SIM8065
Product Release
Push-Push
Nano SIM Card Connector
www.gct.co
Vital Stats
SIM8065 is the first push-push Nano SIM
card connector from GCT, combining the
tiny form factor of the Nano SIM format
with strong card retention and ease of
access afforded by the spring-loaded card
eject mechanism.
SIM Card Type
Card Eject Mechanism
Nano
Push-Push
Operating Temp.
Mating Cycles
-40 to +85°C
5,000
Card Detect Switch
Shell
Yes
Stainless Steel
With a shell solder tab on each corner and
dual plastic locating pegs, SIM8065 is rock
solid when mounted to the PCB, allowing a
rating of 5,000 mating cycles.
• Gold plated contacts.
• Supplied in tape & reel packaging
(1500 pieces per reel)
Plan View
1.37mm
5
6
7
13.09mm
1.00 mm
12.29mm
13.72mm
3
12.00mm
2
1.50mm
Card lock position
1
8.50mm
4
gct.co/connector/sim8065
1
2
3
4
5
6
7
Nano SIM card interface
Push-Push card eject mechanism
6 gold plated contacts
Dual plastic locating pegs
Tiny profile of just 1.37mm above PCB
Card Detect switch
Polarised card stop
Nano SIM Range
SIM8051
Push-Pull Nano SIM card connector
6 contacts without card detect switch
Outer shell tabs, shell stake & optional locating peg
1.35mm profile from PCB
SIM8055
Innovative split contact card detection switch
SIM8060
Hinge & lock Nano SIM card connector
Optional split contact card detection switch
Outer shell tabs & polarised card stop
1.43mm profile from PCB
gct.co/sim-connector/nano-sim-connector
SIM8065-6-1-14-01-A 价格&库存
很抱歉,暂时无法提供与“SIM8065-6-1-14-01-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+20.57400
- 10+17.46360
- 30+15.51960
