FTXD02SL1C
FTXD02SL1C
    II-VI
    MOD TX VCSEL 12X2.5G SNAP12
FTXD02SL1C 数据手册
Finisar Product Specification SNAP12 Parallel Transmitter and Receiver Modules Commercial Temperature FTXD02SL1C / FRXD02SL1C PRODUCT FEATURES  12-channel transmitter and receiver modules  SNAP12 form factor  Multirate capability: 1Gb/s to 2.7Gb/s per channel  Maximum link length of 600m at 2.5Gb/s on OM3 Multimode Fiber (MMF)  Unretimed electrical interface  3.3V power supply required  Reliable VCSEL array technology  Commercial operating case temperature range of -5ºC to 75ºC  MPO type connector  RoHS-6 compliant (lead-free) Product Photo APPLICATIONS  Interchassis connections Finisar’s SNAP12 transmitter and receiver modules are designed to be used in links of up to 32 Gigabit per second over multimode fiber. They are RoHS-6 compliant and leadfree per Directive 2002/95/EC1, and Finisar Application Note AN-20382 PRODUCT SELECTION Part Number Description FTXD02SL1C 12-channel SNAP12 transmitter module, commercial temperature FRXD02SL1C 12-channel SNAP12 receiver module, commercial temperature  Finisar Corporation – 28-March-2013 Rev A5 Page 1 Finisar SNAP12 Modules Product Specification – March 2013 I. Transmitter Pin Assignment K J H G F E D C B A 1 NIC NIC NIC GND GND GND GND GND GND NIC 2 NIC NIC NIC NIC NIC GND GND DIN6P GND GND DIN9P GND 3 NIC NIC VCC VCC GND DIN5P DIN6N GND DIN8P DIN9N GND 4 NIC NIC VCC VCC DIN4P DIN5N GND DIN7P DIN8N GND NIC 5 NIC NIC VCC VCC VCC VCC DIN4N GND DIN3P DIN7N GND DIN10n GND 6 NIC VCC VCC GND DIN2P DIN3N GND DIN11n DIN10p GND 7 NIC NIC NIC NIC DIN1P DIN2N GND DIN12n DIN11p GND NIC 8 NIC NIC RESET- FAULT- DIN1N GND GND DIN12p GND GND NIC 9 NIC NIC TXEN TXDIS GND GND GND GND GND GND NIC NIC 10 NIC NIC SDA SCL NIC NIC NIC NIC NIC NIC NIC Figure 1 – Transmitter 100pin MSA connector assignments as viewed from the topside of the customer line card (Toward MPO connector end of module) Signal Name Din[12:1]P Din[12:1]N NIC GND ResetFAULT– TXDIS TXEN SDA SCL Vcc Signal Description Transmitter Data Non-inverting Input for channels 11 through 0 Transmitter Data Inverting Input for channels 11 through 0 Reserved – Do Not Connect to any voltage on Host PCB Signal Common ground Reset signal to module, Asserted Low. Internal pullup. Transmitter Fault indicator. Logical Low indicates fault Laser disable; LOW = normal operation if TXEN normal; HIGH = lasers off; internal pull-down, Laser enable; HIGH = normal operation if TXDIS normal; LOW = lasers off; internal pull-up. I2C data signal, internal pull-up with a 10 kΩ resistor. I2C clock signal. Internal pull-up with a 10kΩ resistor. 3.3 V Power supply, external common connection of pins required – not common internally  Finisar Corporation – 28-March-2013 Rev A5 I/O I I Type CML CML I O I LVTTL I LVTTL I/O I Page 2 Finisar SNAP12 Modules Product Specification – March 2013 II. Receiver Pin Assignment K J H G F E D C B A 1 Vpp NIC NIC GND GND GND GND GND GND NIC 2 Vpp NIC NIC NIC NIC GND GND DOUT6N GND GND DOUT9N GND 3 NIC NIC VCC VCC GND DOUT5N DOUT6P GND DOUT8N DOUT9P GND 4 NIC NIC VCC VCC DOUT4N DOUT5P GND DOUT7N DOUT8P GND NIC 5 NIC NIC VCC VCC VCC VCC DOUT4P GND DOUT3N DOUT7P GND DOUT10p GND 6 NIC VCC VCC GND DOUT2N DOUT3P GND DOUT11p DOUT10n GND 7 NIC NIC NIC SD DOUT1N DOUT2P GND DOUT12p DOUT11n GND NIC 8 NIC Vpp -SD12 SD1 DOUT1P GND GND DOUT12n GND GND NIC 9 NIC Vpp RXEN ENSD GND GND GND GND GND GND NIC NIC 10 NIC SQEN SDA SCL NIC NIC NIC NIC NIC NIC NIC Figure 2 – Receiver 100pin MSA connector assignments as viewed from the topside of the customer line card (Toward MPO connector end of module) Signal Name DOUT[12:1]P DOUT[12:1]N NIC GND SDA SCL SQEN ENSD RXEN SD SD1 Vcc Vpp Signal Description Receiver Data Non-inverting Input for channels 11 through 0 Receiver Data Inverting Input for channels 11 through 0 Reserved – Do Not Connect to any voltage on Host PCB Signal Common ground I2C data signal. Internal pull-up with a 10 kΩ resistor. I2C clock signal. Internal pull-up with a 10 kΩ resistor. Squelch enable; HIGH = all data outputs driven to logic zero when SD is active (LOW); LOW = squelch disabled; internal pull-up Signal detect enable; HIGH = normal operation; LOW = signal detect output(s) forced active; internal pull-up Output enable; HIGH = normal operation; LOW = receiver disabled; internal pull-up Global signal detect; HIGH = normal operation; LOW = inadequate power on one or more channels Signal detect channel 1; HIGH = normal operation; LOW = inadequate power on channel 1 3.3 V Power supply, external common connection of pins required Not required on this product. Pads not internally connected.  Finisar Corporation – 28-March-2013 Rev A5 I/O I I Type CML CML I/O I I LVTTL I LVTTL I LVTTL O LVTTL O LVTTL I I Page 3 Finisar SNAP12 Modules Product Specification – March 2013 III. Absolute Maximum Ratings The following table represents the absolute maximum ratings for the SNAP12 transmitter and receiver modules. Absolute maximum is defined as the maximum point of exertion without permanent damage to the SNAP12 modules. Parameter Storage case temperature range Symbol TS Min -40 Max 85 Unit o C Ref. 1 500 V 2 Static discharge voltage ESD Relative humidity (non-condensing) RH 5 95 % Supply voltage VCC -0.5 +3.6 V Notes: 1. Operation guaranteed for bit rates up to 2.7 Gbps. 2. Human Body Model (HBM). IV. Power Supply Information Parameter Symbol Vcc Supply voltage Steady supply current Min 3.13 Typ 3.30 Max 3.47 Unit V Ref. 1, 2 Transmitter module ICC 350 420 mA 1, 2 Receiver module ICC 400 450 mA 1, 2 Notes: 1. Performance will be guaranteed as long as the supply voltage range is within the defined parameters. V. Transmission Specification Bit rate Fiber link length @2.5Gbps Parameter Transmitter (per channel) Min 1 Typ 2.5 Max 2.7 Unit Gbps 1 2.5 2.7 Gbps 500 MHz∙km 50μm MMF 300 m 1 2000 MHz∙km 50μm MMF 600 m 1 Receiver (per channel) Ref. Notes: 1. BER
FTXD02SL1C 价格&库存
很抱歉,暂时无法提供与“FTXD02SL1C”相匹配的价格&库存,您可以联系我们找货
