PIR FRESNEL LENS_PF297-79810R-BLACK
    FRESNELFACTORY
    PIR FRESNEL LENS (LENS SIZE 56.8
PIR FRESNEL LENS_PF297-79810R-BLACK 数据手册
.Inc Tel: +82-70-7605-0693, Email: ashton@Fresnel Factory.com, www.FresnelFactory.com 504, Sungsin Techno Park, , Yeongtong-ro 323beon-gil 38, Yeongtong-gu, Suwon-si, Gyeonggi-do, Republic of Korea PF297-79810R Product Specification 1. Dimensions Unit : mm General tolerance : ±0.2 mm Tel: +82-70-7605-0693, Email: ashton@Fresnel Factory.com, www.FresnelFactory.com FresnelFactory.Inc 504, Sungsin Techno Park, , Yeongtong-ro 323beon-gil 38, Yeongtong-gu, Suwon-si, Gyeonggi-do, Republic of Korea 2. Field of view (m) 7 6 40° 5 32° 4 24° 3 16° 2 1 0 8° 1 2 3 1 6° ° 5 2 12° 14 4 32° 3 0 0 6 1 2 3 4 5 6 7 7 0 1 2 3 4 5 6 7 8 9 TOP VIEW 10 11 12 (m) SIDE VIEW 8 9 10 11 (m) Tel: +82-70-7605-0693, Email: ashton@Fresnel Factory.com, www.Fresnel Factory.com 504, Sungshin Techno Park, Yeongtong323beongil, Yeongtong-gu, Suwon-si, Gyeonggi-do, South Korea 3. Material for PIR/FIR(8~13um) wavelength The thermopile and passive infrared sensor that is using for motion sensor detects the wavelength of 8~13um. Without Fresnel lens, the sensor only can detect less than 1m distance and narrower space with lens. To work with Pyroelectronic detector and thermopile, Fresnel lens that collects infrared rays as a sensor is required. Fresnel Factory manufactures Fresnel lenses for passive infrared and absolute temperature sensors. 3-1) Poly FIR 200 (Graph3 – Transmittance of PIR, FIR(Far infrared) material) Material is important to have a wide FOV and excellent Far Infrared transmittance. Therefore, Fresnel Factory is using Poly FIR200 and Poly FIR25, which have a wide FOV and excellent FIR transmittance Transmittance (%) Material name 8~12um Poly FIR200 42.81% at 0.65T PIR(Passive Infrared) sensor detects infrared rays in the 8~12um wavelength emitted from body temperature. Fresnel Factory’s Poly FIR200 has an excellent transmittance of 42.81% on average from 8~12um wavelength when 0.65T. Properties Max tensile strength Impact strength HDT(0.45Map) Melt Flow Rate 24.5Mpa 30.15J/m 73℃ 20g/min The price is low since the productivity is high because the melt flow rate is excellent and the time required for injection is short. Despite having the above properties, it is not suitable for use in environments exposed to high temperatures, impacts, and scratches due to its low hardness, impact strength, and HDT compared to Poly FIR25. Reference *HDT(Heat Deflection Temperature) : It exhibits heat resistance at a specific temperature when the sample has displacement of 2.5mm under a specific load. *Hardness : Abrasion resistance *Izod Impact strength : Impact resistance
PIR FRESNEL LENS_PF297-79810R-BLACK 价格&库存
很抱歉,暂时无法提供与“PIR FRESNEL LENS_PF297-79810R-BLACK”相匹配的价格&库存,您可以联系我们找货
  • 1+18.320721+2.37472
  • 5+16.224495+2.10301
  • 10+15.4671610+2.00484
  • 25+14.5551725+1.88663
  • 50+13.9367450+1.80647
  • 100+13.36763100+1.73270
  • 500+12.22539500+1.58465
  • 1000+11.800201000+1.52953
  • 5000+10.944155000+1.41857
库存:284
