FLIR C2-NIST
FLIR C2-NIST
    FLIR(菲力尔)
    FLIR C2 COMPACT PROFESSIONAL THE
FLIR C2-NIST 数据手册
FLIR C2 P/N: 72001-0101 Copyright © 2015, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: 72001-0101 Release: Commit: 22506 Language: en-US Modified: 2015-01-13 Formatted: 2015-01-13 Corporate Headquarters FLIR Systems, Inc. 27700 SW Parkway Ave. Wilsonville, OR 97070 USA Telephone: +1-503-498-3547 Imaging and optical data NETD 100 mK Field of view 41° × 31° Minimum focus distance • • Thermal: 0.15 m (0.49 ft.) MSX: 1.0 m (3.3 ft.) Focal length 1.54 mm (0.061 in.) Website Spatial resolution (IFOV) 11 mrad http://www.flir.com F-number 1.1 Image frequency 9 Hz Focus Focus free Customer support http://support.flir.com Disclaimer Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Detector data Focal Plane Array Uncooled microbolometer Spectral range 7.5–14 µm Detector pitch 17 µm IR sensor size 80 × 60 Image presentation Display (color) Display, aspect ratio • • 3.0 in. 320 × 240 pixels 4:3 Auto orientation Yes Touch screen Yes, capacitive Image adjustment (alignment calibration) Yes Image presentation modes 1 (6) Infrared image Yes Visual image Yes MSX Yes Gallery Yes www.flir.com FLIR C2 P/N: 72001-0101 Measurement © 2015, FLIR Systems, Inc. Object temperature range –10°C to +150°C (14 to 302°F) Accuracy ±2°C (±3.6°F) or 2%, whichever is greater, at 25° C (77°F) nominal. #72001-0101; r. /22506; en-US Measurement analysis Spotmeter On/off Emissivity correction Yes; matt/semi-matt/semi-glossy + custom value Measurements correction • • Emissivity Reflected apparent temperature • • • • Iron Rainbow Rainbow HC Gray Set-up Color palettes Set-up commands Local adaptation of units, language, date and time formats Languages Arabic, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Russian, Simpl. Chinese, Spanish, Swedish, Trad. Chinese, Turkish. Lamp Output power 0.85 W Field of view 60° Service functions Camera software update Using FLIR Tools Storage of images Storage media Image file format Internal memory store at least 500 sets of images • • Standard JPEG 14-bit measurement data included Video streaming Non-radiometric IR-video streaming Yes Visual video streaming Yes Digital camera Digital camera 640 × 480 pixels Digital camera, focus Fixed focus Data communication interfaces 2 (6) USB, connector type USB Micro-B: Data transfer to and from PC USB, standard USB 2.0 www.flir.com FLIR C2 P/N: 72001-0101 Power system © 2015, FLIR Systems, Inc. Battery type Rechargeable Li-ion polymer battery Battery voltage 3.7 V Battery operating time 2h Charging system Charged inside the camera Charging time 1.5 h #72001-0101; r. /22506; en-US External power operation Power management • • AC adapter, 90–260 VAC input 5 V output to camera Automatic shut-down Environmental data Operating temperature range –10°C to +50°C (14 to 122°F) Storage temperature range –40°C to +70°C (–40 to 158°F) Humidity (operating and storage) IEC 60068-2-30/24 h 95% relative humidity +25° C to +40°C (+77°F to +104°F) / 2 cycles Relative humidity 95% relative humidity +25°C to +40°C (+77°F to +104°F) non condensing EMC • • • • • • WEEE 2012/19/EC RoHs 2011/65/EC C-Tick EN 61000-6-3 EN 61000-6-2 FCC 47 CFR Part 15 Class B Magnetic fields EN 61000-4-8 Battery regulations UL 1642 Encapsulation Camera housing and lens: IP 40 (IEC 60529) Shock 25 g (IEC 60068-2-27) Vibration 2 g (IEC 60068-2-6) Physical data Weight (incl. Battery) 0.13 kg (0.29 lb.) Size (L × W × H) 125 × 80 × 24 mm (4.9 × 3.1 × 0.94 in.) Tripod mounting No Housing material Color • • PC and ABS, partially covered with TPE Aluminum Black and gray Shipping information Packaging, type List of contents Cardboard box • • • • • • Packaging, weight 3 (6) www.flir.com Infrared camera Lanyard Power supply/charger with EU, UK, US, CN and Australian plugs Printed getting started guide USB memory stick with documentation USB cable 0.53 kg (1.17 lb.) FLIR C2 P/N: 72001-0101 Shipping information © 2015, FLIR Systems, Inc. Packaging, size 175 × 115 × 75 mm (6.9 × 4.5 × 3.0 in.) EAN-13 4743254001961 UPC-12 845188010614 Country of origin Estonia #72001-0101; r. /22506; en-US 4 (6) www.flir.com © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. G G H F 1 2 3 3 Camera with build-in IR lens f=1,54mm 2 F E D C B A 1 1,31 33,4 mm 1,78 45,3 mm 0,43 11 mm 4 4 IR Optical axis Visual Optical axis 0,91 23,1 mm 5 5 0,58 14,8 mm 6 6 7 7 4,9 124,5mm MABR Check Drawn by R&D Thermography 9 Basic Dimensions Flir Cx 2014-12-18 Denomination Modified 1,02 25,9 mm Optical axis 8 3,1 78,7 mm 1:1 T128439 Drawing No. A2 Size Scale 10 B 1(1) Size Sheet E D C B A
FLIR C2-NIST 价格&库存
很抱歉,暂时无法提供与“FLIR C2-NIST”相匹配的价格&库存,您可以联系我们找货
