8000 A 02
8000 A 02
    GEDORE
    固定器环 钳子 弯嘴 平滑 5.47"(139.0mm)
8000 A 02 数据手册
GEDORE TOOLS, INC. 7187 Bryhawke Circle, Suite 700 North Charleston, SC 29418 USA T +1-843-225-5015 F +1-843-225-5020 info@gedoretools.com www.gedoretools.com PLIERS RANGE Circlip pliers for external retaining rings (shafts) 8000 AE Flattened tip mounting makes it easier to get at the safety ring eyelets Precision, screwed joint. The screw ensures ease in re-adjusting the pliers legs. Contoured anti-slip handles stop your hands from slipping Secure tip thanks to keyed press-fixing in the pliers head With no retaining groove in the tips, the safety ring cannot be inadvertently bent and it remains absolutely flat. In addition no weakening of the tips from a retaining groove (notching-induced rated breaking point). Wear-resistant and accurate! - The hardened and specially inserted tip is of high-grade roller bearing steel and absolutely cylindrical. Large contact surface for the safety ring stops it becoming twisted A secure internal spring makes work easier with circlip pliers TIP This thus lessens safety ring twisting! ››Always ensure that the fitting side is the right one when installing safety rings. ››The safety ring "eyelets" are stamped and thus they are slightly conical. ››To stop any ring twisting, the narrower side of the eyelets* should rest on the pliers. * The bevel-free side is also the narrower side of the eyelets. 8000 AE 0 - AE 4 CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS B M Form A ››For safety rings as per DIN 471, DIN 983 ››DIN 5254 Form A ››Straight jaws ››Inside-positioned opening spring ››Pliers basic body in GEDORE chrome-vanadium special steel ››Pressed-in tips of highly wear-resistant roller bearing steel ››Twisting-impeding tip geometry ››Screwed joint connection ››Steel-grey with red-dipped anti-slip handles E 3-10 10-25 19-60 40-100 85-140 F 5/32-3/8 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L 144 145 183 230 332 L2 39 39 57 68 95 d 0.9 1.3 1.8 2.3 3.2 0 0.090 0.095 0.180 0.310 0.590 Code 2930633 2930668 2923602 2930676 2930684 No. 8000 AE 0 8000 AE 1 8000 AE 2 8000 AE 3 8000 AE 4 399 400 8000 AE 01 - AE 41 CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS B N 8000 A 0G - A 2G CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS B M Form B ››For safety rings as per DIN 471, DIN 983 ››DIN 5254 Form B ››90° angled jaws ››Inside-positioned opening spring ››Pliers basic body in GEDORE chrome-vanadium ››Pressed-in tips of highly wear-resistant roller bearing steel ››Twisting-impeding tip geometry ››Screwed joint connection ››Steel-grey with red-dipped anti-slip handles special steel ››For shafts without groove ››For retaining rings Seeger as well as Benzing ››Similar to DIN 5254 Form A ››A 0G - A 1G = tips angled 30 ° ››A 2G = straight tips ››With opening spring and adjusting ››High degree of assembly reliability, the limit opening rules out any over-tensioning of the smallest of retaining rings ››Forged GEDORE chrome-vanadium special hardened and tempered steel ››Precision machined, oil hardened and annealed ››Black, with red dipped handles screw to limit opening E 3-10 10-25 19-60 40-100 85-140 F 5/32-3/8 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L 133 133 170 217 311 L2 27 27 44 54 74 d 0.9 1.3 1.8 2.3 3.2 0 0.090 0.095 0.180 0.310 0.590 Code 2930692 2930706 2930714 2930730 2930749 for Seeger circlips E No. 8000 AE 01 8000 AE 11 8000 AE 21 8000 AE 31 8000 AE 41 8000 A 01G - A 21G CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS 1,5-3,5 4,0-9,0 10,0-15,0 B N for Benzing clamping circlips E 1,5-3,5 3,0-11,0 12,0-16,0 L L2 d 0 Code 140 40 0.7 0.099 6700140 140 40 1.1 0.098 6700220 182 57 1.8 0.189 6700300 No. 8000 A 0G 8000 A 1G 8000 A 2G 8000 A 0 - A 4 CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS B M Form A ››For shafts without groove ››For retaining rings Seeger as well as Benzing ››Similar to DIN 5254 Form B ››90 ° angled tips ››With opening spring and adjusting screw to ››High degree of assembly reliability, the limit opening rules out any over-tensioning of the smallest of retaining rings ››Forged GEDORE chrome-vanadium special hardened and tempered steel ››Precision machined, oil hardened and annealed ››Black, with red dipped handles limit opening for Seeger circlips E 1,5-3,5 4,0-9,0 10,0-15,0 for Benzing clamping circlips E 1,5-3,5 3,0-11,0 12,0-16,0 L L2 d 0 Code 134 33 0.7 0.100 6700650 134 33 1.1 0.099 6700730 170 45 1.8 0.184 6700810 No. 8000 A 01G 8000 A 11G 8000 A 21G ››For retaining rings as per DIN 471, DIN 983 ››DIN 5254 Form A ››Straight tips ››With opening spring ››With clamping protection E 3-10 10-25 19-60 40-100 85-140 F 5/32-3/8 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L 141 141 182 230 320 L2 40.0 40.0 54.0 69.0 85.5 ››Forged GEDORE chrome-vanadium special hardened and tempered steel ››Precision machined, oil hardened and annealed ››Black, with red dipped handles d 0.9 1.3 1.8 2.3 3.2 0 0.096 0.098 0.186 0.310 0.555 Code 6701380 6701460 6701540 6701620 6701700 No. 8000 A 0 8000 A 1 8000 A 2 8000 A 3 8000 A 4 PLIERS RANGE 8000 A 01 - A 41 CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS B N 8000 A 02 - A 42 CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS B Form B ››For retaining rings as per DIN 471, DIN 983 ››DIN 5254 Form B ››90° angled tips ››With opening spring ››With clamping protection E 3-10 10-25 19-60 40-100 85-140 F 5/32-3/8 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L 130 130 170 210 305 ››Forged GEDORE chrome-vanadium special hardened and tempered steel ››Precision machined, oil hardened and annealed ››Black, with red dipped handles L2 29 29 43 53 64 d 0.9 1.3 1.8 2.3 3.2 0 0.097 0.097 0.182 0.317 0.563 Code 6702270 6702350 6702430 6702510 6702780 No. 8000 A 01 8000 A 11 8000 A 21 8000 A 31 8000 A 41 8000 A 4 - A 6 CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS ››Straight tips ››Black, tips and lock lever zinc-plated ››The toothed bracket stops the pliers legs from E 3-10 10-25 19-60 40-100 85-140 B M ››Non-crush type release-lever with handle straddling beyond the permitted working area ››This ensures safe working even in hidden ››Similar to DIN 5254 Form B ››45 ° angled tips ››With opening spring ››With clamping protection recesses, red dip-insulated ››Precision machined, oil hardened and annealed ››E-8000 A = pair of spare tips F 5/32-3/8 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L 139 139 179 226 315 ››Forged GEDORE chrome-vanadium special hardened and tempered steel ››Precision machined, oil hardened and annealed ››Black, with red dipped handles L2 38.0 38.0 51.0 65.0 80.5 d 0.9 1.3 1.8 2.3 3.2 0 0.097 0.097 0.182 0.317 0.568 Code 2015021 2015048 2015056 2015064 2015072 No. 8000 A 02 8000 A 12 8000 A 22 8000 A 32 8000 A 42 8000 A 41 - A 61 CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS ››90° angled tips ››Tips and lock lever zinc-plated ››Lever handle-end red dip-insulated ››Finger protection B N ››Reinforced safety arms ››Precision machined, oil hardened and annealed ››E-8000 A = pair of spare tips fitting positions ››Locking pin can be replaced E 85-140 122-300 252-400 F 3.3/8-5.1/2 4.13/16-11.7/8 9.15/16-15.13/16 d 3.2 3.5 4.5 S 8028 0 0.072 0.072 0.112 d 3.2 3.5 4.5 y 550 550 586 Code 2011670 5701840 5701920 0 1.921 1.921 1.922 Code 2011778 6701890 6701970 No. 8000 A 4 EL 8000 A 5 8000 A 6 E 85-140 122-300 252-400 d 3.2 3.5 4.5 No. E-8000 A 4 EL E-8000 A 5 E-8000 A 6   4 25 F 3.3/8-5.1/2 4.13/16-11.7/8 9.15/16-15.13/16 0 0.072 0.112 0.140 1500 ES-8000 d 3.2 3.5 4.5 y 560 560 585 Code 2011697 5702810 5701760 0 1.898 1.898 1.953 Code 2011786 6702860 6718430 No. 8000 A 41 EL 8000 A 51 8000 A 61 No. E-8000 A 41 EL E-8000 A 51 E-8000 A 61   1 03 401 402 Circlip pliers for internal retaining rings (bores) 8000 JE 0 - JE 4 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS A M 8000 JE 01 - JE 41 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS A N Form C Form D ››For safety rings as per DIN 472, DIN 984 ››Twisting-impeding tip geometry ››DIN 5256 Form C ››Screwed joint connection ››Straight jaws ››Steel-grey with blue-dipped anti-slip handles ››Pliers basic body in GEDORE chrome-vanadium ››For safety rings as per DIN 472, DIN 984 ››Twisting-impeding tip geometry ››DIN 5256 Form D ››Screwed joint connection ››90° angled jaws ››Steel-grey with blue-dipped anti-slip handles ››Pliers basic body in GEDORE chrome-vanadium ››Pressed-in tips of highly wear-resistant roller ››Pressed-in tips of highly wear-resistant roller special steel special steel bearing steel C 8-13 12-25 19-60 40-100 85-140 D 3/8-9/16 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 bearing steel L 139 139 182 230 324 L2 41 41 54 68 86 d 0.9 1.3 1.8 2.3 3.2 0 0.090 0.090 0.160 0.280 0.550 Code 2930757 2930765 2930773 2930781 2930803 No. 8000 JE 0 8000 JE 1 8000 JE 2 8000 JE 3 8000 JE 4 8000 J 0 - J 4 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS A M ››For retaining rings as per DIN 472, DIN 984 ››DIN 5256 Form C ››Straight tips ››Forged GEDORE chrome-vanadium special hardened and tempered steel D 3/8-9/16 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 D 3/8-9/16 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L 129 129 170 217 310 L2 30 30 43 53 70 d 0.9 1.3 1.8 2.3 3.2 0 0.090 0.090 0.160 0.280 0.550 Code 2930811 2930838 2930846 2930854 2930862 No. 8000 JE 01 8000 JE 11 8000 JE 21 8000 JE 31 8000 JE 41 8000 J 01 - J 41 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS A N Form D Form C C 8-13 12-25 19-60 40-100 85-140 C 8-13 12-25 19-60 40-100 85-140 L 141 141 183 230 322 1500 CT1-8000 L2 41.0 41.0 54.0 68.0 84.5 ››Precision machined, oil hardened and annealed ››For retaining rings as per DIN 472, DIN 984 ››DIN 5256 Form D ››Black, with blue dipped handles ››90° angled tips ››Forged GEDORE chrome-vanadium special ››Precision machined, oil hardened and annealed ››Black, with blue dipped handles hardened and tempered steel d 0.9 1.3 1.8 2.3 3.2 0 0.080 0.081 0.164 0.281 0.472 Code 6703240 6703320 6703400 6703590 6703670 No. 8000 J 0 8000 J 1 8000 J 2 8000 J 3 8000 J 4 C 8-13 12-25 19-60 40-100 85-140 D 3/8-9/16 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L 129 129 169 214 292 L2 28 28 41 50 65 d 0.9 1.3 1.8 2.3 3.2 0 0.080 0.082 0.161 0.279 0.484 Code 6704130 6704210 6704480 6704560 6704640 No. 8000 J 01 8000 J 11 8000 J 21 8000 J 31 8000 J 41   1 11 PLIERS RANGE 8000 J 02 - J 42 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS A ››Similar to DIN 5256 Form D ››45 ° angled tips ››Forged GEDORE chrome-vanadium special hardened and tempered steel ››Precision machined, oil hardened and annealed ››Black, with blue dipped handles C 8-13 12-25 19-60 40-100 85-140 L 139 139 180 226 316 D 3/8-9/16 3/8-1 3/4-2.3/8 1.5/8-4 3.3/8-5.1/2 L2 39.0 39.0 52.0 64.0 78.5 d 0.9 1.3 1.8 2.3 3.2 Code 2014963 2014971 2014998 2015005 2015013 0 0.080 0.080 0.161 0.279 0.484 No. 8000 J 02 8000 J 12 8000 J 22 8000 J 32 8000 J 42 8000 J 4 - J 6 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS ››Straight tips ››Black, tips and lock lever zinc-plated ››The toothed bracket stops the pliers legs from straddling beyond the permitted working area ››This ensures safe working even in hidden fitting positions ››Locking pin can be replaced ››Non-crush type release-lever with handle recesses, blue dip-insulated ››Precision machined, oil hardened and annealed ››E-8000 J = pair of spare tips Release lever for controlled slackening of the tension 3.2/3.5/4.5 mm tip diameters available for 85 to 400 mm rings. Models for internal and external retaining rings Ratching mechanism for easing the work of the user when fitting the retaining rings 8000 J 4 - J 6 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS A M 8000 J 41 - J 61 CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS ››90° angled tips ››Black, tips and lock lever zinc-plated ››Lever handle-end blue dip-insulated ››Finger protection C 85-140 122-300 252-400 d 3.2 3.5 4.5 D 3.3/8-5.1/2 4.13/16-11.7/8 9.15/16-15.13/16 0 0.072 0.072 0.082 d 3.2 3.5 4.5 y 565 565 575 Code 2011700 5703700 5703890 0 1.835 1.836 1.846 Code 2011794 6703750 6703830 No. E-8000 J 4 EL E-8000 J 5 E-8000 J 6 No. 8000 J 4 EL 8000 J 5 8000 J 6 C 85-140 122-300 252-400 d 3.2 3.5 4.5 D 3.3/8-5.1/2 4.13/16-11.7/8 9.15/16-15.13/16 0 0.072 0.116 0.116 d 3.2 3.5 4.5 A N ››Reinforced safety arms ››Precision machined, oil hardened and annealed ››E-8000 J = pair of spare tips y 575 575 579 Code 2011719 5704780 5702730 0 1.953 1.953 1.934 Code 2011808 6704720 6718510 No. 8000 J 41 EL 8000 J 51 8000 J 61 No. E-8000 J 41 EL E-8000 J 51 E-8000 J 61 403 404 Circlip pliers for retaining rings (parallel) 8005 A PLIERS FOR EXTERNAL RETAINING RINGS ››For shafts ››Supplied with four different clamping tips ››The circlip is securely clamped before removal by choosing a suitable distance between the clamping tips. This means that unnecessary plier movement is avoided, and the circlip may be opened completely. The special parallel movement of the clamping tips and their recesses in the direction of the pressure applied ensure that the circlip will be clamped firmly. For holes from 4.5 to 5.9 mm and rings from 305 to 500 mm Release lever for controlled slackening of the tension Paralleled jaws for the greatest possible safety and torsion-free clamping Ratching mechanism for easing the work of the user when clamping the retaining rings 8005 A CIRCLIP PLIERS FOR EXTERNAL RETAINING RINGS E-8005 A SPARE TIPS for external retaining rings (per piece) Selection aid: ››The spacing of holes for non-tensioned circlips is normally between 20 mm and 50 mm ››The tips used to spread the rings are fitted to match the opening width of the non-tensioned circlip E 305-500 Q 4.5 P 5,9 y 665 0 3.520 Code 6707150 No. 8005 A ››Opening widths 18-28 mm: Combination tips E-8005 1 A and E-8005 2 A ››Opening widths 29-39 mm: Combination tips E-8005 1 A and E-8005 4 A ››Opening widths 40-50 mm: E-8005 J SPARE TIPS Combination tips E-8005 3 A and E-8005 4 A 0 0.068 0.068 for internal retaining rings (per piece) Selection aid: between 80 mm and 140 mm ››The tips used to spread the rings are fitted to match the opening width of the non-tensioned circlip ››Opening widths 140-125 mm: Combination tips E-8005 1 J and E-8005 2 J ››Opening widths 125-110 mm: Combination tips E-8005 1 J and E-8005 4 J ››Opening widths 110-95 mm: Combination tips E-8005 3 J and E-8005 4 J ››Opening widths 95-80 mm: Combination tips E-8005 5 J and E-8005 6 J Code 5703380 5703460 5704190 5703540 No. E-8005 1 J E-8005 2 J E-8005 3 J E-8005 4 J 0 0.116 0.116 No. E-8005 1 A E-8005 2 A 0 0.068 0.068 Code 5702300 5702490 No. E-8005 3 A E-8005 4 A 8005 J CIRCLIP PLIERS FOR INTERNAL RETAINING RINGS ››The spacing of holes for non-tensioned circlips is normally 0 0.116 0.116 0.116 0.113 Code 5700790 5702220 A ››For bores ››Supplied with six different clamping tips ››The circlip is securely clamped before removal by choosing a suitable distance between the clamping tips. This means that unnecessary plier movement is avoided, and the circlip may be opened completely. The special parallel movement of the clamping tips and their recesses in the direction of the pressure applied ensure that the circlip will be clamped firmly. Code 5703620 5703970 No. E-8005 5 J E-8005 6 J C 305-500 Q 4.5 P 5,9 y 705 0 3.885 Code 6707230 No. 8005 J
8000 A 02 价格&库存
很抱歉,暂时无法提供与“8000 A 02”相匹配的价格&库存,您可以联系我们找货
8000 A 02
  • 1+444.005501+57.43889
  • 5+411.518955+53.23626
  • 10+398.2720510+51.52257
  • 25+381.4363325+49.34462
库存:10
