GS1011MIC-EVB2C-S2W-WEB 数据手册
T BRIEF
PR O D UCT B RI E F
GainSpan GS1011M / GS1500M
Evaluation Board Mrk II
PRODUCT OVERVIEW
The GS1011M/GS1500M Evaluation Board supports the GS1011M
(802.11b) or GS1500M (802.11b/g/n) module family which provides
customers the mean to evaluate the capabilities of GainSpan’s ultra-low
power wireless solutions for Wi-Fi networks. The Serial to Wi-Fi embedded
software on the modules allows devices and appliances manufacturers to
easily add Wi-Fi capabilities to their products with minor impact on the host
microcontroller firmware.
EVALUATION BOARD DETAILS:
Feature
Description
The evaluation board comes with pre-loaded serial to Wi-Fi firmware that
supports a Limited AP mode, with built-in web-server for provisioning the
device. The evaluation board works in conjunction with the serial to Wi-Fi
evaluation kit software and firmware.
The evaluation board has various jumpers, switches, push buttons and
LED’s that provide support for evaluating different features and
configuration based on the firmware loaded from the evaluation kit.. For
details see the product briefs of the GS1011M or GS1500M modules.
EVAL BOARD ORDERING INFORMATION
PART NUMBER
IEEE 802.11b/g/n
RF Module(s)
GS1011M (802.11b) or
Radio Frequency
2.4 – 2.497 GHz
Antenna Type
On-board PCB Trace or
External (u.FL)
I/O Port
6-pin serial UART ( 3.3V TTL),
RS232 DB9 Connector,
SPI Connector
LED
2 LED’s to indicate state
Memory
External SPI Flash Memory for
Firmware Upgrade and Restore
Switches
Push button for Alarms, Reset,
WPS, and Configuration
Program Switch
For programming the module
On/Off Switch
Power on/off switch
Serial Select
Jumper
Jumper to select between
UART or RS232 interface or
SPI
Sensors
Temperature and Light
Power Source
Battery or External Power
Adapter
Battery
Two 1.5V AA Battery (Alkaline
or Lithium)
Lithium is recommended for
longer battery life
Power Source
Select
Select power source as either
battery or external power
adapter
Power Adapter
3.3V
Dimensions (in)
3.5 x 3.0 (includes module and
RS232 connector)
Description
GS1011MIP-EVB2-S2W-WEB
GS1011MIE-EVB2-S2W-WEB
GS1011MEP-EVB2-S2W-WEB
GS1011MEE-EVB2-S2W-WEB
Serial to Wi-Fi Evaluation Board with –
GS1500M-EVB-S2W-WEB
Serial to Wi-Fi Evaluation Board with – GS1500M module
© 2011. GainSpan Corporation; http://www.gainspan.com• info@gainspan.com
EVB PB 2.0
Radio Protocol
GS1011MIP module
GS1011MIE module
GS1011MEP module
GS1011MEE module
@GainSpan
GS1011MIC-EVB2C-S2W-WEB 价格&库存
很抱歉,暂时无法提供与“GS1011MIC-EVB2C-S2W-WEB”相匹配的价格&库存,您可以联系我们找货
