USB1015-GF-L-A
USB1015-GF-L-A
    GCT
    弯插
    USB连接器 Type-A 4P 弯插 端口数:1 额定电流:1.5A 额定电压:30V 工作温度:-40℃~+85℃
USB1015-GF-L-A 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1015 B Rev Date 10/12/14 USB Receptacle, Type A, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT Holdowns Page 1 USB1015 Approved Prepared AO www.gct.co Checked ST VJ PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1015 B Rev Date 10/12/14 USB Receptacle, Type A, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT Holdowns Page 2 USB1015 Approved Prepared AO Checked ST VJ 1.0 SCOPE. This specification covers performance, tests and quality requirements for the USB Receptacle USB1015 (Type A, 4-Pin, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT holdowns). 2.0 PRODUCT NAME AND PART NUMBER. USB Receptacle, Type A, 4 Pin, Through Hole, Horizontal, USB1015. 3.0 PRODUCT SHAPE, DIMENSIONS AND MATERIAL. Please refer to drawings. 4.0 RATINGS. 4.1 Current rating ………………………. 1.5 A 4.2 Voltage rating ……………………… 30 V 4.3 Operating Temperature Range …… -40°C TO +85°C 5.0 TEST AND MEASUREMENT CONDITIONS. Product is designed to meet electrical, mechanical and environmental performance requirements specified in Paragraph 6.0. All tests are performed in ambient conditions unless otherwise specified. 6.0 PERFORMANCE. Item Test Condition Requirement Examination of Product Visual, dimensional and functional inspection as per quality plan. Product shall meet requirements of product drawing and specification. www.gct.co PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1015 B Rev Date 10/12/14 USB Receptacle, Type A, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT Holdowns Page 3 USB1015 Approved Prepared AO Checked ST VJ 6.1 Electrical Performance. Item Test Condition Low level Contact Resistance Subject mated contacts assembled in housing to 20mV Max open circuit at 100mA Max. In accordance with EIA-36423. Insulation Resistance Impressed voltage 500 VDC. Test between adjacent circuits of unmated connector. In accordance with EIA-364-21. Dielectric withstanding Voltage 500V AC for 1minute Test between adjacent circuits of unmated connector and in accordance with EIA-364-20. Requirement 30 m 1000 M Max. Min. No creeping discharge or flashover shall occur. Current leakage: 0.5 mA Max. 6.2 Mechanical Performance. Item Insertion Force Extraction Force Durability Vibration Mechanical Shock Test Condition Operation Speed: 12.5 mm/min. Measure the force required to mate connector and in accordance with EIA-364-13. Operation Speed: 12.5mm/min. Measure the force required to unmate connector and in accordance with EIA-364-13. Operation Speed: 200 cycle/Hour Durability Cycles: 1500 Cycles In accordance with EIA-364-09. Subject mated connectors to 10-55-10 Hz traversed in 1minutes at 1.52mm amplitude 2 Hours each of 3 mutually perpendicular planes. 100mA Max. applied. In accordance with EIA-364-28D. Accelerate Velocity: 30Gs Waveform: Half-sine shock plus Duration: 11msec Three shocks in each direction applied along three mutually perpendicular planes for a total of 18 shocks. In accordance with EIA-364-27 www.gct.co Requirement 3.57KGf (35N) Max. 1.02KGf(10N) Min. Contact Resistance 30 m . No electrical discontinuity greater than 1 µsec. shall occur. No damage to product. No electrical discontinuity greater than 1 µsec. shall occur. No damage to product. PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1015 B Rev Date 10/12/14 USB Receptacle, Type A, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT Holdowns Page 4 USB1015 Approved Prepared AO Checked ST Item Test Condition Requirement Contact Retention Force Measure the contact retention force with Tensile strength tester. 1.0 KGf Min. VJ 6.3 Environmental Performance and Others. Item Test Condition Requirement Resistance to Wave Soldering Heat Pre Heat: 150~180°C, 90±30sec. Heat: 230°C Min., 30±10sec. Peak Temp.: 260+0/-5°C, 20~40sec. Duration: 3 cycles No physical damage shall occur. (Lead-Free) Solderability Solder pot temperature: 265 5°C, 5sec The inspected area of each lead must have 95% solder coverage minimum. Thermal Shock Mated Connector -55°C and +85°C Perform this a cycle, repeat 10 cycles. In accordance with EIA-364-32. Contact Resistance 30 m . Humidity-Temperature Cycle Mated Connector 40°C, 90~95% RH, 168hours. In accordance with EIA-364-31. Contact Resistance 30 m . Salt Spray Subject mated connectors to 35+/-2°C and 5+/-1% salt condition for 8hours. After test, rinse the sample with water and recondition the room temperature for 1 hour. In accordance with EIA-364-26. No detrimental corrosion allowed in contact area and base metal exposed. Resistance to Reflow Soldering Heat Mount Connector, place in reflow oven and expose to the temperature profiles shown in fig 1 and 2. No evidence of physical damage or abnormalities adversely affecting performance. www.gct.co PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1015 B Rev Date 10/12/14 USB Receptacle, Type A, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT Holdowns Page 5 USB1015 Approved Prepared AO Checked ST Fig 1 – Temperature profile of Reflow Soldering at 250°C Max. Fig 2 – Temperature profile of Reflow Soldering at 260°C Max. www.gct.co VJ PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1015 B Rev Date 10/12/14 USB Receptacle, Type A, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT Holdowns Page 6 USB1015 Approved Prepared AO ST Checked VJ 7.0 PRODUCT QUALIFICATION AND TEST SEQUENCE Test Item Test Group A B C D E F G H Examination of Product 1, 9 1, 9 1, 4 1, 5 1, 5 1, 3 1, 3 1 Contact Resistance 4, 8 3, 7 2, 4 2, 4 Dielectric Withstanding Voltage 3, 7 Insulation Resistance 2, 6 Mating Force 2, 6 Unmating Force 4, 8 Durability 5 Vibration 2 Mechanical Shock 3 Contact Retention Force 2 Solderability 2 Resistance to Soldering Heat 2 Thermal Shock Humidity Temperature Cycling 3 5 Salt Spray 3 Notes: Numbers indicate sequence in which tests are performed. Discontinuities shall not take place in this test group, during tests. www.gct.co PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1015 B Rev Date 10/12/14 USB Receptacle, Type A, Mid Top Mount, 2.32mm Offset, Through Hole, Horizontal, with Shell Stakes and SMT Holdowns Page 7 USB1015 Approved Prepared AO Checked ST Revision details Revision Information Page Release Date A Specification released. - 18/07/11 B Offset definition changed from 3.90 to 2.32mm Header & Page 2 10/12/14 . www.gct.co VJ
USB1015-GF-L-A 价格&库存
很抱歉,暂时无法提供与“USB1015-GF-L-A”相匹配的价格&库存,您可以联系我们找货
USB1015-GF-L-A
  • 1+8.475321+1.09721
  • 10+7.1848110+0.93014
  • 25+6.7367125+0.87213
  • 50+6.4156350+0.83056
  • 100+6.10842100+0.79079
库存:14180
USB1015-GF-L-A
    库存:4400
    USB1015-GF-L-A
    • 400+5.53837400+0.71699
    • 800+5.27389800+0.68275
    • 1200+5.125101200+0.66349
    • 2000+4.943692000+0.64001
    • 2800+4.827722800+0.62499
    • 4000+4.707774000+0.60947
    库存:14180
    USB1015-GF-L-A
      库存:7600
      USB1015-GF-L-A
      • 1+7.995451+1.03508
      • 10+6.7123410+0.86897
      • 25+6.2759125+0.81247
      • 50+5.9354950+0.76840
      • 100+5.63872100+0.72998
      • 250+5.22847250+0.67687
      • 400+5.00152400+0.64749
      • 800+4.68729800+0.60681
      • 2000+4.285772000+0.55483
      • 2400+4.250862400+0.55031
