T-EJ3-95-S(R)
T-EJ3-95-S(R)
    GLOBTEK
    ADPTR PLUG XCHNGBLE 1.7MMX4.75MM
T-EJ3-95-S(R) 数据手册
  T00 Changeable output plug system for power supplies  The table below explains the standard and nonstandard options available as part of this system. This  system also allows for both Center Positive and Center Negative polarity.  The T00 adapters are not removable without use of special tool.  Over molded versions of these and more options also available with premium cost and lead time.    PART  CROSS  OUTER  INNER  FORM  PIN LENGTH NO.  REFERENCE  DIAMETER  DIAMETER FACTOR  MALE/FEMALE  INCLUDED  TIP  IN TOO KIT COLOR T‐K‐ Philmore®  11‐ 204/2049  S(R)  3.5  1.3  ‐  11  STRIAGHT Female  x  T‐ EJ2‐ Philmore®  95‐ 240 plug  S(R)  4  1.7  ‐  9.5  STRIAGHT Female  Order  Brown  Separately T‐ EJ3‐ Philmore®  95‐ 275 plug  S(R)  4.75  1.7  ‐  9.5  STRIAGHT Female  Order  Red  Separately Blue  T‐C‐ Switchcraft®  12‐ 5.5  722A  S(R)  2.1  ‐  12  STRIAGHT Female  x  Yellow  T‐L‐ Switchcraft®  12‐ 5.5  712A  S(R)  2.5  ‐  12  STRIAGHT Female  x  Black  T‐ EJ4‐ Philmore®  95‐ 255 plug  S(R)  5.5  3.3  1  9.5  STRIAGHT Female  Order  Orange Separately T‐ EJ1‐ Philmore  95‐ 235 plug  S(R)  2.35  0.7     9.5  STRIAGHT Female  Order  Yellow  Separately T‐ EJ5‐ Philmore  115‐ 265 plug  S(R)  6.5  6  1  11.5  STRIAGHT Female  Order  Black  Separately
T-EJ3-95-S(R) 价格&库存
很抱歉,暂时无法提供与“T-EJ3-95-S(R)”相匹配的价格&库存,您可以联系我们找货
T-EJ3-95-S(R)
  • 1+14.613771+1.88899
  • 5+13.466385+1.74068
  • 10+13.0097610+1.68165
  • 25+12.4250025+1.60607
  • 50+12.0007450+1.55123
  • 100+11.59139100+1.49831
  • 250+11.07015250+1.43094
  • 500+10.69168500+1.38202
库存:727
