FLIR T600-15
FLIR T600-15
    FLIR(菲力尔)
    FLIR T600 IR CAMERA 480 X 360 RE
FLIR T600-15 数据手册
FLIR T600 15° (incl. Wi-Fi) P/N: 55903-0922 Copyright © 2014, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: 55903-0922 Release: Commit: 15419 Language: en-US Modified: 2014-06-19 Formatted: 2014-06-22 Corporate Headquarters FLIR Systems, Inc. 27700 SW Parkway Ave. Wilsonville, OR 97070 USA Telephone: +1-503-498-3547 Website http://www.flir.com Customer support http://support.flir.com Disclaimer Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. General description The FLIR T600 is designed for the expert requiring the highest performance and the latest technology available. The camera combines excellent ergonomics and a walk-up-and-use interface with superior image quality of 480 × 360 pixel IR resolution. The T600 is flexible and can meet your every need, and has extensive communication options. Benefits: • • • Highest performance with the latest technology: The T600 camera is equipped with the innovative ‘Multi Spectral Dynamic Imaging (MSX)’ feature, which produces an image richer in detail than ever before. Ground-breaking efficiency: You can highlight objects of interest, on both the IR and the visual images, by sketching or adding pre-defined stamps directly on the camera’s capacitive touch screen. The user interface is intuitive and logical for effective operation. Auto-orientation allows you to tilt between landscape and portrait views. Extensive communication options: The Wi-Fi connectivity of the T600 allows you to connect to smart phones or tablet PCs for the wireless transfer of images or the remote control of the camera. The Bluetooth-based Meterlink function transfers readings from external measurement instruments to the IR image. Imaging and optical data 1 (16) IR resolution 480 × 360 pixels Thermal sensitivity/NETD 2.5 hours at 25°C (+68°F) and typical use Charging system In camera (AC adapter or 12 V from a vehicle) or 2-bay charger Charging time 2.5 h to 90 % capacity, charging status indicated by LED's Charging temperature 0°C to +45°C (+32°F to +113°F) External power operation AC adapter 90–260 VAC, 50/60 Hz or 12 V from a vehicle (cable with standard plug, optional) Power management Automatic shutdown and sleep mode (user selectable) #55903-0922; r. -/15419; en-US Environmental data Operating temperature range –15°C to +50°C (+5°F to +122°F) Storage temperature range –40°C to +70°C (–40°F to +158°F) Humidity (operating and storage) IEC 60068-2-30/24 h 95% relative humidity +25° C to +40°C (+77°F to +104°F) / 2 cycles EMC Radio spectrum • • • • • • ETSI EN 301 489-1 (radio) ETSI EN 301 489-17 EN 61000-6-2 (Immunity) EN 61000-6-3 (Emission) FCC 47 CFR Part 15 Class B (Emission) ICES-003 • • • ETSI EN 300 328 FCC Part 15.247 RSS-210 Encapsulation IP 54 (IEC 60529) Bump 25 g (IEC 60068-2-29) Vibration 2 g (IEC 60068-2-6) Safety EN/UL/CSA/PSE 60950-1 Physical data 5 (16) Weight 1.33 kg (2.93 lb.) Size (L × W × H) 143 × 195 × 95 mm (5.6 × 7.7 × 3.7 in.) Camera size, excl. lens (L × W × H) 143 × 195 × 95 mm (5.6 × 7.7 × 3.7 in.) Tripod mounting UNC ¼"-20 Housing material Magnesium www.flir.com FLIR T600 15° (incl. Wi-Fi) P/N: 55903-0922 Shipping information © 2014, FLIR Systems, Inc. • • • • • • • • • • • • • • • • • #55903-0922; r. -/15419; en-US Infrared camera with lens Battery (2 ea.) Battery charger Bluetooth headset Calibration certificate FLIR Tools download card User documentation CD-ROM Printed documentation HDMI-DVI cable HDMI-HDMI cable Hard transport case Lens cap Memory card Neck strap Power supply, incl. multi-plugs Tripod adapter USB cable, Std A to Mini-B EAN-13 7332558006641 UPC-12 845188006990 Country of origin Sweden Supplies & accessories: • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 6 (16) T197914; IR lens, f=41.3 mm (15°) with case T197922; IR lens, f=24.6 mm (25°) with case T197915; IR lens, f=13.1 mm (45°) with case T198059; Close-up IR lens, 2.9× (50 µm) with case T198060; Close-up IR lens, 5.8× (100 µm) with case T198166; IR lens, f=88.9 mm (7°) with case and support for T6xx T198065; IR lens, f=6.5 mm (80°) with case T198066; Close-up IR lens, 1.5× (25 µm) with case T197896; High temp option +300°C to 2000°C (+572°F to 3632°F) for FLIR A6xxsc and T6xx T910814; Power supply, incl. multi plugs T198126; Battery charger, incl. power supply with multi plugs T6xx T198506; Li-Ion Battery pack 3.7V 29Wh T911230ACC; Memory card SDHC 4 GB 1910423; USB cable Std A Mini-B T198509; Cigarette lighter adapter kit, 12 VDC, 1.2 m/3.9 ft. T910930ACC; HDMI type C to DVI cable 1.5 m T910891ACC; HDMI type C to HDMI type A cable 1.5 m T198625ACC; Hard transport case for T6xx series T198495; Pouch for FLIR T6xx and T4xx series T198497; Large eyecup T198498; Tripod Adapter T198496; Stylus pen T198499; Neck strap T197771ACC; Bluetooth Headset T910972; EX845: Clamp meter + IR therm TRMS 1000A AC/DC T910973; MO297: Moisture meter, pinless with memory T911093; Tool belt T198586; FLIR Reporter Professional (license only) T198584; FLIR Tools T198583; FLIR Tools+ (license only) DSW-10000; FLIR IR Camera Player www.flir.com FLIR T600 15° (incl. Wi-Fi) P/N: 55903-0922 © 2014, FLIR Systems, Inc. #55903-0922; r. -/15419; en-US 7 (16) • • • • • • • • • • • • • • • APP-10002; FLIR Tools Mobile (Android Application) APP-10004; FLIR Tools (MacOS Application) T127597L5; FLIR ResearchIR 3 (license only), 5 user licenses T127597L10; FLIR ResearchIR 3 (license only), 10 user licenses T127598L5; FLIR ResearchIR 3 Max (license only), 5 user licenses T127598L10; FLIR ResearchIR 3 Max (license only), 10 user licenses T198696; FLIR ResearchIR Max 4 T198697; FLIR ResearchIR Max + HSDR 4 T198579; FLIR ResearchIR 3 (CD) T198578; FLIR ResearchIR 3 (license only) T198575; FLIR ResearchIR 3 Max (CD) T198574; FLIR ResearchIR 3 Max (license only) T198292; Upgrade previous version to FLIR ResearchIR 3 T198291; Upgrade previous version to FLIR ResearchIR 3 Max T198290; Upgrade FLIR ResearchIR 3 to FLIR ResearchIR 3 Max www.flir.com ‹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‹)/,56\VWHPV,QF$OOULJKWVUHVHUYHGZRUOGZLGH1RSDUWRIWKLVGUDZLQJPD\EHUHSURGXFHGVWRUHGLQDUHWULHYDOV\VWHPRUWUDQVPLWWHGLQDQ\IRUPRUE\DQ\PHDQVHOHFWURQLFPHFKDQLFDOSKRWRFRS\LQJUHFRUGLQJRURWKHUZLVH ZLWKRXWZULWWHQSHUPLVVLRQIURP)/,56\VWHPV,QF6SHFLILFDWLRQVVXEMHFWWRFKDQJHZLWKRXWIXUWKHUQRWLFH'LPHQVLRQDOGDWDLVEDVHGRQQRPLQDOYDOXHV3URGXFWVPD\EHVXEMHFWWRUHJLRQDOPDUNHWFRQVLGHUDWLRQV/LFHQVHSURFHGXUHVPD\DSSO\ 3URGXFWPD\EHVXEMHFWWR86([SRUW5HJXODWLRQV3OHDVHUHIHUWRH[SRUWTXHVWLRQV#IOLUFRPZLWKDQ\TXHVWLRQV'LYHUVLRQFRQWUDU\WR86ODZLVSURKLELWHG + * ) ( ' & % $    LQ PP LQ PP    &DPHUDZLWK/HQV,5I PP ƒ       LQ PP  -27$ &KHFN   7 'UDZLQJ1R  $ 6FDOH 6L]H $ * ) ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO  'HQRPLQDWLRQ 0RGLILHG  LQ PP LQ PP LQ PP ‹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ƒ     LQ PP   LQ  PP  LQ  PP -27$ &KHFN  7 'UDZLQJ1R  $ 6FDOH 6L]H $ ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO  'HQRPLQDWLRQ 0RGLILHG   LQ  PP LQ  PP ‹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ƒ       LQ PP  LQ  PP  -27$ &KHFN   7 'UDZLQJ1R  $ 6FDOH 6L]H $ ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO  'HQRPLQDWLRQ 0RGLILHG  LQ  PP  LQ  PP LQ PP ‹)/,56\VWHPV,QF$OOULJKWVUHVHUYHGZRUOGZLGH1RSDUWRIWKLVGUDZLQJPD\EHUHSURGXFHGVWRUHGLQDUHWULHYDOV\VWHPRUWUDQVPLWWHGLQDQ\IRUPRUE\DQ\PHDQVHOHFWURQLFPHFKDQLFDOSKRWRFRS\LQJUHFRUGLQJRURWKHUZLVH ZLWKRXWZULWWHQSHUPLVVLRQIURP)/,56\VWHPV,QF6SHFLILFDWLRQVVXEMHFWWRFKDQJHZLWKRXWIXUWKHUQRWLFH'LPHQVLRQDOGDWDLVEDVHGRQQRPLQDOYDOXHV3URGXFWVPD\EHVXEMHFWWRUHJLRQDOPDUNHWFRQVLGHUDWLRQV/LFHQVHSURFHGXUHVPD\DSSO\ 3URGXFWPD\EHVXEMHFWWR86([SRUW5HJXODWLRQV3OHDVHUHIHUWRH[SRUWTXHVWLRQV#IOLUFRPZLWKDQ\TXHVWLRQV'LYHUVLRQFRQWUDU\WR86ODZLVSURKLELWHG +  * *    ) LQ PP LQ PP  ) ( ' & % $  &DPHUDZLWK/HQV,5I PP ƒ      LQ PP  LQ  PP  -27$ &KHFN   7 'UDZLQJ1R  $ 6FDOH 6L]H $ ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO  'HQRPLQDWLRQ 0RGLILHG  LQ  PP LQ  PP LQ  PP ‹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ƒ LQFOVXSSRUW LQ  PP   LQ PP  LQ  PP    LQ  PP LQ PP  -27$ &KHFN  7 'UDZLQJ1R  $ 6FDOH 6L]H $ * ) ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO  'HQRPLQDWLRQ 0RGLILHG   LQ  PP  LQ  PP  ‹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—P     LQ PP  -27$ &KHFN   7 'UDZLQJ1R  $ 6FDOH 6L]H $ * ) ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO  'HQRPLQDWLRQ 0RGLILHG  LQ  PP LQ PP LQ  PP LQ  PP ‹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—P     LQ PP  LQ  PP  LQ  PP  7 'UDZLQJ1R  $ 6FDOH 6L]H $ * ) ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO -27$ &KHFN &ORVHXSOHQV &ORVHXSOHQV  ,5/HQVI PP ƒ  'HQRPLQDWLRQ 0RGLILHG  LQ PP LQ  PP LQ  PP LQ  PP  ‹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—P    LQ PP   LQ  PP  LQ  PP  -27$ &KHFN  7 'UDZLQJ1R  $ 6FDOH 6L]H $ * ) ( ' & % $   6L]H 6KHHW )RUDGGLWLRQDOGLPHQVLRQVVHHSDJH 5 '7KHUPRJUDSK\ 'UDZQE\  %DVLFGLPHQVLRQV)/,57[[PNOO  'HQRPLQDWLRQ 0RGLILHG  &ORVHXSOHQV ,5/HQVI PP ƒ &ORVHXSOHQV  LQ  PP LQ  PP LQ  PP
FLIR T600-15 价格&库存
很抱歉,暂时无法提供与“FLIR T600-15”相匹配的价格&库存,您可以联系我们找货
