GS1011MEE-EVK2-S2W-WEB 数据手册
T BRIEF
PR O D UCT B RI E F
GainSpan GS1011M EVK Mrk
II Evaluation Kit
PRODUCT OVERVIEW
The GS1011M EVK Mrk II Evaluation Kit provides GainSpan customers
the means to evaluate capabilities of the GS1011 ultra-low power
wireless system-on-a-chip and the Serial-to-WiFi embedded software for
Wi-Fi networks. The Serial-to-WiFi embedded software allows devices
and appliances manufacturers to easily add Wi-Fi capabilities to their
products with minimal impact on host microcontroller firmware.
The GS1011M EVK Mrk II Evaluation Kit provides all the hardware and
software necessary to quickly set up a serial (UART or SPI) based link to
a PC or external microcontroller. In order to evaluate the ease of adding
secure Wi-Fi communications to a product using the GainSpan AT
command set, the kit includes all the software tools necessary for
configuration of Serial-to-Wi-Fi and GS1011M modules, data transfer
using “AT” command-set and protocol analyzer for validation of packet &
frame fields. For additional details on the module features, please refer to
the GS1011M module product briefs.
Host Microcontroller
Embedded
Application
Serial-to-WiFi
“Driver”
GS1011M
SPI or
UART
Serial-to-WiFi
Power Management
SSL
HTTP Server
TCP/IP
Device Drivers
RTOS
WPA/2
WPS
802.11 MAC
BENEFITS:
GS1011M highly integrated ultra- low power
802.11b Wi-Fi radio Family of modules
Easy integration of Wi-Fi and web
connectivity to devices with existing
microcontroller and UART or SPI interface
Easy device provisioning through LimitedAP (embedded web pages) or Wi-Fi
Protected Set-up (WPS)
Serial to Wi-Fi firmware allows easy addition
of Wi-Fi capabilities to embedded system
Offloads Wi-Fi and TCP/ IP networking from
smaller host microcontrollers
Simple AT commands for configuration and
data communication
Support for over the air firmware updates
using external flash
FEATURES:
The GS1011M EVK Mrk II Evaluation Kit enables GainSpan customers to
develop software on their existing microcontrollers to support the “AT”
command set, and connect it to either the UART or SPI interface on the
evaluation kit reference board.
Push button for Alarms and Firmware
Restore from External Flash
Full Wi-Fi and networking stack services
including TCP/UDP/IP, DNS, DHCP, HTTP
and SSL
Wi-Fi Security
Supports Infrastructure, Limited AP and
Adhoc networking
Two UART and SPI ports. Clock Data rates
are
o UART: up to 921 Kbps
o SPI: up to 3 Mbps
o
WEP, WPA/WPA2 Personal
o
WPA/WAP2 Enterprise
o
Wi-Fi Protected Setup (WPS 2.0)
Power Save Modes – PS-Poll, Sleep, Deep
Sleep, Standby
PR O D UCT B RI E F
AT COMMAND SET
The ‘AT’ command set supports the full range of capabilities provided by the underlying GainSpan network services software that
abstract the complexity of IP networking and Wi-Fi communication from the embedded application, allowing complete control.
Types
Commands
Serial Interface Configuration
Set Serial Parameters (baud rate, flow control)
Profile Management
Load/Save/Restore profiles
Wi-Fi Interface
Scan/associate/disassociate
Security
Enable/set security
Network Management
Static or DHCP client/server, DNS client/server
Connection management
UDP/TCP/HTTP client/server
Power management
Enable/disable PS-Poll, deep sleep and standby
Services
Upgrade firmware
EVALUATION BOARD SPECIFICATIONS
Feature
Description
Radio Protocol
IEEE 802.11b (IEEE 802.11 b/g/n Compatible)
RF Module
GS1011M Ultra-Low Power Module Family
(GS1011MIP, GS1011MIE, GS1011MEP, GS1011MEE)
RF Output Power (Typical)
8 dBm (GS1011MIx), 18 dBm (GS1011MEx)
Radio Frequency
2.412 – 2.484 GHz
Antenna Type
PCB Trace (GS1011MxP) or u.FL connector for external antenna (GS1011MxE)
I/O Port
6-pin serial UART interface, 15540 compatible; DB9 RS232 Connector; SPI
Power Source
1.5 V Lithium Batteries (2x) or External Power Adapter
GS1011M Firmware
Serial to Wi-Fi (default); Temperature and light sensor (TLS) Application
Dimensions
3.5 in X 3.0 in (includes module and RS232 connector)
EVALUATION KIT CONTENTS
ITEM
Description
GS1011M Evaluation Board
Evaluation board based on low power GS1011M module
USB Memory Stick
Installation software for firmware, Documentation, Tools and Utilities
Batteries
Two 1.5V Lithium AA Batteries
Wi-Fi Access Point
Off the Shelf Wi-Fi Access Point for out of box functionality
Cable
6-pin serial UART to USB cable to connect to host PC
Software Tools
TeraTerm --- Open Source Serial Terminal Emulator
Wireshark --- Open Source, Network Protocol Analyzer
GSDemo – GainSpan tool to demonstrate TLS application
GS Flash Program --- GainSpan tool for Firmware Upgrade
Documentation
Quick Start Guide, Programmers Guide, Schematics
EVALUATION KIT ORDERING INFORMATION
ITEM
PART NUMBER
GS1011MIP-EVK2-S2W-WEB
GS1011MEP-EVK2-S2W-WEB
GS1011MIE-EVK2-S2W-WEB
© 2011. GainSpan Corporation; http://www.gainspan.com• info@gainspan.com
GS1011M EVK PB 2.0
Description
Serial to Wi-Fi Evaluation kit based on the ultra-low power GS1011M
module base board. The Serial to Wi-Fi firmware supports embedded webserver for provisioning
@GainSpan
GS1011MEE-EVK2-S2W-WEB 价格&库存
很抱歉,暂时无法提供与“GS1011MEE-EVK2-S2W-WEB”相匹配的价格&库存,您可以联系我们找货
