ECD0658EB
ECD0658EB
    FREEWAVE
    网络 配用
ECD0658EB 数据手册
Model SPECS ZIQ-P / ZIQ-P2 902 - 928 MHz Board Level Data Port: Serial and Ethernet Protocol: RS232 / RS485, TCP/IP MENU Model SPECS ZIQ-PE 902 - 928 MHz Enclosed Data Port: Serial and Ethernet Protocol: RS232 / RS485, TCP/IP MENU Options: Description AOH0001HT ASC2402PT ECD0324ER ECD0658EB Kit, DIN Rail Bracket Cable, power Assembly, 40" pigtail (default) 3' Cable Assembly, RJ-45 to DB9 Female Cable, Ethernet, Cat 5E, Shielded, Blue EMD1280AX 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin. FWT1004IE FWT1030AU FWT1100TP FWT1112TP FWT1122TP FWT1122TB SET0000CA SET0002CA SET0000ZD SET0001ZD Ignition Edge Jail IQ AutoSol eACM Software v1.0.3 ZumLink ZumIQ Developer Edition v1.1.0 Zumlink / ZumIQ Developer Edition v1.1.1.2 ZumLink / ZumIQ Developer Edition v1.1.2.2 (Default) ZumLink / ZumIQ Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled Setting, WC Custom Applications - no reset DevUser Password login - Enable Devuser Password Login - Unique Options: Description AOH4003SP ASC0002ZL ASC0003ZL ECD0324ER ECD0658EB EMD1280UW FWT1004IE FWT1030AU FWT1100TP FWT1122TP FWT1122TB SET0000CA SET0002CA SET0000ZD SET0001ZD KIT, DIN Rail bracket reversible ZumLink Cable Assembly, 12" power, 2-SKT Plug to Barrel Jack, Z9-PE Cable Assembly, 40" External Power Pigtail (default for Z9-PE radio) Cable, Serial, 3' Serial Assembly, RJ-45 to DB9 Female Cable, Ethernet, Cat 5E, Shielded, Blue 800mA, Wall Mount Power Adapter, with barrel connector. Mates with ASC0002ZL for Z9-PE Ignition Edge Jail IQ AutoSol eACM Software v1.0.3 ZumLink / ZumIQ Developer Edition v1.1.0 ZumLink / ZumIQ Developer Edition v1.1.2.2 (default) ZumLink / ZumIQ Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled Setting, WC Custom Applications - no reset DevUser Password login - Enable Devuser Password Login - Unique Model SPECS Options: Description 902 - 928 MHz Enclosed Data Port: Serial and Ethernet AOH4003SP ASC2402PT ECD0324ER ECD0658EB ZIQ-PE2 Protocol: RS232 / RS485, TCP/IP MENU Model SPECS ZIQ-IO-PE-FT 902 - 928 MHz Enclosed Data Port: Serial and Ethernet Protocol: RS232 / RS485, TCP/IP MENU EMD1280AX FWT1004IE FWT1030AU FWT1100TP FWT1122TP FWT1122TB SET0000CA SET0002CA SET0000ZD SET0001ZD KIT, DIN Rail bracket reversible ZumLink Cable, power Assembly, 40" pigtail (default with Z9-PE2 radio) Cable, Serial, 3' Serial Assembly, RJ-45 to DB9 Female Cable, Ethernet, Cat 5E, Shielded, Blue 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin for Z9-PE2 Ignition Edge Jail IQ AutoSol eACM Software v1.0.3 ZumLink / ZumIQ Developer Edition v1.1.0 ZumLink / ZumIQ Developer Edition v1.1.2.2 (default) ZumLink / ZumIQ Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled Setting, WC Custom Applications - no reset DevUser Password login - Enable Devuser Password Login - Unique Options: Description AOH0001HT ECD0324ER ECD0658EB EMD1280UW FWT1122TP FWT1122TB SET0000CA Kit, DIN Rail Bracket Cable, Serial, 3' Serial Assembly, RJ-45 to DB9 Female Cable, Ethernet, Cat 5E, Shielded, Blue 800mA, Wall Mount Power Adapter, with barrel connector. Mates with ASC0002ZL for Z9-PE ZumLink / ZumIQ Developer Edition v1.1.2.2 (default) ZumLink / ZumIQ Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled March 3, 2020 Model SPECS Z9-T / Z9-C 902 - 928 MHz Board Level Data Port: TTL / RS232 RF Connector: MMCX Protocol: TTL / RS232 Model SPECS Z9-P / Z9-P2 902 - 928 MHz Board Level Data Port: Serial and Ethernet RF Connector: SMA Female Protocol: RS232 / RS485, TCP/IP Options: FWT1040TA FWT1070TA Options: AOH0001HT EMD1280AX ASC2402PT ECD0324ER ECD0658EB FWT1004IE FWT1030AU FWT1100TP FWT1122TP FWT1122TB SET0000CA SET0001CA SET0002CA SET0000ZD SET0001ZD EAN0900SR EAN0900WC EAN0905WC EAN0906YC Model SPECS Z9-PC / Z9-PC-SR001 902 - 928 MHz Board Level Data Port: Serial and Ethernet RF Connector: MMCX Protocol:  RS232 / RS485, TCP/IP MENU Model SPECS Z9-PE 902 - 928 MHz Enclosed Data Port: Serial and Ethernet RF Connector: TNC Female Protocol:  RS232 / RS485, TCP/IP Z9-T/C 1.0.7.0 Firmware Release (default) MENU EAN0900SQ MENU Description Zumlink Radio Module Firmware v1.0.4.0 EWP0401YR EWP0402YR Description Kit, DIN Rail Bracket 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin. Cable, power Assembly, 40" pigtail (default) 3' Cable Assembly, RJ-45 to DB9 Female 6'5" Ethernet cable, Cat 5 Enhanced, Shielded, Blue Ignition Edge Jail IQ AutoSol eACM Software v1.0.3 ZumLink / ZumIQ Developer Edition v1.1.0 ZumLink / ZumIQ Developer Edition v1.1.2.2 (default) ZumLink / ZumIQ Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled Setting, WC Custom Applications - Disabled (Default) Enabled IQ License Key - No Reset DevUser Password login - Enable Devuser Password Login - Unique Whip Stub Antenna 900 MHz 1/4 Wave 0 dBi with Straight SMA Male RF connector. Whip Stub Antenna 900 MHz Half Wave 2 dBi Right Angle-360 degree swivel with Straight SMA 896-940 MHz 5.15 dBi open coil antenna. 896-970 MHz 5 dBi trilinear elevated feed antenna. 890-960 MHz 8.65 dBi 3 element Yagi directional antenna. 1 Year Extended Warranty (option for Z9-P2 only) 2 Year Extended Warranty (option for Z9-P2 only) Options: Description ECD0324ER FWT1004IE FWT1030AU FWT1100TP FWT1122TP FWT1122TB SET0000CA SET0001CA SET0002CA SET0000ZD SET0001ZD 6'5" Ethernet cable, Cat 5 Enhanced, Shielded, Blue (option for Z9-PC-SR001 only) 3' Cable Assembly, RJ-45 (ETH) to DB9 Female Ignition Edge Jail IQ AutoSol eACM Software v1.0.3 ZumLink ZumIQ Developer Edition v1.1.0 ZumLink ZumIQ Developer Edition v1.1.2.2 (default) Z9-Pxx / ZIQ-Pxx Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled Setting, WC Custom Applications - Disabled Enabled IQ License Key - No Reset DevUser Password login - Enable Devuser Password Login - Unique ECD0658EB Options: Description AOH4003SP Kit, DIN Rail Bracket, Reversible, ZumLink Z9-PE Cable Assembly, 12" power, 2-SKT Plug to Barrel Jack, Z9-PE Cable Assembly, 40" External Power Pigtail, Z9-PE (default) 3' Cable Assembly, RJ-45 (ETH) to DB9 Female 6'5" Ethernet cable, Cat 5 Enhanced, Shielded, Blue 800mA, Wall Mount Power Adapter, with barrel connector. Mates with ASC0002ZL Ignition Edge Jail IQ AutoSol eACM Software v1.0.3 ZumLink ZumIQ Developer Edition v1.1.0 ZumLink ZumIQ Developer Edition v1.1.2.2 (default) Z9-Pxx / ZIQ-Pxx Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled ASC0002ZL ASC0003ZL ECD0324ER ECD0658EB EMD1280UW FWT1004IE FWT1030AU FWT1100TP FWT1122TP FWT1122TB SET0000CA SET0001CA SET0002CA SET0000ZD SET0001ZD EAN0900SQ EAN0900SR EAN0900WC EAN0905WC EAN0906YC MENU Model SPECS Z9-PE2 902 - 928 MHz Enclosed Data Port: Serial and Ethernet RF Connector: TNC Female Protocol:  RS232 / RS485, TCP/IP EWP0401YR EWP0402YR Options: Description AOH4003SP EMD1280AX ASC2402PT ECD0324ER ECD0658EB FWT1004IE FWT1030AU FWT1100TP FWT1122TP FWT1122TB SET0000CA SET0001CA SET0002CA SET0000ZD SET0001ZD Kit, DIN Rail Bracket, Reversible, ZumLink Z9-PE2 EAN0900SQ EAN0900SR EAN0900WC EAN0905WC EAN0906YC MENU Model SPECS Z9-IO-PE 902 - 928 MHz Enclosed Data Port: Serial and Ethernet RF Connector: TNC Female Protocol:  RS232 / RS485, TCP/IP MENU Setting, WC Custom Applications - Disabled Enabled IQ License Key - No Reset DevUser Password login - Enable Devuser Password Login - Unique Whip Stub Antenna 900 MHz 1/4 Wave 0 dBi with Straight SMA Male RF connector. Whip Stub Antenna 900 MHz Half Wave 2 dBi Right Angle-360 degree swivel with Straight SMA Male RF connector. 896-940 MHz 5.15 dBi open coil antenna. 896-970 MHz 5 dBi trilinear elevated feed antenna. 890-960 MHz 8.65 dBi 3 element Yagi directional antenna. 1 Year Extended Warranty 2 Year Extended Warranty EWP0401YR EWP0402YR 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin. Cable, power Assembly, 40" pigtail (default) 3' Cable Assembly, RJ-45 (ETH) to DB9 Female 6'5" Ethernet cable, Cat 5 Enhanced, Shielded, Blue Ignition Edge Jail IQ AutoSol eACM Software v1.0.3 ZumLink ZumIQ Developer Edition v1.1.0 ZumLink ZumIQ Developer Edition v1.1.2.2 (default) Z9-Pxx / ZIQ-Pxx Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled Setting, WC Custom Applications - Disabled Enabled IQ License Key - No Reset DevUser Password login - Enable Devuser Password Login - Unique Whip Stub Antenna 900 MHz 1/4 Wave 0 dBi with Straight SMA Male RF connector. Whip Stub Antenna 900 MHz Half Wave 2 dBi Right Angle-360 degree swivel with Straight SMA Male RF connector. 896-940 MHz 5.15 dBi open coil antenna. 896-970 MHz 5 dBi trilinear elevated feed antenna. 890-960 MHz 8.65 dBi 3 element Yagi directional antenna. 1 Year Extended Warranty 2 Year Extended Warranty Options: Description AOH4003SP ASC2402PT ECD0324ER ECD0658EB EMD1280UW FWT1122TP FWT1122TB SET0000CA SET0001CA Kit, DIN Rail Bracket, Reversible, ZumLink Z9-PE2 Cable, power Assembly, 40" pigtail 3' Cable Assembly, RJ-45 (ETH) to DB9 Female 6'5" Ethernet cable, Cat 5 Enhanced, Shielded, Blue 800mA, Wall Mount Power Adapter, with barrel connector. Mates with ASC0002ZL ZumLink ZumIQ Developer Edition v1.1.2.2 (default) Z9-Pxx / ZIQ-Pxx Family Firmware Version 1.1.2.2 (default) Setting, WC Custom Applications - Enabled Setting, WC Custom Applications - Disabled Model SPECS FGR3-CE-U 902 - 928 MHz Enclosed Data Port: DB9 Options: Cable, Diagnostics Port and Programming. MBRK-DIN-K AOB7001AA MBRK-DIN-N DIN Rail mounting bracket kit for Gannet style enclosures. (edge bracket) Din Rail mount bracket assembly for the new enclosure. EMD1280AX RF Connector: TNC Female Protocol: RS232 / RS485 MENU Model SPECS Description ASC0409DC ECN0502TB ASC0032TF ASC0032TN ECD2409DM ECN1234TN FWF110011 SET0001TD SET0002TD SET0128AE SET0192AE SET0256AE EWP0401YR EWP0402YR Options: 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin (default) Power connector, locking 2-Pin Phoenix type. Note: Connector only. For designing a custom power harness. 3' LMR-240 Coaxial cable with N-Type Female RF connector and TNC Male connector. 3' LMR-240 Coaxial cable with N-Type Male RF connector and TNC Male connector. 6' DB9 Serial extender cable, straight through, Male to Female (Default) RF adapter, TNC Male to N-Type Female. FGR3 v11.00.11 Firmware Release (default) Setting, TDMA Enabled Setting, Super Epoch TDMA Setting, 128 AES Encryption Enabled Setting, 192 AES Encryption Enabled Setting, 256 AES Encryption Enabled 1 Year Extended Warranty 2 Year Extended Warranty Description FGR3-C-U ASC2009DC Cable, Diagnostics Port and Programming 902 - 928 MHz Board Level Data Port: 10-Pin Header RF Connector: SMA Female Protocol:  RS232 / RS485 MBRK-DIN-K PMB-ENCL EMD1280UW ASC3610CP DIN Rail mounting bracket kit for Board Level radios. Protective mounting bracket for Board Level radios. 800mA, Wall Mount Power Adapter with barrel connector. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin for FGR, FGR2, & FGR3 Series board level transceivers, w/DB9 connector and barrel jack for power. Mates with EMD1280UW Power Adapter MENU Model SPECS FGR3-T-U 902 - 928 MHz Board Level Data Port: 10-Pin Header RF Connector: SMA Female Protocol:  TTL MENU ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGR, FGR2, & FGR3 Series board level transceivers, w/flying leads EOP7510LP FWF110011 SET0001TD SET0002TD SET0128AE SET0192AE SET0256AE Clear Light Pipe, Snap-On FGR3 v11.00.11 Firmware Release (default) Setting, TDMA Enabled Setting, Super Epoch TDMA Setting, 128 AES Encryption Enabled Setting, 192 AES Encryption Enabled Setting, 256 AES Encryption Enabled Options: Description ASC2009DC Cable, Diagnostics Port and Programming MBRK-DIN-K PMB-ENCL EMD1280UW ASC3610CP DIN Rail mounting bracket kit for Board Level radios. Protective mounting bracket for Board Level radios. 800mA, Wall Mount Power Adapter with barrel connector. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin for FGR, FGR2, & FGR3 Series board level transceivers, w/DB9 connector and barrel jack for power. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGR, FGR2, & FGR3 Series board level transceivers, w/flying leads EOP7510LP FWF110011 SET0001TD SET0002TD SET0128AE SET0192AE SET0256AE Clear Light Pipe, Snap-On FGR3 v11.00.11 Firmware Release (default) Setting, TDMA Enabled Setting, Super Epoch TDMA Setting, 128 AES Encryption Enabled Setting, 192 AES Encryption Enabled Setting, 256 AES Encryption Enabled Model SPECS FGR2-CE-U (International) 902 - 928 MHz Enclosed Data Port: DB9 RF Connector: TNC Female Protocol: RS232 / RS485 MENU Model SPECS Options: Description ASC0409DC Cable, Diagnostics Port and Programming. AOB7001AA MBRK-DIN-N MHS-WMS DIN Rail mounting bracket kit for Gannet style enclosures. EMD1280AX ASC0032TF ASC0032TN ECD2409DM ECN1234TN FWF1074AA FWF0877AA FWF1067AA FWF1068AA SET0001TD SET0002TD SET0128AE SET0192AE SET0256AE EWP0401YR EWP0402YR Mounting shoe for Gannet radios. 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin. (Default) 3' LMR-240 Coaxial cable with N-Type Female RF connector and TNC Male connector. 3' LMR-240 Coaxial cable with N-Type Male RF connector and TNC Male connector. 6' DB9 Serial extender cable, straight through, Male to Female (default) RF adapter, TNC Male to N-Type Female. Firmware, FGR2 (D2, MM2) Family, v10.7.04 (default) Firmware, FGR2 (D2, MM2) Family, v8.77 Firmware, FGR2 (D2, MM2) Family, v10.6.7 Firmware, FGR2 (D2, MM2) Family, v10.6.8 Setting, TDMA Enabled Setting, Super Epoch TDMA Setting, 128 AES Encryption Enabled Setting, 192 AES Encryption Enabled Setting, 256 AES Encryption Enabled 1 Year Extended Warranty 2 Year Extended Warranty Options: Description FGR2-C-U (International) ASC2009DC Cable, Diagnostics Port and Programming. 902 - 928 MHz MBRK-DIN-K DIN Rail mounting bracket kit for Board Level radios. Board Level Data Port: 10-Pin Header RF Connector: Straight SMA Female Protocol:  RS232 / RS485 PMB-ENCL EMD1280UW ASC3610CP Protective mounting bracket for Board Level radios. 800mA, Wall Mount Power Adapter with barrel connector. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/DB9 connector and barrel jack for power. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/flying leads EOP7510LP FWF1074AA FWF0877AA FWF1067AA FWF1068AA SET0001TD SET0002TD SET0128AE SET0192AE SET0256AE Clear Light Pipe, Snap-On Firmware, FGR2 (D2, MM2) Family, v10.7.04 (default) Firmware, FGR2 (D2, MM2) Family, v8.77 Firmware, FGR2 (D2, MM2) Family, v10.6.7 Firmware, FGR2 (D2, MM2) Family, v10.6.8 Setting, TDMA Enabled Setting, Super Epoch TDMA Setting, 128 AES Encryption Enabled Setting, 192 AES Encryption Enabled Setting, 256 AES Encryption Enabled Model SPECS ASC2009DC Cable, Diagnostics Port and Programming. EXF0224WL Transformer 117/234vac Primary Dual 12v Secondarys 2 VA Wire leads Dual Bobbin 902 - 928 MHz ASC3610CP 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/DB9 connector and barrel jack for power. Mates with EMD1280UW Power Adapter MENU FGR2-CP FGR2-CP-S Board Level Data Port: 10-Pin Header RF Connector: Straight SMA Female Protocol:  RS232 / RS485 EOL July, 2020 Model SPECS FGR2-P ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/flying leads FWF0876LCP Firmware FGR2-CP v8.76LCP Whip Stub Antenna 900 MHz Half Wave 2 dBi Right Angle-360 degree swivel with Straight SMA Male RF connector. EAN0900SR MENU Options: Description AOH0001HT Kit, DIN Rail Bracket 902 - 928 MHz Board Level EMD1280AX EMD1230UX Data Ports: (4) Ports. Port 1 and 2: RJ-45 Serial; Port 3 and 4: RJ-45 Ethernet RF Connector: SMA Female Protocol:  RS232 / RS485, TCP/IP EOL July, 2020 MENU Model SPECS FGR2-PE FGR2-PE-U ECN0502TB ASC2402PT ECD0324ER ECD0324EC ECD0658EB ECD2408ED FWF0222AA FWF0314BA Options: Description AOB7001AA MBRK-DIN-N 902 - 928 MHz Enclosed MHS-WMS EMD1280AX Data Ports: (4) Ports. Port 1 and 2: RJ-45 Serial; Port 3 and 4: RJ-45 Ethernet RF Connector: TNC Female Protocol:  RS232 / RS485, TCP/IP EOL July, 2020 MENU Model SPECS FGR2-T-U (International) 902 - 928 MHz Board Level Data Port: 10-Pin Header RF Connector: Straight SMA Female Protocol:  TTL MENU Model SPECS 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin. AC Power Adapter 120VAC Input 12VDC Output 3A regulated with locking polarized 2-Pin. (Phoenix connector) Power connector, locking 2-Pin Phoenix type. Note: Connector only. For designing a custom power harness. (default) 2' Power Adapter pigtail Cable Assembly, 24 gauge, with front 2-Pin Phoenix connector. 3' Cable, RJ-45 to DB9 Female (Default) 3' Cable, RJ45 to Open End, Red 6' 5" Ethernet Cable, Cat 5 Enhanced, Shielded, Blue (default) 3' Cable, RJ-45 to DB9 Female, Null Modem Firmware, FGR2-P / PE-U, v2.22 Firmware FGR2-P / PE-U, v3.14 (default) Din Rail mount bracket assembly for the new enclosure. Mounting shoe for Gannet radios. 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin (Default) EMD1250XP Open ended power adapter (can be used as 24V plug). EMD1280UW 800mA, Wall Mount Power Adapter with barrel connector. Power connector, locking 2-Pin Phoenix type. Note: Connector only. For designing a custom power harness. 3' LMR-240 Coaxial cable with N-Type Female RF connector and TNC Male connector. 3' LMR-240 Coaxial cable with N-Type Male RF connector and TNC Male connector. 2' Power Adapter pigtail Cable Assembly, 24 gauge, with front 2-Pin Phoenix connector. 3' Cable, RJ45 to Open End, Red 3' Cable Assembly, RJ-45 to DB9 Female (default) 6' 5" Ethernet Cable, Cat 5 Enhanced, Shielded, Blue (default) 3' Cable, RJ-45 to DB9 Male, Null Modem RF Connector, adapter, TNC Male to N-Type Female. Firmware, FGR2-P / PE-U, v2.22 Firmware FGR2-P / PE-U, v3.14 (default) Setting, TDMA Enabled Setting, Super Epoch TDMA 1 Year Extended Warranty 2 Year Extended Warranty ECN0502TB ASC0032TF ASC0032TN ASC2402PT ECD0324EC ECD0324ER ECD0658EB ECD2408ED ECN1234TN FWF0222AA FWF0314BA SET0001TD SET0002TD EWP0401YR EWP0402YR Options: Description ASC2009DC Cable, Diagnostics Port and Programming. MBRK-DIN-K DIN Rail mounting bracket kit for Board Level radios. Protective mount bracket for Board Level radios. 800mA, Wall Mount Power Adapter with barrel connector. 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/DB9 connector and barrel jack for power. Mates with EMD1280UW Power Adapter PMB-ENCL EMD1280UW ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/flying leads EOP7510LP FWF1074AA FWF0877AA FWF1067AA FWF1068AA FWF1070AA SET0001TD SET0002TD SET0128AE SET0192AE SET0256AE Clear Light Pipe, Snap-On Firmware, FGR2 (D2, MM2) Family, v10.7.04 (default) Firmware, FGR2 (D2, MM2) Family, v8.77 Firmware, FGR2 (D2, MM2) Family, v10.6.7 Firmware, FGR2 (D2, MM2) Family, v10.6.8 Firmware, FGR2 (D2, MM2) Family, v10.7 Setting, TDMA Enabled Setting, Super Epoch TDMA Setting, 128 AES Encryption Enabled Setting, 192 AES Encryption Enabled Setting, 256 AES Encryption Enabled Options: Description FGR2-WC (International) MBRK-DIN-K DIN Rail mounting bracket kit 902 - 928 MHz Enclosed Waterproof EMD1280UW ASC0613WW 800mA, Wall Mount Power Adapter with barrel connector. Cable assembly, 6' Blue tinned leads and 11-pin fisher connector, for WP housing, no Power Supply Jack. Port: Fischer 11-Pin ASC0613PK RF Connector: N-Type Female Protocol:  RS232 / RS485 FWF1074AA FWF1070AA Cable assembly, 6' Blue 11-pin pisher connecter, for WP housing, with Power Supply Jack and DB9 connector. Allows convenient programming & diagnostics of waterproof transceivers. Firmware, FGR2 (D2, MM2) Family, v10.7.04 (default) Firmware, FGR2 (D2, MM2) Family, v10.7 MENU FWF1067AA FWF1068AA SET0001TD SET0002TD SET0128AE SET0192AE SET0256AE EWP0401YR EWP0402YR Firmware, FGR2 (D2, MM2) Family, v10.6.7 Firmware, FGR2 (D2, MM2) Family, v10.6.8 Setting, TDMA Enabled Setting, Super Epoch TDMA Setting, 128 AES Encryption Enabled Setting, 192 AES Encryption Enabled Setting, 256 AES Encryption Enabled 1 Year Extended Warranty 2 Year Extended Warranty Model SPECS FGRIO-M 902 - 928 MHz Board Level Data Port: 10-Pin Header RF Connector: SMA Female Protocol: RS232 / RS485 MENU Model SPECS Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC2009NM ASC3610CP NULL MODEM Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. EOP7510LP FWD0266ZA FWD0269AA Clear Light Pipe, Snap-On Firmware, Dev, FGRIO-M, v2.66z Firmware, Dev, FGRIO-M, v2.69 (default) Options: Description FGR2-IO-IOE ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 902 - 928 MHz Enclosed Data Port: 10-Pin Header ASC2009NM EMD1280UW ASC3610CP NULL MODEM Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 800mA, Wall Mount Power Adapter with barrel connector. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack.Mates with EMD1280UW Power Adapter 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter RF Connector: SMA Female Protocol:  Modbus, RS232 / RS485 MENU Model SPECS FGR2-IOS-CE-U 902 - 928 MHz Enclosed Data Port: DB9 RF Connector: TNC Female Protocol:  Modbus,  RS232 / RS485 MENU Model SPECS FGR2-IOS-C-U 902 - 928 MHz Board Level Data Port: 10-Pin Header RF Connector: SMA Female Protocol:  Modbus,  RS232 / RS485 MENU ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. FWZ0977AA EAN0900SQ EWP0401YR EWP0402YR Firmware, FGR2 30VIO & FGR2 IOE, v9.77 (default) Options: Antenna, 900 MHz, Whip Stub, 1/4 Wave, 0 dBi, with Straight SMA Male RF connector. 1 Year Extended Warranty 2 Year Extended Warranty Description ASC0409DC Cable, Diagnostics Port and Programming. DB-9 to mini 3-pin AOB7001AA MBRK-DIN-N MHS-WMS ECD2409DM FWZ0977AA SET0001TD DIN Rail mounting bracket kit for Gannet style enclosures. (edge bracket) SET0002TD EWP0401YR EWP0402YR Setting, Super Epoch TDMA 1 Year Extended Warranty 2 Year Extended Warranty Options: Mounting shoe for Gannet radios. (plate bracket) 6' Serial cable, DB9, straight through, Male to Female. Firmware, FGR2 30VIO & FGR2 IOE, v9.77 (default) Setting, TDMA Enabled Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC2009NM MBRK-DIN-K PMB-ENCL ASC3610CP NULL MODEM Cable, Diagnostics and Programming 20-Pin Board Level connector to DB9 DIN Rail mounting bracket kit for Board Level radios. Protective mounting bracket for Board Level radios. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. EOP7510LP FWZ0977AA Clear Light Pipe, Snap-On Firmware, FGR2 30VIO & FGR2 IOE, v9.77 (default) Model SPECS IOE-4404 IO Expansion Serial Base Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin connector to DB9 (Board Level) ASC2009NM EMD1280UW AWR3610SJ Diagnostics and Programming cable, null-modem, 20-Pin, Board Level connector to DB9 800mA, Wall Mount Power Adapter with barrel connector. NULL MODEM, data interface cable, 10-pin to 10-pin, to connect two serial devices with joined power supply lines and a power plug (2mm Barrel Connector). (Rainbow Cable + power) NULL MODEM, data interface cable, 10-pin to 10-pin, to connect two serial devices. (Rainbow Cable ) 3' NULL MODEM Data cable, 10-Pin, Board Level connector plus a power jack to DB9. 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, oriented away from board and DB9 connector plus a jack for power input. AWR3610SP ASC3610CP ASC3610DJ MENU Model SPECS IOE-4422 IO Expansion Serial Base ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, oriented away from board. FWI0222AA Firmware, I/O Expansion, v2.2.2 (default) Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin connector to DB9 (Board Level) ASC2009NM EMD1280UW AWR3610SJ Diagnostics and Programming cable, null-modem, 20-Pin, Board Level connector to DB9 800mA, Wall Mount Power Adapter with barrel connector. NULL MODEM, data interface cable, 10-pin to 10-pin, to connect two serial devices with joined power supply lines and a power plug (2mm Barrel Connector). (Rainbow Cable + power) NULL MODEM, data interface cable, 10-pin to 10-pin, to connect two serial devices. (Rainbow Cable ) 3' NULL MODEM Data cable, 10-Pin, Board Level connector plus a power jack to DB9. 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/DB9 connector and barrel jack for power. Mates with EMD1280UW Power Adapter AWR3610SP ASC3610CP ASC3610DJ MENU Model SPECS IOE-4440 IO Expansion Serial Base ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, oriented away from board. FWI0222AA Firmware, I/O Expansion, v2.2.2 (default) Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin connector to DB9 (Board Level) ASC2009NM EMD1280UW AWR3610SJ Diagnostics and Programming cable, null-modem, 20-Pin, Board Level connector to DB9 800mA, Wall Mount Power Adapter with barrel connector. NULL MODEM, data interface cable, 10-pin to 10-pin, to connect two serial devices with joined power supply lines and a power plug (2mm Barrel Connector). (Rainbow Cable + power) NULL MODEM, data interface cable, 10-pin to 10-pin, to connect two serial devices. (Rainbow Cable ) 3' NULL MODEM Data cable, 10-Pin, Board, Level connector plus a power jack to DB9. 3' Data Interface cable, 10-Pin for FGR and FGR2 Series board level transceivers, w/DB9 connector and barrel jack for power. Mates with EMD1280UW Power Adapter AWR3610SP ASC3610CP ASC3610DJ MENU ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, oriented away from board. FWI0222AA Firmware, I/O Expansion, v2.2.2 (default) Model SPECS GX-C 2.4 - 2.483 GHz Board Level Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC3610CP 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ Data Ports: 10-Pin Header RF Connector: SMA Female Protocol:  RS232 MENU Model SPECS ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. FWI0877AA FWI0979AA FWG0983AA SET0001PL SET0001TD SET0256AE Firmware, MM24, GX, I2, v8.77 Firmware, GX / I2 Firmware v9.7.9 Firmware GX / I2 Firmware v9.8.3 (Default) Setting, GX Output Power limited to 20dB Setting, TDMA Enabled Setting, 256 AES Encryption Enabled Options: Description GX-CE ASC0409DC Cable, Diagnostics Port and Programming. DB-9 to mini 3-pin Din Rail mount bracket assembly for the new enclosure Enclosed Data Port: DB9 AOB7001AA MBRK-DIN-N MHS-WMS EMD1280AX Mounting shoe for Gannet radios 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin (Default) ECD2409DM FWG0900AE FWI0979AA FWG0983AA SET0001PL SET0256AE EWP0401YR EWP0402YR 6' DB9 Serial extender cable, straight through, Male to Female (default) Firmware, v9.0.0, GX/GXM AES Firmware, GX / I2 Firmware v9.7.9 Firmware GX / I2 Firmware v9.8.3 (Default) Setting, GX Output Power Limited to 20dB Setting, 256 AES Encryption Enabled 1 Year Extended Warranty 2 Year Extended Warranty 2.4 - 2.483 GHz RF Connector: TNC Female Protocol:  RS232 / RS485 MENU Model SPECS GX-T 2.4 GHz Board Level Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC3610CP 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ Data Port: 10-Pin Header RF Connector: SMA Female Protocol: Serial TTL MENU Model SPECS GXM-T14 GXM-T14-SR300 2.4 GHz Board Level Options: Description ASC2009DC ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. FWI0877AA FWI0979AA FWG0983AA SET0001PL SET0001TD SET1256AE Firmware, MM24, GX, I2, v8.77 Firmware, GX / I2 Firmware v9.7.9 Firmware GX / I2 Firmware v9.8.3 (Default) Setting, GX Output Power Limited to 20dB Setting, TDMA Enabled Setting, 256 AES Encryption Enabled Options: Description ASC2414DJ ASC3610CP ASC3610DJ Data Interface cable, 14-Pin 2-row board Level connector to DB-9, plus power jack (2mm Barrel power connector), and setup switch. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter Data Port: 14-Pin Header RF Connector: MMCX Female Protocol: RS232 or TTL MENU Model SPECS GXM-T24 GXM-T24-SR100 GXM-T24-SR101 2.4 GHz Board Level Data Port: 24-Pin Header RF Connector: MMCX Female Protocol: RS232 or TTL MENU Model SPECS GXM-MR-R GXM-MR-T 2.4 GHz Board Level ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. FWG0878EA FWG0900AE FWI0979AA FWG0983AA SET0001PL SET0001TD SET0256AE Firmware GX/M v8.78 w/AES Encryption Firmware GX/M v9.0.0 w/AES Encryption Firmware GX / I2 Firmware v9.7.9. Firmware GX / I2 Firmware v9.8.3 (Default) Setting, GX Output Power Limited to 20dB Setting, TDMA Enabled Setting, 256 AES Encryption Enabled Options: Description ASC3610CP 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. ASC3610DJ 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. FWG0900AE FWI0979AA FWG0983AA SET0001PL SET0001TD SET0128AE SET0256AE Firmware GX/M v9.0.0 w/AES Encryption Firmware GX / I2 Firmware v9.7.9. Firmware GX / I2 Firmware v9.8.3 (Default) Setting, GX Output Power Limited to 20dB Setting, TDMA Enabled Setting, 128 AES Encryption Enabled (default on GXM-T24-SR100 Only) Setting, 256 AES Encryption Enabled (default on GXM-T24-SR101 Only) Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC3610CP 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ Data Port: 10-Pin Header RF Connector: MMCX Female Protocol: RS232 or TTL MENU ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. FWI0877AA FWI0979AA FWI0983AA SET0001PL SET0001TD SET0256AE Firmware, MM24, GX, I2, v8.77 Firmware, GX / I2 Firmware v9.7.9 Firmware GX / I2 Firmware v9.8.3 (Default) Setting, GX Output Power Limited to 20dB Setting, TDMA Enabled (default on GSM-MR-R only) Setting, 256 AES Encryption Enabled (Default) Model SPECS I2-IOM-U 2.4 - 2.483 GHz Board Level Port: 10-Pin Header RF Connector:  SMA Female Protocol: Serial. RS232 / RS485 MENU Model SPECS I2-IOS-C-U 2.4 - 2.483 GHz Board Level Port: 10-Pin Header RF Connector:  SMA Female Protocol: Serial. RS232 / RS485 MENU Model SPECS I2-IOS-C-U-SR010 2.4 - 2.483 GHz Board Level Port: 10-Pin Header RF Connector:  Right Angle SMA Female Protocol: Serial. RS232 / RS485 MENU Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC2009NM ASC3610CP NULL MODEM Cable, Diagnostics and Programming 20-Pin Board Level connector to DB9 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. EOP7510LP FWI0870LA SET0001TD SET0002TD Clear Light Pipe, Snap-On Firmware, I2-IOM, v8.70L (default) Setting, TDMA Enabled Setting, Super Epoch TDMA Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC2009NM ASC3610CP NULL MODEM Cable, Diagnostics and Programming 20-Pin Board Level connector to DB9 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. EOP7510LP FWI0978KA FWI0981AA SET0001TD SET0002TD Clear Light Pipe, Snap-On Firmware, I2-IO, v9.78k Firmware, I2-IO, v9.81k (default) Setting, TDMA Enabled Setting, Super Epoch TDMA Options: Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 ASC2009NM ASC3610CP NULL MODEM Cable, Diagnostics and Programming 20-Pin Board Level connector to DB9 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. EOP7510LP SET0001TD SET0002TD Clear Light Pipe, Snap-On Setting, TDMA Enabled Setting, Super Epoch TDMA Model SPECS LRS140-CE 1.427 - 1.432 GHz Enclosed Data Port: DB9 Female RF Connector: N-Type Female Protocol: Serial. RS232 / RS485 EOL Aug, 2020 MENU Model SPECS LRS140-CSU 1.427 - 1.432 GHz Board Level Data Port: Straight 10-Pin Header RF Connector: SMA Female Protocol: Serial RS232 / RS485 EOL Aug, 2020 MENU Model SPECS LRS455-CE-U 435 - 470 MHz Enclosed Data Port: DB9 Female RF Connector: TNC Female Protocol: Serial RS232 / RS485 MENU Model SPECS LRS455-C-U 435 - 470 MHz Board Level Data Port: Straight 10-Pin Header RF Connector: SMA Female Protocol: Serial RS232 / RS485 MENU Options: Description ASC0409DC Cable, Diagnostics Port and Programming. DB-9 to mini 3-pin AOB7001AA MBRK-DIN-N MHS-WMS Din Rail mount bracket assembly for the new enclosure. EMD1280AX ASC0032TF ASC0032TN ECD2409DM ECN1234TN FWL0936CA SET0001TD Options: Mounting shoe for Gannet radios. 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin. (Default) 3' LMR-240 Coaxial cable with N-Type Female RF connector and TNC Male connector. 3' LMR-240 Coaxial cable with N-Type Male RF connector and TNC Male connector. 6' DB9 serial cable, straight through, Male to Female (default) RF adapter, TNC Male to N-Type Female. Firmware, 1.4GHz, 9.36c (default) Setting, TDMA Enabled Description ASC2009DC Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 MBRK-DIN-K ASC3610CP Mnt Bracket Assy Din Rail 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. ASC0032TF ASC0032TN ECD2409DM EOP7510LP FWL0936CA 3' LMR-240 Coaxial cable with N-Type Female RF connector and TNC Male connector. 3' LMR-240 Coaxial cable with N-Type Male RF connector and TNC Male connector. 6' DB9 serial cable, straight through, Male to Female. Clear Light Pipe, Snap-On Firmware, 1.4GHz, 9.36c (default) Options: Description ASC0409DC Cable, Diagnostics Port and Programming. DB-9 to mini 3-pin AOB7001AA MBRK-DIN-N MHS-WMS Din Rail mount bracket assembly for the new enclosure. EMD1280AX EMD1230UX ASC0032TF ASC0032TN ASC2402PT ECD2409DM ECN1234TN FWF0174AA FWF0179AA SET0001TD SET0002TD Options: Mounting shoe for Gannet radios. 800mA, power supply works for all radios with Phoenix connector; locking polarized 2-Pin. (Default) AC Power Adapter 120VAC Input 12VDC Output 3A regulated with locking polarized 2-Pin. (Phoenix connector) 3' LMR-240 Coaxial cable with N-Type Female RF connector and TNC Male connector. 3' LMR-240 Coaxial cable with N-Type Male RF connector and TNC Male connector. Cable, power Assembly, 40" pigtail 6' DB9 serial cable, straight through, Male to Female. (Default) RF adapter, TNC Male to N-Type Female. Firmware, 455 MHz, v1.74 Firmware, 455 MHz, v1.79 (default) Setting, TDMA Enabled Setting, Super Epoch TDMA Description ASC2009NM Diagnostics and Programming cable, null-modem, 20-Pin, Board Level connector to DB9 ASC2009DC EMD1230FP ASC3610CP Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 AC Power Adapter, 120VAC Input, 12VDC Output, 3A, regulated. Raw tinned calbe ends. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. EOP7510LP FWF0174AA FWF0179AA Clear Light Pipe, Snap-On Firmware, 455 MHz, v1.74 Firmware, 455 MHz, v1.79 (default) Model SPECS LRS455-T-U 435 - 470 MHz Board Level Data Port: Straight 10-Pin Header RF Connector: SMA Female Protocol: Serial TTL MENU Options: Description ASC2009NM Diagnostics and Programming cable, null-modem, 20-Pin, Board Level connector to DB9 ASC0409DC EMD1230FP ASC3610CP Cable, Diagnostics and Programming, 20-Pin Board Level connector to DB9 AC Power Adapter, 120VAC Input, 12VDC Output, 3A, regulated. 3' NULL MODEM Data cable, 10-Pin Board Level connector to DB9, plus a power jack. 3' Data Interface cable, 10-Pin board level connector to DB9, plus barrel jack for power and setup switch. Mates with EMD1280UW Power Adapter ASC3610DJ ASC3610FL 3' Data Interface cable, 10-Pin for FGRO Series Board Level transceivers, with raw tinned leads. EOP7510LP FWF0174AA FWF0179AA Clear Light Pipe, Snap-On Firmware, 455 MHz, v1.74 Firmware, 455 MHz, v1.79 (default) Model SPECS Options: Description WC20i-485 WC20i-485-2DI WC20i-AN ASM0001SF Replacement battery for WC20i Endpoints & WC15i Multi-Input, UL-C1D1. WC-BAT-3D-IS WC20i-DI WC20i-HART WC20i-KTh WC20i-RTD Replacement battery for WC20i Modular Endpoint Solar Panel kit with bracket, charger, and High Capacity battery pack (Included when purchasing “-Solar” models) WC-USB-4PIN 902 - 928 MHz Enclosed Data Port: DB9 Female RF Connector: N-Type Female Protocol: Serial. RS232 / RS485 Model SPECS WC20i-Solar WAVECONTACT USB to Serial Interface Cable, 4-pin Endpoint. MENU Options: Description WC20i-485-S WC20i-485-2DI-S WC20i-AN-S WC20i-DI-S WC20i-HART-S ASM0004SF Mounting Kit for WC20i Solar Kit - Yokogawa EJA Series. ASM0005SF Mounting Kit for WC20i Solar Kit - Rosemount 5300. ASM0007SF Mounting Kit for WC20i Solar Kit - Vega Single Chamber Radar. WC-BAT-3D-IS WC20i-KTh-S WC20i-RTD-S ASC0001SF Replacement battery for WC20i Modular Endpoint Solar Panel kit with bracket, charger, and High Capacity battery pack (Included when purchasing “-Solar” models) Solar Kit Extension Cable. WC-USB-4PIN WAVECONTACT USB to Serial Interface Cable, 4-pin Endpoint. 902 - 928 MHz Enclosed Data Port: DB9 Female RF Connector: N-Type Female Protocol: Serial. RS232 / RS485 Model SPECS WC20i-Solar MENU WC25i-WL-PM WC25i-WL-W Options: Description WC-USB-DB9 USB to Serial Interface Cable DB9 902 - 928 MHz ASM0008SF Whip Antenna suitable for use in fiberglass / plastic enclosures with direct mount to DIN mounted card. Enclosed Data Port: DB9 Female RF Connector: N-Type Female Protocol: Serial. RS232 / RS485 ASM0009SF Panel Mount Antenna, for mount outside of an enclosure. Model SPECS WC30i-PSI-1 WC30i-PSI-20 WC30i-PSI-100 WC30i-PSI-500 WC30i-PSI-1k WC30i-PSI-3k WC30i-PSI-5k WC30i-PSI-10k 902 - 928 MHz Enclosed Data Port: DB9 Female RF Connector: N-Type Female MENU Options: Description ASM0002SF WC30i Wireless Sensor replacement battery. ASC0003SF WAVECONTACT USB to Serial Interface Cable, 4-pin Endpoint. Protocol: Serial. RS232 / RS485 Model SPECS MENU WC40i-AN WC40i-MB Options: Description ASC0002SF ASM0008SF WAVECONTACT USB to Serial Interface Cable DB9 Whip Antenna suitable for use in fiberglass / plastic enclosures with direct mount to DIN mounted card. WC40i-COUNT WC40i-RSD WC40i-BB ASM0009SF Panel Mount Antenna, for mount outside of an enclosure. 902 - 928 MHz Enclosed Data Port: DB9 Female RF Connector: N-Type Female Protocol: Serial. RS232 / RS485 Model SPECS MENU WC45i-GW WC45i-GW-DIN Options: Description ASC0002SF WAVECONTACT USB to Serial Interface Cable DB9 902 - 928 MHz ASM0008SF Whip Antenna suitable for use in fiberglass / plastic enclosures with direct mount to DIN mounted card. Enclosed Data Port: DB9 Female RF Connector: N-Type Female Protocol: Serial. RS232 / RS485 ASM0009SF Panel Mount Antenna, for mount outside of an enclosure. MENU
ECD0658EB 价格&库存
很抱歉,暂时无法提供与“ECD0658EB”相匹配的价格&库存,您可以联系我们找货
