UC2550-13NNN
UC2550-13NNN
    GHIELECTRONICS,LLC
    UC2550
UC2550-13NNN 数据手册
UC2550 Overview The efficiency of our UC2550 makes it ideal for low power applications. It is also our lowest cost UCM and offers a large complement of peripherals. Unlike the UC5550 however, it does not support USB host, a parallel LCD display, Ethernet PHY, or DCMI (Digital Camera Interface). We currently stock the UC2550 both with and without Wi-Fi depending on the model. We also offer customized, non-stock versions of our SoMs. See Options below for more information. Getting Started The UCM development options can greatly simplify the process of building a product or prototype using the UC2550. Options include a development board and displays which can get you programming in minutes. Please refer to the Development Optionspage for more information. Using TinyCLR OS TinyCLR provides a way to program the UC2550 in C# or Visual Basic from the Microsoft Visual Studio integrated development environment. To get started you must first install the bootloader and firmware on the UC2550 (instructions below) and then go to the TinyCLR Getting Started page for instructions on setting up the host computer and writing and deploying programs. Loading Bootloader Version 2 Download the UC2550 bootloader from here. Go to the Uploading DFU Files section of the STM32 Bootloader page for instructions on installing the bootloader. Loading the Firmware TIP First make sure you have bootloader v2 loaded. This needs to be done only once. To activate bootloader v2, hold the LDR0 signal low (press BOOT B on the UCM Dev and Breakout boards) and reset the board. You may have to wait a couple of seconds before releasing LDR0. Download the UC2550 firmware and follow the Loading the Firmware steps. Setup the Host Computer and Start Coding Now that you have installed the bootloader and firmware on the UC2550, you can setup your host computer and start programming. Go to the TinyCLR Getting Startedpage for instructions. Using Native Code with TinyCLR TinyCLR OS also lets you use native code that that works alongside your managed application. Native code can be used to provide improved performance or access to advanced features not exposed through TinyCLR. For more information check out Native Code on TinyCLR. TinyCLR cannot relocate native code, so you will have specify its location in the scatterfile. For the UC2550, the interop region starts at address 0x2003E000, and its length is 0x1FF8. Updating the Wi-Fi Module Firmware To update the firmware on the UC2550 Wi-Fi module, follow the instructions on this page. Schematic The schematic for the UC2550 can be found here. Options Model Number Wi-Fi External QSPI Flash UC2550-13NNN no no UC2550-13NNW yes no Customization We also offer customized, non-stock versions of our SoMs. Many options are available, such as various sizes of external QSPI flash. Please contact us for details. We will always do our best to provide you with a module to fit your exact needs. Specifications Specs Value Processor STM STM32F413 32-bit ARM Cortex-M4 Speed 100 MHz Internal RAM 320 KByte (SRAM) Internal Flash 1 MByte External RAM 0 KByte External Flash Up to 4 MByte (QSPI) Dimensions 67.7 x 31.7 x 3.2 mm Note: Not all memory will be available for your application. Peripherals Peripheral UCM Standard Overall* UART 4 9 (including HS) UART HS 2 2 I2C 2 2 SPI 2 3 CAN 2 2 SDIO 1 1 ADC 8 15 Peripheral UCM Standard Overall* PWM 8 27 GPIO 10 67 IRQ 4 67 USB Client Supported Supported USB Host Not supported Not supported LCD Not supported Not supported Ethernet PHY Not supported Not supported Wi-Fi Supported Supported DCMI Not supported Not supported VBAT Supported Supported JTAG SWD SWD *The "Overall" column includes peripherals that fall outside of the UCM standard definition. Using these peripherals may reduce code portability with our other UCM models. Also, as many of these nonstandard peripherals share I/O pins, not all of them will be available to your application. Pin Assignments SO-DIMM Pin Universal Compute Standard Function Name 1 AGND AGND 2 Ethernet TX- 3 Module Specific 1 4 Ethernet TX+ 5 Analog VREF- (Wi-Fi PIN14) Wi-Fi Power LED Analog VREF- SO-DIMM Pin Universal Compute Standard 6 Ethernet RX- 7 Reserved 8 Ethernet RX+ 9 Reserved 10 Indicator A (Wi-Fi PIN15) Wi-Fi Link Up LED 11 Indicator B (Wi-Fi PIN5) Wi-Fi Running (Blink) LED 12 Reserved 13 GND 14 DCMI D0 15 DCMI D1 16 DCMI D2 17 DCMI D3 18 DCMI D4 19 DCMI D5 20 Analog 3.3V 21 DCMI D6 22 DCMI D7 23 DCMI VSYNC 24 DCMI HSYNC Function Name GND Analog 3.3V SO-DIMM Pin Universal Compute Standard 25 DCMI PIXCLK 26 DCMI XCLK 27 GND GND 28 PWM E PE5, TIM9 CH1 29 PWM F PE6, TIM9 CH2 30 PWM G PB14, TIM12 CH1 31 PWM H PB15, TIM12 CH2 32 Analog VREF+ Analog VREF+ 33 Reserved 34 5V 35 Module Specific 4 (Wi-Fi PIN13) 36 Module Specific 5 (Wi-Fi PIN16) 37 Module Specific 6 (Wi-Fi PIN22) 38 Module Specific 7 39 Module Specific 8 40 GND GND 41 GND GND 42 LCD 24bpp R0 43 LCD 24bpp R1 44 LCD 24bpp R2 Function Name SO-DIMM Pin Universal Compute Standard 45 LCD 24bpp G0 46 3.3V 47 LCD 24bpp G1 48 LCD 24bpp B0 49 LCD 24bpp B1 50 LCD 24bpp B2 51 GND 52 Module Specific 9 53 I2S SCK 54 I2S WD 55 I2S WS 56 5V 57 IRQ A PC0, ADC10 58 IRQ B PC1, ADC11 59 IRQ C PC2, ADC12 60 3.3V 3.3V 61 IRQ D PC3, ADC13 62 GPIO A PC4, ADC14 63 GPIO B PC5, ADC15 64 GPIO C PA15, TIM2 CH1 Function Name 3.3V GND SO-DIMM Pin Universal Compute Standard Function Name 65 GND GND 66 GPIO D PB0, ADC8, TIM3 CH3 67 GPIO E PB7, TIM4 CH2 68 GPIO F PD7 69 GPIO G PD10 70 5V 71 Reserved 72 3.3V 3.3V 73 I2C B SDA PB8, I2C3 SDA, TIM10 CH1 74 I2C B SCL PA8, I2C3 SCL, MCO1 75 UART C TX PE1, UART8 TX 76 UART C RX PE0, UART8 RX 77 UART D TX PD15, USART9 TX, TIM4 CH4 78 UART D RX PD14, USART9 RX, TIM4 CH3 79 GND GND 80 Reserved 81 Reserved 82 Reserved 83 Reserved 84 Reserved SO-DIMM Pin Universal Compute Standard 85 Reserved 86 5V 87 USB Device ID 88 3.3V 3.3V 89 UART B TX PE8, USART7 TX 90 UART B RX PE7, USART7 RX 91 ADC A PA0, ADC0, TIM5 CH1 92 GPIO H PE10 93 SPI B MISO (Wi-Fi PIN6) PE13, SPI5 MISO, TIM1 CH3 94 SPI B MOSI (Wi-Fi PIN8) PE14, SPI5 MOSI, TIM1 CH4 95 GND GND 96 SPI B SCK (Wi-Fi PIN10) PE12, SPI5 SCK 97 ADC B PA1, ADC1, TIM5 CH2 98 CAN A TD PD1, CAN1 TX, UART4 TX 99 CAN A RD PD0, CAN1 RX, UART4 RX 100 CAN B TD PB13, CAN2 TX, UART5 TX 101 CAN B RD PB12, CAN2 RX, UART5 RX 102 UART HS A TX PD5, USART2 TX 103 UART HS A RX PD6, USART2 RX Function Name SO-DIMM Pin Universal Compute Standard Function Name 104 ADC C PA2, ADC2, TIM5 CH3 105 PWM A PE9, TIM1 CH1 106 3.3V 3.3V 107 BOOT A BOOT0 108 Module Specific 2 (Wi-Fi PIN2) 109 Module Specific 3 (Wi-Fi PIN4) 110 ADC D PA3, ADC3, TIM5 CH4 111 BOOT C PE3, LDR1 112 PWM B PE11, TIM1 CH2 113 GND GND 114 ADC E PA4, ADC4, DAC1 115 I2C A SDA PB9, I2C2 SDA, TIM10 CH1 116 I2C A SCL PB10, I2C2 SCL, TIM2 CH3 117 UART A RX PA10, USART1 RX 118 UART A TX PA9, USART1 TX 119 GPIO I PD14, UART9 RX, TIM4 CH3 120 UART HS A RTS PD4, USART2 RTS 121 UART HS A CTS PD3, USART2 CTS 122 GPIO J PD15, UART9 RX, TIM4 CH4 123 SD Card D0 PC8, SD D0, TIM8 CH3 SO-DIMM Pin Universal Compute Standard Function Name 124 3.3V 3.3V 125 SD Card CMD PD2, SD CMD 126 SD Card CLK PC12, SD CLK, SPI3 MOSI 127 SD Card D1 PC9, SD D1, TIM8 CH4 128 SD Card D2 PC10, SD D2, SPI3 SCK 129 SD Card D3 PC11, SD D3, SPI3 MISO 130 PWM C PC6, TIM3 CH1, USART6 TX 131 GND GND 132 GPIO K 133 PWM D PC7, TIM3 CH2, USART6 RX 134 BOOT B PB2, LDR0 135 BOOT D PE4, MODE 136 GPIO L 137 Module Specific 10 138 UART HS B RTS PD12, USART3 RTS 139 UART HS B CTS PD11, USART3 CTS 140 UART HS B TX PD8, USART3 TX 141 UART HS B RX PD9, USART3 RX 142 3.3V 3.3V 143 LCD VSYNC SO-DIMM Pin Universal Compute Standard 144 LCD HSYNC 145 LCD CLK 146 LCD DE 147 Module Specific 11 148 SD Card CD 149 Module Specific 12 150 Reserved 151 GND 152 LCD B3 153 LCD B4 154 LCD B5 155 LCD B6 156 LCD B7 157 ADC F PA5, ADC5, DAC2 158 ADC G PA6, ADC6 159 ADC H PA7, ADC7 160 3.3V 3.3V 161 LCD G2 162 LCD G3 163 LCD G4 Function Name PC13 GND SO-DIMM Pin Universal Compute Standard 164 LCD G5 165 LCD G6 166 Module Specific 13 167 Indicator C 168 LCD R7 169 GND 170 LCD G7 171 LCD R3 172 LCD R4 173 LCD R5 174 LCD R6 175 SPI A SCK PB3, SPI1 SCK, TIM2 CH2 176 SPI A MISO PB4, SPI1 MISO 177 Module Specific 14 178 SPI A MOSI 179 Module Specific 15 180 3.3V 181 Module Specific 16 182 Module Specific 17 183 VBAT Function Name GND PB5, SPI1 MOSI 3.3V VBAT SO-DIMM Pin Universal Compute Standard 184 Module Specific 18 185 GND GND 186 GND GND 187 RESET RESET 188 USB Host D+ 189 JTAG RTCK 190 USB Host D- 191 JTAG TDO 192 3.3V 193 JTAG NTRST 194 USB Device D+ 195 JTAG TDI 196 USB Device D- PA11, USB D- 197 JTAG TCK (SWCLK) PA14, JTCK, SWCLK 198 GND GND 199 JTAG TMS (SWDIO) PA13, JTMS, SWDIO 200 Indicator D Function Name 3.3V PA12, USB D+
UC2550-13NNN 价格&库存
很抱歉,暂时无法提供与“UC2550-13NNN”相匹配的价格&库存,您可以联系我们找货
