REMOTEID-1
REMOTEID-1
    FLUKENETWORKS
    REMOTE ID #1 FOR LINKIQ
REMOTEID-1 数据手册
LinkIQ Datasheet LinkIQ™ Cable+Network Tester Cable testing you trust. Network testing you need. LinkIQ™ enables you to: • Find maximum cabling speed (Up to 10 Gb/s) • Install and troubleshoot PoE devices via Switch Negotiation and PoE Load Test • Identify connected switch information (Switch Name, Port Number, and VLAN) • Document your work through LinkWare™ PC LinkIQ Datasheet Overview The LinkIQ™ Cable+Network Tester is the testing solution to verify cable performance up to 10 Gb/s and solve network connectivity problems. LinkIQ validates cable performance using frequency-based measurements and provides distance to fault information along with a wire map of the cable under test. The LinkIQ also performs nearest switch diagnostics to identify key network issues and validate switch configuration eliminating the need of using another device. Additional features include Analog and Digital Toning, Port Blink, 802.1x authentication, Remote Office Locators, and the ability to manage results via LinkWare™ PC. Cable Testing You Trust The LinkIQ™ is capable of measuring lengths up to 1000 feet (305 m) and provides distance to faults such as opens, shorts, and unterminated cable. Using the remote ID allows for a complete wire map of the cable pairs which helps identify miswired and split pairs. The primary cable testing feature of LinkIQ™ is the cable performance test which qualifies the cabling bandwidth from 10BASE-T to 10GBASE-T (10 Mb/s up to 10 Gb/s). It performs these tests via frequencybased measurements. Using IEEE-standards-based measurements ensures that tested links meet performance requirements as opposed to transmission testers which only prove that the specific test devices can communicate over the link. Operators may set performance requirements from 10 Mb/s to 10 Gb/s for a simple pass/fail indication. LinkIQ Datasheet Cable test without remote attached shows length and pairing of each wire Cable test with remote attached shows remote ID number 5, length and pairing of each wire and cable performance of up to 10 Gb/s LinkIQ Datasheet Cable test with remote attached shows remote ID number 1, length and pairing of each wire and cable performance of up to 2.5 Gb/s but failed the test due to a user-set limit of 10 Gb/s performance. Network Testing You Need Along with the robust cable testing features, the LinkIQ™ also provides detailed information on the nearest connected switch. The LinkIQ™ negotiates with the switch to identify the advertised data rate (up to 10GBASE-T), half/full duplex identification, the switch name, port number, and VLAN info. LinkIQ Datasheet Switch port test shows port number, switch name and port VLAN along with advertised speed and duplex settings. Scrolling down shows Power over Ethernet results. LinkIQ Datasheet Switch port Power over Ethernet settings shows pairs used, power and class available and results of the PoE test under load. In-Depth PoE Testing While Power over Ethernet makes installation of devices such as security cameras and access points simpler, a survey by the Ethernet Alliance of over 800 installers, integrators and end users found that four of five respondents experienced difficulties in integrating PoE systems. Part of this can be traced to the fact that the IEEE offers three PoE standards, the term “PoE” is not registered and there are a variety of non-standards-compliant implementations as well. To simplify PoE installation and troubleshooting, the LinkIQ displays the pairs where power is provided, including the different power levels and pairs for dual-signature implementations. Further, the LinkIQ will actually place a load on the connection to ensure that the advertised power is actually being delivered by the switch across the cabling infrastructure. LinkIQ Datasheet LinkWare™ Documentation The LinkIQ provides complete documentation abilities for the tests it performs. Up to 1,000 results can be stored in the tester with descriptive names and recalled. Test names and numbers automatically increment as each is saved (“Annex B-1”, “Annex B-2”, “Annex B-3”, etc.) saving lots of time when testing cables in sequence. Report data may be exported to a PC for documentation purposes. The LinkIQ uses LinkWare™ PC, Fluke Networks’ reporting software which supports a variety of testers going back 20 years and is the industry’s de facto reporting solution with tens of thousands of active users. LinkWare can be used to store the results as well as generate PDF reports. Use LinkWare PC to generate PDF test reports. LinkIQ Datasheet Additional Features • Generates Analog or Digital tones compatible with the IntelliTone™ Probe or Pro3000™ to assist in locating cables in a wall or telecommunications room • Blink Port light on switch to help identify the connected switch port • Compatible with MicroScanner™ PoE Remote Identifiers for Ethernet outlet identification • Touch Sensitive gesture-based display • Rechargeable Li-Ion battery • Easy Feature and Network Testing Upgrades via USB-C via LinkWare™ PC • Charging via standard USB-C port LIQ-100 includes LinkIQ mainframe and accessories. LinkIQ Datasheet LinkIQ™ Feature Breakout 1. 2. 3. 4. 5. 6. 7. 8. RJ45 Port PASS/FAIL frequency-based measurement results Touch Screen Color Display Length measurement shows distance to termination, open or short Wiremap shows type and location of fault (miswires, split pairs, shorts, breaks) USB-C port for data export, software updates and charging Cable “Speedometer” provides bandwidth information up to 10G Save up to 1000 test results on the unit and export to LinkWare™ PC LinkIQ Datasheet Ordering Information MODEL DESCRIPTION LIQ-100 LinkIQ Cable+Network Tester with Remote ID 1, Quick Reference Guide, USB-C to USB-A cable, Charging cable, Cat6A patch cord, RJ45/11 Modular Adapter, hanging strap with Remote ID holder, and Carrying Case LIQ-KIT LinkIQ Cable+Network Tester with Remote IDs 1-7, IntelliTone Probe, Quick Reference Guide, USB-C to USB-A cable, Charging cable (with international adapters), Cat 6A patch cord, RJ45/11 Modular Adapter, hanging strap with Remote ID holder, and Duffle Bag REMOTEID-1 Replacement ID for LinkIQ Remote ID #1 REMOTEID-KIT Remote ID Kit (IDs #2-#7) for LinkIQ and MicroScanner PoE GLD-LIQ 1 Year Gold Support LinkIQ Cable Performance & Network Tester GLD3-LIQ 3 Year Gold Support LinkIQ Cable Performance & Network Tester LinkIQ Datasheet General Specifications Feature Description Languages supported in UI English (SW v1.0) Weight 1 lbs 6 oz (624g) Battery Type: Lithium-ion, 3.6 V, 6400 mAh; Life: 8 hours typical; Charge time: 4.5 hours; Charging temperature range: 0 °C to +40 °C Power Adapter Input: 100 to 240 VAC ±10%, 50/60Hz; Output: 15 VDC, 2 A maximum; Class II Host Interface USB type C Display 800 x 480 color capacitive multi-touch Dimensions 8.5 in x 4.5 in Operating Temperature 0°C to 45°C Storage Temperature -20°C to 50°C (-4°F to 122°F) Operating Relative Humidity 0 % to 90 %, 0°C to 35°C; 0 % to 70 %, 35°C to 45°C Operating Altitude 4,000 m; 3,200 m with ac adapter Vibration Random, 2 g, 5 Hz-500 Hz Drop 1 m drop, 6 sides LinkIQ Datasheet Active Network Diagnostics Feature Description Diagnostic Protocols Link Layer Discovery Protocol (LLDP), Cisco Discovery Protocol (CDP), Fast Link Pulses (FLP) Nearest Device Diagnostics, (If available through diagnostic protocols) Switch Name, Port Number, VLAN Name, Advertised Data Rates, Advertised Duplex Power Over Ethernet Compatibility IEEE 802.3af/at (SW v1.0), Hardware negotiation with signature resistance, Software negotiation with LLDP/CDP Power Over Ethernet Diagnostics Advertised Power Class (1 to 4) (SW v1.0), Advertised Available Power, Powered Pairs, Diagnostics for both Single and Dual signatures Power Over Ethernet Measurements Loaded Voltage (V), Loaded Power (W) Port Blink Blink the light of the connected port LinkIQ Datasheet Cable Test Specifications Feature Description Test Port Shielded 8-pin modular jack accepts 8-pin modular (RJ45) plugs Commissioning Autotests 10GBASE-T, 5GBASE-T, 2.5GBASE-T, 1000BASE-T, 100BASE-TX, 10BASE-T, Wire map Only. Test Speed: 6 seconds for lengths < 70 m Cable Types Balanced twisted-pair cabling; Unshielded twisted-pair; Screened twisted-pair; 2-pair and/or 4-pair Wire Map-Only Tests Document wire map, Length of each pair, Diagnose split pairs, User selectable T568A or T568B, User selectable crossover settings (Straight through, Halfcrossover, Full-crossover). Test speed: 1 second for lengths < 120 m Length (Maximum) 305 m (1000 ft) Nominal Velocity of Propagation (NVP) User settable Tone Generator Generates digital tones compatible with Fluke Networks IntelliTone probe. Generates analog tones compatible with general analog probes. Remote ID Locators Use remote ID terminations to identify up to 7 unique ports or office outlets
REMOTEID-1 价格&库存
很抱歉,暂时无法提供与“REMOTEID-1”相匹配的价格&库存,您可以联系我们找货
