1743414
1743414
    GEDORE
    侧面(对角) 切割器 椭圆形 4.92"(125.0mm)
1743414 数据手册
384 385 8306-6 MINIATURE ELECTRONIC SIDE CUTTER ››Short, head pointed and flattened (relief-milled), with small bevel ››Induction-hardened precision cutting edges, 61 - 63 HRC Cutting values: ››Medium-hard wire: 0,8 mm/AWG 20| ››Soft wire: 1,5 mm/AWG 15 CL 10 y 120 0 0.072 > ››ESD = electrostatic discharge protection 8306-8 MINIATURE ELECTRONIC SIDE CUTTER ››With wire gripper ››Oval head, with bevel ››Induction-hardened precision cutting edges, > ››ESD = electrostatic discharge protection 61 - 63 HRC Cutting values: ››Hard wire: 0,4 mm/AWG 26| ››Medium-hard wire: 1,0 mm/AWG 18 ››Soft wire: 1,5 mm/AWG 1 Code 6727500 CL 13 No. 8306-6 y 125 0 0.076 Code 6727930 No. 8306-8 Electronic side cutter carbide ››Tungsten-carbide cutting edges induction-hardened, 84-86 HRA 8306-7 ELECTRONIC SIDE CUTTER CARBIDE ››Oval head, with bevel ››Tungsten-carbide cutting edges for an ››ESD = electrostatic discharge protection extremely long service life ››Hardness 84 - 86 HRA Cutting values: ››Piano wire: 0,6 mm/AWG 22| ››Hard wire: 1,0 mm/AWG 18 ››Soft wire: 2,0 mm/AWG 12 CL 11 y 125 0 0.076 Code 6727770 No. 8306-7 > 8306-9 ELECTRONIC SIDE CUTTER CARBIDE ››Tungsten-carbide cutting edges for an extremely long service life ››Hardness 84 - 86 HRA ››Pointed, slim head for work in confined spaces ››With small bevel Cutting values: ››Piano wire: 0,4 mm / 26 AWG ››Hard wire: 0,8 mm / 20 AWG ››Soft wire: 1,8 mm / 13 AWG CL 11 y 125 0 0.076 ››Especially for cutting SMD components ››With opening spring ››ESD = electrostatic discharge protection Code 1743414 No. 8306-9 >
1743414 价格&库存
很抱歉,暂时无法提供与“1743414”相匹配的价格&库存,您可以联系我们找货
  • 1+2764.282851+356.61527
  • 5+2562.259175+330.55255
  • 10+2479.9658710+319.93603
  • 25+2375.3262625+306.43666
库存:1
