VSA4-1-W
VSA4-1-W
    FLIR(菲力尔)
    WIRELESS 4 WAY 8MM ART CAM W 1M
VSA4-1-W 数据手册
Wireless four-way articulating camera, focal length 60 mm to infinity P/N: VSA4-1-W Copyright © 2015, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: VSA4-1-W Release: Commit: 29700 Language: Modified: 2015-10-16 Formatted: 2015-10-20 Part number VSA4-1-W Part description Disclaimer Specifications subject to change without further notice. Camera models and accessories subject to regional market considerations. License procedures may apply. Products described herein may be subject to US Export Regulations. Please refer to exportquestions@flir.com with any questions. The new FLIR wireless four-way articulation videoscope cameras for the VS70 allows for inspection of tight, remote, and off-center targets. Use both articulation knobs to control movement of the camera up, down, left, and right to get a complete video or picture for your inspection. These cameras come with an integrated handset that contains power and brightness adjustment buttons. Set your display down or let it hang from the neck strap while you focus on your probe orientation without worrying about cords. Also included are the handy camera tip accessories that allow viewing at a 45° angle (mirror), retrieving a metallic object (magnet), and reduce the likelihood of getting stuck (anti-snag ball). General information Compatible main unit VS70 Integrated handset Yes Wireless capabilities 2.4 GHz to main unit Wireless maximum range 30 m Compatible wireless handset N/A Compatible detachable cameras N/A Warranty 2 years Camera specifications 1 (3) Articulation 240 ± 20° manual tip articulation Diameter 8 mm Resolution VGA ( 640 × 480 pixels) Probe length 1m Focal length 60 mm to infinity Field of view 60° Imaging sensor CMOS Video format NTSC www.flir.com Wireless four-way articulating camera, focal length 60 mm to infinity P/N: VSA4-1-W Camera specifications © 2015, FLIR Systems, Inc. Brightness control Manual with variable options Lamp type LED Adjustable articulation tension Yes, via manual knob #VSA4-1-W; r. /29700; Power system Power requirements 3.7 V rechargeable lithium polymer Run time 2 hours continuous use Auto power off No Power adapter 100–240 V input/5 V DC output Environmental data IP rating IP67 Drop test 2m Operating ambient temperature –20 to 70°C (–4 to 158°F) Operating humidity 95% maximum Storage temperature –20 to 70°C (–4 to 158°F) Storage humidity 80% maximum Meter physical data Weight: 0.88 kg (1.95 lb.) Dimensions (H × W × L) 82.55 mm × 63.5 mm × 1168.4 mm (3.25″ × 2.5″ × 46″) Material PC-ABS, rubber hand grip, nylon strap Color Gray, black Shipping information Packaging type White box with FLIR accessory printing Packaging contents White box with FLIR accessory graphic, VSA4-1W, user guide, camera attachments: mirror, antisnag tip, magnet Packaging weight 1.52 kg (3.35 lb.) Packaging dimensions (H × W × L) 69.8 mm × 361.9 mm × 431.8 mm (2.75″ × 14.25″ × 17″) Carton weight 7 kg (15.4 lb.) Carton dimensions 387.4 mm × 444.5 mm × 330.2 mm (15.25″ × 17.5″ × 13″) Carton quantity 4 EAN-13 0793950406199 UPC-12 793950406199 Country of origin Taiwan Tariff code 9013909000 Accessories Extra camera accessories 2 (3) www.flir.com VS80-A
VSA4-1-W 价格&库存
很抱歉,暂时无法提供与“VSA4-1-W”相匹配的价格&库存,您可以联系我们找货
