FLIR C3
FLIR C3
    FLIR(菲力尔)
    FLIR C3 COMPACT PROFESSIONAL THE
FLIR C3 数据手册
FLIR C3 (incl. Wi-Fi) P/N: 72003-0303 Copyright © 2018, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: 72003-0303 Release: Commit: 48853 Language: en-US Modified: 2018-04-04 Formatted: 2018-04-04 Website http://www.flir.com Customer support http://support.flir.com Disclaimer Imaging and optical data Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. NETD 100 mK Field of view 41° × 31° Minimum focus distance • • Thermal: 0.15 m (0.49 ft.) MSX: 1.0 m (3.3 ft.) Focal length 1.54 mm (0.061 in.) Spatial resolution (IFOV) 11 mrad F-number 1.1 Image frequency 9 Hz Focus Focus free Detector data Focal Plane Array Uncooled microbolometer Spectral range 7.5–14 µm Detector pitch 17 µm IR sensor size 80 × 60 Image presentation Display (color) • • 3.0 in. 320 × 240 pixels Display, aspect ratio 4:3 Auto orientation Yes Touch screen Yes, capacitive Image adjustment (alignment calibration) Yes Image presentation modes Infrared image Yes Visual image Yes MSX Yes Gallery Yes Picture in Picture IR area on visual image FLIR C3 (incl. Wi-Fi) P/N: 72003-0303 Measurement © 2018, FLIR Systems, Inc. Object temperature range –10°C to +150°C (14 to 302°F) Accuracy ±2°C (±3.6°F) or 2%, whichever is greater, at 25° C (77°F) nominal. #72003-0303; r. /48853; en-US Measurement analysis Spotmeter On/off Area Box with max./min. Emissivity correction Yes; matt/semi-matt/semi-glossy + custom value Measurements correction • • Emissivity Reflected apparent temperature • • • • Iron Rainbow Rainbow HC Gray Set-up Color palettes Set-up commands Local adaptation of units, language, date and time formats Languages Arabic, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Russian, Simpl. Chinese, Spanish, Swedish, Trad. Chinese, Turkish. Lamp Output power 0.85 W Field of view 60° Service functions Camera software update Using FLIR Tools Storage of images Storage media Image file format Internal memory store at least 500 sets of images • • Standard JPEG 14-bit measurement data included Video streaming Non-radiometric IR video streaming Yes Visual video streaming Yes Digital camera Digital camera 640 × 480 pixels Digital camera, focus Fixed focus Data communication interfaces Wi-Fi Peer-to-peer (ad hoc) or infrastructure (network) USB, connector type USB Micro-B: Data transfer to and from PC USB, standard USB 2.0 FLIR C3 (incl. Wi-Fi) P/N: 72003-0303 Radio © 2018, FLIR Systems, Inc. Wi-Fi #72003-0303; r. /48853; en-US • • Standard: 802.11 b/g/n Frequency range: ◦ ◦ • 2400–2480 MHz 5150–5260 MHz Max. output power: 15 dBm Power system Battery type Rechargeable Li-ion polymer battery Battery voltage 3.7 V Battery operating time 2h Charging system Charged inside the camera Charging time 1.5 h External power operation Power management • • AC adapter, 90–260 VAC input 5 V output to camera Automatic shut-down Environmental data Operating temperature range –10°C to +50°C (14 to 122°F) Storage temperature range –40°C to +70°C (–40 to 158°F) Humidity (operating and storage) IEC 60068-2-30/24 h 95% relative humidity +25° C to +40°C (+77°F to +104°F) / 2 cycles Relative humidity 95% relative humidity +25°C to +40°C (+77°F to +104°F) non condensing EMC Radio spectrum • • • • • • WEEE 2012/19/EC RoHs 2011/65/EC C-Tick EN 61000-6-3 EN 61000-6-2 FCC 47 CFR Part 15 Class B • • • ETSI EN 300 328 FCC 47 CSR Part 15 RSS-247 Issue 2 Magnetic fields EN 61000-4-8 Battery regulations UL 1642 Encapsulation Camera housing and lens: IP 40 (IEC 60529) Shock 25 g (IEC 60068-2-27) Vibration 2 g (IEC 60068-2-6) Drop 2 m (6.6 ft.) Physical data Weight (incl. Battery) 0.13 kg (0.29 lb.) Size (L × W × H) 125 × 80 × 24 mm (4.9 × 3.1 × 0.94 in.) Tripod mounting No Housing material Color • • PC and ABS, partially covered with TPE Aluminum Black and gray FLIR C3 (incl. Wi-Fi) P/N: 72003-0303 Shipping information © 2018, FLIR Systems, Inc. Packaging, type #72003-0303; r. /48853; en-US List of contents Cardboard box • • • • • • • Infrared camera Lanyard Pouch Power supply/charger with EU, UK, US, CN and Australian plugs Printed documentation Tripod mount USB cable Packaging, weight TBD Packaging, size 175 × 110 × 105 mm (6.9 × 4.3 × 4.1 in.) EAN-13 4743254002845 UPC-12 845188014094 Country of origin Estonia
FLIR C3 价格&库存
很抱歉,暂时无法提供与“FLIR C3”相匹配的价格&库存,您可以联系我们找货
