FLIR T1020-KIT-12-45
    FLIR(菲力尔)
    FLIR T1020 WITH STANDARD 28 LENS
FLIR T1020-KIT-12-45 数据手册
FLIR T1020 28°, 12°, and 45° P/N: 72501-0106 Copyright © 2016, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: 72501-0106 Release: Commit: 34878 Language: en-US Modified: 2016-04-11 Formatted: 2016-04-11 Website General description http://www.flir.com The FLIR T1020 is designed for the expert requiring the highest performance and the latest technology available. The camera combines excellent ergonomics and feature-rich flexibility with superior image quality at an infrared resolution of 1024 × 768 pixels. Customer support http://support.flir.com Disclaimer Benefits: Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. • • • Flexible and feature rich: A wide variety of measuring and analysis functions make the FLIR T1020 flexible for your every need. Two programmable buttons provide easy access to favorite functions. Highest performance with the latest technology: The FLIR T1020 is equipped with the innovative Multi Spectral Dynamic Imaging (MSX) feature, which produces an image richer in detail than ever before. With its continuous autofocus, the FLIR T1020 is a fully automatic infrared camera. Support for UltraMax: When enabling UltraMax in the camera, the resolution of images can be substantially enhanced when importing the images into FLIR Tools. Imaging and optical data 1 (14) IR resolution 1024 × 768 pixels MSX resolution 1024 × 768 pixels UltraMax Yes Thermal sensitivity/NETD 2.5 hours at 25°C (+68°F) and typical use Charging system In camera (AC adapter or 12 V from a vehicle) or two-bay charger Charging time 2.5 hours to 90% capacity, charging status indicated by LEDs Charging temperature 0–45°C (32–113°F) External power operation AC adapter 90–260 V AC, 50/60 Hz or 12 V from a vehicle (cable with a standard plug, optional) Power management Automatic power-off functionality, user configurable between 5 minutes, 20 minutes, and no automatic shutdown Environmental data 5 (14) Operating temperature range –15°C to +50°C (+5°F to +122°F) Storage temperature range –40 to +70°C (–40 to +158°F) Humidity (operating and storage) IEC 60068-2-30 / 24 hours, 95% relative humidity, 25–40°C (77–104°F) / 2 cycles www.flir.com FLIR T1020 28°, 12°, and 45° P/N: 72501-0106 Environmental data © 2016, FLIR Systems, Inc. EMC #72501-0106; r. /34878; en-US Radio spectrum • • • • • • ETSI EN 301 489-1 (radio) ETSI EN 301 489-17 EN 61000-6-2 (Immunity) EN 61000-6-3 (Emission) FCC 47 CFR Part 15 Class B (Emission) ICES-003 • • • ETSI EN 300 328 FCC Part 15.247 RSS-247 issue 1 Encapsulation IP 54 (IEC 60529) Shock 25 g (IEC 60068-2-29) Vibration 2 g (IEC 60068-2-6) Safety EN/UL/CSA/PSE 60950-1 Ergonomics The viewfinder plus the 120° rotating optical block allow you to point the camera in multiple directions while maintaining a comfortable position Physical data Weight 1.9 kg (4.3 lb.) Camera size, excl. lens (L × W × H) 167.2 mm × 204.5 mm × 188.3 mm (6.6 in. × 8.0 in. × 7.4 in.) Tripod mounting UNC ¼"-20 Housing material Magnesium Warranty information Warranty • • • 2 years parts and labor coverage on the camera 5 years coverage on the battery 10 years coverage on the detector – the most vital part of the whole camera Shipping information Packaging, type List of contents 6 (14) Cardboard box • • • • • • • • • • • • • • • • • Infrared camera with lens Battery (2 ea.) Battery charger Bluetooth headset Calibration certificate FLIR Tools+ license card Hard transport case HDMI-HDMI cable IR lens, 12° IR lens, 45° Lens cap Memory card Neck strap Power supply, including multi-plugs Printed documentation USB cable, Std A to Micro-B User documentation CD-ROM Packaging, weight 8.2 kg (18.0 lb.) Packaging, size 494 × 355 × 188 mm (19.4 × 14.0 × 7.4 in.) www.flir.com FLIR T1020 28°, 12°, and 45° P/N: 72501-0106 Shipping information © 2016, FLIR Systems, Inc. EAN-13 7332558011300 UPC-12 845188012182 Country of origin Sweden #72501-0106; r. /34878; en-US Supplies & accessories: • • • • • • • • • • • • • • • • • • • • • • • • 7 (14) T199064; IR lens f=36mm (28°) with case T199066; IR lens f=21.2mm (45°) with case T199077; IR lens f=83.4mm (12°) with case T910814; Power supply, incl. multi plugs T198126; Battery charger, incl. power supply with multi plugs T6xx T198506; Li-Ion Battery pack 3.7V 29Wh T911230ACC; Memory card SDHC 4 GB 1910423; USB cable Std A Mini-B T198509; Cigarette lighter adapter kit, 12 VDC, 1.2 m/3.9 ft. T910930ACC; HDMI type C to DVI cable 1.5 m T910891ACC; HDMI type C to HDMI type A cable 1.5 m T198625ACC; Hard transport case T198497; Large eyecup T197771ACC; Bluetooth Headset T911093; Tool belt T198586; FLIR Reporter Professional (license only) T198584; FLIR Tools T198583; FLIR Tools+ (download card incl. license key) DSW-10000; FLIR IR Camera Player APP-10002; FLIR Tools Mobile (Android Application) APP-10003; FLIR Tools Mobile (iPad/iPhone Application) APP-10004; FLIR Tools (MacOS Application) T199233; FLIR Atlas SDK for .NET T199234; FLIR Atlas SDK for MATLAB www.flir.com © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 2 Camera housing 1 1,72in 43,7mm 5,63in 142,9mm 6,58in 167,2mm 3 2,68in 68mm 3 4 4 7,1in 180,4mm 7,41in 188,3mm 4,76in 120,8mm 4,55in 115,5mm 5 5 5,67in 144mm 6 6 5,37in 136,3mm JOTA Check 8 R&D Thermography Drawn by 9 1,74in 44,3mm 2,77in 70,4mm Basic dimensions FLIR T10xx 2015-09-17 8,05in 204,5mm 6,31in 160,2mm Denomination Modified - Viewfinder Optional 7 1,72in 43,7mm 0,55in 14mm 2,3in 58,4mm 10 T128849 Drawing No. 1:2 A3 Scale Size 1,75in 44,5mm 4,55in 115,5mm 5,63in 143mm 7,41in 188,3mm D 1(7) Size Sheet G F E D C B A © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 8,63in 219,2mm 7,67in 194,9mm 2 3 3 IR-LENS 12° (f=83,4mm) 1 5,28in 134,1mm 5,19in 131,9mm 4 4 5,02in 127,4mm 5 5 6 8,29in 210,4mm 6 7 JOTA Check 8 R&D Thermography Drawn by 3,96in 100,5mm Basic dimensions FLIR T10xx Denomination 2015-09-17 Modified 7,67in 194,9mm 9 10 T128849 Drawing No. A3 1:2 Size Scale 5,9in 149,9mm D 2(7) Size Sheet G F E D C B A © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 2 6,07in 154,2mm 7,03in 178,5mm 3 3 IR-LENS 28° (f=36mm) 1 3,68in 93,4mm 3,59in 91,2mm 4 4 4,83in 122,6mm 5 5 6 8,1in 205,7mm 6 7 JOTA Check 8 R&D Thermography Drawn by 3,58in 91mm Basic dimensions FLIR T10xx Denomination 2015-09-17 Modified 7,49in 190,1mm 9 10 T128849 Drawing No. 1:2 A3 Size Scale 4,32in 109,8mm D 3(7) Size Sheet G F E D C B A © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 2 6,21in 157,8mm 7,17in 182,1mm 3 3 IR-LENS 45° (f=21,2mm) 1 3,82in 96,9mm 3,73in 94,8mm 4 4 4,83in 122,6mm 5 5 6 8,1in 205,7mm 6 7 JOTA Check 8 R&D Thermography Drawn by 3,58in 91mm Basic dimensions FLIR T10xx Denomination 2015-09-17 Modified 7,49in 190,1mm 9 10 T128849 Drawing No. 1:2 A3 Size Scale 4,46in 113,3mm D 4(7) Size Sheet G F E D C B A © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 8,37in 212,6mm 7,42in 188,4mm 2 3 3 IR-LENS CLOSE-UP (3X) 1 5,02in 127,5mm 4,94in 125,4mm 4 4 4,83in 122,7mm 5 5 6 8,1in 205,7mm 6 7 JOTA Check 8 R&D Thermography Drawn by 3,58in 91mm Basic dimensions FLIR T10xx Denomination 2015-09-17 Modified 7,49in 190,1mm 9 10 T128849 Drawing No. 1:2 A3 Size Scale 5,67in 143,9mm D 5(7) Size Sheet G F E D C B A © 2012, FLIR Systems, Inc. All rights reserved worldwide. No part of this drawing may be reproduced, stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission from FLIR Systems, Inc. Specifications subject to change without further notice. Dimensional data is based on nominal values. Products may be subject to regional market considerations. License procedures may apply. Product may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. Diversion contrary to US law is prohibited. H G F E D C B A 1 2 2 Battery Charger 3,85in 97,7mm 1 3,4in 86,4mm 5,25in 133,2mm 3 3 2,01in 51mm 4 4 5 5 6 6 7 JOTA Check 8 R&D Thermography Drawn by 1,57in 39,8mm Basic dimensions FLIR T10xx Denomination 2015-09-17 Modified 1,47in 37,3mm 9 3,3in 83,8mm T128849 Drawing No. 1:2 A3 Size Scale 10 D 6(7) Size Sheet G F E D C B A
FLIR T1020-KIT-12-45 价格&库存
很抱歉,暂时无法提供与“FLIR T1020-KIT-12-45”相匹配的价格&库存,您可以联系我们找货
