USB1061-GF-L-A
USB1061-GF-L-A
    GCT
    SMD
    USB连接器 Type-A 4P 卧贴 端口数:1 额定电流:3A 额定电压:30V 工作温度:-55℃~+85℃
USB1061-GF-L-A 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1061 A1 Rev USB Plug, Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stakes USB1061 Prepared CC www.gct.co Checked VJ Date 12/03/21 Page 1 Approved PH PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1061 A1 Rev USB Plug, Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stakes USB1061 Prepared CC Checked VJ Date 12/03/21 Page 2 Approved PH 1.0 SCOPE. This specification covers performance, tests and quality requirements for the USB Plug USB1061 (Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stake). 2.0 PRODUCT NAME AND PART NUMBER. USB Plug, Type A, 4 Pin, Mid-Mount, Horizontal, USB1061. 3.0 PRODUCT SHAPE, DIMENSIONS AND MATERIAL. Please refer to drawings. 4.0 RATINGS. 4.1 Current rating ………………………. 3.0 A 4.2 Voltage rating ……………………… 30 V 4.3 Operating Temperature Range …… -55°C TO +85°C 5.0 TEST AND MEASUREMENT CONDITIONS. Product is designed to meet electrical, mechanical and environmental performance requirements specified in Paragraph 6.0. All tests are performed in ambient conditions unless otherwise specified. 6.0 PERFORMANCE. Item Test Condition Requirement Examination of Product Visual, dimensional and functional inspection as per quality plan. Product shall meet requirements of product drawing and specification. www.gct.co PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1061 A1 Rev USB Plug, Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stakes USB1061 Prepared CC Checked VJ Date 12/03/21 Page 3 Approved PH 6.1 Electrical Performance. Item Test Condition Requirement Low level Contact Resistance Subject mated contacts assembled in housing to 20mV Max open circuit at 100mA Max. In accordance with EIA-36423. 30m Insulation Resistance Impressed voltage 500V DC. Test between adjacent circuits of unmated connector. In accordance with EIA-364-21. 1000M Dielectric withstanding Voltage 500V AC for 1minute Test between adjacent circuits of unmated connector and in accordance with EIA-364-20. Max. Min. No creeping discharge or flashover shall occur. Current leakage: 0.5mA Max. 6.2 Mechanical Performance. Item Test Condition Requirement Insertion Force Operation Speed: 12.5 mm/min. Measure the force required to mate connector and in accordance with EIA-364-13. 3.57KGf (35N) Max. Extraction Force Operation Speed: 12.5mm/min. Measure the force required to unmate connector and in accordance with EIA-364-13. 1.02KGf(10N) Min. Durability Operation Speed: 200 cycle/Hour Durability Cycles: 5000 Cycles In accordance with EIA-364-09. Contact Resistance 30m . Mating force: 3.57KGf (35N) Max. Unmating force: 1.02KGf(10N) Min. Contact resistance: 10m change Max. Random Vibration Mate connectors and subject to 5.35 Gs RMS. For a period of 15 minutes in each of 3 mutually perpendicular axes. In accordance with EIA-364-28D. No electrical discontinuity greater than 1 µsec. shall occur. No damage to product. Contact resistance: 10 m change Max. Mechanical Shock Accelerate Velocity: 30Gs Waveform: Half-sine shock plus Duration: 11msec Three shocks in each direction applied along three mutually perpendicular planes for a total of 18 shocks. In accordance with EIA-364-27 No electrical discontinuity greater than 1 µsec. shall occur. No damage to product. Contact resistance: 10m change Max. www.gct.co PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1061 A1 Rev USB Plug, Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stakes USB1061 Prepared CC Checked VJ Date 12/03/21 Page 4 Approved PH 6.3 Environmental Performance and Others. Item Solderability Test Condition Solder pot temperature: 245 Requirement 5°C, 5sec The inspected area of each lead must have 95% solder coverage minimum. Thermal Shock Mated Connector -55°C and +85°C Perform this a cycle, repeat 10 cycles. In accordance with EIA-364-32. Contact resistance: 10 m change Dielectric withstanding Voltage : no breakdown Insulation Resistance: 100 M Min. Humidity Mated Connector 40°C, 90~95% RH, 168hours. In accordance with EIA-364-31. Contact resistance: 10 m change Dielectric withstanding Voltage : no breakdown Insulation Resistance: 100 M Min. Temperature life Subject mated connectors to temperature life at 85 for 500hours ,In accordance with EIA 364-17 Test Condition 2 Method A Contact resistance: 10 m Salt Spray Subject mated connectors to 35+/-2°C and 5+/-1% salt condition for 8hours. After test, rinse the sample with water and recondition the room temperature for 1 hour. In accordance with EIA-364-26. No detrimental corrosion allowed in contact area and base metal exposed. Resistance to Reflow Soldering Heat Mount Connector, place in reflow oven and expose to the temperature profiles shown in fig 1 No evidence of physical damage or abnormalities adversely affecting performance. www.gct.co change PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1061 A1 Rev USB Plug, Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stakes USB1061 Prepared CC Checked VJ Fig 1 – Temperature profile of Reflow Soldering at 250°C Max. www.gct.co Date 12/03/21 Page 5 Approved PH PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1061 A1 Rev USB Plug, Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stakes USB1061 Prepared CC VJ Checked Date 12/03/21 Page 6 Approved 7.0 PRODUCT QUALIFICATION AND TEST SEQUENCE Test Item Test Group A B C D E F G Examination of Product 1,7 1, 9 1, 6 1, 5 1, 5 1, 3 1, 3 Contact Resistance 2,8 3, 7 2,5 2, 4 2, 4 Dielectric Withstanding Voltage 3,9 Insulation Resistance 4,10 Mating Force 2, 6 Unmating Force 4, 8 Durability 5 Random Vibration 4 Mechanical Shock 3 Temperature life 3 Solderability 2 Resistance to reflow soldering Heat 2 Thermal Shock 5 Humidity 6 Salt Spray 3 www.gct.co PH PRODUCT SPECIFICATION Part Number Product Description Doc Number USB1061 A1 Rev USB Plug, Type A, 4 Pin, Mid-Mount, Offset 1.43mm, SMT, Horizontal, Top Mount, Plastic Peg & Kinked Shell Stakes USB1061 Prepared CC Checked VJ Date 12/03/21 Page 7 Approved Revision details :Revision A A1 Information Page Release Date Specification released. - 31/10/14 2&3 12/03/21 Change current rating form 1.5A to 3A; change durability from 1500 cycles to 5000 cycles. . www.gct.co PH
USB1061-GF-L-A 价格&库存
很抱歉,暂时无法提供与“USB1061-GF-L-A”相匹配的价格&库存,您可以联系我们找货
USB1061-GF-L-A
    • 5+8.424275+1.08534
    • 6+7.020646+0.90450
    库存:10
    USB1061-GF-L-A
      USB1061-GF-L-A
