12.88664
12.88664
    GEYER
    4-SMD, No Lead
    Crystal 14.3181800Mhz 12pF SMD
12.88664 数据手册
Quartz Crystal SMD-version part no. 12.88664 model frequency KX – 7 14.318180 MHz mode fundamental operating temperature -20° ~ +70°C frequency tolerance at +25°C ±30 ppm temperature tolerance -20° ~ +70°C ±50 ppm load capacitance CL 12 pF series resistance R1 max. 70 Ohm aging at 25°C (first year) max ±2 ppm shunt capacitance Co max. 3.0 pF drive level max. 200 µW contents of reel 1000 pcs. Dimensions (mm): Reflow soldering condition: Suggested soldering pad: Tape specification: reel diameter 178 mm GEYER Electronic GmbH Lochhamer Schlag 5 82166 Gräfelfing/München Tel. +49 89 546868-0 quartz@geyer-electronic.de www.geyer-electronic.de Version 14.07.2021
12.88664
物料型号:12.88664 器件简介:GEYER Iquartz技术,石英晶体SMD版本 引脚分配:#1 #2 #3 #4(#2和#4连接到金属盖) 参数特性: - 型号:KX-7 - 频率:14.318180MHz - 模式:基础模式 - 工作温度:-20°C至+70°C - +25°C时频率容差:+30ppm - -20°C至+70°C的温度容差:+50ppm - 负载电容CL:12pF - 串联电阻R1最大值:70Ohm - 25°C下老化(第一年)最大值:±2ppm - 并联电容C最大值:3.0pF - 最大驱动电平:200mW - 卷带内容物:1000件
回流焊接条件: - 尺寸(mm):3.2±0.2 x 2.0±0.2 - 焊接时间:260℃,10秒最大 - 温度曲线:200℃,220±5℃,180±5℃ - 建议的焊接垫规格:2.3mm x 1.3mm
封装信息: - 胶带规格:4.0±0.25mm x 2.0±0.1mm x 1.50.1mm - 卷径:178mm
12.88664 价格&库存
很抱歉,暂时无法提供与“12.88664”相匹配的价格&库存,您可以联系我们找货
  • 1+4.050411+0.52470
  • 10+3.5345110+0.45787
  • 25+3.3426525+0.43301
  • 50+3.2032350+0.41495
  • 100+3.07096100+0.39782
  • 250+2.90457250+0.37626
  • 500+2.78434500+0.36069
库存:1338
12.88664
  • 1000+2.669041000+0.34575
  • 2000+2.558642000+0.33145
  • 3000+2.496223000+0.32336
  • 5000+2.419725000+0.31346
  • 7000+2.370637000+0.30710
  • 10000+2.3197010000+0.30050
库存:1338
