drain output, which should be pulled up with a 4.7k – 10k Ohms resistor on 2. T FAULT 3. 4. 5. the host board if intended for use. Pull up voltage should be between 2.0V to Vcc + 0.3V. A high output indicates a transmitter fault caused by either the TX bias current or the TX output power exceeding the preset alarm thresholds. A low output indicates normal operation. In the low state, the output is pulled to 2.0V or open, enabled on TDIS
FTLX8574D3BNL 价格&库存
很抱歉,暂时无法提供与“FTLX8574D3BNL”相匹配的价格&库存,您可以联系我们找货
