VSC25
VSC25
    FLIR(菲力尔)
    25MM CAMERA HEAD FOR SPOOL VSS-X
VSC25 数据手册
25 mm camera head for spool, spool (VCS-20 or VCS-30) needed for operation P/N: VSC25 Copyright © 2014, FLIR Systems, Inc. All rights reserved worldwide. Names and marks appearing herein are either registered trademarks or trademarks of FLIR Systems and/or its subsidiaries. All other trademarks, trade names or company names referenced herein are used for identification only and are the property of their respective owners. Document identity Publ. No.: VSC25 Release: Commit: 14349 Language: Modified: 2014-05-26 Formatted: 2014-05-27 Part No. VSC25 General information Short description 25 mm camera head for spool, spool (VCS-20 or VCS-30) needed for operation Compatible main unit VS70 Integrated handset No Wireless capabilities N/A Compatible wireless handset With optional VST Compatible detachable cameras N/A Warranty 2 years Camera specifications Articulation No Diameter 25 mm Resolution VGA (640 × 480 pixels) Probe length N/A Focal length 65 mm to infinity Field of view 72° Imaging sensor CMOS Video format NTSC Brightness control Manual with variable options Lamp type LED Power system Power requirements N/A Environmental data Operating temperature –10 to 50°C (14–122°F) Operating humidity 80% maximum Storage temperature –40 to 80°C (–40 to 176°C) Physical data 1 (2) Weight See shipping information Dimensions (H × W × L) See shipping information Material Stainless steel, PC-ABS, rubber hand grip, nylon strap Color Gray, black 25 mm camera head for spool, spool (VCS-20 or VCS-30) needed for operation P/N: VSC25 Shipping information © 2014, FLIR Systems, Inc. Packaging type White box with FLIR accessory printing Packaging contents White box with FLIR accessory graphic, camera Packaging weight 0.23 kg Packaging dimensions (H × W × L) 23.5 cm × 7.5 cm × 7 cm Carton weight 7 kg Carton dimensions (H × W × L) 47 cm × 25.5 cm × 30 cm Carton quantity 24 EAN-13 7332558007587 UPC-12 793950400913 Country of origin TW Tariff code 9013909000 #VSC25; r. -/14349; 2 (2)
VSC25 价格&库存
很抱歉,暂时无法提供与“VSC25”相匹配的价格&库存,您可以联系我们找货
