GS1011MIP-EVB2-S2W-WEB
    TELITWIRELESSSOLUTIONS(泰利特)
    EVAL BOARD 802.11
GS1011MIP-EVB2-S2W-WEB 数据手册
T BRIEF PR O D UCT B RI E F GainSpan GS1011M / GS1500M Evaluation Board Mrk II PRODUCT OVERVIEW The GS1011M/GS1500M Evaluation Board supports the GS1011M (802.11b) or GS1500M (802.11b/g/n) module family which provides customers the mean to evaluate the capabilities of GainSpan’s ultra-low power wireless solutions for Wi-Fi networks. The Serial to Wi-Fi embedded software on the modules allows devices and appliances manufacturers to easily add Wi-Fi capabilities to their products with minor impact on the host microcontroller firmware. EVALUATION BOARD DETAILS: Feature Description The evaluation board comes with pre-loaded serial to Wi-Fi firmware that supports a Limited AP mode, with built-in web-server for provisioning the device. The evaluation board works in conjunction with the serial to Wi-Fi evaluation kit software and firmware. The evaluation board has various jumpers, switches, push buttons and LED’s that provide support for evaluating different features and configuration based on the firmware loaded from the evaluation kit.. For details see the product briefs of the GS1011M or GS1500M modules. EVAL BOARD ORDERING INFORMATION PART NUMBER IEEE 802.11b/g/n RF Module(s) GS1011M (802.11b) or GS1500M (802.11b/g/n) Radio Frequency 2.4 – 2.497 GHz Antenna Type On-board PCB Trace or External (u.FL) I/O Port 6-pin serial UART ( 3.3V TTL), RS232 DB9 Connector, SPI Connector LED 2 LED’s to indicate state Memory External SPI Flash Memory for Firmware Upgrade and Restore Switches Push button for Alarms, Reset, WPS, and Configuration Program Switch For programming the module On/Off Switch Power on/off switch Serial Select Jumper Jumper to select between UART or RS232 interface or SPI Sensors Temperature and Light Power Source Battery or External Power Adapter Battery Two 1.5V AA Battery (Alkaline or Lithium) Lithium is recommended for longer battery life Power Source Select Select power source as either battery or external power adapter Power Adapter 3.3V Dimensions (in) 3.5 x 3.0 (includes module and RS232 connector) Description GS1011MIP-EVB2-S2W-WEB GS1011MIE-EVB2-S2W-WEB GS1011MEP-EVB2-S2W-WEB GS1011MEE-EVB2-S2W-WEB Serial to Wi-Fi Evaluation Board with – Serial to Wi-Fi Evaluation Board with – Serial to Wi-Fi Evaluation Board with – Serial to Wi-Fi Evaluation Board with – GS1500M-EVB-S2W-WEB Serial to Wi-Fi Evaluation Board with – GS1500M module © 2011. GainSpan Corporation; http://www.gainspan.com• info@gainspan.com EVB PB 2.0 Radio Protocol GS1011MIP module GS1011MIE module GS1011MEP module GS1011MEE module @GainSpan
GS1011MIP-EVB2-S2W-WEB 价格&库存
很抱歉,暂时无法提供与“GS1011MIP-EVB2-S2W-WEB”相匹配的价格&库存,您可以联系我们找货
