6576PC
6576PC
    FLAMBEAU
    塑料 - 未指定 元件储存 黑色 独立抽屉 16.500" 长 x 12.000" 宽(419.10mm x 304.80mm) X 6.250"(158.75mm)
6576PC 数据手册
STORAGE PRODUCTS Parts Station Storage Cabinet Catalog #: C26P Description Reduce costs and maximize storage space with the reinforced, durable 12" x 6 1/4" x 16 1/2" (30.48 x 15.88 x 41.91 cm) Parts Station plastic frame storage cabinet. Each drawer cabinet contains styrene translucent drawers and drawer stops that prevent accidental spills. The Rototower has a heavy-duty, tip-resistant steel base with slip-proof feet. A ball-bearing rotating system aids in maneuverability. Specifications Catalog # C26P Stock Number 6576PC Division Code 612 Compartments 1 Color Clear|Gray Material HIPS) Styrene (S) Outside Overall: 12" x 6 1/4" x 16 1/2" (M) Outside Overall: 30.48 x 15.88 x 41.91 cm (S) Outside Length: 0.00000 (S) Outside Width: 0.00000 (S) Outside Depth: 0.00000 (M) Outside Length: 0.00000 (M) Outside Width: 0.00000 (M) Outside Depth: 0.00000 (S) Inside Length: 0.00000 (S) Inside Width: 0.00000 (S) Inside Depth: 0.00000 (M) Inside Length: 0.00000 (M) Inside Width: 0.00000 (M) Inside Depth: 0.00000 Accessories: 1108|1109|1110|1111|1112|1113|1114|1
6576PC 价格&库存
很抱歉,暂时无法提供与“6576PC”相匹配的价格&库存,您可以联系我们找货
